VW Amarok 2012 Halogen to Bi-Xenon with LED DRL retrofit coding issue
AudiGit
Cardiff(ish), South Wales, UK.
C?ID=288281
Hi Folks!
I have been tasked with facelifting a UK 2012 Amarok with the newer Bi-Xenon headlights with LED DRLs.
I have replaced the BCM from 6R7 937 087 H to 7H0 937 090 D and added the wires from the T10 headlight plug to the T73 BCM plugs and replaced the light switch to 6R0 941 531 G.
I have got all function apart from side lights, DRLs and main beam flash when lights are in the off position, however, I can hear the shutters moving when the stalk is pulled. Main beam works fine with the light switch in the dipped beam position...
Here is the autoscan with the old BCM fitted (taken a while ago but still correct)
Wednesday,10,April,2019,16:36:48:50827
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
VIN: WV1ZZZ2HZCA025970   License Plate:
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 10 15 17 19 22 25 56 69
VIN: WV1ZZZ2HZCA025970   Mileage: 144270km-89645miles
69-Trailer -- Status: Not registered 0001
Address 01: Engine (J623-CDCA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 FA    HW: 03L 907 309 K
   Component: R4 2.0l BTD   H43 9978
   Revision: 26H43---    Serial number: 00000000000000
   Coding: 01194012232600080000
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM20BTD01103L906019FA 004006
   ROD: EV_ECM20BTD01103L906019FA_004.rod
   VCID: 6FAE22C7B65B873234-803A
13812 - Exhaust Gas Temperature Sensor 4 Bank 1
          P246F 00 [096] - Implausible Signal
Address 03: ABS Brakes (-----)       Labels: 2H0-907-37x-ESP.clb
   Part No SW: 2H0 907 379 G    HW: 2H0 907 379 D
   Component: ESP MK25A XT  H44 0106
   Revision: 00H44001
   Coding: C07324B69196039A24AB89AAAF5010
   Shop #: WSC 07456 790 49164
   VCID: 3424EDAB97FDE4EA09-8060
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 2H0 907 040 D    HW: 2H0 907 040 D
   Component: ClimatronicT5 H11 0304
   Revision: 00001002
   Coding: 0000000002
   Shop #: WSC 07456 790 50316
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 22081BF335097A5AEB-8076
9481988 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
   Part No SW: 6R7 937 087 H    HW: 6R7 937 087 H
   Component: PQ25 BCM      H12 0022
   Revision: -1------    Serial number: 1002480801
   Coding: 3C0002380C410400923008003C0A04C40080410E600000003000
   Shop #: WSC 00513 210 99189
   VCID: 49DAAC5FE07F89024A-801C
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3321
   Coding: 110000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3321
   Coding: 110000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor      001  001 0103
   Component: LIN BACKUP HORN H11  H11 9005
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3321
   Coding: 100000
   Subsystem 7 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3321
   Coding: 100000
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 D    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47301122400266
   Coding: 108003
   ASAM Dataset: EV_VW75XParkAssis4K A01006
   ROD: EV_VW75XParkAssis4K_A01.rod
   VCID: 3326EEB79AF3E3D210-8066
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag00M H06 0013
   Revision: --------    Serial number: 003HN0052J2S
   Coding: 00000000000000000000000000000000304D
   Shop #: WSC 07446 790 50316
   Serial number: 3495RRB40630LCOSB8G4
   Serial number: 3505RRB405H0LCOS415R
   Serial number: 3555YRB40670II4KIO82
   Serial number: 3565YRB40570IOK4D1CR
   Part No SW: 2H0 920 963 BX    HW: 2H0 920 963 BX
   Component: KOMBI         H02 0505
   Coding: 450A00
   VCID: 014A747F90CF8142D2-8054
   Part No SW: 6N0 909 901     HW: 6R7 937 087 H
   Component: GW-K-CAN TP20 0022
   Revision: -1------
   Coding: 742300
   VCID: 70AC21BBA36598CA2D-8024
   Part No SW: 2H0 927 755 B    HW: 2H0 927 755 B
   Component: SG offroad VTG      0153
   Revision: 00H06000    Serial number: T1IYC23212BIS0
   Coding: 0000013
   VCID: 2F2EE2C7BEDBC73274-807A
   Component: IMMO          H02 0505
   VCID: 6A9833D38DB9621A63-803E
Address 56: Radio
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000398123109
   Coding: 0100000100000000
   VCID: 302CE1BB63E5D8CA6D-8064
End----(Elapsed Time: 01:24, VBatt start/end: 11.5V/11.5V. VIgn 11.6V)-----
and here is the scan after fitting the wiring and BCM MAX (I stupidly tried coding I found online but no dice)
Monday,29,April,2019,22:45:21:50827
Scan: 01 03 04 08 09 10 15 17 19 22 25 56 69 0B
VIN: WV1ZZZ2HZCA025970   Mileage: 144960km-90073miles
03-ABS Brakes -- Status: Not registered 0011
04-Steering Angle -- Status: Not registered 0001
08-Auto HVAC -- Status: Not registered 0011
10-Park/Steer Assist -- Status: Not registered 0001
15-Airbags -- Status: Not registered 0011
22-AWD -- Status: Not registered 0001
56-Radio -- Status: Not registered 0011
4482 - Function Restriction due to Implausible Message(s)
          U1112 00 [032] - -
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [032] - -
   Revision: 00H44001
03095 - Diagnostic interface for databus (J533) implausible messa.:
   Revision: 00001002
   Coding: 0000000002
13701936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
          B10AF 04 [009] - Internal System Fault
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H78 0726
   Revision: B9078001    Serial number: 0661 163150037
   Coding: 640002380CB3040011300E316DCB84D45A81672F60053041300000020003
   Shop #: WSC 18752 008 00032
   VCID: 2F2EE2C77EDBC73274-807A
   Coding: 110000
   Coding: 110000
   Component: DWA-Sensor 00  001 0103
   Component: LIN BACKUP HO  H11 9005
   Coding: 100000
   Coding: 100000
01516 - Terminal 30; Left
00927 - Terminal 30 (Right)
   Coding: 108003
12854016 - Databus
          U1122 00 [009] - Implausible Message
          [Kombi1 DLC Error]
   Coding: 450A00
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H78 0726
   Revision: B9078001
   Coding: 002000
01771 - Control Module for Headlight Range (J431)
   Coding: 0000013
Address 56: Radio
End----(Elapsed Time: 02:17, VBatt start/end: 11.7V/11.6V. VIgn 11.7V)-----
There were loads of differing guides on what is needed to get the lights fully working but most were for left hand drive and lower spec models so for example where it was saying to add in new power wires from the fuse box to the BCM, the fuse locations were already occupied? I also have VCP to hand if needed.
Any and all help will be hugely appreciated!
m87a
Bosnia and Herzegovina
C?ID=156900
i have done amarok bi xenon led upgrade and can't recall but i think that one earth wire was missing check if you have brown wire on pins 5 & 7 if missing splice from other wire, maybe i'm imagining things, it was long ago, anyway check that and for coding:
byte 11 bit 0 set to 1 activate bi xenon (high beam shutter)
byte 12 bit 0 LED DRL to ON
byte 18 set to 67 or 65 if using LED license plate lights
byte 22 bit 4 set to 1 to enable LED DRL module
AudiGit
C?ID=288281
Fantastic, thank you for that!
With the potential missing earths, which plug is that for? On the BCM or light switch?
Thanks dude
iichel
Netherlands, eastern part
C?ID=284912
He's talking about the connector on the headlight. And for the high beams, do the coding as suggested.
AudiGit
C?ID=288281
Brill, thanks iichel,
All coding is as posted above when checked but byte 12 bit 0 is labelled as “Parking Lights ON with “Terminal 15 ON”” it is ticked.
Checked the headlight plug, pin 5 has a brown present but pin 7 was empty so I’ve added an earth to chassis. Still no life with either the side lights or DRLs...
Xenon shutters are working but the actual bulb doesn’t flash when the light switch is in the off or sidelight position? I can hear the shutter moving though, just no light! Dipped beam functions fine when light switch in the dipped beam position.
Also, we noticed that the remote central locking is no longer working?! Do the keys need to be re-added? The vehicle starts, just no central locking.
siLc
Tallinn, Estonia
C?ID=330192
Since you swapped the BCM to a new one, then of course.
m87a
C?ID=156900
did you try to clear errors and then try lights after you added ground to pin7?
also check these
terminal 30 (constant power) if missing will stop a lot of functions from working, maybe it's just coding?
AudiGit
C?ID=288281
Thanks for the clarification, not had much dealings with the Amarok or T5/T6 so wasn't aware, I have since linked the remote and it is now working but it still refuses to lock from the remote or door lock switch or outer key lock. I can hear relays clicking when pressing the lock button on the remote but nothing happens. When I swap back the original BCM the locks work fine... Does the new BCM need wiring changes for the central loacking?
also check these
I have now cleared these error codes except the 01516 - Terminal 30; Left 011 - Open Circuit fault code. I added more wiring changes from the fuse box to the BCM which I later found out were needed but only one of those wiring changes had a terminal 30 live coming from it, maybe there is a fault elsewhere in the car?
The additional wiring changes were close to what iichel mentioned in the post above:
Install new 2.5mm2 wire from SC53 fuse output to T73a/63 BCM black connector. New 25Amp fuse.
Install new 2.5mm2 wire from SC51 fuse output to T73b/68 BCM white connector. New 25Amp fuse.
This is from information I have found online from someone else that has successfully completed this retrofit.
Those terminal 30 errors will require some wires from the fuse box to pins 63 (or something) iirc of the bcm
Check the wiring diagrams for this...
For the remotes, see channel 000 and 001 here
http://wiki.ross-tech.com/wiki/index.php/VW_Jetta_(16)_Body_Control_Module
Thanks iichel, I have now added the remote but still seem to have an issue with locking the truck, I can hear relays clicking (maybe inside the BCM?) when I press lock on the remote but nothing else happens.
I have also added the wiring you mentioned as follows:
However, only one of those fuse locations had permanent power when probed, the other didn't, maybe there is another fault in the car at a different location?
At the moment I am stumped. Still no LED DRLs or side lights working. Also, the main beam shutter is working but it won't "flash" with the lights turned off, I can just hear the shutter moving but no light.
Here are the working functions:
Dipped beam, indicators, main beam shutter.
Not working:
Main beam flash with dipped beams off, LED DRLs, Side lights.
Here is the latest auto scan:
Saturday,25,May,2019,17:11:08:50827
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4504.4
VIN: WV1ZZZ2HZCA025970   Mileage: 145700km-90533miles
Readiness: 1010 0000
   Revision: 00H44001
            000 -  -  - Intermittent
   Revision: 00001002
   Coding: 0000000002
          U1113 00 [008] - -
   Coding: 3D8002B80C41040092300C312D4A84D41A81672F60051040300000020003
   Coding: 110000
   Coding: 110000
   Coding: 100000
   Coding: 108003
12854016 - Databus
          [Kombi1 DLC Error]
   Coding: 450A00
   Revision: B9078001
   Coding: 002000
   Coding: 0000013
Address 56: Radio
End----(Elapsed Time: 02:09, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
The new fault code for the rear door is not related, it has magically appeared since my last visit and I noticed the door card for that door has been removed at some point in my absence so no idea whats happened there since I last went to the vehicle lol.
AudiGit
C?ID=288281
I guess I should just torch it and walk away ha ha.
I’ve reached the end of my skill set with this so will give the customer the option to revert it all back to standard or leave it 90% completed for him to take it elsewhere to finish off.
Tbh, it’s giving me mental health issues lol!
iichel
C?ID=284912
These positions on the BCM should be held by a +30 (permanent power) connection. I think they relate to your 01516 DTC and to the failing light functions as well.
T73a/63 +30
T73b/11 +30
T73b/67 +30
T73b/68 +30
Otherwise perhaps torching it would be a nice option indeed.
koket
Romania
C?ID=327557
Hi, did anyone solved to finish this to 100%? I'm stuck like others at 90% , only drl and headlight, no parking light at all :(
