New user 2014 passat tdi steering wheel coding after clock spring install
tclivin
C?ID=395762
Hi all, I'm a new vcds user and new to the volkswagon community. I have a 2014 VW Passat TDI. I replaced the clock spring and now the cruise control doesn't work nor the right side up and down steering wheel controls. I purchased the vcds after I put the new clock spring in so don't have the previous codes. Any help would be appreciated.
Wednesday,19,February,2020,14:19:03:39201
VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4508.4
Mileage: 76240km-47373mi   Repair Order:
                Address 16: Steering wheel       Labels: 5K0-953-569.clb
Control Module Part Number: 5K0 953 569 AL    HW: 5K0 953 569 AL
  Component and/or Version: LENKS.MODUL   016 0180
           Software Coding: 7982A00000
            Work Shop Code: WSC 01286 386 08256
              ASAM Dataset: EV_VW360SteerWheelUDS A03004 (VW41)
                      VCID: 025D8C5844868307DF1-8056
226838 - Turn Signal Switch
          B1144 12 [008] - Short to Plus
                    Reset counter: 18
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:38
          B1149 13 [009] - Open Circuit
                    Fault Frequency: 81
                    Reset counter: 235
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:01
229127 - Cruise Control Switch
          B1154 11 [009] - Short to Ground
                    Reset counter: 234
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:01
229147 - Cruise Control Switch
          B1154 13 [009] - Open Circuit
                    Reset counter: 234
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:01
335876 - Powertrain Databus
          U0002 00 [009] - No Communications
                    Reset counter: 231
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:01
1140738 - Steering angle sensor
                    Reset counter: 231
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:01
                    UBat: 12.20 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
Hi and welcome.
Please post a complete Auto-Scan for context, not just the module in question.
tclivin
C?ID=395762
Ok here is the auto scan
Wednesday,19,February,2020,14:30:27:39201
VIN: 1VWBN7A35EC074934   License Plate:
Chassis Type: A3-VW41 (7N0)
          75 77
VIN: 1VWBN7A35EC074934   Mileage: 76240km-47373miles
   Component: R4 2.0l TDI   H24 9982
   Revision: 71H24---    Serial number:
   Coding: 001D0012042400000000
   Shop #: WSC 04907 444 00000
   ROD: EV_ECM20TDI01103L997009J.rod
   VCID: 3B2331BC63EC32CFDC7-806E
4481 - Cruise Control Switch (E45)
          P0568 00 [040] - Implausible Signal
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:04
                    Engine speed: 0.00 /min
                    Coolant temperature: 62 °C
                    Intake air temperature: 38 °C
                    Ambient air pressure: 810 mbar
                    Voltage terminal 30: 12.040 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 64
                    Cruise Control System (CCS): status-Bits 0-7: 204
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Fault Frequency: 19
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:04
   Part No SW: 02E 300 062 B    HW: 02E 927 770 AT
   Component: GSG DSG AG6     541 9437
   Revision: 06454104    Serial number: 00001904240486
   Shop #: WSC 03347 003 1048576
   VCID: 1471BA0022721DB77DD-8040
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -
                    Fault Frequency: 19
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:00
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: C54BC0F5492900FEA31403E7921D0042A1100012
   Shop #: WSC 09003 957 00200
   VCID: 7EA5F8A830FEE7E7BB9-802A
                    Reset counter: 16
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 19:13:46
                    Count: 2
                    Count: 12
                    Count: 12800
                    Count: 16390
                    Count: 49920
                    Count: 1
                    Count: 255
   Part No SW: 561 907 426 E    HW: 561 907 426 E
   Component: AC Manuell    H02 0303
   Revision: 00001K02
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1D67DF24DD385CFFC23-8048
   Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
   Component: BCM PQ35 B+   122 0173
   Revision: BH122001
   Coding: EF200E1B902B28D4098800010600044800F1A08640801520648060000C70
   VCID: 73B3D99C0BBCBA8FC47-8026
   Serial number: 003MWM047F4N
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75B7E7840548A4BFEA3-8020
   Serial number: 6940000Y1400011LDC0K
   Coding: 303044
   Serial number: 3572MSME54177940ZZZU
   Serial number: 3582MSME662F307EZZZ4
   Serial number: 3516KSME7A13332AZZZS
   Serial number: 3526KSME11250B2AZZZM
   Serial number: 3556LSME7942052AZZZX
   Serial number: 3566LSME05097E29ZZZ+
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20190910100370
   Coding: 7982A00000
   Shop #: WSC 01286 386 08256
   Serial number: 00000000000000812885
   Coding: E20000
                    Reset counter: 18
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:38
                    Fault Frequency: 81
                    Reset counter: 235
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:01
                    Reset counter: 234
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:01
                    Reset counter: 234
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:01
                    Reset counter: 231
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:01
                    Reset counter: 231
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:01
                    UBat: 12.20 V
   Part No SW: 561 920 970 G    HW: 561 920 970 G
   Coding: 231E01
   VCID: 1E65D828D03E47E7DB9-804A
   Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1642
   Revision:   H55       Serial number: 21011403000569
   Coding: 461000
   VCID: 7BA3F1BC23ECF2CF9C7-802E
Address 1C: Position Sensing
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC4F85CF67B47771-803E
Address 2E: Media Player 3
   Revision: 13110009    Serial number: 0007720401
   Coding: 0404F5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BE3913C83AC12CFFC7-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630140117135612
   Coding: 800000
131584 - Motor for Rear Window Regulator
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 19
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:43:01
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 290    3501
   Revision: 00H22000
   VCID: 392F2BB4655000DFCEB-806C
   Component: EZE_2         H55 1642
   Coding: 01030108
   VCID: 6FBBD5EC67949E6F20F-803A
   Serial number: 53388786011331500464
   Coding: 181100
   Revision: 15110009    Serial number: 0007809934
   Coding: 0404F4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CE1922086A215F7F5D-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14202631140128151208
   Coding: 800000
   Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
   Component: Radio Prem-8  H07 0008
   Revision: -----11S    Serial number: VWZ4Z7P3533797
   Coding: 0100044004000B
   VCID: 2B0301FC930CA24F4C7-807E
                    Reset counter: 231
                    Mileage: 75917 km
                    Date: 2020.02.14
                    Time: 18:42:59
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0102
   Serial number: 000003554140512
   Coding: 02140102C2163A007F1606C00000
   ROD: EV_OCULow_001.rod
   VCID: 53F3791CEB7CDA8F247-8006
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 235
                    Mileage: 76243 km
                    Date: 2020.02.19
                    Time: 15:15:53
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007664869937
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 2E0508E8A09ED7676B9-807A
End----(Elapsed Time: 01:04, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
Reaper78
Utah, USA
C?ID=394919
I just replaced my clock spring as well. I need to know how to reprogram the new one.
I have the old coding from the old clock spring. Think I can match the coding from the old one?
Please post a scan with the new clock-spring installed.
Reaper78
Utah, USA
C?ID=394919
New clock spring scan
VIN: WVWAP7AN3EE500845   License Plate:
Chassis Type: AN-VW46 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 53 55 56 62
          65 72 75 77
VIN: WVWAP7AN3EE500845   Mileage: 218160km-135558miles
Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
   Part No SW: 06J 906 027 GP    HW: 06J 907 309 B
   Component: MED17.5.2 TFSI 2 06 5696
   Revision: PAH04---    Serial number: VWZCZ000000000
   Coding: 0404010818070160
   Shop #: WSC 05314 000 00000
   VCID: 7F5B05B8EBFA5DB32A8-802A
               P0300 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 217801 km
                    Date: 2014.08.28
                    Time: 03:38:05
                    RPM: 1298 /min
                    Load: 14.5 %
                    Temperature: 47.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 860.0 mbar
                    Voltage: 14.097 V
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected - MIL ON
                    Fault Frequency: 9
                    Mileage: 217801 km
                    Date: 2014.08.28
                    Time: 03:38:07
                    RPM: 1298 /min
                    Load: 14.5 %
                    Temperature: 47.0°C
                    Temperature: 30.0°C
                    Voltage: 14.097 V
004874 - Cylinder Disabling
               P130A - 000 -  - Intermittent
                    Mileage: 217833 km
                    Date: 2014.08.29
                    Time: 00:24:32
                    RPM: 3997 /min
                    Load: 40.0 %
                    Speed: 33.0 km/h
                    Temperature: 96.0°C
                    Temperature: 32.0°C
                    Voltage: 13.843 V
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected - Intermittent
                    Mileage: 218125 km
                    Date: 2014.08.31
                    Time: 23:24:51
                    RPM: 2120 /min
                    Load: 39.2 %
                    Speed: 18.0 km/h
                    Temperature: 96.0°C
                    Temperature: 33.0°C
                    Voltage: 13.716 V
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - Intermittent
                    Mileage: 218125 km
                    Date: 2014.08.31
                    Time: 23:24:51
                    RPM: 2251 /min
                    Load: 38.0 %
                    Speed: 19.0 km/h
                    Temperature: 96.0°C
                    Temperature: 33.0°C
                    Voltage: 13.843 V
005703 - Check Coding of ECUs on Powertrain Data Bus
               P1647 - 000 -  - MIL ON
                    Mileage: 218153 km
                    Date: 2014.09.01
                    Time: 06:10:20
                    RPM: 1293 /min
                    Load: 25.9 %
                    Temperature: 42.0°C
                    Temperature: 33.0°C
                    Voltage: 13.335 V
   Part No SW: 3AA 614 109 AP    HW: 3AA 614 109 AP
   Component: J104   C2 450M V471 0030
   Revision: --H07---    Serial number: 00000007039086
   Coding: 0000396
   Shop #: WSC 05311 000 00000
   VCID: 7BA3F1A8FFE24193060-802E
   Part No SW: 3AA 907 044 BH    HW: 3AA 907 044 BH
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 0714019048
   Shop #: WSC 00015 115 00000
   VCID: 77ABED98CF4A65F3628-8022
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 R    HW: 3AA 937 087 R
   Component: BCM PQ47 H++  422 0474
   Revision: BD422001
   Coding: 0008002000000000008802819400094C20550B0840200D20E484402400C0
   Shop #: WSC 12345 123 61029
   VCID: 49CF5B60E9BE2303C4C-801C
   Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
   Component: WWS464 170413  010 0604
   Serial number: 170413
   Coding: 00B795
   Component: RLFS  024 0042
   Serial number: Y13M05D11H04M13S00S4
   Coding: 0228DD
   Part No SW: 5N0 959 655 AE    HW: 5N0 959 655 AE
   Component: J234__517 VW10 HI   2318
   Revision: 27019000    Serial number: 003N5P8JTZ6O
   Coding: 0012599
   VCID: 005986449604224B532-8054
   Subsystem 1 - Part No: 3C8 959 339 A
   Subsystem 2 - Serial number: 0000000000D068
   Subsystem 3 - Serial number: 0015.03.130000300000650071ÿ†63
   Subsystem 4 - Serial number: 650071ÿ†6332MTS622651173 ÿ†63
   Subsystem 5 - Serial number: 51173 ÿ†6342MTS609621073 ÿ†63
   Subsystem 6 - Serial number: 21073 ÿ†6351HTS68CHKRBKR ÿ†63
   Subsystem 7 - Serial number: KRBKR ÿ†6361HTS66MV9RBKJ ÿ†63
   Subsystem 8 - Serial number: 9RBKJ ÿ†63727TS6DEAESBKJ ÿ†63
   Subsystem 9 - Serial number: ESBKJ ÿ†63827TS6HNONRBKJ ÿ
   Subsystem 10 - Serial number: NRBKJ ÿ
            001 - Upper Limit Exceeded - Intermittent - MIL ON
                    Fault Status: 10100001
                    Mileage: 208570 km
                    Date: 2014.06.08
                    Time: 20:08:09
   Part No SW: 5K0 953 569 AS    HW: 5K0 953 569 AS
   Revision: --X01---    Serial number: 20190415300045
   Coding: 7982A10000
   VCID: 094F9B60A9BE630304C-805C
   Component: E221__MFL-TK6  H07 0022
   Serial number: 40000000000000866553
   Coding: E20000
14 Faults Found:
0516 - Databus
                    Reset counter: 112
                    Mileage: 218153 km
                    Date: 2020.04.10
                    Time: 06:10:19
147462 - Terminal 15
          B1148 12 [009] - Short to Plus
226827 - Turn Signal Switch
          B1144 13 [008] - Open Circuit
226839 - Turn Signal Switch
          B1144 11 [009] - Short to Ground
                    Fault Frequency: 11
                    Reset counter: 113
227339 - Windshield Wiper Switch
          B1145 13 [008] - Open Circuit
                    Fault Frequency: 23
                    Reset counter: 113
          B1154 11 [008] - Short to Ground
                    Reset counter: 152
          B1154 13 [008] - Open Circuit
                    Reset counter: 152
332660 - Databus
                    Reset counter: 152
336904 - Databus
342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [008] - Performance
365080 - Controls in Steering Wheel
          U108E 00 [008] - No Communications
                    Reset counter: 152
617736 - Selector Lever Park Position Lock Switch
          B1162 29 [008] - Signal Implausible
                    UBat: 13.70 V
   Part No SW: 3C8 920 971 E    HW: 3C8 920 971 E
   Coding: 240F00
   Shop #: WSC 05314 115 00000
   VCID: 2F3B15F8779A6D33FA8-807A
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1642
   Revision:   H56       Serial number: 090513F2001208
   Coding: 469006
   VCID: 7CA1F2B4F6EC46AB0FA-8028
                    Fault Status: 00110100
                    Reset counter: 152
                    Mileage: 218153 km
                    Date: 2014.09.01
                    Time: 06:01:02
   Part No SW: 3AA 959 433 C    HW: 3AA 959 433 C
   Component:    IMMO         042 0407
   VCID: 392F2BA0B55EB38354C-806C
   Part No SW: 1K0 035 274 F    HW: 1K0 035 274 F
   Component: RNS315-NAR    H70 0409
   Serial number: VWZAZ2N0281159
   Coding: 0400042104000F0000008000
   ROD: EV_RNS315NARV2UDS.rod
   VCID: 270BFDD85F6A3573328-8072
   Component: NAR_V4  0041
          B11CF 53 [009] - Deactivated
                    Reset counter: 133
                    Mileage: 119689 km
                    Date: 2018.06.09
                    Time: 11:15:38
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0555
   Revision: 12110009    Serial number: 0006961057
   Coding: 0004B7
   Shop #: WSC 05311 115 00000
   VCID: 6D87CFF0BD16DF23884-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000003464524
   Coding: 010490
   Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.302 1202
   Revision: 1BH04737    Serial number: 00131220006501
   Coding: 0000258
   VCID: 3FDB45B8AB7A9DB36A8-806A
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 113
                    (no units): 4.0
                    Voltage: 12.30 V
                    Reset counter: 113
                    Mileage: 218161 km
                    Date: 2014.09.02
                    Time: 00:04:38
                    (no units): 4.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 6
   Component:    KSG PQ47 ELV 042 0645
   Coding: 1B910F8001862E521204141FF08A0F0E107C02
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1642
   Coding: 00000008
   VCID: 6FBBD5F8B79A2D33BA8-803A
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0004
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0555
   Revision: 14110009    Serial number: 0006924813
   Coding: 0004B6
   VCID: 6E85C8FCB010243BB1E-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000003478390
   Coding: 010490
   Revision:   H19       Serial number: 00000001007373
   Coding: 0022156
   VCID: 3635209C84405CFBB9E-8062
   Component: AFS-ECU       H04 0111
   Coding: 071200010B000400
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   VCID: 372B2D988FCAA5F3A28-8062
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 350000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 350000
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000214338
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
   VCID: 3537279095C657E3B04-8060
   Component: OCULowUSA     014 0078
   Serial number: 000003554140500
   Coding: 02640402C2421A107F1606000000
   VCID: 53F379083B7269D3BE0-8006
12670464 - Databus
          [CAN TO brake]
                    Reset counter: 114
                    Mileage: 216684 km
                    Date: 2020.03.13
                    Time: 00:26:14
0035 - Databus
          [CAN TO Airbag]
                    Fault Frequency: 198
                    Reset counter: 152
                    Mileage: 146063 km
                    Date: 2018.12.12
                    Time: 16:17:53
                    Fault Priority: 8
                    Reset counter: 113
                    Mileage: 218161 km
                    Date: 2020.04.11
                    Time: 00:06:27
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007664725018
   Coding: 0A100300A0010110
   ROD: EV_UHVUMI.rod
   VCID: 2E0508FC7090643BF1E-807A
End----------(Elapsed Time: 01:40, VBatt start/end: 12.4V/12.4V)-----------
Old clock spring scan
Mileage: 215920km-134166mi   Repair Order:
          65 72 75 77
VIN: WVWAP7AN3EE500845   Mileage: 215920km-134166miles
   VCID: 7F5B05B8EBFA5DBFB0F-802A
                    Fault Frequency: 11
                    Mileage: 210706 km
                    Date: 2014.06.18
                    Time: 05:21:09
                    RPM: 1264 /min
                    Load: 9.0 %
                    Temperature: 26.0°C
                    Temperature: 7.0°C
                    Absolute Pres.: 870.0 mbar
                    Voltage: 14.351 V
000772 - Cylinder 4
                    Fault Frequency: 11
                    Mileage: 210706 km
                    Date: 2014.06.18
                    Time: 05:21:09
                    RPM: 1264 /min
                    Load: 9.0 %
                    Temperature: 26.0°C
                    Temperature: 7.0°C
                    Voltage: 14.351 V
   Component: J104   C2 450M V41C 0030
   Coding: 0000396
   VCID: 7BA3F1A8FFE2419F9C7-802E
   Revision: 00001K01
   Coding: 0714019048
   VCID: 77ABED98CF4A65FFF8F-8022
   Revision: BD422001
   VCID: 49CF5B60E9BE230F5EB-801C
   Coding: 00B795
   Coding: 0228DD
   Coding: 0012599
   VCID: 0059864496042247C95-8054
                    Fault Status: 11100001
                    Mileage: 208570 km
                    Date: 2014.06.09
                    Time: 20:08:09
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010041    Serial number: 20130503100531
   Coding: 018A270000
   VCID: 72BDDC8CA42800D7CF1-8026
          U108E 00 [009] - No Communications
                    Reset counter: 68
                    Mileage: 205102 km
                    Date: 2019.12.13
                    Time: 11:47:52
   Coding: 240F00
   VCID: 2F3B15F8779A6D3F60F-807A
   Coding: 469006
   VCID: 7CA1F2B4F6EC46A795D-8028
   VCID: 392F2BA0B55EB38FCEB-806C
   ROD: EV_RNS315NARV2UDS_VW46.rod
   VCID: 270BFDD85F6A357FA8F-8072
                    Reset counter: 133
                    Mileage: 119689 km
                    Date: 2018.06.10
                    Time: 11:15:38
   Coding: 0004B7
   VCID: 6D87CFF0BD16DF2F123-8038
   Slave Driver:
   Coding: 010490
   Coding: 0000258
   VCID: 3FDB45B8AB7A9DBFF0F-806A
   Coding: 00000008
   VCID: 6FBBD5F8B79A2D3F20F-803A
   Coding: 0004B6
   VCID: 6E85C8FCB01024372B9-803A
   Slave Passenger:
   Coding: 010490
   Coding: 0022156
   VCID: 3635209C84405CF7239-8062
   VCID: 372B2D988FCAA5FF38F-8062
   Coding: 350000
   Coding: 350000
   VCID: 3537279095C657EF2A3-8060
   VCID: 53F379083B7269DF247-8006
0035 - Databus
          [CAN TO Airbag]
                    Fault Frequency: 190
                    Reset counter: 53
                    Mileage: 146063 km
                    Date: 2018.12.13
                    Time: 16:17:53
                    Fault Priority: 8
                    Reset counter: 27
   ROD: EV_UHVUMI.rod
   VCID: 2E0508FC709064376B9-807A
End----(Elapsed Time: 01:41, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Theoretically I should be able to input the same long coding from the old clock spring?
Not necessarily. You've replaced 3C5-953-501-BN with with 5K0-953-569-AS. The coding charts for them are similar, but not identical.
Is 5K0-953-569-AS really an appropriate replacement for 3C5-953-501-BN ?
golfi_vend
Tartu, Estonia
C?ID=195131
Coding is identical. OE Partnumbers also refers to stalks and other vital components around SWCM.
If You check HW You see it's different by index, which is superseeded.
Just copy-paste coding.
Reaper78
Utah, USA
C?ID=394919
5K0-953-569-AB is the original part number that was manufactured when the car was. However, the successor to the "AB" is now 5K0-953-569-AS. This is confirmed by the dealership via their internal VW parts finder. The only difference in part numbers is the last letter... from "B" to "S." This is why I'm thinking I might be able to long code it with the same code from the old one.
Reaper78
Utah, USA
C?ID=394919
If it's that easy it would solve all the problems, except for my cyl4 misfire. But right now my cruise doesn't work, power assist steering, airbag, and toggling through the menu doesn't work
Reaper78
Utah, USA
C?ID=394919
Installed the new clock spring. Coded it just like the old one. Now the steering wheel buttons work, but steering assist, airbag, and ESP aren't working. I've checked the modules and the coding matches from old scans, but still not working right. Ideas?
