Thursday,21,November,2019,14:01:45:23193
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 19.6.2.0 (x64) HEX-NET : 0.4508.4
Dealer/Shop Name: Motorcare
VIN: WVGZZZ1TZ6W034015 License Plate:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
VIN: WVGZZZ1TZ6W034015 Mileage: 272590km-169379miles
03- Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 1010
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 016 CD HW: 028 101 194 5
Component: R4 1,9L G000SG 6246
Revision: 12345678 Serial number: VWZ7Z0E2430747
Coding: 0000072
Shop #: 01324 785 00200
VCID: 679EA4BC56374D7706-8032
7 Faults Found:
19558 - Motor for Intake Manifold Flap (V157)
P3102 - 000 - No Signal
Torque: 0.0 Nm
Load: 78.4 %
Voltage: 12.31 V
Bin. Bits: 00001110
Torque: 0.0 Nm
Torque: 320.0 Nm
18049 - Please check Memory of A/C Controller
P1641 - 000 -
Torque: 0.0 Nm
Load: 78.4 %
Voltage: 12.39 V
Bin. Bits: 00001110
Temperature: 26.1°C
(no units): 144.0
16955 - Brake Switch (F)
P0571 - 000 - Implausible Signal - MIL ON
Torque: -98.0 Nm
Voltage: 12.46 V
Bin. Bits: 00000000
Torque: 0.0 Nm
Bin. Bits: 0 00 0
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - Intermittent
Torque: 0.0 Nm
Voltage: 12.31 V
Bin. Bits: 00001110
Bin. Bits: 00000000
(no units): 0.0
17057 - Cylinder 3 Glow Plug Circuit (Q12)
P0673 - 000 - Electrical Fault
Torque: 190.0 Nm
Voltage: 11.32 V
Bin. Bits: 00001110
Temperature: -0.9°C
Bin. Bits: 00110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Torque: 190.0 Nm
Voltage: 11.32 V
Bin. Bits: 00001110
Temperature: -0.9°C
Bin. Bits: 00110000
18009 - Relay for Supply Voltage Terminal 30 (J317)
P1601 - 000 - Implausible Signal
Torque: -98.0 Nm
Voltage: 12.54 V
Bin. Bits: 00000000
Bin. Bits: 0
(no units): 0.0
Readiness: 0 1 0 1 1
Address 03: Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021190
Shop #: 00375 210 82282
VCID: 73A6C0EC12EFB1D7AA-8026
Part No: 1K0 820 047 DF
Component: Climatic PQ35 090 0505
Shop #: 00000 000 00000
VCID: 6B96D88C4ADF691762-803E
00457 - Central Electronics Control Module / (J519)
009 - Open or Short to Ground
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000012045
Coding: 00890F210004100000120C000000000000087B075C
VCID: 2A181D8885A5B01FD9-807E
Subsystem 1 - Part No: 1T0 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 161115 021 0501
Coding: 00038805
Shop #: 01324
Reset counter: 101
Mileage: 272593 km
Voltage: 7.85 V
Fault Status: 00100001
Reset counter: 101
Mileage: 272593 km
Voltage: 16.35 V
Reset counter: 101
Mileage: 272593 km
Voltage: 7.55 V
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0ECX08
Coding: 0012338
VCID: 35223EF45C1BEFE744-8060
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000042
VCID: 76A0F9F8019DA4FF8D-8022
00888 - Wiper Switch for Intermittent Operation (E22)
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
Part No: 1T0 920 962 A
Component: KOMBIINSTRUMENT VDD 1012
Coding: 0003401
Shop #: 00187 067 57207
VCID: 322805E8AD75F8DF61-8066
00003 - Control Module
014 - Defective
00771 - Fuel Level Sensor (G)
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Revision: A Serial number: 09010046
Coding: 0000011
01489 - Over-Temp Sensor (G189)
Fault Status: 00101010
Reset counter: 101
Mileage: 403665 km
Time: 00:28:44
Temperature: 48.0°C
Temperature: 11.0°C
Reset counter: 61
Mileage: 131072 km
Time: 16:00:00
014 - Defective
Reset counter: 61
Mileage: 131072 km
Time: 16:00:00
01411 - Temperature Sensor (G18)
Fault Status: 00100111
Fault Frequency: 62
Reset counter: 80
Mileage: 257441 km
Time: 27:54:56
Malfunction
Temperature: 205.0°C
Temperature: 36.0°C
00664 - Fuel gauge
Reset counter: 197
Mileage: 193346 km
Time: 10:55:30
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010570501D7
Coding: 3D3F1340078003
Fault Frequency: 44
Reset counter: 101
Time Indication: 15
Reset counter: 101
Time Indication: 15
Fault Status: 01100010
Reset counter: 61
Mileage: 272593 km
Time: 19:40:28
Component: IMMO VDD 1012
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX1.lbl
Part No: 1T0 959 701 A
Component: Tuersteuergeraet 09 0158
Coding: 0000052
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 332600EC526FF1D76A-8066
02546 - Steering Limit Stop
Temperature: 9.0°C
Voltage: 12.40 V
Voltage: 12.20 V
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 01C802087F2D8405485FC61010CC
VCID: 79BAF2C43083CB87E0-802C
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Shop #: 00000
Subsystem 6 - Part No: 1K0 951 605 C
Component: BACKUP HORN H03 1301
Subsystem 7 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000052
VCID: 75A2FEF41C9BAFE784-8020
Part No: 1K0 035 186 P
Component: Radio GR0 015 0019
Revision: 0001503S Serial number: VWZ2Z2E1149074
Coding: 0022200
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
VCID: 2F2E0C9CBE47D5370E-807A
01813 - Supply Voltage for Door Controller; Rear Left (J388)
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 302C0FE0A379CACF17-8064
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End----------(Elapsed Time: 01:10, VBatt start/end: 12.1V/12.6V)-----------
