Hi everyone !
I have a 2016 Passat B8 estate. I installed front seats with ventilation, electric and memory. I made the wiring (from BCM - T73, PIN 42 to seats - for ventilation, 12v and ground to seats to power them), i changed the climatronic whith the one that have ventilation commands.
Now the seats ar working (the seat heating is working, the seats adjustments is working) except the ventilation. I can't find anyware to activate ventilation. When i press the ventilation button it light blue for 1sec then it turn off. Any ideeas on how to make this work would be helpfull
Autoscan below:
Autoscan below:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 2B 36 3C 42 44 52
55 5F 69 6C 6D A5 BB BC CF
VIN: WVWZZZ3CZGE175511 Mileage: 132545km-82359miles
Address 01: Engine (J623-DFCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 GA HW: 04L 907 309 M
Component: R4 2.0l TDI X23 2013
Revision: B4X23---
Coding: 011D003A047605083000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM20TDI01104L906026GA 004002
ROD: EV_ECM20TDI01104L906026FM_004_VW48.rod
VCID: 6FAE291BB6A33B3770-803A
Part No SW: 0D9 300 012 A HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4902
Revision: 06253104 Serial number: TFK01601151026
Shop #: WSC 05311 115 00064
ROD: EV_TCMDQ250021.rod
VCID: 146446F7FF45B8EF2D-8040
21153 - Gear 1
P072C 00 [002] - Not Selectable
21159 - Gear R
P072B 00 [002] - Not Selectable
10906 - Cooling Oil Valve
P179D 00 [002] - Electrical Malfunction
Part No SW: 3Q0 907 379 AC HW: 3Q0 907 379 H
Component: ESC H34 0912
Revision: 00000000 Serial number: 40126000000626
Coding: 40EC6A8F34274B71077C070141C44902562CD2E0E08292F9B8625078EAA9
Shop #: WSC 00015 115 00001
VCID: 7BB60D4BF2DB5797CC-802E
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0710
Revision: 00026000 Serial number: 0394856215
Coding: 000F0F0F03
Shop #: WSC 05311 115 00309
ASAM Dataset: EV_KessyHellaMQBAB 004032
VCID: 393AD743B867A5879E-806C
Part No SW: 5G1 907 044 C HW: 5G1 907 044 C
Component: Climatronic H03 1001
Revision: 00001K10
Coding: 12020104204101001115505C0010190A
ROD: EV_ACClimaBHBVW37X_003_VW48.rod
VCID: 281C020753CD2C0FF1-807C
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Revision: -------- Serial number: 86582701160124
Coding: 00031E46C2C10AFF17844094B11C57281C80000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 034675AB8A2B2F5784-8056
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160104 042 0607
Serial number: 160125150701
Subsystem 2 - Part No SW: 8UD 955 559 B HW: 8UD 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 30010158
Coding: 00006E
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 16 11 2015 10000196
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY1601329AV
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000064882532
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183616039
Coding: 0A71167951
ASAM Dataset: EV_EPHVA2CAU3700000 009017
ROD: EV_EPHVA2CAU3700000.rod
VCID: 0D525393DC6F6927E2-8058
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0192
Coding: 320467DB5DFFC728949C804D
ASAM Dataset: EV_ACCBOSCHVW48X 001008
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3424E6779F0558EF4D-8060
Part No SW: 3Q0 959 655 BA HW: 3Q0 959 655 BA
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003SSP227WEC
Coding: 98FCC0C0008000005C5400CC000800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7EB0045FE1C942BFEB-802A
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 3G1857705G0043Q00333
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 3G1857706G0043Q00821
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 002 301 16
Serial number: 3576U000000E531CC81L
Subsystem 4 - Part No SW: ----------- HW: 454 002 401 16
Serial number: 3586U000000E302CC81I
Subsystem 5 - Part No SW: ----------- HW: 454 800 701 16
Component: SideSensor_Dr 301 0148
Serial number: 3516R0D65C3090000004
Subsystem 6 - Part No SW: ----------- HW: 454 800 901 16
Component: SideSensor_Pr 301 0148
Serial number: 3526R9173C2090000000
Subsystem 7 - Part No SW: ----------- HW: 454 800 701 16
Component: FrontSensor_D 304 0149
Serial number: 3556VE5976409000000I
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 3Q0 953 521 AN HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0205
Revision: FF034034 Serial number: 20160111501416
Coding: 8C10
ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7CB40E57F7D550AFC5-8028
291088 - Temperature Sensor for Heated Steering Wheel
B1455 11 [009] - Short to Ground
Reset counter: 197
Mileage: 132545 km
Date: 2019.08.23
Time: 15:01:04
Ubat 30 Voltage: 12.50 V
Internal error state: 0
LIN_Temp: 255
Isense: 0
Max.Leistung: 110
PWM: 0
Offset: 242
Slope: 135
kp: 13
OUT: 50
Temperatur Statisch: 30
p_t_soll_0: 39.00 °C
p_t_soll_1: 43.00 °C
p_t_soll_2: 47.00 °C
Part No SW: 3G0 920 791 A HW: 3G0 920 791 A
Component: KOMBI 410 1340
Coding: 03A5181BEF8C000801887B2B3001000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009048
VCID: 271E013B5ED32377F8-8072
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 E HW: 5Q0 963 272 E
Component: STH-MQB 007 0072
Coding: 9309
ASAM Dataset: EV_AuxilParkiHeateWOS 002018
VCID: 383CD247836DBC8F61-806C
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000127688
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 06021610800683
Coding: 030300345F017300FB00225E1E0F00010001070000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 79BA1743F8E76587DE-802C
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29180000044240098041
Coding: 2DFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 6826078903
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 2001201600010014
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00012.01.16
Coding: 0301
Shop #: WSC 00015 115 08193
VCID: 4AD8988FED813E1F07-801E
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000020819012
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71AA2F63A0972DC766-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 3Q0 959 760 B HW: 3Q0 959 760 B
Component: Sitzmemory H04 0020
Serial number: Y0006OI117998
Coding: 011000020000000081E481808080000000008181000000F400
VCID: 3A38C84FBD61AE9F97-806E
7 Faults Found:
9655636 - Motor for Seat Fore/Aft Adjustment
B1355 54 [009] - Missing Calibration / Basic Setting
Reset counter: 197
Mileage: 132545 km
Date: 2019.08.23
Time: 15:01:04
9655380 - Motor for seat height adjustment
B1354 54 [009] - Missing Calibration / Basic Setting
Reset counter: 197
Mileage: 132545 km
Date: 2019.08.23
Time: 15:01:04
9655124 - Motor for Seat Tilt Adjustment
B1353 54 [009] - Missing Calibration / Basic Setting
Reset counter: 197
Mileage: 132545 km
Date: 2019.08.23
Time: 15:01:04
9654868 - Motor for Lumbar Support Fore/Aft Adjustment
B1352 54 [009] - Missing Calibration / Basic Setting
Reset counter: 197
Mileage: 132545 km
Date: 2019.08.23
Time: 15:01:04
9654612 - Motor for Lumbar Support Height Adjustment
B1351 54 [009] - Missing Calibration / Basic Setting
Reset counter: 197
Mileage: 132545 km
Date: 2019.08.23
Time: 15:01:04
9657641 - Sensor for Seat Fore/Aft Adjustment
B135D 29 [009] - Signal Implausible
Reset counter: 197
Mileage: 132545 km
Date: 2019.08.23
Time: 15:01:04
10489856 - No Basic Setting
B2010 00 [009] - -
[keine oder falsche Grundeinstellung/Adaption]
Reset counter: 197
Mileage: 132545 km
Date: 2019.08.23
Time: 15:01:04
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 B HW: 3Q0 907 566
Component: MRR1Rear H16 0230
Revision: --------
Coding: 14C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
VCID: 373ED17B8E73B3F768-8062
Component: TSG FS 020 0041
Serial number: 070116EA605685
Coding: 003F0A20D000028000001000
VCID: 43C6B5ABCAABEF57C4-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0000610054
Coding: 01010011005001
Shop #: WSC 00015 115 00309
ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
VCID: 3D32C353AC4F99A7B2-8068
Component: TSG BFS 020 0041
Serial number: 080116EA802347
Coding: 003F0020DC00028000001000
VCID: 42C8B0AFD5B1E65FCF-8016
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0120
Coding: 03AA00004F210200
Shop #: WSC 05311 000 08193
ROD: EV_HeadlRegulAFSMQBMLB.rod
VCID: 3FCEB95BA6438BB7A0-806A
Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0003
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0003
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 043 C HW: 3G0 035 043
Component: MU-H-N-EU H50 0343
Serial number: A683B0GB018057
Coding: 02840201FF00000051110001000808001F0308E4012000009F
VCID: 1C742ED71795F0AF65-8048
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU304UWU
Subsystem 2 - Part No SW: V03 959 800 QN HW: -----------
Component: ECE 2016 --- 0134
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1012
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anhaenger H21 0203
Revision: 8A001003 Serial number: 0394177910
Coding: 0100000202000000
VCID: 3B36CD4BB25B97978C-806E
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 568 HW: 5Q0 980 568
Component: RVC Compact+ H05 0100
Coding: 0184020163002017000048
ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW48.rod
VCID: 7AB8084FFDE16E9FD7-802E
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 J HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30453114900000
Coding: 0280
ASAM Dataset: EV_DeckLidCONTIAU736 001012
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 653 D HW: 3Q0 980 653
Component: MQB_B_MFK H08 0072
Serial number: 29011611K20698
Coding: 00040802040004010022234FC050A100980084300040
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 200116BAJ03028
Coding: 000E00200100028000001000
Shop #: WSC 61255 002 1048576
VCID: 45C2ABB3C49FD167EA-8010
Component: TSG HBFS 020 0041
Serial number: 200116BAJ03024
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 B HW: 3Q0 907 590
Revision: --------
Coding: 14C002
ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
