Passat B8 2016 retrofiting ventilated seats
koz
Romania
C?ID=256244
Hi everyone !
I have a 2016 Passat B8 estate. I installed front seats with ventilation, electric and memory. I made the wiring (from BCM - T73, PIN 42 to seats - for ventilation, 12v and ground to seats to power them), i changed the climatronic whith the one that have ventilation commands.
Now the seats ar working (the seat heating is working, the seats adjustments is working) except the ventilation. I can't find anyware to activate ventilation. When i press the ventilation button it light blue for 1sec then it turn off. Any ideeas on how to make this work would be helpfull
Autoscan below:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 2B 36 3C 42 44 52
          55 5F 69 6C 6D A5 BB BC CF
VIN: WVWZZZ3CZGE175511   Mileage: 132545km-82359miles
Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 GA    HW: 04L 907 309 M
   Component: R4 2.0l TDI   X23 2013
   Revision: B4X23---
   Coding: 011D003A047605083000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01104L906026GA 004002
   ROD: EV_ECM20TDI01104L906026FM_004_VW48.rod
   VCID: 6FAE291BB6A33B3770-803A
   Part No SW: 0D9 300 012 A    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4902
   Revision: 06253104    Serial number: TFK01601151026
   Shop #: WSC 05311 115 00064
   ROD: EV_TCMDQ250021.rod
   VCID: 146446F7FF45B8EF2D-8040
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21159 - Gear R
          P072B 00 [002] - Not Selectable
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
   Part No SW: 3Q0 907 379 AC    HW: 3Q0 907 379 H
   Component: ESC           H34 0912
   Revision: 00000000    Serial number: 40126000000626
   Coding: 40EC6A8F34274B71077C070141C44902562CD2E0E08292F9B8625078EAA9
   Shop #: WSC 00015 115 00001
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7BB60D4BF2DB5797CC-802E
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0710
   Revision: 00026000    Serial number: 0394856215
   Coding: 000F0F0F03
   Shop #: WSC 05311 115 00309
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 393AD743B867A5879E-806C
   Part No SW: 5G1 907 044 C    HW: 5G1 907 044 C
   Revision: 00001K10
   Coding: 12020104204101001115505C0010190A
   ROD: EV_ACClimaBHBVW37X_003_VW48.rod
   VCID: 281C020753CD2C0FF1-807C
   Air quality sensor:
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86582701160124
   Coding: 00031E46C2C10AFF17844094B11C57281C80000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 034675AB8A2B2F5784-8056
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    160104  042 0607
   Serial number:         160125150701
   Subsystem 2 - Part No SW: 8UD 955 559 B    HW: 8UD 955 559 B  Labels: 8U0-955-559.CLB
   Serial number: 30010158
   Coding: 00006E
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 16 11 2015  10000196
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY1601329AV
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064882532
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616039
   Coding: 0A71167951
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 0D525393DC6F6927E2-8058
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Coding: 320467DB5DFFC728949C804D
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3424E6779F0558EF4D-8060
   Part No SW: 3Q0 959 655 BA    HW: 3Q0 959 655 BA
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003SSP227WEC
   Coding: 98FCC0C0008000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7EB0045FE1C942BFEB-802A
   Belt Pretensioner left:
   Serial number: 3G1857705G0043Q00333
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 3G1857706G0043Q00821
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 002 301 16
   Serial number: 3576U000000E531CC81L
   Subsystem 4 - Part No SW: -----------    HW: 454 002 401 16
   Serial number: 3586U000000E302CC81I
   Subsystem 5 - Part No SW: -----------    HW: 454 800 701 16
   Serial number: 3516R0D65C3090000004
   Subsystem 6 - Part No SW: -----------    HW: 454 800 901 16
   Serial number: 3526R9173C2090000000
   Subsystem 7 - Part No SW: -----------    HW: 454 800 701 16
   Serial number: 3556VE5976409000000I
   Part No SW: 3Q0 953 521 AN    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0205
   Revision: FF034034    Serial number: 20160111501416
   Coding: 8C10
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CB40E57F7D550AFC5-8028
291088 - Temperature Sensor for Heated Steering Wheel
          B1455 11 [009] - Short to Ground
                    Reset counter: 197
                    Mileage: 132545 km
                    Date: 2019.08.23
                    Time: 15:01:04
                    Ubat 30 Voltage: 12.50 V
                    Internal error state: 0
                    LIN_Temp: 255
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 242
                    Slope: 135
                    kp: 13
                    OUT: 50
                    Temperatur Statisch: 30
                    p_t_soll_0: 39.00 °C
                    p_t_soll_1: 43.00 °C
                    p_t_soll_2: 47.00 °C
   Part No SW: 3G0 920 791 A    HW: 3G0 920 791 A
   Component: KOMBI         410 1340
   Coding: 03A5181BEF8C000801887B2B3001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009048
   VCID: 271E013B5ED32377F8-8072
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 E    HW: 5Q0 963 272 E
   Component: STH-MQB       007 0072
   Coding: 9309
   VCID: 383CD247836DBC8F61-806C
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000127688
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 06021610800683
   Coding: 030300345F017300FB00225E1E0F00010001070000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 79BA1743F8E76587DE-802C
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29180000044240098041
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 6826078903
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 2001201600010014
   Serial number: HA1-00012.01.16
   Coding: 0301
   Shop #: WSC 00015 115 08193
   VCID: 4AD8988FED813E1F07-801E
   Serial number: 16000020819012
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71AA2F63A0972DC766-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
   Component: Sitzmemory    H04 0020
   Serial number: Y0006OI117998
   Coding: 011000020000000081E481808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   VCID: 3A38C84FBD61AE9F97-806E
7 Faults Found:
9655636 - Motor for Seat Fore/Aft Adjustment
          B1355 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 197
                    Mileage: 132545 km
                    Date: 2019.08.23
                    Time: 15:01:04
9655380 - Motor for seat height adjustment
          B1354 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 197
                    Mileage: 132545 km
                    Date: 2019.08.23
                    Time: 15:01:04
9655124 - Motor for Seat Tilt Adjustment
          B1353 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 197
                    Mileage: 132545 km
                    Date: 2019.08.23
                    Time: 15:01:04
9654868 - Motor for Lumbar Support Fore/Aft Adjustment
          B1352 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 197
                    Mileage: 132545 km
                    Date: 2019.08.23
                    Time: 15:01:04
9654612 - Motor for Lumbar Support Height Adjustment
          B1351 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 197
                    Mileage: 132545 km
                    Date: 2019.08.23
                    Time: 15:01:04
9657641 - Sensor for Seat Fore/Aft Adjustment
          B135D 29 [009] - Signal Implausible
                    Reset counter: 197
                    Mileage: 132545 km
                    Date: 2019.08.23
                    Time: 15:01:04
10489856 - No Basic Setting
          B2010 00 [009] - -
          [keine oder falsche Grundeinstellung/Adaption]
                    Reset counter: 197
                    Mileage: 132545 km
                    Date: 2019.08.23
                    Time: 15:01:04
   Part No SW: 3Q0 907 566 B    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0230
   Revision: --------
   Coding: 14C002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
   VCID: 373ED17B8E73B3F768-8062
   Serial number: 070116EA605685
   Coding: 003F0A20D000028000001000
   VCID: 43C6B5ABCAABEF57C4-8016
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000610054
   Coding: 01010011005001
   Shop #: WSC 00015 115 00309
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
   VCID: 3D32C353AC4F99A7B2-8068
   Serial number: 080116EA802347
   Coding: 003F0020DC00028000001000
   VCID: 42C8B0AFD5B1E65FCF-8016
   Component: AFS-ECU       H01 0120
   Coding: 03AA00004F210200
   Shop #: WSC 05311 000 08193
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3FCEB95BA6438BB7A0-806A
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 3G0 035 043 C    HW: 3G0 035 043
   Component: MU-H-N-EU     H50 0343
   Serial number: A683B0GB018057
   Coding: 02840201FF00000051110001000808001F0308E4012000009F
   VCID: 1C742ED71795F0AF65-8048
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU304UWU
   Subsystem 2 - Part No SW: V03 959 800 QN    HW: -----------
   Component: ECE 2016  --- 0134
   Compact Disc Database:
   Component: Gracenote2  --- 1012
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0203
   Revision: 8A001003    Serial number: 0394177910
   Coding: 0100000202000000
   VCID: 3B36CD4BB25B97978C-806E
   Part No SW: 5Q0 980 568     HW: 5Q0 980 568
   Component: RVC Compact+  H05 0100
   Coding: 0184020163002017000048
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
   ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW48.rod
   VCID: 7AB8084FFDE16E9FD7-802E
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30453114900000
   Coding: 0280
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   Part No SW: 3Q0 980 653 D    HW: 3Q0 980 653
   Component: MQB_B_MFK     H08 0072
   Serial number: 29011611K20698
   Coding: 00040802040004010022234FC050A100980084300040
   Serial number: 200116BAJ03028
   Coding: 000E00200100028000001000
   Shop #: WSC 61255 002 1048576
   VCID: 45C2ABB3C49FD167EA-8010
   Serial number: 200116BAJ03024
   Part No SW: 3Q0 907 590 B    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
darkchina811
ITALY
C?ID=333184
my best bet is BCM coding or adaptations, and if coding it's probably not documented. you might need to find an autoscan of a car that has the feature and compare.
I am wondering if the seat ventilation can be retrofitted to the Golf. it doesn't exist as stock, but the car is MQB, so same BCM, same Climatronic panel.
mihai p
Romania
C?ID=378213
Thank you @darkchina811
It’s my car and i solved the problem. I manage to find an autoscan from a passat that have from factory ventilated seats and i copy the coding from BCM and paste to my BCM.
All work fine !!!
About working on golf, if the seats can be installed, i think it can be done.
mihai p
Romania
C?ID=378213
Hello, her it is:
Friday,20,September,2019,12:33:14:24994
VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
Dealer/Shop Name: mky
VIN: WVWZZZ3CZGE175511   License Plate:
Mileage: 135385km-84124mi   Repair Order:
VIN: WVWZZZ3CZGE175511   Mileage: 135385km-84124miles
   Revision: B4X23---
   VCID: 6FBBD31BE71B165F233-803A
   VCID: 1471BCF7AEFD95877E1-8040
   VCID: 7BA3F74BA3637AFF9FB-802E
   Coding: 000F0F0F03
   VCID: 392F2D43E9DF88EFCD7-806C
   Revision: 00001K10
   Coding: 12020104204101011115505C0010190A
   VCID: 2809F80702750167A29-807C
   Air quality sensor:
   Coding: 00879E46C2C10AFF17844094B11C57281C80000000000000000000000000
   VCID: 03538FABDB93023FD7B-8056
   Coding: 00006E
   Seat Backrest Fan 1 Front Left:
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE0245302
   Seat Cushion Fan 1 Front Left:
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0249643
   Seat Backrest Fan 1 Front Right:
   Subsystem 9 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0194278
   Seat Cushion Fan 1 Front Right:
   Subsystem 10 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0249664
   Coding: 0A71167951
   VCID: 0D47A9938DD7444FB1F-8058
   Coding: 320C67FB5DFFC728949C804D
   VCID: 34311C77CEBD75871E1-8060
   VCID: 7EA5FE5FB0716FD7B85-802A
   Coding: 80000D
   Coding: 80000D
   Coding: 8C10
   VCID: 7CA1F457A66D7DC7961-8028
                    Fault Frequency: 89
                    Reset counter: 231
                    Mileage: 135014 km
                    Date: 2019.09.19
                    Time: 13:26:59
                    Ubat 30 Voltage: 12.10 V
                    LIN_Temp: 255
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 242
                    Slope: 135
                    kp: 13
                    OUT: 50
   VCID: 270BFB3B0F6B0E1FAB3-8072
   Coding: 9309
   VCID: 38292847D2D591E7329-806C
   VCID: 79AFED43A95F48EF8D7-802C
   Coding: 2DFFFF
   Analog clock:
   Coding: 0301
   VCID: 4ACD628FBC39137754D-801E
   VCID: 71BFD563F12F00AF357-8024
   Part No SW: 3Q0 959 760 D    HW: 3Q0 959 760 D
   Component: Sitzmemory    H06 0024
   Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿ
   Coding: 0018000000000500818480808080000000008080000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3C213457E6EDBDC7D61-8068
9655892 - Motor for Seat Backrest Adjustment
          B1356 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 231
                    Mileage: 135385 km
                    Date: 2019.09.20
                    Time: 12:24:50
                    Reset counter: 231
                    Mileage: 135385 km
                    Date: 2019.09.20
                    Time: 12:24:50
                    Reset counter: 231
                    Mileage: 135385 km
                    Date: 2019.09.20
                    Time: 12:24:50
                    Reset counter: 231
                    Mileage: 135385 km
                    Date: 2019.09.20
                    Time: 12:24:50
10487040 - invalid data record
          B2005 00 [009] - -
                    Reset counter: 231
                    Mileage: 135385 km
                    Date: 2019.09.20
                    Time: 12:24:50
          B2010 00 [009] - -
                    Reset counter: 231
                    Mileage: 135385 km
                    Date: 2019.09.20
                    Time: 12:24:50
   Revision: --------
   Coding: 14C002
   VCID: 372B2B7BDFCB9E9F3B3-8062
   Coding: 003F0A20D200028000001000
   VCID: 43D34FAB9B13C23F97B-8016
   VCID: 3D273953FDF7B4CFE1F-8068
   Coding: 003F0020DE00028000001000
   VCID: 42DD4AAF8409CB379CD-8016
   VCID: 3FDB435BF7FBA6DFF33-806A
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Coding: E02400
   VCID: 1C61D4D7462DDDC7361-8048
   VCID: 3B23374BE3E3BAFFDFB-806E
   VCID: 7AADF24FAC5943F784D-802E
   Coding: 0280
   VCID: 45D751B39527FC0FB9F-8010
   Revision: --------
   Coding: 14C002
End----------(Elapsed Time: 02:49, VBatt start/end: 12.1V/12.1V)-----------
morski
Cheshire UK
C?ID=90186
Run the basic settings in vcds for the seat in order to clear the faults. It needs to learn all the end stops for the seat in every position
mihai p
Romania
C?ID=378213
I tried, is call norming in basing settings, but the motors for lumbar suport don’t want to calibrate. In coding, i disable the motors for lumbar suport and the seat calibrate and the memory work fine. The problem is that i can’t use lumbar suport anymore and the massage function.
morski
Cheshire UK
C?ID=90186
When running basic settings do you run the seat through its full motion ie all the way forward and then full back ?
mihai p
Romania
C?ID=378213
Yes, it run forward, up, back, down, lumbar up, lumbar down. But remain the error with lumbar missing calibration. When i turn off lumbar motors, the seat make the moving, except from lumbar moving and at the final i hear a chime from the instruments that all is ok. From now the seat works perfect except the lumbar and massage.
The problem is complicated even more :). When i bought the seats, driver seat don’t have the ecu. From the research i made i resume that i need 3Q0 959 760 B. I bought one from ebay and also 3Q0 959 760 D brand new. I have the same problem with both.
morski
Cheshire UK
C?ID=90186
3Q0 959 760 B supercedes to D and is for Passat 2015 onwards so its the correct one. If your using a brand new ecu then its probably missing its parameter files from VW
mihai p
Romania
C?ID=378213
Yes, the new one is missing the parameters that’s why it have the error “invalid data record”, but the second one have the same errors, except for the “invalid data record”.
For both is ok when i code with no lumbar motor.
