VW Touran Speedo Change
Dougal
C?ID=382259
Hi
I am new to this forum not sure where to post this problem i have?
i have down loaded the inf on how to change a speedo but nothing seems to be correct
ie it says select 01- Engine > Measuring Blocks 08 > Go i have no string lines like this no 17 didget codes ?
I have removed the old head and sent for repair was told it is US and needs replacing
So i have a brand new head all sealed and need to fit it please advise
Bruce
Near Philadelphia, PA, USA
Welcome to our forum. In order to help, we need information. That information is provided by your VCDS tool through the AutoScan. Please post an AutoScan so we may know how the Touran is configured.
Likely you have a UDS cluster and the swap information you are reading is not the info needed as it is for older clusters.
[h=3]How to post an Auto-Scan[/h]
Dougal
C?ID=382259
Hi Bruce i hope i have the correct info
Thursday,21,November,2019,14:01:45:23193
Dealer/Shop Name: Motorcare
VIN: WVGZZZ1TZ6W034015   License Plate:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ6W034015   Mileage: 272590km-169379miles
09-Cent. Elect. -- Status: Malfunction 1010
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 016 CD    HW: 028 101 194 5
   Component: R4 1,9L EDC G000SG  6246
   Revision: 12345678    Serial number: VWZ7Z0E2430747
   Coding: 0000072
   Shop #: WSC 01324 785 00200
   VCID: 679EA4BC56374D7706-8032
7 Faults Found:
19558 - Motor for Intake Manifold Flap (V157)
            P3102 - 000 - No Signal
                    Torque: 0.0 Nm
                    Load: 78.4 %
                    Voltage: 12.31 V
                    Bin. Bits: 00001110
                    Torque: 0.0 Nm
                    Torque: 320.0 Nm
18049 - Please check DTC Memory of A/C Controller
            P1641 - 000 -
                    Torque: 0.0 Nm
                    Load: 78.4 %
                    Voltage: 12.39 V
                    Bin. Bits: 00001110
                    Temperature: 26.1°C
                    (no units): 144.0
16955 - Brake Switch (F)
            P0571 - 000 - Implausible Signal - MIL ON
                    Torque: -98.0 Nm
                    Voltage: 12.46 V
                    Bin. Bits: 00000000
                    Torque: 0.0 Nm
                    Bin. Bits:  0 00  0
            P1570 - 000 -  - Intermittent
                    Torque: 0.0 Nm
                    Voltage: 12.31 V
                    Bin. Bits: 00001110
                    Bin. Bits: 00000000
                    (no units): 0.0
17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault
                    Torque: 190.0 Nm
                    Voltage: 11.32 V
                    Bin. Bits: 00001110
                    Temperature: -0.9°C
                    Bin. Bits: 00110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
            P0674 - 000 - Electrical Fault
                    Torque: 190.0 Nm
                    Voltage: 11.32 V
                    Bin. Bits: 00001110
                    Temperature: -0.9°C
                    Bin. Bits: 00110000
18009 - Relay for Supply Voltage Terminal 30 (J317)
            P1601 - 000 - Implausible Signal
                    Torque: -98.0 Nm
                    Voltage: 12.54 V
                    Bin. Bits: 00000000
                    Bin. Bits:        0
                    (no units): 0.0
Readiness: 0 1 0 1 1
   Revision: 00H11001
   Coding: 0021190
   Shop #: WSC 00375 210 82282
   VCID: 73A6C0EC12EFB1D7AA-8026
6 Faults Found:
   Part No: 1K0 820 047 DF
   Component: Climatic PQ35   090 0505
   VCID: 6B96D88C4ADF691762-803E
            009 - Open or Short to Ground
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000000012045
   Coding: 00890F210004100000120C000000000000087B075C
   VCID: 2A181D8885A5B01FD9-807E
   Subsystem 1 - Part No: 1T0 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 161115 021  0501
   Coding: 00038805
   Shop #: WSC 01324
00532 - Supply Voltage B+
                    Reset counter: 101
                    Mileage: 272593 km
                    Voltage: 7.85 V
00447 - Function Limitation due to Over-Voltage
                    Fault Status: 00100001
                    Reset counter: 101
                    Mileage: 272593 km
                    Voltage: 16.35 V
                    Reset counter: 101
                    Mileage: 272593 km
                    Voltage: 7.55 V
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 C    HW: 1T0 909 605 C
   Component: 02 AIRBAG VW62 0506 1500
   Revision: 09025000    Serial number: 0038BD0ECX08
   Coding: 0012338
   VCID: 35223EF45C1BEFE744-8060
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0000042
   VCID: 76A0F9F8019DA4FF8D-8022
6 Faults Found:
00888 - Wiper Switch for Intermittent Operation (E22)
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
   Part No: 1T0 920 962 A
   Component: KOMBIINSTRUMENT VDD 1012
   Coding: 0003401
   Shop #: WSC 00187 067 57207
   VCID: 322805E8AD75F8DF61-8066
00003 - Control Module
            014 - Defective
00771 - Fuel Level Sensor (G)
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 1K0 815 071 H
   Component: Zuheizer        031 1312
   Revision:        A    Serial number: 09010046
   Coding: 0000011
01489 - Over-Temp Sensor (G189)
                    Fault Status: 00101010
                    Reset counter: 101
                    Mileage: 403665 km
                    Time: 00:28:44
                    Temperature: 48.0°C
                    Temperature: 11.0°C
                    Reset counter: 61
                    Mileage: 131072 km
                    Time: 16:00:00
            014 - Defective
                    Reset counter: 61
                    Mileage: 131072 km
                    Time: 16:00:00
01411 - Temperature Sensor (G18)
                    Fault Status: 00100111
                    Fault Frequency: 62
                    Reset counter: 80
                    Mileage: 257441 km
                    Time: 27:54:56
                        Malfunction
                    Temperature: 205.0°C
                    Temperature: 36.0°C
00664 - Fuel gauge
                    Reset counter: 197
                    Mileage: 193346 km
                    Time: 10:55:30
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 280010570501D7
   Coding: 3D3F1340078003
                    Fault Frequency: 44
                    Reset counter: 101
                    Time Indication: 15
                    Reset counter: 101
                    Time Indication: 15
                    Fault Status: 01100010
                    Reset counter: 61
                    Mileage: 272593 km
                    Time: 19:40:28
   Component: IMMO            VDD 1012
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
   Part No: 1T0 959 701 A
   Component: Tuersteuergeraet 09 0158
   Coding: 0000052
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 332600EC526FF1D76A-8066
02546 - Steering Limit Stop
                    Temperature: 9.0°C
                    Voltage: 12.40 V
                    Voltage: 12.20 V
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 01C802087F2D8405485FC61010CC
   VCID: 79BAF2C43083CB87E0-802C
   Subsystem 5 - Part No: 1K0 947 291 F
   Component: Innenraumueberw.009 4809
   Coding: 00000000
   Subsystem 6 - Part No: 1K0 951 605 C
   Subsystem 7 - Part No: 1K0 907 719 C
   Component: Neigungssensor  005 0003
6 Faults Found:
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Coding: 0000052
   VCID: 75A2FEF41C9BAFE784-8020
   Part No: 1K0 035 186 P
   Component: Radio GR0       015 0019
   Revision: 0001503S    Serial number: VWZ2Z2E1149074
   Coding: 0022200
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 06 0214
   Coding: 0000048
   VCID: 2F2E0C9CBE47D5370E-807A
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Coding: 0000048
   VCID: 302C0FE0A379CACF17-8064
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End----------(Elapsed Time: 01:10, VBatt start/end: 12.1V/12.6V)-----------
Since this is a 2006 and the ECU still has a VWZ Immo ID, it might be doable with VCDS if you had the security codes for the car, but I'm going to assume you don't. So the path of least resistance is to take it to a dealer or other specialist with access to VW's servers.
Dougal
C?ID=382259
Yes i have a code 09287 so can i do it with this code ?
Dougal
C?ID=382259
All done thanks
Only 1 problem the traction control light is on
Code 01435 brake pressure Sensor 1 G201 No or Wrong Adaptation
Code 01423 Lateral Acceleration Sensor (G200) No or Wrong Adaption
All was woring fine untill the above was carried out any ideas please
Dougal
MasterTommy
Amsterdam
C?ID=295586
You have to do basic settings since they were wiped, there should be articles for that in the wiki.
