RETROFIT VIRTUAL COCKPIT NOW PROBLEMS HELP PLZ
   #21
andyhud
C?ID=32695
2013 audi a3 2.0 tdi hatchback 5 door
Do not know what 4E is cant get rid of it
4E is for Rear Seat Entertainment. Its set on the MIB2.
Go into Adaptation of 5F and look for "Smart Display Carrier 1" or 2 under "Installation List"
Set it to No, and apply and reboot your MIB2 with 3 Finger Salute. This will clear 4E from your Autoscan list.
I'm not sure if VCDS shows the names next to each installation list now (it didnt previously).. but might do now. Otherwise use ODIS.
Andy
p.s. - Did you buy a brand new VC cockpit then (0 Miles) and set RS "Dials" (the big centre dial) before removing CP and putting mileage back on it?
Codeme
Manchester, UK
C?ID=231524
Andy
hi thanks for the help. and i got mine used the guy sold unit. display and cockpit togather. it was from an S3. if you are going to buy a used 1. ebay is good so your backed up i got really lucky as it could have been stolen. i seen a few from an s3 cockpit
   #23
Morski
Cheshire UK
C?ID=90186
So what have you done with the mileage? Using the one on the S3 shown or...??
   #24
Codeme
Manchester, UK
C?ID=231524
THE MILEAGE IS LEFT AS IT IS. THERE IS NOT ANYONE WHO CAN CHANGE IT AT THE MOMENT BUT OH WELL...
   #25
Codeme
Manchester, UK
C?ID=231524
Does anyone have virtual cockpit with 2.0 diesel dsg. Need to compare coding if possible. Thank you in advance.
   #26
myounus
Northwest UK
C?ID=321059
With these retrofits you need to update your CAN Gateway to a 3Q0 version as they are notorius for errors with older gateways.
   #27
Codeme
Manchester, UK
C?ID=231524
Yes you are right. It sorted a lot of problems out
   #28
k.barghouthi
Palestine
C?ID=326133
1st you need to do KS master connection system, then FES restore for 19 and 5F :)
   #30
atesz.takacs
Hungary
C?ID=376838
Hi All, I was crazy enough to retrofit VC too. Now I would need some help or hint to fix coding of 0x17 Instruments.
Coding of my original cluster HW:8V0-920-860-E is 07A519002B8000080100E800100000.
Saturday,13,February,2021,16:23:10:25714
VCDS Version: 20.4.2.0  HEX-NET CB: 0.4513.4
Workshop Code: *** ***** 000016
VIN: WAUZZZ8V5E*******   License Plate: ****
Mileage: 85088km-52871mi   Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F 6C BB BC
VIN: WAUZZZ8V5E1039408   Mileage: 85088km-52871miles
Address 01: Engine (J623-CXSB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 AJ    HW: 04E 907 309 AC
   Component: 1.4l R4 TSI   H21 6966
   Revision: R7H21---
   Coding: 02190032232401082000
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM14TFS01104E906027AJ 001004
   ROD: EV_ECM14TFS01104E906027AJ.rod
   VCID: 6C94D02187EF85E6DF-8038
17158 - Databus
          U1123 00 [036] - Received Error Message
                    Date: 2021.02.13
                    Time: 15:47:29
                    Coolant temperature: 9 ░C
                    Intake air temperature: 5 ░C
                    Voltage terminal 30: 11.520 V
                    Mass flow through throttle valve: 0.0 kg/h
Readiness: 1110 0001
   Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
   Component: ESC           H31 0472
   Revision: 00000000    Serial number: 610140000003FD
   Coding: 13F16AA224232A75037B060041CB29C8562454C0608294F7022100788608
   ROD: EV_Brake1UDSContiMK100IPB_033.rod
   VCID: 075E8F8DBE4946BE52-8052
   Revision: 20026000    Serial number: 00000000296179
   Coding: 03000004000000011000000000001100
   Shop #: WSC 00046 000 00000
   VCID: 33260B5D9A511A1EDE-8066
   Serial number: 18A98227000000000001
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011409702541
   Coding: 04040A46C24122FD43804004001807A80000000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   VCID: 7BB6E37DF281125E46-802E
   Component: WWS371 140408  042 0585
   Serial number:         140410233444
   Coding: 0A47F7
   Serial number: 22482575
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
   Serial number: 29 12 2013  00000939
   Part No SW: 5QA 919 294     HW: 5QA 919 294
   Component: PDC 8 KanalH07 0031
   Serial number: 000308418615253
   Coding: 0470151001
   ASAM Dataset: EV_EPHVA18AU3700000 009027
   ROD: EV_EPHVA18AU3700000_009_AU37.rod
   VCID: 095A89B5A85D30CE44-805C
13637426 - Databus
                    Reset counter: 1
                    Date: 2021.02.13
                    Time: 15:47:34
   Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
   Component: AirbagVW20    014 0385
   Serial number: 003MMR017URA
   Coding: 98CCC0000C0000005C5400CA004800000065
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 004C94919B67718613-8054
   Subsystem 1 - Part No SW: -----------    HW: 480 001 404 14
   Serial number: 357670000006DA51AF02
   Subsystem 2 - Part No SW: -----------    HW: 480 001 404 14
   Serial number: 35867000000D8B51AF06
   Subsystem 3 - Part No SW: -----------    HW: 480 402 503 14
   Serial number: 3516502B5153FB93139C
   Subsystem 4 - Part No SW: -----------    HW: 480 402 503 14
   Serial number: 352650299153FB95824I
   Subsystem 5 - Part No SW: -----------    HW: 480 401 003 14
   Serial number: 35565029F14D3E72F1D.
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 402 14
   Serial number: 2286502B7142B1C580EF
   Subsystem 7 - Part No SW: -----------    HW: 480 402 402 14
   Serial number: 2296502BB12F629371BJ
   Subsystem 8 - Part No SW: -----------    HW: 480 001 702 14
   Serial number: I0M8000000086871EE0K
   Subsystem 9 - Part No SW: -----------    HW: 480 001 702 14
   Serial number: I0N8000000030BF8FE0T
   Part No SW: 8V0 953 521 JD    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 18081608490271
   Coding: A008
   ROD: EV_SMLSKLOMQB_019_AU37.rod
   VCID: 05428585844554AE20-8050
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790 C    HW: 8V0 920 790 C
   Component: FBenRDW       H19 0109
   Coding: 04A519002B80000A0900E8001000000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001032
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 3C342061B70FD5660F-8068
          U1014 00 [009] - -
          [ECU incorrectly coded]
                    Reset counter: 216
                    Date: 2021.02.13
                    Time: 15:47:34
   Component: GW MQB High   518 5323
   Serial number: 16061810520124
   Coding: 030100042B0857005B000248080B00000001010000000000000000000000
   ROD: EV_GatewNF_AU37.rod
   VCID: 383C3C718337F946EB-806C
   Subsystem 2 - Part No SW: 81A 951 523     HW: 81A 951 523
   Component: J453 MFL  H04 0003
   Serial number: 20170822124041 21544
   Serial number: 2781922603
8526361 - LV Energy Management
          B1802 F1 [009] - Warning Triggered
                    Reset counter: 216
                    Mileage: 85088 km
                    Date: 2021.02.13
                    Time: 16:16:59
                    Supply voltage: Terminal 30: 11.3 V
                    Terminal 15: On
   Serial number: 09041406071301
   Coding: 001C8E204000040000001002
   VCID: 40CC5491DBE7B18653-8014
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 8103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41CA5195D0EDB88E5C-8014
   Serial number: 13041403110055
   Coding: 001C86204400040000001002
   VCID: 3FCE576DA619CE7E2A-806A
   Coding: 019A000001000000
   VCID: 75A2F545D4A5442E30-8020
   Component: RVC Compact   H18 0231
   Coding: 0273010102002001400040
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
   VCID: 393A3975B83DE04E14-806C
   Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0025
   Serial number: 04041404080187
   Coding: 000C86204000040000001002
   VCID: 42C85E99D5EBA39645-8016
   Component: TSG HBFS      020 0025
   Serial number: 04041401100216
End----(Elapsed Time: 01:18, VBatt start/end: 11.4V/11.5V. VIgn 11.5V)-----
Address 01: DTCs cleared
Address 17: DTCs cleared
   #31
myounus
Northwest UK
C?ID=321059
   Revision: R7H21---
17158 - Databus
                    Date: 2021.02.13
                    Time: 15:47:29
   Coding: 0A47F7
   Coding: 00006C
   Light switch:
   Coding: 0470151001
13637426 - Databus
                    Reset counter: 1
                    Date: 2021.02.13
                    Time: 15:47:34
   Coding: A008
          U1014 00 [009] - -
                    Reset counter: 216
                    Date: 2021.02.13
                    Time: 15:47:34
                    Reset counter: 216
                    Mileage: 85088 km
                    Date: 2021.02.13
                    Time: 16:16:59
                    Terminal 15: On
   Coding: 8103
What issues are you facing? What is not working?
   #32
atesz.takacs
Hungary
C?ID=376838
I did nor recognized any malfunction / missing fuction but wouldn't like to ignore the "Control Module Incorrectly Coded" DTC
   #33
myounus
Northwest UK
C?ID=321059
Just ignore that dtc if it’s not causing a problem. The module wants to be coded by SVM which will reset it back to factory standard, removing all your changes. As long as there is no issue, just ignore it
   #34
atesz.takacs
Hungary
C?ID=376838
That's a half-truth, I was able to sort out that DTC by changing a single bit.
If anyone ever facing the same.. Advanced Meas Values can show which coding is causing the DTC.
uc
The problem is that I do not have Parallel Parking assistance ECU but PDC only. I think some additional coding must be done in 03 or who knows..
Question to other retrofitters, is there any re-coding needed in ABS or other ECU to have the VC error free?
downtime
C?ID=280813
No need to set any other modules when retrofitting VC
   #36
DV52
C?ID=194404
@Codeme: hmm........ comparison of the long-code strings from hex19 modules on your 2 x scans:
Code_String to Byte_list convert
ByteHexBinaryHexBinary
003000000110300000011
105000001010100000001
200000000000000000000
304000001000400000100
40B000010110B00001011
508000010000800001000
676011101107601110110
700000000000000000000
85B010110115B01011011
900000000000000000000
1002000000100200000010
1148010010004801001000
121C000111001C00011100
130B000010110B00001011
1400000000000000000000
1500000000000000000000
1600000000000000000000
1701000000010100000001
1800000000000000000000
1900000000000000000000
2000000000000000000000
2100000000000000000000
2200000000000000000000
2300000000000000000000
2400000000000000000000
2500000000000000000000
2600000000000000000000
2700000000000000000000
2800000000000000000000
2900000000000000000000
Seems that second scan has Byte 1, Bit 2 set - which is "driver profile rotary switch". I'm aware from your discussion above that your car has a FEC for driver profile - but presumably this applied in your first scan and this software switch wasn't set
