Wednesday,19,February,2020,14:30:27:39201
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: 1VWBN7A35EC074934 License Plate:
Mileage: 76240km-47373mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72
75 77
VIN: 1VWBN7A35EC074934 Mileage: 76240km-47373miles
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H24 9982
Revision: 71H24--- Serial number:
Coding: 001D0012042400000000
Shop #: WSC 04907 444 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005
ROD: EV_ECM20TDI01103L997009J.rod
VCID: 3B2331BC63EC32CFDC7-806E
4481 - Cruise Control Switch (E45)
P0568 00 [040] - Implausible Signal
Mileage: 75917 km
Date: 2020.02.14
Time: 18:43:04
Coolant temperature: 62 °C
Intake air temperature: 38 °C
Ambient air pressure: 810 mbar
Voltage terminal 30: 12.040 V
Cruise Control System (CCS): switch position-Bits 0-7: 64
Cruise Control System (CCS): status-Bits 0-7: 204
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4483 - Function Restriction due to Faults in Other Modules
U1113 00 [047] - -
Fault Frequency: 19
Mileage: 75917 km
Date: 2020.02.14
Time: 18:43:04
Part No SW: 02E 300 062 B HW: 02E 927 770 AT
Component: GSG DSG AG6 541 9437
Revision: 06454104 Serial number: 00001904240486
Shop #: WSC 03347 003 1048576
VCID: 1471BA0022721DB77DD-8040
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 -
Fault Frequency: 19
Reset counter: 40
Mileage: 75917 km
Date: 2020.02.14
Time: 18:43:00
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: C54BC0F5492900FEA31403E7921D0042A1100012
Shop #: WSC 09003 957 00200
VCID: 7EA5F8A830FEE7E7BB9-802A
Reset counter: 16
Mileage: 75917 km
Date: 2020.02.14
Time: 19:13:46
Count: 2
Count: 12
Count: 12800
Count: 16390
Count: 49920
Count: 1
Count: 255
Part No SW: 561 907 426 E HW: 561 907 426 E
Component: AC Manuell H02 0303
Revision: 00001K02
Coding: 0010001002
ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
ROD: EV_ACManuaElectGen2BHTC_VW36.rod
VCID: 1D67DF24DD385CFFC23-8048
Part No SW: 5K0 937 085 AB HW: 5K0 937 085 AB
Component: BCM PQ35 B+ 122 0173
Revision: BH122001
Coding: EF200E1B902B28D4098800010600044800F1A08640801520648060000C70
VCID: 73B3D99C0BBCBA8FC47-8026
Part No SW: 5C0 959 655 AE HW: 5C0 959 655 AE
Component: AirbagVW10G 014 0851
Serial number: 003MWM047F4N
Coding: 00005033
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 75B7E7840548A4BFEA3-8020
Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Serial number: 6940000Y1400011LDC0K
Coding: 303044
Serial number: 3572MSME54177940ZZZU
Serial number: 3582MSME662F307EZZZ4
Serial number: 3516KSME7A13332AZZZS
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME11250B2AZZZM
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME7942052AZZZX
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME05097E29ZZZ+
Part No SW: 5K0 953 569 AL HW: 5K0 953 569 AL
Component: LENKS.MODUL 016 0180
Revision: --X01--- Serial number: 20190910100370
Coding: 7982A00000
Shop #: WSC 01286 386 08256
VCID: 025D8C5844868307DF1-8056
Component: E221__MFL-YVJ H07 0022
Serial number: 00000000000000812885
Coding: E20000
6 Faults Found:
226838 - Turn Signal Switch
B1144 12 [008] - Short to Plus
Reset counter: 18
Mileage: 75917 km
Date: 2020.02.14
Time: 18:43:38
B1149 13 [009] - Open Circuit
Fault Frequency: 81
Reset counter: 235
Mileage: 75917 km
Date: 2020.02.14
Time: 18:43:01
229127 - Cruise Control Switch
B1154 11 [009] - Short to Ground
Reset counter: 234
Mileage: 75917 km
Date: 2020.02.14
Time: 18:43:01
229147 - Cruise Control Switch
B1154 13 [009] - Open Circuit
Reset counter: 234
Mileage: 75917 km
Date: 2020.02.14
Time: 18:43:01
335876 - Powertrain Databus
U0002 00 [009] - No Communications
Reset counter: 231
Mileage: 75917 km
Date: 2020.02.14
Time: 18:43:01
1140738 - Steering angle sensor
Reset counter: 231
Mileage: 75917 km
Date: 2020.02.14
Time: 18:43:01
UBat: 12.20 V
MC1 interner Fehlercode: 0
MC2 interner Fehlercode: 0
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 G HW: 561 920 970 G
Component: KOMBI H04 0811
Coding: 231E01
VCID: 1E65D828D03E47E7DB9-804A
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 21011403000569
Coding: 461000
VCID: 7BA3F1BC23ECF2CF9C7-802E
Address 1C: Position Sensing
Component: IMMO H04 0811
VCID: 6A8DC4F85CF67B47771-803E
Address 2E: Media Player 3
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0525
Revision: 13110009 Serial number: 0007720401
Coding: 0404F5
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 5BE3913C83AC12CFFC7-800E
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14102630140117135612
Coding: 800000
131584 - Motor for Rear Window Regulator
B11EE 54 [008] - Missing Calibration / Basic Setting
Reset counter: 19
Mileage: 75917 km
Date: 2020.02.14
Time: 18:43:01
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 290 3501
Revision: 00H22000
VCID: 392F2BB4655000DFCEB-806C
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 01030108
VCID: 6FBBD5EC67949E6F20F-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011331500464
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0005
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0525
Revision: 15110009 Serial number: 0007809934
Coding: 0404F4
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 5CE1922086A215F7F5D-8008
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14202631140128151208
Coding: 800000
Part No SW: 1K0 035 188 F HW: 1K0 035 188 F
Component: Radio Prem-8 H07 0008
Revision: -----11S Serial number: VWZ4Z7P3533797
Coding: 0100044004000B
VCID: 2B0301FC930CA24F4C7-807E
Reset counter: 231
Mileage: 75917 km
Date: 2020.02.14
Time: 18:42:59
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0102
Serial number: 000003554140512
Coding: 02140102C2163A007F1606C00000
ROD: EV_OCULow_001.rod
VCID: 53F3791CEB7CDA8F247-8006
2103041 - Control Module
Fault Priority: 8
Reset counter: 235
Mileage: 76243 km
Date: 2020.02.19
Time: 15:15:53
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007664869937
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 2E0508E8A09ED7676B9-807A
End----(Elapsed Time: 01:04, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
