- Aug 30, 2019
- 23
- 2
- Manchester, UK
- C?ID=231524
2013 audi a3 2.0 tdi hatchback 5 door
HELLO
i did a retrofit a VIRTUAL COCKPIT. calibrated and removed compoment protection but i have lost my drive select, and cruise control. the auto stop and start works sometimes only. i havd got mib2 works perfect. do not know what 4E is cant get rid of it
new steering wheel lights and paddelswork but no butons are working. . Been going mad trying to sort it out, HELP NEEDED THANK YOU VERY MUCH IN ADVANCE.
AUTO SCAN DONE
HELLO
AUTO SCAN DONE
Friday,11,October,2019,07:20:31:31689
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ8V5EA002827 License Plate:
Chassis Type 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 47 4E 52 55 5F BB
BC
VIN: WAUZZZ8V5EA002827 Mileage: 13002km-8079miles
47-Sound System -- Status: Not registered 0001
4E-Ctrl Head RR -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DT HW: 04L 907 309 D
Component: R4 2,0L EDC H22 5520
Revision: 83H22---
Coding: 021D0012032501083000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
ROD: EV_ECM20TDI01104L906021DT_002.rod
VCID: 7AFC785BFDA4909FE9-802E
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [038] - -
Mileage: 13002 km
Date: 2019.10.11
Time: 07:14:24
Engine speed: 772.00 /min
Normed load value: 31.4 %
Coolant temperature: 31 °C
Intake air temperature: 19 °C
Voltage terminal 30: 14.420 V
ACC variants-Bits 0-7: 0
CCS Switch-Bits 0-7: 1
Cruise control switch actuation-Bits 0-7: 32
Cruise control switch actuation-Bits 0-7: 0
ACC variants (coding)-Bits 0-7: 1
Acceleration: 0.000 m/s²
Part No SW: 0D9 300 040 K HW: 02E 927 770 AN
Component: DQ250-6F MQB H52 4005
Revision: 05652104 Serial number: TFK01304221308
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021.rod
VCID: 1F4A69CF06C615B7BE-804A
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 61323000000604
Coding: 12F18AA224200A6E037F060241CA2948512450C0608294F3026100788508
Shop #: WSC 27496 003 104857
VCID: 7BF27D5FF29EA997F2-802E
8299 - Databus
Reset counter: 13
Date: 2019.10.11
Time: 07:14:23
8309 - Engine Control Module Incorrectly Coded
P1612 00 [008] - -
Reset counter: 53
Mileage: 13002 km
Date: 2019.10.11
Time: 07:14:25
Revision: 00021000 Serial number: 0207224423
Coding: 030C0C
VCID: 3A7CB85BBD24509FA9-806E
Part No SW: 8V0 820 043 HW: 8V0 820 043
Component: AC Automat H12 0031
Revision: 20020000 Serial number: 00000000086272
Coding: 03100114002000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
VCID: 6FEA590FB6E6C5374E-803A
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: DB480CA6000000000001
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011313501857
Coding: 07111A42C24122FD03844004B31C07A80810000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 77FA616FCEB68DF796-8022
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130509 041 0580
Serial number: 130510235859
Coding: 0AC7F7
Component: G397_RLFS H06 0002
Serial number: 21318029
Coding: 03006C
Subsystem 3 - Part No SW: 8V0 941 531 L HW: 8V0 941 531 L
Serial number: 01 04 2013 00000599
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY1311427SE
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000056755419
Sun Roof:
Subsystem 6 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.009 H02 0007
Serial number: WOO21753350
Coding: 901E00
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 B HW: 5Q0 919 283
Component: PARKHILFE 4K H09 0033
Revision: -------- Serial number: 60831313901784
Coding: 0001050011
ASAM Dataset: EV_EPHVA14AU3700000 002018
VCID: 3878A2538328428F5F-806C
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R01LV1M
Coding: 98FCC0000C0000005C5400CA00C800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4B92ED9FE2BED91702-801E
Subsystem 1 - Part No SW: ----------- HW: 480 001 005 13
Serial number: 35767000000A08904D0T
Subsystem 2 - Part No SW: ----------- HW: 480 001 005 13
Serial number: 35867000000CF7904D03
Subsystem 3 - Part No SW: ----------- HW: 480 402 504 13
Serial number: 3516502B51050652021H
Subsystem 4 - Part No SW: ----------- HW: 480 401 704 13
Serial number: 3526502BF0FBDE3303C.
Subsystem 5 - Part No SW: ----------- HW: 480 401 503 13
Serial number: 35565029B0FAE89452A.
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 605 13
Component: PedP_Sensor_D 001 6149
Serial number: 2286502C51050652027R
Subsystem 7 - Part No SW: ----------- HW: 480 400 605 13
Component: PedP_Sensor_P 001 6149
Serial number: 2296502C51050653F0C4
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 400 605 13
Component: PedP_Sensor_C 001 6149
Serial number: 2306502C91050654419V
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 8V0 953 521 P HW: 5Q0 953 549
Revision: -------- Serial number: 14051308490504
Coding: AC18
VCID: 479AD1AFFED63D7726-8012
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 790 A HW: 8V0 920 790 A
Component: FBenRDW H16 0066
Coding: 24BD09122B8006000101E8000400000000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001027
ROD: EV_DashBoardFPKAU37X.rod
U1014 00 [009] - -
Reset counter: 13
Mileage: 13002 km
Date: 2019.10.11
Time: 07:14:22
16776994 - Databus
Reset counter: 13
Mileage: 13002 km
Date: 2019.10.11
Time: 07:14:22
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000573341
Coding: 030100040B0876005B0002481C0B00000001000000000000000000000000
ROD: EV_GatewLear_009.rod
VCID: 3B72BD5FB21E6997B2-806E
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 11 05 2013 B0191706
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051357328
Part No SW: 5Q0 905 861 HW: 5Q0 905 861
Component: ELV-MQBA H06 0010
Revision: 00000000 Serial number: 13000084091001
Coding: 0900000000000000
ASAM Dataset: EV_ELVMarquMQB 003008
ROD: EV_ELVMarquMQB_003.rod
VCID: 73E2557FDACEE1D7AA-8026
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 05051301100200
Coding: 00559E205C01040000001003
VCID: 3F8AC94FA60675B79E-806A
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D76B347AC0A67A78C-8068
Part No SW: 8V0 035 465 A HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0370
Serial number: AUZ8ZAD090098JE
Coding: 01030300AAAA2AAA01
ASAM Dataset: EV_AMPMst16C1ALPI 004024
ROD: EV_AMPMst16C1ALPI_004_AU37.rod
VCID: 3664AC6B893CB4FF4D-8062
Address 4E: Ctrl Head RR
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 03051301100606
Coding: 00559E205401040000001002
VCID: 3E74B44BA10C7CBF95-806A
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Coding: 019E000001000000
VCID: 75E66B67D4BAFFE784-8020
Part No SW: 8V1 035 035 B HW: 8V1 035 035
Component: MU-P-LND-EU 054 1106
Serial number: A698I0H2530761
Coding: 017350010000000011111102000A00332F0027E7017001009E
Shop #: WSC 00046 123 12345
VCID: 316E9F77605293C718-8064
Subsystem 1 - Part No SW: V03 959 801 FD HW: -----------
Component: ECE 2017/2018 --- 0161
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9H1Y05D3Y
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BE HW: 8V0 919 614 BE
Component: ControlUnit_B H50 0103
Serial number: ALJAL124051600010009
Compact Disc Database:
Component: Gracenote2 --- 1016
9 Faults Found:
B201A 00 [009] - -
Reset counter: 13
Mileage: 13002 km
Date: 2019.10.11
Time: 07:14:31
Voltage terminal 30: 14.3 V
Status_Software_Version_Management-module_name: MDUA201/Front
15360768 - Component Protection
U1101 00 [009] - Active
Reset counter: 13
Mileage: 13002 km
Date: 2019.10.11
Time: 07:14:25
Voltage terminal 30: 14.4 V
1552 - Expanded Bus Activity Active
U1104 00 [009] - -
Reset counter: 13
Mileage: 13002 km
Date: 2019.10.11
Time: 07:14:24
Voltage terminal 30: 14.5 V
1637 - Interface for External Media
U11B8 00 [009] - No Communications
Reset counter: 13
Mileage: 13002 km
Date: 2019.10.11
Time: 07:14:25
Interface for external media: status-Status: Open circuit
3073 - Cellular Antenna
B1053 13 [009] - Open Circuit
Reset counter: 13
Mileage: 13002 km
Date: 2019.10.11
Time: 07:14:25
3084 - GSM antenna 2
B1533 13 [009] - Open Circuit
Reset counter: 13
Mileage: 13002 km
Date: 2019.10.11
Time: 07:14:25
3077 - Telephone baseplate
B1051 13 [009] - Open Circuit
Reset counter: 13
Mileage: 13002 km
Date: 2019.10.11
Time: 07:14:24
7191 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 13
Mileage: 13002 km
Date: 2019.10.11
Time: 07:14:27
BAP-BAP_Function_ID: 02
7228 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 13
Mileage: 13002 km
Date: 2019.10.11
Time: 07:14:27
Part No SW: 5Q0 959 595 A HW: 5Q0 959 595
Component: TSG HFS 010 0006
Serial number: 27041301101166
Coding: 004196204001040000001002
VCID: 418ECFB7D0F20347E8-8014
Component: TSG HBFS 010 0006
Serial number: 27041304081175
End-------------------------(Elapsed Time: 04:57)--------------------------
