Problem retrofitting AID e-Golf 7
skolelyset
Norway
C?ID=366923
Ok, so I did this stupid thing..
I want to retrofit the AID-cluster on my 2014 e-golf.. I have the cluster and the optical loop wire. I have stripped the interior, and was just test-fitting the AID.
Didnt work of course because of the component protection. (The AID come from a crashed 2019 e-golf.)
So I just refitted my original cluster, and then the problems started..
I've got about a million faultcodes, and the car i almost impossible to drive.
Yeah, and I did not backup my codes before I testfitted...
I have my car at the dealer right now, and they have removed CP from the AID, but the faultcodes are still there.
They have now remounted the original cluster, and are trying to remove the faultcodes..
Q1: Can I clear the faultcodes myself, or does the dealer have to do this?
Q2: If I try to mount the AID again, will the faultcodes reappear? Is this in the cluster or stored in the car? Dealer says the AID is a different communication protocol than the car.
Here is the autoscan with the faultcodes..
Tuesday,22,October,2019,18:51:22:58245
VIN: WVWZZZAUZFW901768   License Plate:
Chassis Type: AU-VW37 (5QE)
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 55 5F 75
          8C A5 BD C6
VIN: WVWZZZAUZFW901768   Mileage: 58864km-36576miles
23-Brake Booster -- Status: Malfunction 0010
51-Electric Drive -- Status: Malfunction 0010
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
C6-Batt. Chrg. -- Status: Malfunction 0010
Address 01: Engine (J623-EAGA)       Labels:. 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 A    HW: 0EA 907 309 A
   Component: E-Vehicle     H22 7907
   Revision: WMH22---
   Coding: 000D0012006404003000
   ASAM Dataset: EV_VCU00XXX0110EA906016A 002014
   ROD: EV_VCU00XXX0110EA906016A_002.rod
   VCID: 2D0708C73D9F063F521-8078
17158 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:27
                    Engine speed: 16383.75 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Voltage terminal 30: 13.664 V
                    Acceleration: 0.000 m/s²
24175 - Please Check Fault Codes in Control Module for ESP
          U102C 00 [039] - -
          [ESPRead out DTC]
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:15
                    Voltage terminal 30: 14.936 V
          U0428 00 [039] - -
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:12
                    Voltage terminal 30: 14.889 V
4716 - No Communications with Parking Brake Control Module
          U0128 00 [039] - -
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:11
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 907 379 N    HW: 5Q0 907 379 H
   Component: ESC           H31 0807
   Revision: 00000000    Serial number: 61954000000159
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
   ROD: EV_Brake1UDSContiMK100OMG_001_VW37.rod
   VCID: 47CB5A6FBF23CC6F48D-8012
9 Faults Found:
0195 - Control module not coded
          U1013 00 [167] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Date: 2019.10.21
                    Time: 21:36:14
0212 - Longitudinal Acceleration Sensor
          C1017 54 [167] - Missing Calibration / Basic Setting
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:12
0270 - Lateral Acceleration Sensor
          C1079 54 [167] - Missing Calibration / Basic Setting
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:12
0279 - Brake Pressure Sensor 1
          C107A 54 [167] - Missing Calibration / Basic Setting
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:12
0295 - Steering angle sensor
          B1168 54 [167] - Missing Calibration / Basic Setting
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:12
8290 - Coding Not Possible
          U10BC 00 [167] - -
          [FCAN: Unplausible VIN number]
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:12
8306 - Databus
          U1122 00 [167] - Implausible Message
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:12
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [047] - -
          [FCAN: Coding of ESP and TSK does not fit together]
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:13
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [175] - Switches/Motors Detected
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:14
   Revision: 00021000    Serial number: 0343294710
   Coding: 030C0C
   VCID: 3A2D339BFCD1A187C73-806E
   Part No SW: 5GE 907 044 S    HW: 5GE 907 044 S
   Component: Climatronic   H02 1103
   Revision: 00001K07
   Coding: 00022200200100010105000200101000
   ASAM Dataset: EV_ACClimaBHBVW37X 005132
   ROD: EV_ACClimaBHBVW37X_005_VW37.rod
   VCID: 4CC16543A6452F3765F-8018
   Subsystem 3 - Part No SW: 12E 963 231 E    HW: 12E 963 231 E
   Component: J848 HV-PTC  H09 0205
   Serial number:  T142203003805000024
H01
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011421700904
   Coding: 00011B66C34102F32BA44080B11407201800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 00598173DA8D3B57C97-8054
   Component: WWS    140726  043 0551
   Serial number:         140801011851
   Component: RLHS  037 0059
   Serial number: S4Y14M08D18H13M41S56
   Coding: 00A8DD
   Serial number: 000000000ZY142021PV6
   Serial number: 00000000000060302941
   Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0047
   Revision: --------    Serial number: 39431421800859
   Coding: 2031161011
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 42DD4B7B9401E9479F3-8016
12658704 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
13697024 - Control Module
          U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
          [Steuergerät für Bremse - ESP_02.ESP_Status_ESP_PLA - PLA-Codierung in Bremse prüfen]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
13637426 - Databus
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 14081477030976
   Coding: 001C2700FE0739
   VCID: 38292993C2DDB397317-806C
6 Faults Found:
1071 - Databus
          [FAULT_CIS_AXV_INVALID]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
                    Control Module temperature: 23 °C
                    Voltage terminal 15: 14.9 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
1078 - Databus
          [FAULT_CIS_SAS_INIT]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
0261 - Databus
          [FAULT_CIM_TIMEOUT_EPB_01]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
1043 - Automatic Distance Control
          B10E7 F0 [009] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    009 0870
   Serial number: 003MFR003TAN
   Coding: 98FCC0C0002000005C5400CF004800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 50F971334A6D0BD7197-8004
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0341
   Serial number: 34169667B20081440169
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0341
   Serial number: 34169668B20081441266
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 408 14
   Serial number: 3570000000085835B01D
   Subsystem 4 - Part No SW: -----------    HW: 480 001 408 14
   Serial number: 358000000000E5B8C01O
   Subsystem 5 - Part No SW: -----------    HW: 480 401 408 14
   Serial number: 3510002A516FC222720W
   Subsystem 6 - Part No SW: -----------    HW: 480 401 108 14
   Serial number: 3520002A516DB810811Y
   Subsystem 7 - Part No SW: -----------    HW: 480 401 408 14
   Serial number: 3550002AB16DB80531EC
9682162 - Multiple collision brake
          B13BC F2 [137] - No function
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
1049093 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Querbeschleunigung]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
1050117 - Databus
          [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
1049094 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
1049095 - Databus
          [NWD: 0x101 ESP_02 error value ESP_Gierrate]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
   Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 11081404400275
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 7BA3F69FB36B588F9C5-802E
Address 17: Instruments (J285)       Labels:* None-SRI3
   Part No SW: 5GE 920 755     HW: 5GE 920 755
   Component: KOMBI         301 4280
   Coding: 072518186F940008008868031600000000000000
   VCID: 7DA7F887AD7F56BFA21-8028
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:09
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:09
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 B    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3186
   Revision: --------    Serial number: 21071410800890
   Coding: 0201001746F81000EF001210081E00000001050100030000000000000000
   ASAM Dataset: EV_GatewEVConti 011017
   ROD: EV_GatewEVConti_011.rod
   VCID: 45D75067852FDE7FBA1-8010
   Subsystem 1 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0038
   Serial number: 27140002073650124341
   Coding: 2CFFFF
   Subsystem 2 - Part No SW: 5GE 915 181     HW: 5GE 915 181
   Component: J367-BDMHella  H03 8050
   Serial number: 7773663003
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 A    HW: 5QE 909 059 A
   Component: EBKV          H12 0160
   Serial number:   085430010046
   Coding: 01720100321900030002000500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 002014
   ROD: EV_BrakeBoostBoschMQBOMG_002_VW37.rod
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 A    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0140
   Serial number: 05802861160714213901
163584 - No Communications with Parking Brake Control Module
          U0128 00 [047] - -
          [iBoVAG_ComScl_EPB_01_Timeout]
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:12
   Revision: 00000000    Serial number: 14000210624005
   Coding: 7900000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311DA3DEB557F71DF-8060
   Serial number: 28071403110311
   Coding: 003F1220D000048000001000
   VCID: 40D941739A0DFB57897-8014
   Serial number: 00000000000003510459
   Component: EPS_MQB_ZFLS  123 1043
   Coding: D302
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DF44779107F25F869-8014
15873 - Steering angle sensor
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
                    Motor status: 00
                    Supply voltage: 14.75 V
                    Temperature: 15.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5B
                    uioUdNotFilt_xdu16: 14.88 V
                    uAdSensI_SwitchedKl30_xdu16: 14.88 V
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 55
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:50:49
                    Motor status: 00
                    System status: Driving mode
                    Temperature: 16.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 15.03 V
                    uAdSensI_SwitchedKl30_xdu16: 15.03 V
Address 51: Electric Drive (J841)       Labels: None
   Part No SW: 5QE 907 080 B    HW: 5QE 907 080 B
   Component: VW370E2615010 H05 2453
   Revision: 00H05000
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM09550115QE907080B 001018
   ROD: EV_DMCM09550115QE907080A.rod
27161 - No Communication with ESP (Vehicle Dynamics) Control Module
          U0122 00 [039] - -
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:11
                    Voltage terminal 30: 14.902 V
                    Drive control condition: Standby
                    RPM of electric machine: 0 /min
                    Power electronics: IGBT module temp: phase U: 11.36 °C
                    E-machine: stator temperature: 10.45 °C
                    Power electronics: traction network voltage: 314.84 V
                    Torque: current value: -0.06 Nm
   Serial number: 07081404080747
   Coding: 003F1020DE00048000001000
   VCID: 3FDB428FE7F384AFF0D-806A
   Serial number: 00000000000003470520
   Coding: 190000
   Coding: 051A000001010000
   VCID: 75B7E0A7954F0EFFEA1-8020
13705992 - Databus
          U1123 00 [137] - Received Error Message
          [LWI_01: Fehlerwert im Signal LWI_Lenkradwinkel]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:59:55
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 020 D    HW: 5G0 035 020 D
   Component: MU-H-ND-EU    H43 0362
   Serial number: A310G0EB004179
   Coding: 027370010000000011111202000800001F0105B40100010097
   ASAM Dataset: EV_MUHig6C3HBAS 001041
   ROD: EV_MUHig6C3HBAS_VW37.rod
   VCID: 1A6DD31B5C118187273-804E
   Component: ABT_High  H61 0030
   Serial number: VWZ8Z9PS100H78
   Subsystem 2 - Part No SW: V03 959 806 F    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Component: Gracenote  --- 1010
7175 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:15
                    Voltage terminal 30: 15.2 V
                    BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:15
   Part No SW: 5QE 035 284     HW: 5QE 035 284
   Component: OCULowMQBEU   007 0535
   Coding: 0273700110829A01007800000000
   ROD: EV_OCULowMQB.rod
   VCID: 015F8477D187325FC69-8054
Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 5QE 915 227 M    HW: 5QE 915 227 H
   Component: K8C           H13 0731
   Serial number: VWADEH600E
   ASAM Dataset: EV_BECM08820215QE915227M 003016
   ROD: EV_BECM08820215QE915227H.rod
   VCID: 52FD7B3B446179C72F3-8006
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 10000115618
   Coding: 0101010001020303000500000100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B23369FF3EB988FDC5-806E
6553600 - Databus
          [LH_EPS_03_BERECHN_LW_SIG_FAILURE]
                    Reset counter: 15
                    Mileage: 58864 km
                    Date: 2019.10.21
                    Time: 21:36:10
                    Control Module temperature: 39 °C
                    Outside air temperature: 4.5 °C
                    Vehicle speed: 0.00 km/h
                    Terminal 15 on: 489.6 s
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:| 5QE-915-022.clb
   Part No SW: 5QE 915 022 E    HW: 12E 915 022 C
   Component: LMSG          H08 1072
   Serial number: 00920043010056
   Coding: CA0903
   ASAM Dataset: EV_HVChargManagVWMQB 001001
   ROD: EV_HVChargManagVWMQB_001.rod
   VCID: 43D34E7F8B1BE04F945-8016
Address C6: Batt. Chrg. (JAX4)       Labels: 5QE-915-681.clb
   Part No SW: 12E 915 682 G    HW: 12E 915 682 G
   Component: OBC KOSTAL    H42 0142
   Revision: --------    Serial number: 2507140GI0000M
   ASAM Dataset: EV_OBCSinglPhaseKLOVW3707 002001
   ROD: EV_OBCSinglPhaseKLOVW3707_002.rod
   VCID: 2E050FCB30997D276BB-807A
1048581 - Input Voltage Network Malfunction
          P31C6 00 [008] - -
                    Fault Frequency: 16
                    Reset counter: 55
                    Mileage: 58864 km
                    Date: 2019.10.22
                    Time: 07:00:25
End----------(Elapsed Time: 02:16, VBatt start/end: 13.2V/13.3V)-----------
You'll need to restore the ABS coding, then most of the other faults should be clear-able.
If the AID still has another car's VIN, then the ABS will lose its coding again. If it has been properly matched by the dealer, I think it will be OK, but I've not done this kind of swap myself, so I'm not positive.
downtime
C?ID=280813
Uwe is correct. Dealer can re-code the ABS with ODIS and running online coding guided function and that should get rid of most of the problems.
They can match the AID to your car but they cannot online code it. Coding you need to do yourself.
skolelyset
Norway
C?ID=366923
Ok, I will ask them to do that.
Does the VIN need to be stored in the AID? Or should I just tell them to remove the VIN from the AID?
As I understand they have removed the component protection, but the dealer is not so familiar with retro/custom.. They have never done this before..
downtime
C?ID=280813
Removing CP from AID should also adapt the VIN. You cannot remove VIN from AID
skolelyset
Norway
C?ID=366923
So my VIN should now be in the AID?
I'm sorry if my questions are dumb.. I'm a noob...
golfi_vend
Tartu, Estonia
C?ID=195131
I really didn't dig into Your scan, but I want to share few thought about this.
Does Your cluster support Your MIB radio? Does Your gw support AID? Are You able to take on this epic journey retrofitting stuff to e-golf?
There was this thread on drive2.ru, about golf GTE thought, but in the end he has to replace kinda everything to 7.5 level to get everything working. Also ECU flashed because MODE wasn't working correctly anymore due to newer GW needed to work with MIB2.5, but it not working with older ECU software.
I honestly have 0 experience with GTE and E myself, but have taken notice from other people warnings.
Why?
VW Hybrides are annoying contemporaries.
Much is completely different than regular burners, so you should rather stay away from a GTE and eGolf.
- My Note to ALL Hybridists and Retrofiters -> DO NOT TOUCH THE GTE Gateway, Engine, AID, MIB2 ... everything will be a neverending story with no time, experience and good contacts!
skolelyset
Norway
C?ID=366923
I have a MIB2 (5G0 919 606) and Dynaudio system.
I know it have been done before on the e-golf..
Spacewalker
Poland
C?ID=159607
MIB 1 (5G0) not support MAP display via Fiber Wire
5Q0 ACC not support Distance display on Virtual cluster
but all must be do online, so waste of time asking what to do via VCDS
There is few topic already about AID replace... try to look there and compare equipment's and read other people problems
skolelyset
Norway
C?ID=366923
Ok, so now the dealer has reset my abs module.
There is one fault. Is it the trailer hitch? I don't have that on my car..
Tuesday,29,October,2019,23:16:57:58245
          8C A5 BD C6
VIN: WVWZZZAUZFW901768   Mileage: 58924km-36613miles
C6-Batt. Chrg. -- Status: OK 0000
   Revision: WMH22---
          U102C 00 [032] - -
          [ESPRead out DTC]
                    Mileage: 58923 km
                    Date: 2019.10.29
                    Time: 19:10:45
                    Voltage terminal 30: 14.913 V
   Coding: 01FA40A12C20316D037E060641CB298002348CC0608294B3F881507AC242
   Shop #: WSC 36834 003 104857
8299 - Databus
          U1121 00 [047] - Missing Message
          [FCAN: Anhaenger_01_alt veraltet bit is set]
                    Mileage: 58923 km
                    Date: 2019.10.29
                    Time: 19:10:42
   Coding: 030C0C
   Revision: 00001K07
   Coding: 00022200200100010105004200101000
H01
   Coding: 00A8DD
   Coding: 2031161011
   Coding: 333135
   Coding: 333135
   Coding: 0C10
   Shop #: WSC 00185 218 00000
   Coding: 2CFFFF
   Coding: D302
   Shop #: WSC 36834 003 1048576
   Revision: 00H05000
   Coding: 190000
   Coding: 027370010000000011111202000802001F0105B40100010097
15360768 - Component Protection
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6300)]
                    Reset counter: 16
                    Mileage: 58922 km
                    Date: 2019.10.29
                    Time: 00:05:39
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 16
                    Mileage: 58922 km
                    Date: 2019.10.29
                    Time: 00:05:41
   Coding: CA0903
End----------(Elapsed Time: 02:07, VBatt start/end: 14.8V/14.8V)-----------
Somnus
SLC, USA
C?ID=215931
there should be an adaptation channel in the ABS module called "Vehicle and Trailer Stabilization" that is most likely the cause of that error. try disabling it, clear codes in the ABS module, and rescan
IDE04774-IDE06589 -- Vehicle and trailer stabilization
