Coding rejected, Error 31: Request out of range
Devilz
Birmingham, England
C?ID=253973
I have recently bought 2017 Tiguan. Did my first scan and all is good except two modules where it says interface not compatible. I am trying to do some instrument tweaks like needle sweep,refuel quantity in AID but it won't accept any changes and every time I get Coding rejected, Error 31: Request out of range message. I have genuine Hex+Can cable and running the latest vcds software. Any suggestions will be highly appreciated. Thanks
Thursday,19,September,2019,11:53:05:25423
VCDS Version: 19.6.1.0
Chassis Type  5N-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 4B 52 5F A5 BB BC
          CA
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 HT    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 3617
   Revision: B4H25---
   Coding: 0125001203661D082000
   ASAM Dataset: EV_ECM20TDI01104L906026HT 004003
   ROD: EV_ECM20TDI01104L906026GP_004.rod
   VCID: 0305DF368A76575784-8056
   Part No SW: 0DL 300 011 N    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2002
   Revision: 00H06V07
   VCID: 33654FF69A5627D754-8066
   Revision: 00000000    Serial number: 60477000000313
   Coding: 0AEE929A34200B714780070562CA4950492CD0E2E046927D38625078C22A4200002F641A1B13111435351919323200
   VCID: 77FDBBE6CEAE0BF7A8-8022
   Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000E00420403
   Coding: 0012012420211001110510000010102A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 4A9B3212EDDC461F07-801E
   Subsystem 2 - Part No SW: 3G0 907 049 D    HW: 3G0 907 049 D
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
263425 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
                    Reset counter: 58
                    Mileage: 67586 km
                    Date: 2019.09.19
                    Time: 11:45:29
                    Outside air temperature: 19.5 °C
                    Voltage terminal 30: 12.2 V
                    System run time-Engine running time: 61 s
                    System run time-Terminal 15 on: 253 s
                    Air quality status: ERROR
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001704700445
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F0D53C6E69E33B7E0-802A
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 161220  033 0372
   Serial number: 00000001612140479964
   Component: RLHS  042 0105
   Serial number: S3Y17M02D23H21M07S38
   Coding: 00A8DD
   Serial number: 000000000ZY170231E3D
   Serial number: 00000000000068556361
   Part No SW: 3Q0 919 294 A    HW: 3Q0 919 294
   Component: PDC 8 Kanal   H07 0020
   Serial number: 002812167478081
   Coding: 0071451811
   ASAM Dataset: EV_EPHBO18VW3260000 007015
   ROD: EV_EPHBO18VW3260000_007.rod
   VCID: 377D7BE68E2ECBF768-8062
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 320147C158FF8728749C8065804085
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001.rod
   VCID: 3B7567D6B206EF978C-806E
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2MP50/
   Coding: 98CCC0C00C0000005C5400CF008800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 102FE07ACB003CCF09-8044
   Belt Pretensioner left:
   Component: BeltPretRevFL  106 1032
   Serial number: 5NC857705C0044R01024
   Coding: 80000D
   Belt Pretensioner right:
   Component: BeltPretRevFR  106 1032
   Serial number: 5NC857706C0044R00588
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 002 302 17
   Serial number: 3570000000084D9CC12X
   Subsystem 4 - Part No SW: -----------    HW: 480 002 402 17
   Serial number: 35800000000404E48029
   Subsystem 5 - Part No SW: -----------    HW: 480 401 502 17
   Serial number: 3510001C32537332E54U
   Subsystem 6 - Part No SW: -----------    HW: 480 401 702 17
   Serial number: 3520001BB2537335679/
   Subsystem 7 - Part No SW: -----------    HW: 480 401 702 17
   Serial number: 3550001A72537334364S
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 401 702 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001A12537335D27V
   Subsystem 9 - Part No SW: -----------    HW: 480 401 702 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001A12537335825P
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 401 702 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001A32537331C35K
   Subsystem 11 - Part No SW: -----------    HW: 480 001 302 17
   Serial number: I0M00000000C7D5D512C
   Subsystem 12 - Part No SW: -----------    HW: 480 001 302 17
   Serial number: I0N00000000CEB306124
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20170220501272
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 4189153ED0EA8547D6-8014
   Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
   Component: KOMBI         408 2170
   Coding: 27A400086F84060001886B031401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   Component: GW MQB High   418 4286
   Revision: --------    Serial number: 0005928965
   Coding: 030500045F087300FB07225E1E0F00010001050000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 2F6D4386767E033730-807A
   Serial number: 29170000325700107062
   Coding: 2DFFFF
   Serial number: 1158373104
   Serial number: HA1-00031.01.17
   Coding: 0101
   Serial number: 310117EAT09337
   Coding: 003F0220D001048000001000
   VCID: 43851F36CAF69757C4-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 4581012EC4C2A967EA-8010
Address 4B: Multifunc. Module
Interface not compatible.
   Serial number: 040217EB403449
   Coding: 003F0020DE01048000001000
   VCID: 428B1A32D5EC9E5FCF-8016
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0751
   Coding: 02730601FF00000051110101008808001F0106E6012000008F
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 316945FE604A15C726-8064
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL07BSM
   Subsystem 2 - Part No SW: 3G0 919 866 AQ    HW: -----------
   Component: ECE1 2017  --- 0730
1539 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 97
                    Mileage: 67550 km
                    Date: 2019.09.18
                    Time: 00:00:49
                    Voltage terminal 30: 8.4 V
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 21021712K23255
   Coding: 0003070600000401000213448050A90094000E200040
   Serial number: 020217EB129982
   Coding: 002A00200100048000001000
   Serial number: 240117EAN03474
Address CA: Sunroof
End-------------------------(Elapsed Time: 05:03)--------------------------
Not every instrument cluster supports every feature. Trying to code in a feature that the cluster doesn't support will result in "Request out of range".
It's also possible you may have to change the WSC, Importer, and Equipment Number for a coding change to take.
Try setting WSC to 01369, Importer to 210, and Equipment Number to 40505 in the User Interface and Identification tab of the Options screen in VCDS. Then click [Save]. Exit and re-start VCDS for this to become effective. Then try one simple change at a time, for example "Gauge Test/Needle Sweep (Staging) active" in Byte 01.
Eddie-NL
C?ID=41179
Had a strange one last week
2 cars both with 1.6 Tdi CAYC one a 2011 and the other 2015
I retrofitted cruise and went to code the Engine ECU
2015 coded fine, but the 2011 had the error 31
Tried several things, but nothing worked. I made a note of what had to be changed and coded it with VCP and it accepted it.
Devilz
Birmingham, England
C?ID=253973
Sorry for my noobness but I don't know how to do these changes :(
Bruce
Near Philadelphia, PA, USA
The VCDS Manual online on our web site gives help to Noobs...
Take a look at the Options screen: https://www.ross-tech.com/vcds/tour/option_screen.php
Note there are two tabs - Port and Protocol Options & User Interface and Identification.
Click on the User Interface and Identification tab. Now you will see the WSC, the Importer Code, and the Equipment number.
Change these as Uwe has suggested you do.
hadez16
C?ID=289891
What exactly did you try to change?
Devilz
Birmingham, England
C?ID=253973
Guage sweep and tried to change the colour of AID
I have noticed only Instrument (17) coding gets rejected.
Rest I can do tweaks without any issue
PetrolDave
Westbury, UK
C?ID=1423
Which suggests that the coding change(s) you are trying to make is not applicable to your Instrument ECU, if you detail what coding change(s) you are trying to make then someone may be able to suggest other options?
DV52
C?ID=194404
hmm........ you do know that later model MQB platform vehicles (like the Tiggy mk2) use a different security code for the hex17 module? In the past, the SA was 20103, but for post MY16 built units, the SA is 47115.
So, if you are using instructions from early MQB vehicles, this could be the problem - albeit I would have thought that VCDS software would return a more specific error message!!
Anyhow - a more fulsome list of SA for your Tiggy can be found here
downtime
C?ID=280813
Do you try to do both changes at once? Try to enable only needle sweep, that should work.
For the color change, there’s instructions on how to do a few adaptation changes to 5F and your able to change the colors from ambient light setting in car menu. Does not change the color of ambient lights as Tiguan only has one color led bars but it changes AID and MIB color schemes.
Coding info (copied from Aus Tiguan forum) :
Control unit: 09 Central Electrics - Adaptions - Int. light, 2nd generation - Instrumententafelbeleuchtung mehrfarbig - Set to Active
Control unit: 09 Central Electrics - Adaptions - Interior light, light configuration - Ambient_Farbliste_HMI - Set to Active
Control unit: 09 Central Electrics - Adaptions - Ambientelicht Farbliste - Set the RGB Values for all 10 Colour options
And here’s a link to obdeleven forums which also has a list of rgb colors in case you don’t want to figure them out yourself :)
https://www.vwroc.com/forums/topic/...ign-and-colour/?do=findComment&comment=431296
o33err
C?ID=317589
Also sometimes I have found that on an Error 31, you need to let the car go to sleep before a coding on a module is accepted, especially if the coding is related to another module that you have just coded.
Devilz
Birmingham, England
C?ID=253973
I have set first two options to Active but can't find third one (Control unit: 09 Central Electrics - Adaptions - Ambientelicht Farbliste - Set the RGB Values for all 10 Colour options)
link you posted is for obdeleven whereas I am using VCDS
Devilz
Birmingham, England
C?ID=253973
I did these changes but still the same. Can't do guage sweep or anyother mod through long coding.
Well, the only reason that I can think of for "Request out of Range" if you've done that is your Instrument Cluster doesn't support the gauge sweep.
downtime
C?ID=280813
It doesn't matter, the adaptation channels are universal and the guide is generic.
If you don't find the adaptation channel that unfortunately means that the BCM is not supporting this function.
And also the same goes for instrument cluster like Uwe already mentioned.
Edit:
You have CG BCM, I have CF and that supports the color setting. That is interesting because you have a newer BCM.
Yours :
Mine :
   Serial number: 02001616700623
   VCID: 7EA5FEEB8073EE47B85-802A
