Passat B8 2015 Lane Assist retrofit coding
siLc
Tallinn, Estonia
C?ID=330192
This is a continuation of this topic here -> https://forums.ross-tech.com/showthread.php?16420-PQ-vs-MQB-retrofittings-differences
I've mostly completed the physical install for Lane Assist and Dynamic Light Assist on a very early-2015 B8 which has High LED headlights, ACC and PLA 3.0 from the factory. The windscreen has been changed, A5 camera 3Q0 980 654F and wiring installed. Only thing left to complete is to connect the Sensor Fusion CAN to the ACC coupling point under the hood.
I mostly managed to code the vehicle to display the "Lane assistance" option under the assistance systems but naturally Lane Assist doesn't work as the camera hasn't yet been calibrated. The aim of this topic is to make sure I have the proper codings nailed down so I can finish coding the car (activate DLA) once the camera has been calibrated.
This is the original autoscan before any modifications:
Friday,26,October,2018,14:16:51:46309
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: WVWZZZ3CZFE429445   License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F 69
          6C
VIN: WVWZZZ3CZFE429445   Mileage: 100250km-62292miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H21 1990
   Revision: B5H21---
   Coding: 011D003A04741D083000
   Shop #: WSC 11214 002 1048576
   ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
   ROD: EV_ECM20TDI01104L906026FL.rod
   VCID: 00597DB07A884D579E5-8054
17158 - Databus
          U0428 00 [032] - -
   Part No SW: 0D9 300 041 A    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4801
   Revision: 03253104    Serial number: TFK01411260701
   Shop #: WSC 05311 115 00089
   ROD: EV_TCMDQ250021.rod
   VCID: 16753BE8080CD3E7549-8042
   Part No SW: 3Q0 907 379 N    HW: 3Q0 907 379 G
   Component: ESC           H42 0710
   Revision: 00000000    Serial number: 63264000002668
   Coding: 0FEC6A8F34220B75077B060441C849F0562CD0E0608292F1B862F078C202
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   VCID: 45D7ACA4252AA87FED3-8010
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0354550591
   Coding: 000F0F0703
   Shop #: WSC 05311 115 00300
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   VCID: 77AB166C2F460AEFAFF-8022
   Part No SW: 5G0 907 044 AK    HW: 5G0 907 044 AK
   Revision: 00001K10
   Coding: 12020104204101012015500000101802
   VCID: 70B92D704A285DD76E5-8024
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86582611140296
   Coding: 00031C46C24102FF0BA44084B11C07081C80000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DA704440D7A20BFF53-8028
   Component: WWS    141018  042 0607
   Serial number:         141022045300
   Component: RLHS  037 0059
   Serial number: S3Y14M12D04H05M44S28
   Coding: 00A8DD
   Light switch:
   Serial number: 12 11 2014  00000087
   Serial number: 000000000ZY142671Y4Y
   Serial number: 00000000000060679132
   Part No SW: 5Q0 919 298 C    HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0013
   Serial number: ATW-00101.12.14
   Coding: 0471161151
   ASAM Dataset: EV_EPHVA2CAU3700000 008017
   ROD: EV_EPHVA2CAU3700000_008_VW48.rod
   VCID: 3FDBBE4C47F6F2AFA7F-806A
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0126
   Coding: 3260670B10FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3333E27C7BBE26CF537-8066
0862 - Databus
          [FAULT_DIRECTION_OF_TRAVEL_INVALID_SIGNAL]
                    Reset counter: 108
                    Mileage: 98635 km
                    Date: 2018.05.22
                    Time: 16:46:38
                    Control Module temperature: 28 °C
                    Voltage terminal 15: 13.6 V
                    Velocity_vehicle_reference: 0.17 m/s
                    Longitudinal_acceleration_vehicle_reference: 1.06 m/s²
   Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R1PPZ6G4D
   Coding: 88CCC000008000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 015F78B47182445F91B-8054
   Belt Pretensioner left:
   Component: BeltPretRevFL  105 1032
   Serial number: 3G1857705E0332O01142
   Coding: 80000A
   Belt Pretensioner right:
   Component: BeltPretRevFR  105 1032
   Serial number: 3G1857706E0331O00209
   Coding: 80000A
   Subsystem 3 - Part No SW: -----------    HW: 454 002 411 14
   Serial number: 3576U0000000A125911.
   Subsystem 4 - Part No SW: -----------    HW: 454 002 411 14
   Serial number: 3586U000000A397CE11N
   Subsystem 5 - Part No SW: -----------    HW: 454 800 112 14
   Serial number: 3516R4EAA43050000006
   Subsystem 6 - Part No SW: -----------    HW: 454 801 711 14
   Serial number: 3526RB95D44050000008
   Subsystem 7 - Part No SW: -----------    HW: 454 800 611 14
   Serial number: 3556VD1F3F404000000J
   Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
   Revision: --------    Serial number: 20141212500949
   Coding: 0410
   Shop #: WSC 36043 001 1048576
   ASAM Dataset: EV_SMLSVALEOMQB 001010
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3C21C94056E0E9B782D-8068
   Part No SW: 3G0 920 741     HW: 3G0 920 741
   Component: KOMBI         209 4311
   Coding: 07A409182F80000800882A003001000000000000
   VCID: 619F583491C2E45FF1B-8034
   Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
   Component: STH-MQB       006 0069
   Coding: 9309
   VCID: 3635DB6868CC33E7749-8062
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001031108
   Revision: --------    Serial number: 08111410800368
   Coding: 030300344F017300EF00025E1C0F00010001070000000000000000000000
   ROD: EV_GatewConti_011_VW48.rod
   VCID: 72BD277844246FC7981-8026
   Component: E221__MFL-DC1  H16 0038
   Serial number: 21140000167660054455
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 0322274703
   Analog clock:
   Component: Analoguhr  111 1004
   Serial number: 2511201400010391
   Serial number: 14000252983004
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BF2874412254DF61B-8024
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Serial number: 221114BKM0596A
   Coding: 00350A208000028000001000
   VCID: 42DDB7B834049F47C81-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000480270
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    203 2033
   Revision: 00000000    Serial number: 0000090330
   Coding: 01010010005000
   Shop #: WSC 00015 115 00300
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3B23CA5C53EEEE8F8B7-806E
   Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Serial number: 231114BKN0090A
   Coding: 003500208000028000001000
   VCID: 41DFB8B43102845FD1B-8014
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000523857
   Coding: 090000
   Coding: 039A00000F200200
   Shop #: WSC 03306 002 1048576
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 0001
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 0001
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
   Part No SW: 3Q0 035 824     HW: 3Q0 035 824
   Component: MU-S--ER      H04 0135
   Serial number: VWZAZ2P4627456
   Coding: 02840200FF00000011110001000808001F0100840120010000
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 6A8D3F186CF4A707201-803E
   Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
   Component: ABT_Std-2  H42 1015
   Serial number: VWZ8Z9PD7001QY
          B201A 00 [009] -  -
                    Reset counter: 68
                    Mileage: 98632 km
                    Date: 2018.05.18
                    Time: 15:54:14
                    Voltage terminal 30: 12.0 V
   Part No SW: 5Q0 907 383 D    HW: 5Q0 907 383 D
   Component: Anhaenger     H14 0137
   Revision: 8A001001    Serial number: 0353974037
   Coding: 0100000202000000
   VCID: 3829D55062D8C597665-806C
   Part No SW: 5Q0 980 568     HW: 5Q0 980 568
   Component: RVC Compact+  H05 0100
   Coding: 0184020163002017000048
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
   ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW37.rod
   VCID: 7AAD0F581C541787D01-802E
End----------(Elapsed Time: 02:08, VBatt start/end: 12.0V/12.1V)-----------
Using these two links as a reference, I managed to code Lane Assist to modules 17, 19, 44, 5F and A5 in the following ways:
https://forums.ross-tech.com/showth...fit-Mk-7-Golf)&p=110229&viewfull=1#post110229
https://www.ascoding.ch/en/activate-lane-assist/
Address	19,5Q0	907	530	AC,recoded	(Installation	List),from,01543C0000000600C00C90000006C80000,to,01543C0000000600C08C90000006C80000,,Saturday,15,December,2018,14:12:39:46309
Address	A5,3Q0	980	654	F,recoded	(Long	Coding),from,0003070900000401002623558040A10094000E000020,to,000408020000040100260354C040A10094000E300040,(19460/666/12345),Saturday,15,December,2018,14:18:37:46309
Address	17,3G0	920	741	,recoded	(Long	Coding),from,07A409182F80000800882A003001000000000000,to,07A409186F80000800882A083001000000000000,(00015/115/00001),Saturday,15,December,2018,14:23:53:46309
Address	A5,3Q0	980	654	F,recoded	(Long	Coding),from,000408020000040100260354C040A10094000E300040,to,000408020000040100260355C040A10094000E300040,(19460/666/12345),Saturday,15,December,2018,14:26:40:46309
Address	44,5Q0	909	143	K,recoded	(Long	Coding-exp),from,01010010005000,to,01010011005000,(00015/115/00300),Saturday,15,December,2018,14:30:06:46309
Address	17,3G0	920	741	,recoded	(Long	Coding-exp),from,07A409186F80000800882A083001000000000000,to,07A409186F80000800882A023001000000000000,(00015/115/00001),Saturday,15,December,2018,14:53:19:46309
Address	A5,3Q0	980	654	F,recoded	(Long	Coding),from,000408020000040100260355C040A10094000E300040,to,000408020000040100260055C040A10094000E300040,(19460/666/12345),Saturday,15,December,2018,14:58:53:46309
Address	5F,3Q0	35	824	,channel	ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,adapted	from,not	activated	,to,activated	,Saturday,15,December,2018,14:31:21:46309
Address	5F,3Q0	35	824	,channel	ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,adapted	from,not	activated	,to,activated	,Saturday,15,December,2018,14:31:50:46309
But these links don't reference ACC at all - does it or does it not need coding changes of their own? Also does the PLA module need coding changes? The second link seems to think so but I checked in the long coding helper and there were no references to Lane Assist. Both links tell me there should be adaptation changes in the A5 module. I used the login and checked adaptations - there were no such adaptations. Why it this?
I didn't code DLA in module 55 just yet as it would have hindered the function of the high beams until the camera is calibrated. Is the described procedure valid for this purpuse? Here -> https://www.ascoding.ch/en/activate-dynamic-light-assist-dla-mj-2017/
Unfortunately I was running short on time and didn't make an after-installation autoscan. The A5 module was left with some fault codes afterwards...
Saturday,15,December,2018,14:27:19:46309
VCDS Version: 18.9.0.1 (x64)  HEX-V2 CB: 0.4436.4
                Address A5: Frt Sens. Drv. Assist       Labels: 3Q0-980-65X-A5.clb
Control Module Part Number: 3Q0 980 654 F    HW: 3Q0 980 654
  Component and/or Version: MQB_B_MFK     H06 0220
           Software Coding: 000408020000040100260355C040A10094000E300040
            Work Shop Code: WSC 19460 666 12345
              ASAM Dataset: EV_MFKBoschMQBB 001001 (VW48)
                      VCID: 3A2DCF585CD4D787902-806E
0768 - No Basic Setting
          B2010 00 [009] -  -
          [Calibration_VIN_mismatch]
                    Reset counter: 164
                    Mileage: 103364 km
                    Date: 2018.12.15
                    Time: 14:09:07
                    Control Module temperature: 16 °C
                    Outside air temperature: 16.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 2.8 s
                    Voltage terminal 15: 12.0 V
                    mid: 00 52
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
1122675 - Databus
          [TIMEOUT_LWR_AFS_02]
                    Reset counter: 164
                    Mileage: 103364 km
                    Date: 2018.12.15
                    Time: 14:18:24
                    Control Module temperature: 25 °C
                    System run time: 449.0 s
                    Voltage terminal 15: 11.9 V
                    mid: 01 E8
                    Status of camera: System malfunction
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
1122597 - Local Data Bus
          U1169 00 [009] - Missing Message
                    Reset counter: 164
                    Mileage: 103364 km
                    Date: 2018.12.15
                    Time: 14:09:08
                    System run time: 3.3 s
                    mid: 01 42
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
1122649 - Databus
          [Timeout_SWA_01]
                    Reset counter: 164
                    Mileage: 103364 km
                    Date: 2018.12.15
                    Time: 14:09:08
                    mid: 02 0B
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
I presume this "[TIMEOUT_LWR_AFS_02]" is because I coded DLA lights but the 55 module is not yet coded to support this? But what is this "[Timeout_SWA_01]" ? SWA should be Spurwechselassistent but this car does not have blind spot assist and I don't remember seeing it in the A5 coding.
downtime
C?ID=280813
To me it looks like the coding is correct for the modules. Can you post adamap from 5F and A5?
SWA = LCA = Lane change assist. Make sure you have not enabled that in any of the modules.
And no changes needed to ACC nor PLA for lane assist.
By the way, did you update the dataset to one with traffic jam assist? 654 should support that.
siLc
Tallinn, Estonia
C?ID=330192
Sure can. See below...
When I get the chance, I'll check it out.
I don't yet have the tools needed for this. I hope golfi_vend helps me out :)
A5:
	SW:3Q0-980-654-F			HW:3Q0-980-654	---		Frt	Sens.	Drv.	Assist
	Component:MQB_B_MFK					H06	220	Coding:000408020000040100260354C040A10094000E300040
	EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB_001_VW36.rod
	Saturday,15,December,2018,14:19:47:46309
	VCDS	Version:	Release	18.9.0	(x64)		Data	version:	20180927	DS296.0
IDE00001-Production	mode,Deactivating	0,3
IDE00820-ENG130919-Activating	and	deactivating	all	development	messages-Activation_of_development_messages_EHR,not	activated	0,1
IDE00820-ENG130920-Activating	and	deactivating	all	development	messages-Activation_of_development_messages_HCA_lane,not	activated	0,1
IDE00820-ENG130921-Activating	and	deactivating	all	development	messages-Activation_of_development_messages_HCA_state,not	activated	0,1
IDE00820-ENG130922-Activating	and	deactivating	all	development	messages-Activation_of_development_messages_internal,not	activated	0,1
IDE00820-ENG130916-Activating	and	deactivating	all	development	messages-Activation_of_development_messages_lane,not	activated	0,1
IDE00820-ENG130915-Activating	and	deactivating	all	development	messages-Activation_of_development_messages_reserved,not	activated	0,1
IDE00820-ENG130918-Activating	and	deactivating	all	development	messages-Activation_of_development_messages_VZF/TSR,not	activated	0,1
IDE00820-ENG130917-Activating	and	deactivating	all	development	messages-Activation_of_development_messages_WLA,not	activated	0,1
IDE02332-Deactivate	production	mode,0	0,3
IDE04160-Direct.	stab.	assist	speed	threshold	during	towing	mode,300	km/h,2
IDE04733-Road	sign	detection	fusion	mode,Road	sign	fusion	0,1
IDE06425-Roller	test	bench	mode:	functional,not	activated	0,1
IDE07358-Distance	to	calibration	field,1500	mm,2
IDE07596-Personalization	of	lane	dept.	warning	Cl.	15	on,Last	setting	0,1
IDE09375-IDE05717-Axle	offset-Front	axle	transverse	position,-7.99999	mm,4
IDE09375-IDE05718-Axle	offset-Rear	axle	transverse	position,-9.99999	mm,4
IDE09376-IDE02001-Body	height	wheel	house	edge-Body	height	left	front	wheel	house	edge,682	mm,8
IDE09376-IDE02002-Body	height	wheel	house	edge-Body	height	right	front	wheel	house	edge,689	mm,8
IDE09376-IDE02003-Body	height	wheel	house	edge-Body	height	left	rear	wheel	house	edge,691	mm,8
IDE09376-IDE02004-Body	height	wheel	house	edge-Body	height	right	rear	wheel	house	edge,707	mm,8
IDE09391-MAS08824-Calibration	target	position-Target	1:	calibration	mark	1:	x-coordinate,2460	mm,24
IDE09391-MAS08825-Calibration	target	position-Target	1:	calibration	mark	1:	y-coordinate,742	mm,24
IDE09391-MAS08826-Calibration	target	position-Target	1:	calibration	mark	1:	z-coordinate,1497	mm,24
IDE09391-MAS08827-Calibration	target	position-Target	1:	calibration	mark	2:	x-coordinate,2460	mm,24
IDE09391-MAS08828-Calibration	target	position-Target	1:	calibration	mark	2:	y-coordinate,-742	mm,24
IDE09391-MAS08829-Calibration	target	position-Target	1:	calibration	mark	2:	z-coordinate,1497	mm,24
IDE09391-MAS08830-Calibration	target	position-Target	1:	calibration	mark	3:	x-coordinate,2460	mm,24
IDE09391-MAS08831-Calibration	target	position-Target	1:	calibration	mark	3:	y-coordinate,742	mm,24
IDE09391-MAS08832-Calibration	target	position-Target	1:	calibration	mark	3:	z-coordinate,903	mm,24
IDE09391-MAS08833-Calibration	target	position-Target	1:	calibration	mark	4:	x-coordinate,2460	mm,24
IDE09391-MAS08834-Calibration	target	position-Target	1:	calibration	mark	4:	y-coordinate,-742	mm,24
IDE09391-MAS08835-Calibration	target	position-Target	1:	calibration	mark	4:	z-coordinate,903	mm,24
IDE10407-Personalization	of	intervention	moment	at	T.	15	on,Last	setting	0,1
IDE10870-Switch-on	condition:	lane	depart.	warn.,on	(setting	via	menu)	0,1
IDE10871-System	mode:	lane	depart.	warn:,Steering	wheel	vibration	not	active	0,1
IDE10872-Warning	intensity:	lane	depart.	warning,Medium	0,1
IDE10873-BAP	personalization,activated	0,1
IDE10924-MAS02479-Initial	calibration:	result-Yaw	angle,0.021	°,8
IDE10924-MAS05286-Initial	calibration:	result-Roll	angle,-0.037	°,8
IDE10924-MAS05287-Initial	calibration:	result-Pitch	angle,1.509	°,8
IDE10924-MAS10678-Initial	calibration:	result-Camera	height,1406	mm,8
ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR,0	0,3
ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF,0	0,3
ENG130776-ENG130838-Adaptation_tsr-Par_country_mode,automatic	0,3
ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode,Enabled	0,3
ENG120319-Mask_error_reactions_for_development,not	activated	0,1
ENG107577-Masked_fault_classes-,255	0,4
ENG130777-standstill_mode,not	activated	0,1
ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,1	0,5
ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,20	0,5
ENG130779-Xcp_interface,not	activated	0,1
Elapsed	Time:	00:07
5F:
	SW:3Q0-035-824			HW:3Q0-035-824	---		Information	Electr.
	Component:MU-S--ER						H04	135	Coding:02840200FF00000011110001000808001F0100840120010000
	EV_MUStd4CTSAT,001018,EV_MUStd4CTSAT_VW36.rod
	Friday,26,October,2018,14:22:47:46309
IDE00001-Production	mode,00	0	0	0,3
IDE00346-Summertime-automatic,Europe	0,1
IDE00758-Base	volume	of	telephone,50	%,1
IDE00759-Base	volume	of	speech	output,50	%,1
IDE00760-Microphone	sensitivity,0	dB,1
IDE00769-Number	1	for	Info	call,FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	0,23
IDE00770-Number	1	for	roadside	assistance,FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	0,23
IDE00820-ENG117828-Activating	and	deactivating	all	development	messages-Infotainment_CAN_Messages,OFF	0,1
IDE00820-ENG117829-Activating	and	deactivating	all	development	messages-MIB_CAN_Messages,OFF	0,1
IDE02121-CD	eject	button,Enabled	0,1
IDE02122-Developer	mode,not	activated	0,1
IDE02330-Number	2	for	Info	call,FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	0,23
IDE02331-Number	2	for	roadside	assistance,FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	0,23
IDE02476-MAS03001-Electrical	test	of	loudspeakers-Mode,automatic	0,49
IDE02476-ENG117360-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000	Hz,49
IDE02476-ENG117361-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36	0,49
IDE02476-ENG117378-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000	Hz,49
IDE02476-ENG117379-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36	0,49
IDE02476-ENG117380-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000	Hz,49
IDE02476-ENG117381-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36	0,49
IDE02476-ENG117382-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000	Hz,49
IDE02476-ENG117383-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36	0,49
IDE02476-ENG117384-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000	Hz,49
IDE02476-ENG117385-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36	0,49
IDE02476-ENG117386-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000	Hz,49
IDE02476-ENG117387-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36	0,49
IDE02476-ENG117388-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000	Hz,49
IDE02476-ENG117389-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36	0,49
IDE02476-ENG117390-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000	Hz,49
IDE02476-ENG117391-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36	0,49
IDE02476-ENG117362-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000	Hz,49
IDE02476-ENG117363-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36	0,49
IDE02476-ENG117364-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000	Hz,49
IDE02476-ENG117365-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36	0,49
IDE02476-ENG117366-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000	Hz,49
IDE02476-ENG117367-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36	0,49
IDE02476-ENG117368-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000	Hz,49
IDE02476-ENG117369-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36	0,49
IDE02476-ENG117370-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000	Hz,49
IDE02476-ENG117371-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36	0,49
IDE02476-ENG117372-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000	Hz,49
IDE02476-ENG117373-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36	0,49
IDE02476-ENG117374-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000	Hz,49
IDE02476-ENG117375-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36	0,49
IDE02476-ENG117376-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000	Hz,49
IDE02476-ENG117377-Electrical	test	of	loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36	0,49
IDE02502-Confirmation	of	installation	change,90	34	0,2
IDE02699-Number	1	for	roadside	assistance,FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	0,23
IDE02701-Number	1	(roaming)	for	roadside	assistance,FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	FF	0,23
IDE04331-Selection	of	release	codes	for	a	SWaP	function,FF	FF	FF	FF	0,4
IDE04550-Bluetooth:	Sniff	mode,OFF	0,1
IDE05113-Infotainment	Recorder,activated	0,1
IDE10221-MAS00839-Audio	Management	Input	Gain	Generation	2-TV	Tuner,-128	0,4
IDE10221-MAS00846-Audio	Management	Input	Gain	Generation	2-Satellite	radio,-128	0,4
IDE10221-MAS01984-Audio	Management	Input	Gain	Generation	2-Radio	(FM),-128	0,4
IDE10221-MAS01985-Audio	Management	Input	Gain	Generation	2-Radio	(AM),-128	0,4
IDE10221-MAS01986-Audio	Management	Input	Gain	Generation	2-Digital	radio	(DAB),-128	0,4
IDE10221-ENG125854-Audio	Management	Input	Gain	Generation	2-Exbox_DMB,-128	0,4
IDE10221-ENG117430-Audio	Management	Input	Gain	Generation	2-HFP,-128	0,4
IDE10221-ENG125846-Audio	Management	Input	Gain	Generation	2-Media_Airplay,-128	0,4
IDE10221-ENG125837-Audio	Management	Input	Gain	Generation	2-Media_AUX_Adapter,-128	0,4
IDE10221-ENG125836-Audio	Management	Input	Gain	Generation	2-Media_AUXIN,-128	0,4
IDE10221-ENG125843-Audio	Management	Input	Gain	Generation	2-Media_Bluray,-128	0,4
IDE10221-ENG125841-Audio	Management	Input	Gain	Generation	2-Media_BTDevice,-128	0,4
IDE10221-ENG125838-Audio	Management	Input	Gain	Generation	2-Media_CDA,-128	0,4
IDE10221-ENG125848-Audio	Management	Input	Gain	Generation	2-Media_Cloud,-128	0,4
IDE10221-ENG125839-Audio	Management	Input	Gain	Generation	2-Media_DVD,-128	0,4
IDE10221-ENG125844-Audio	Management	Input	Gain	Generation	2-Media_HDMI,-128	0,4
IDE10221-ENG125840-Audio	Management	Input	Gain	Generation	2-Media_MFP,-128	0,4
IDE10221-ENG125847-Audio	Management	Input	Gain	Generation	2-Media_UPNP,-128	0,4
IDE10221-ENG125855-Audio	Management	Input	Gain	Generation	2-Mirrorlink,-128	0,4
IDE10221-ENG125859-Audio	Management	Input	Gain	Generation	2-Phone_Ringer_MFP,-128	0,4
IDE10221-ENG125860-Audio	Management	Input	Gain	Generation	2-Phone_Ringer_OB,-128	0,4
IDE10221-ENG125858-Audio	Management	Input	Gain	Generation	2-Phone_Voice,-128	0,4
IDE10221-ENG125842-Audio	Management	Input	Gain	Generation	2-TA_Tuner_FM,-128	0,4
IDE10221-ENG125850-Audio	Management	Input	Gain	Generation	2-Tone_Beep,-128	0,4
IDE10221-ENG125853-Audio	Management	Input	Gain	Generation	2-Tone_Messaging,-128	0,4
IDE10221-ENG125852-Audio	Management	Input	Gain	Generation	2-Tone_Touchscreen,-128	0,4
IDE10221-ENG125851-Audio	Management	Input	Gain	Generation	2-Tone_Warning,-128	0,4
IDE10221-ENG125856-Audio	Management	Input	Gain	Generation	2-TTS_Nav,-128	0,4
IDE10221-ENG125857-Audio	Management	Input	Gain	Generation	2-TTS_SDS,-128	0,4
IDE10221-ENG125845-Audio	Management	Input	Gain	Generation	2-Tuner_Online,-128	0,4
IDE10221-ENG125849-Audio	Management	Input	Gain	Generation	2-Tuner_Personal,-128	0,4
IDE10221-ENG125835-Audio	Management	Input	Gain	Generation	2-Tuner_TI,-128	0,4
IDE10221-ENG125861-Audio	Management	Input	Gain	Generation	2-TV_AV_IN,-128	0,4
IDE10480-MAS10741-Interface	for	external	media:	activation-Connection	1,not	activated	0,4
IDE10480-MAS10742-Interface	for	external	media:	activation-Connection	2,not	activated	0,4
IDE10480-MAS10743-Interface	for	external	media:	activation-Connection	3,not	activated	0,4
IDE10480-MAS10744-Interface	for	external	media:	activation-Connection	4,not	activated	0,4
IDE10604-Menu	entries	for	mobile	online	services,not	activated	0,1
IDE11122-Country	identification:	country	of	sale	HMI,SE	0,2
MAS00951-Bluetooth,On	0,1
MAS02809-MAS02870-Check	tone	frequency-High	note	frequency	range,4000	Hz,6
MAS02809-MAS02871-Check	tone	frequency-Medium	note	frequency	range,1000	Hz,6
MAS02809-MAS02872-Check	tone	frequency-Low	note	frequency	range,100	Hz,6
MAS03782-WLAN,On	0,1
ENG117917-BAP_Debug_Mode_Release,not_released	0,1
ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP	0,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not	activated	0,6
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not	activated	0,6
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not	activated	0,6
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not	activated	0,6
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not	activated	0,6
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not	activated	0,6
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not	activated	0,6
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not	activated	0,6
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not	activated	0,6
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not	activated	0,6
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not	activated	0,6
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not	activated	0,6
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not	activated	0,6
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not	activated	0,6
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not	activated	0,6
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated	0,6
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not	activated	0,6
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not	activated	0,6
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated	0,6
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not	activated	0,6
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not	activated	0,6
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not	activated	0,6
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not	activated	0,6
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not	activated	0,6
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not	activated	0,6
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not	activated	0,6
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not	activated	0,6
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not	activated	0,6
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not	activated	0,6
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not	activated	0,6
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not	activated	0,6
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not	activated	0,6
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not	activated	0,6
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not	activated	0,6
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not	activated	0,6
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated	0,6
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not	activated	0,6
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not	activated	0,6
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated	0,6
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not	activated	0,6
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not	activated	0,6
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not	activated	0,6
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not	activated	0,6
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not	activated	0,6
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not	activated	0,6
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not	activated	0,6
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not	activated	0,6
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not	activated	0,6
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not	activated	0,6
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not	activated	0,6
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,activated	0,6
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not	activated	0,6
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not	activated	0,6
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated	0,6
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not	activated	0,6
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated	0,6
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not	activated	0,6
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not	activated	0,6
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated	0,6
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not	activated	0,6
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not	activated	0,6
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not	activated	0,6
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not	activated	0,6
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated	0,6
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not	activated	0,6
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated	0,6
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not	activated	0,6
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not	activated	0,6
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated	0,6
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not	activated	0,6
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated	0,6
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not	activated	0,6
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not	activated	0,6
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated	0,6
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not	activated	0,6
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated	0,6
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not	activated	0,6
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not	activated	0,6
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated	0,6
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not	activated	0,6
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated	0,6
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not	activated	0,6
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not	activated	0,6
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated	0,6
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not	activated	0,6
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated	0,6
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not	activated	0,6
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not	activated	0,6
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated	0,6
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not	activated	0,6
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated	0,6
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not	activated	0,6
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not	activated	0,6
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated	0,6
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not	activated	0,6
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not	activated	0,6
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not	activated	0,6
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not	activated	0,6
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated	0,6
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not	activated	0,6
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated	0,6
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not	activated	0,6
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not	activated	0,6
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated	0,6
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not	activated	0,6
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated	0,6
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not	activated	0,6
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not	activated	0,6
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated	0,6
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not	activated	0,6
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not	activated	0,6
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not	activated	0,6
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not	activated	0,6
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not	activated	0,6
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not	activated	0,6
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not	activated	0,6
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not	activated	0,6
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not	activated	0,6
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not	activated	0,6
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not	activated	0,6
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not	activated	0,6
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not	activated	0,6
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not	activated	0,6
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not	activated	0,6
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not	activated	0,6
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not	activated	0,6
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not	activated	0,6
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not	activated	0,6
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated	0,6
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not	activated	0,6
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not	activated	0,6
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not	activated	0,6
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not	activated	0,6
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated	0,6
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not	activated	0,6
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not	activated	0,6
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not	activated	0,6
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not	activated	0,6
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not	activated	0,6
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not	activated	0,6
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not	activated	0,6
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not	activated	0,6
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not	activated	0,6
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated	0,6
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not	activated	0,6
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated	0,6
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not	activated	0,6
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not	activated	0,6
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated	0,6
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not	activated	0,6
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not	activated	0,6
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not	activated	0,6
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not	activated	0,6
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated	0,6
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not	activated	0,6
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not	activated	0,6
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not	activated	0,6
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not	activated	0,6
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated	0,6
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not	activated	0,6
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not	activated	0,6
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not	activated	0,6
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not	activated	0,6
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated	0,6
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not	activated	0,6
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not	activated	0,6
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not	activated	0,6
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not	activated	0,6
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated	0,6
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not	activated	0,6
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not	activated	0,6
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not	activated	0,6
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not	activated	0,6
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not	activated	0,6
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not	activated	0,6
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not	activated	0,6
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not	activated	0,6
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not	activated	0,6
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not	activated	0,6
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not	activated	0,6
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not	activated	0,6
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not	activated	0,6
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not	activated	0,6
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not	activated	0,6
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not	activated	0,6
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated	0,6
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not	activated	0,6
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not	activated	0,6
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated	0,6
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not	activated	0,6
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not	activated	0,6
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not	activated	0,6
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not	activated	0,6
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,activated	0,6
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not	activated	0,6
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated	0,6
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not	activated	0,6
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not	activated	0,6
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated	0,6
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not	activated	0,6
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not	activated	0,6
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not	activated	0,6
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not	activated	0,6
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not	activated	0,6
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not	activated	0,6
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,activated	0,6
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not	activated	0,6
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not	activated	0,6
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated	0,6
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not	activated	0,6
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not	activated	0,6
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not	activated	0,6
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not	activated	0,6
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated	0,6
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not	activated	0,6
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not	activated	0,6
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not	activated	0,6
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not	activated	0,6
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated	0,6
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not	activated	0,6
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not	activated	0,6
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not	activated	0,6
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not	activated	0,6
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not	activated	0,6
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not	activated	0,6
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated	0,6
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not	activated	0,6
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not	activated	0,6
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated	0,6
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not	activated	0,6
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not	activated	0,6
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not	activated	0,6
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not	activated	0,6
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not	activated	0,6
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not	activated	0,6
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not	activated	0,6
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not	activated	0,6
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not	activated	0,6
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not	activated	0,6
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not	activated	0,6
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not	activated	0,6
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not	activated	0,6
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not	activated	0,6
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not	activated	0,6
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not	activated	0,6
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not	activated	0,6
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not	activated	0,6
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not	activated	0,6
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not	activated	0,6
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not	activated	0,6
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated	0,6
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not	activated	0,6
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not	activated	0,6
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated	0,6
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not	activated	0,6
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not	activated	0,6
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not	activated	0,6
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not	activated	0,6
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not	activated	0,6
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not	activated	0,6
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not	activated	0,6
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not	activated	0,6
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not	activated	0,6
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not	activated	0,6
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not	activated	0,6
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not	activated	0,6
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not	activated	0,6
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not	activated	0,6
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not	activated	0,6
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not	activated	0,6
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated	0,6
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not	activated	0,6
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not	activated	0,6
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated	0,6
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not	activated	0,6
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated	0,6
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not	activated	0,6
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not	activated	0,6
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated	0,6
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not	activated	0,6
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated	0,6
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not	activated	0,6
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not	activated	0,6
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated	0,6
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not	activated	0,6
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated	0,6
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not	activated	0,6
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not	activated	0,6
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated	0,6
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not	activated	0,6
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated	0,6
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not	activated	0,6
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not	activated	0,6
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated	0,6
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not	activated	0,6
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,not	activated	0,6
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not	activated	0,6
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not	activated	0,6
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not	activated	0,6
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not	activated	0,6
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated	0,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus	extended	0,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not	activated	0,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension	data	bus	0,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not	activated	0,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,CAB_9	0,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not	activated	0,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,activated	0,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated	0,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal	15	0,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not	activated	0,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus	drivetrain	0,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated	0,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus	Infotainment	0,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated	0,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension	data	bus	0,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated	0,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not	activated	0,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus	Infotainment	0,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not	activated	0,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated	0,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,activated	0,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated	0,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not	activated	0,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Databus	Infotainment	0,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not	activated	0,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not	activated	0,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort	data	bus	0,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not	activated	0,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not	activated	0,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not	activated	0,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated	0,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not	activated	0,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not	activated	0,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus	drivetrain	0,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated	0,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not	activated	0,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus	extended	0,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated	0,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not	activated	0,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus	Infotainment	0,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated	0,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not	activated	0,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,CAB_9	0,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated	0,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal	15	0,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not	activated	0,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not	activated	0,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus	extended	0,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not	activated	0,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus	Infotainment	0,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not	activated	0,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,activated	0,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus	drivetrain	0,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not	activated	0,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort	data	bus	0,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not	activated	0,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort	data	bus	0,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not	activated	0,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort	data	bus	0,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated	0,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not	activated	0,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,CAB_9	0,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not	activated	0,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort	data	bus	0,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated	0,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus	Infotainment	0,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not	activated	0,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus	extended	0,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated	0,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension	data	bus	0,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not	activated	0,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus	extended	0,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not	activated	0,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort	data	bus	0,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not	activated	0,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not	activated	0,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal	15	0,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated	0,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort	data	bus	0,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated	0,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus	Infotainment	0,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated	0,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus	Infotainment	0,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated	0,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort	data	bus	0,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not	available	0,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort	data	bus	0,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not	available	0,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus	Infotainment	0,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available	0,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus	Infotainment	0,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not	available	0,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus	drivetrain	0,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available	0,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension	data	bus	0,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not	available	0,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort	data	bus	0,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort	data	bus	0,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not	available	0,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available	0,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort	data	bus	0,8
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0	0,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50	0,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100	0,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0	0,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50	0,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100	0,6
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1,0	0,6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2,50	0,6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3,100	0,6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1,0	0,6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2,50	0,6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3,100	0,6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0	0,12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10	0,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100	0,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150	0,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220	0,12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253	0,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1	%,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1	%,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,8	%,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20	%,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60	%,12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100	%,12
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04	1	52	4	52	10	52	40	52	32	0	64	0	3C	0	7C	1	1D	1	50	0	14	0	14	0	14	0	14	0	FF	FF	FF	FF	FF	FF	FF	FF	2	0	A8	0,4
ENG117809-p_damping_Display,5	ms,1
ENG117808-p_HMI_Display,13	%,1
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0	0,2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0	0,2
ENG117919-Startup_Screen_Sticker_HMI,00	0	0,2
ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,OFF	0,3
ENG109862-ENG142146-Vehicle_configuration-allow_message_editing,OFF	0,3
ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,OFF	0,3
ENG109862-ENG185764-Vehicle_configuration-Apple_DIO_Wireless,OFF	0,3
ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_Life,OFF	0,3
ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_ios,OFF	0,3
ENG109862-ENG185765-Vehicle_configuration-Baidu_Car_Life_ios_Wireless,OFF	0,3
ENG109862-ENG185766-Vehicle_configuration-Baidu_Car_Life_Wireless,OFF	0,3
ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epb,blocked	0,3
ENG109862-ENG142151-Vehicle_configuration-conditioning_variant,0	0,3
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,On	0,3
ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_support,OFF	0,3
ENG109862-ENG185778-Vehicle_configuration-FoD,SWaP	0,3
ENG109862-ENG130248-Vehicle_configuration-Google_GAL,OFF	0,3
ENG109862-ENG185779-Vehicle_configuration-Google_GAL_Wireless,OFF	0,3
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,OFF	0,3
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,OFF	0,3
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF	0,3
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF	0,3
ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_data,not	activated	0,3
ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_Extender,Deactivated	0,3
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,Not	Present	0,3
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,Not	Present	0,3
ENG109862-ENG127492-Vehicle_configuration-LGI,OFF	0,3
ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated	0,3
ENG109862-ENG142142-Vehicle_configuration-map_email_support,OFF	0,3
ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_support,OFF	0,3
ENG109862-ENG142141-Vehicle_configuration-map_sms_support,OFF	0,3
ENG109862-ENG142152-Vehicle_configuration-Map_Style,0	0,3
ENG109862-ENG152537-Vehicle_configuration-media_control,not	activated	0,3
ENG109862-ENG138662-Vehicle_configuration-Mirror_link,OFF	0,3
ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_Code,MIB_EU	0,3
ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_Preference,RGB565	0,3
ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF	0,3
ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF	0,3
ENG109862-ENG127495-Vehicle_configuration-online_media,OFF	0,3
ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF	0,3
ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF	0,3
ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF	0,3
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF	0,3
ENG109862-ENG152553-Vehicle_configuration-online_radio,Deactivated	0,3
ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF	0,3
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF	0,3
ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold,00	0,3
ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis,00	0,3
ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy,0	0,3
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data	&	language	service	active	0,3
ENG109862-ENG117844-Vehicle_configuration-picture_navi,OFF	0,3
ENG109862-ENG167523-Vehicle_configuration-Pilot_Parking,not	activated	0,3
ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_use,not	activated	0,3
ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest,0	0,3
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF	0,3
ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzo,OFF	0,3
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5	0,3
ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF	0,3
ENG109862-ENG138661-Vehicle_configuration-RSE_software_component,activated	0,3
ENG109862-ENG245031-Vehicle_configuration-rvc_low_black_screen_trunk_open,not	activated	0,3
ENG109862-ENG244966-Vehicle_configuration-rvc_low_black_screen_velocity_threshold,not	activated	0,3
ENG109862-ENG245015-Vehicle_configuration-rvc_low_failsafe,not	activated	0,3
ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS	0,3
ENG109862-ENG152556-Vehicle_configuration-scon_telephony,not	activated	0,3
ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivation,no	restriction	0,3
ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flag,no_region	0,3
ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switch,not	activated	0,3
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,Not	Present	0,3
ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_support,OFF	0,3
ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmi,activated	0,3
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,1	0,3
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF	0,3
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF	0,3
ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,OFF	0,3
ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_location,OFF	0,3
ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF	0,3
ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_driving,blocked	0,3
ENG109862-ENG137647-Vehicle_configuration-UOTA,OFF	0,3
ENG109862-ENG167532-Vehicle_configuration-UOTA_2,OFF	0,3
ENG109862-ENG117852-Vehicle_configuration-UPnP,OFF	0,3
ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_sound,not	activated	0,3
ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_sound,not	activated	0,3
ENG109862-ENG152558-Vehicle_configuration-voice_over_lte,not	activated	0,3
ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF	0,3
ENG109862-ENG127494-Vehicle_configuration-VZO,OFF	0,3
ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMI,OFF	0,3
ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,OFF	0,3
ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switch,not	activated	0,3
Elapsed	Time:	00:34
Please keep in mind these are original admaps (without changes in regards to Lane Assist).
downtime
C?ID=280813
Ok, you probably know what adaptation channels to change for lane departure warning. I would’ve like to see the maps after modification :)
siLc
Tallinn, Estonia
C?ID=330192
Can anyone confirm that the Sensor Fusion CAN line between the ACC and Lane Assist camera is only to allow the 160km/h max speed ACC radar (which this car has) to offer a higher top speed of 210km/h with the use of ACC? This article allegres so -> http://mqb.pl/en/adaptive-cruise-control-retrofit-acc-on-mqb/
downtime
C?ID=280813
My understanding is no but not sure. The 210km/h would still need LRR radar.
downtime
C?ID=280813
Probably not. But are we talking still retrofits here or factory installed radar?
siLc
Tallinn, Estonia
C?ID=330192
I managed to get a after-coding autoscan but with the car had developed an unrelated problem.
The owner complained that the Passat had beeped and displayed "Front assist error" and "Park pilot error" on the MFA and flashed the parking aid button. As far as I see from the below autoscan, the factory-fitted trailer module had a canbus fault for some unknown reason. The owner said it happened two days in a row (so 5th and 6th of January) at pretty much the same time and in similar conditions. I briefly googled and threads on other forums led me to think that a newly retrofitted or even a factory trailer module on the MQB platform can cause this error randomly? Also what is this "ESP_21 missing" that went through modules 05 and 17 ?
On the retrofit side, I'm kind of lost why module 17 is complaining. Both bytes and bits should be correctly filled out.
07 A4 09 18 6F 80 00 08 00 88 2A 02 30 01 00 00 00 00 00 00 after
07 A4 09 18 2F 80 00 08 00 88 2A 00 30 01 00 00 00 00 00 00 before
Tuesday,08,January,2019,15:31:47:46309
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: WVWZZZ3CZFE429445   License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F 69
          6C A5
VIN: WVWZZZ3CZFE429445   Mileage: 104865km-65160miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 ET    HW: 04L 907 309 R
   Component: R4 2.0l TDI   H21 1990
   Revision: B5H21---
   Coding: 011D003A04741D083000
   Shop #: WSC 11214 002 1048576
   ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
   ROD: EV_ECM20TDI01104L906026FL.rod
   VCID: 00597DB07A884D579E5-8054
17158 - Databus
4865 - No Communication with Towing System Control Module (J345)
          U1003 00 [040] - -
          [Towing recognition control moduleNo Communication]
                    Fault Frequency: 31
                    Mileage: 104784 km
                    Date: 2019.01.05
                    Time: 19:37:55
                    Engine speed: 738.50 /min
                    Normed load value: 27.8 %
                    Coolant temperature: 39 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 11.920 V
                    Cruise Control System (CCS): status-Bits 0-7: 2
                    selected gear-Bits 0-7: 0
          U0428 00 [032] - -
   Part No SW: 0D9 300 041 A    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4801
   Revision: 03253104    Serial number: TFK01411260701
   Shop #: WSC 05311 115 00089
   ROD: EV_TCMDQ250021.rod
   VCID: 16753BE8080CD3E7549-8042
   Part No SW: 3Q0 907 379 N    HW: 3Q0 907 379 G
   Component: ESC           H42 0710
   Revision: 00000000    Serial number: 63264000002668
   Coding: 0FEC6A8F34220B75077B060441C849F0562CD0E0608292F1B862F078C202
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   VCID: 45D7ACA4252AA87FED3-8010
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0354550591
   Coding: 000F0F0703
   Shop #: WSC 05311 115 00300
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   VCID: 77AB166C2F460AEFAFF-8022
133124 - Databus
          [Message Klemmen_status_01 missing]
                    Fault Frequency: 17
                    Reset counter: 236
                    Mileage: 104803 km
                    Date: 2019.01.06
                    Time: 19:43:27
12718085 - Databus
          [Message ESP_21 missing]
                    Fault Frequency: 101
                    Reset counter: 236
                    Mileage: 104803 km
                    Date: 2019.01.06
                    Time: 19:43:18
   Part No SW: 5G0 907 044 AK    HW: 5G0 907 044 AK
   Revision: 00001K10
   Coding: 12020104204101012015500000101802
   VCID: 70B92D704A285DD76E5-8024
328199 - Position Sensor for Right Temperature Flap Motor
          B1095 15 [008] - Open or Short to Plus
                    Reset counter: 230
                    Mileage: 103305 km
                    Date: 2018.12.14
                    Time: 15:35:59
                    Voltage terminal 30: 14.5 V
                    Outside air temperature: -1.0 °C
                    Interior temperature: 1.7 °C
                    Right temperature flap: actual value: 0.0 %
                    Right temperature flap: actual value: 235
                    Right temperature flap: specified value: 234
459015 - Databus
          [Feuchtesensor innen - kein Signal/Kommunikation]
                    Reset counter: 204
                    Mileage: 103122 km
                    Date: 2018.12.10
                    Time: 17:48:58
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86582611140296
   Coding: 00031C46C24102FF0BA44084B11C07081C80000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DA704440D7A20BFF53-8028
   Component: WWS    141018  042 0607
   Serial number:         141022045300
   Component: RLHS  037 0059
   Serial number: S3Y14M12D04H05M44S28
   Coding: 00A8DD
   Light switch:
   Serial number: 12 11 2014  00000087
   Serial number: 000000000ZY142671Y4Y
   Serial number: 00000000000060679132
529173 - Databus
                    Fault Frequency: 80
                    Reset counter: 236
                    Mileage: 104784 km
                    Date: 2019.01.05
                    Time: 19:37:55
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [008] - -
          [Sensor für Diebstahlwarnanlagekeine Kommunikation]
                    Reset counter: 204
                    Mileage: 103364 km
                    Date: 2018.12.15
                    Time: 12:41:21
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Reset counter: 40
                    Mileage: 103364 km
                    Date: 2018.12.15
                    Time: 12:42:00
   Part No SW: 5Q0 919 298 C    HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0013
   Serial number: ATW-00101.12.14
   Coding: 0471161151
   ASAM Dataset: EV_EPHVA2CAU3700000 008017
   ROD: EV_EPHVA2CAU3700000_008_VW48.rod
   VCID: 3FDBBE4C47F6F2AFA7F-806A
13632273 - Databus
          [Steuergerät für Anhängererkennung-J345 - Gateway_72.Anhaenger_01_alt - kein Signal/keine Kommunikation]
                    Fault Frequency: 88
                    Reset counter: 236
                    Mileage: 104784 km
                    Date: 2019.01.05
                    Time: 19:37:57
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0126
   Coding: 3260670B10FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3333E27C7BBE26CF537-8066
0862 - Databus
          [FAULT_DIRECTION_OF_TRAVEL_INVALID_SIGNAL]
                    Reset counter: 229
                    Mileage: 104650 km
                    Date: 2019.01.02
                    Time: 20:28:37
                    Control Module temperature: 9 °C
                    Voltage terminal 15: 14.6 V
                    Velocity_vehicle_reference: -0.10 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.51 m/s²
1538 - Sensor for Automatic Distance Control
          [FAULT_SENSOR_BLIND]
                    Reset counter: 226
                    Mileage: 104533 km
                    Date: 2019.01.01
                    Time: 01:12:00
                    Control Module temperature: 15 °C
                    Velocity_vehicle_reference: 14.33 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.17 m/s²
1542 - Sensor for Automatic Distance Control
          [FAULT_SYSTEM_BLIND]
                    Reset counter: 226
                    Mileage: 104533 km
                    Date: 2019.01.01
                    Time: 01:12:00
0937 - Databus
          [FAULT_TRAILOR_OBSOLETE_DATA]
                    Fault Frequency: 87
                    Reset counter: 236
                    Mileage: 104784 km
                    Date: 2019.01.05
                    Time: 19:37:55
                    Control Module temperature: 17 °C
                    Voltage terminal 15: 10.2 V
                    Status_ACC_System: ACC_irreversible error
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 236
                    Mileage: 104784 km
                    Date: 2019.01.05
                    Time: 19:37:55
                    Voltage terminal 15: 12.1 V
   Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R1PPZ6G4D
   Coding: 88CCC000008000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 015F78B47182445F91B-8054
   Belt Pretensioner left:
   Component: BeltPretRevFL  105 1032
   Serial number: 3G1857705E0332O01142
   Coding: 80000A
   Belt Pretensioner right:
   Component: BeltPretRevFR  105 1032
   Serial number: 3G1857706E0331O00209
   Coding: 80000A
   Subsystem 3 - Part No SW: -----------    HW: 454 002 411 14
   Serial number: 3576U0000000A125911.
   Subsystem 4 - Part No SW: -----------    HW: 454 002 411 14
   Serial number: 3586U000000A397CE11N
   Subsystem 5 - Part No SW: -----------    HW: 454 800 112 14
   Serial number: 3516R4EAA43050000006
   Subsystem 6 - Part No SW: -----------    HW: 454 801 711 14
   Serial number: 3526RB95D44050000008
   Subsystem 7 - Part No SW: -----------    HW: 454 800 611 14
   Serial number: 3556VD1F3F404000000J
   Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
   Revision: --------    Serial number: 20141212500949
   Coding: 0410
   Shop #: WSC 36043 001 1048576
   ASAM Dataset: EV_SMLSVALEOMQB 001010
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3C21C94056E0E9B782D-8068
   Part No SW: 3G0 920 741     HW: 3G0 920 741
   Component: KOMBI         209 4311
   Coding: 07A409186F80000800882A023001000000000000
   VCID: 619F583491C2E45FF1B-8034
          U1014 00 [008] - -
                    Reset counter: 204
                    Mileage: 103364 km
                    Date: 2018.12.15
                    Time: 14:09:05
16776993 - Databus
          [ESP_21 keine Kommunikation]
                    Reset counter: 236
                    Mileage: 104806 km
                    Date: 2019.01.06
                    Time: 19:55:11
   Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
   Component: STH-MQB       006 0069
   Coding: 9309
   VCID: 3635DB6868CC33E7749-8062
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001031108
0036 - Fuel Level too Low
          P1250 00 [008] - -
                    Reset counter: 220
                    Mileage: 104347 km
                    Date: 2018.12.27
                    Time: 19:05:18
                    Operating condition of parking heater: OFF
                    71
                    Coolant temperature of parking heater: 21 °C
                    Coolant temperature: 44 °C
                    Engine running status: detected
                    Fuel level: 8 l
                    Heater output: 0 W
   Revision: --------    Serial number: 08111410800368
   Coding: 030300344F017300EF00025E1C0F00010001070000000000000000000000
   ROD: EV_GatewConti_011_VW48.rod
   VCID: 72BD277844246FC7981-8026
   Component: E221__MFL-DC1  H16 0038
   Serial number: 21140000167660054455
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 0322274703
   Analog clock:
   Component: Analoguhr  111 1004
   Serial number: 2511201400010391
131655 - No Communication with Towing System Control Module (J345)
          U1003 00 [008] - -
          [Timeout Knoten 0x47 / 69 - Steuergerät für Anhängererkennung]
                    Fault Frequency: 71
                    Reset counter: 236
                    Mileage: 104784 km
                    Date: 2019.01.05
                    Time: 19:37:59
                    Terminal 15: On
   Serial number: 14000252983004
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BF2874412254DF61B-8024
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Serial number: 221114BKM0596A
   Coding: 00350A208000028000001000
   VCID: 42DDB7B834049F47C81-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000480270
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    203 2033
   Revision: 00000000    Serial number: 0000090330
   Coding: 01010011005000
   Shop #: WSC 00015 115 00300
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3B23CA5C53EEEE8F8B7-806E
   Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Serial number: 231114BKN0090A
   Coding: 003500208000028000001000
   VCID: 41DFB8B43102845FD1B-8014
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000000523857
   Coding: 090000
   Coding: 039A00000F200200
   Shop #: WSC 03306 002 1048576
   ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
   Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 0001
   Coding: E02400
   Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H07 0001
   Coding: E02400
   Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0003
   Coding: E02400
   Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0003
   Coding: E02400
13705478 - Databus
          [RLS_01 Datenbus fehlende Botschaft]
                    Reset counter: 204
                    Mileage: 103364 km
                    Date: 2018.12.15
                    Time: 11:13:18
   Part No SW: 3Q0 035 824     HW: 3Q0 035 824
   Component: MU-S--ER      H04 0135
   Serial number: VWZAZ2P4627456
   Coding: 02840200FF00000011110001000808001F0100840120010000
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 6A8D3F186CF4A707201-803E
   Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
   Component: ABT_Std-2  H42 1015
   Serial number: VWZ8Z9PD7001QY
          B201A 00 [009] -  -
                    Reset counter: 68
                    Mileage: 98632 km
                    Date: 2018.05.18
                    Time: 15:54:14
                    Voltage terminal 30: 12.0 V
1564 - Microphone 1
          B129B 13 [008] - Open Circuit
                    Reset counter: 204
                    Mileage: 103364 km
                    Date: 2018.12.15
                    Time: 11:14:58
                    Voltage terminal 30: 12.2 V
   Part No SW: 5Q0 907 383 D    HW: 5Q0 907 383 D
   Component: Anhaenger     H14 0137
   Revision: 8A001001    Serial number: 0353974037
   Coding: 0100000202000000
   VCID: 3829D55062D8C597665-806C
342030 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0010 00 [008] - Malfunction
          [Convenience data bus - faulty]
                    Fault Frequency: 249
                    Reset counter: 236
                    Mileage: 104784 km
                    Date: 2019.01.05
                    Time: 19:37:57
   Part No SW: 5Q0 980 568     HW: 5Q0 980 568
   Component: RVC Compact+  H05 0100
   Coding: 0184020163002017000048
   ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
   ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW37.rod
   VCID: 7AAD0F581C541787D01-802E
13705483 - Databus
          [Oldbit-monitoring Gateway_72.Anhaenger_01_alt]
                    Fault Frequency: 93
                    Reset counter: 236
                    Mileage: 104784 km
                    Date: 2019.01.05
                    Time: 19:37:59
                    ARA_error_bits: 0
                    ARA_function_operating_time: 0.0000 s
                    Reason: Environmental conditions
                    current likeliness: 0.0000
                    Camera_System_Operating_Condition: passive
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0220
   Serial number: 25071611P12817
   Coding: 000408020000040100260055C040A10094000E300040
   Shop #: WSC 19460 666 12345
   VCID: 3A2DCF585CD4D787901-806E
0768 - No Basic Setting
          B2010 00 [009] -  -
          [Calibration_VIN_mismatch]
                    Reset counter: 196
                    Mileage: 103364 km
                    Date: 2018.12.15
                    Time: 14:54:47
                    Control Module temperature: 29 °C
                    Outside air temperature: 17.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 221.2 s
                    Voltage terminal 15: 11.9 V
                    mid: 00 52
                    Status of camera: System malfunction
                    Engine_Running_Info: 0
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
1123377 - Databus
          [Timeout_Gateway_72_Anhaenger_01_alt]
                    Fault Frequency: 94
                    Reset counter: 236
                    Mileage: 104784 km
                    Date: 2019.01.05
                    Time: 19:37:57
                    Control Module temperature: 18 °C
                    Outside air temperature: -2.5 °C
                    System run time: 748.3 s
                    mid: 02 94
                    Engine_Running_Info: 1
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
1122675 - Databus
          [TIMEOUT_LWR_AFS_02]
                    Reset counter: 196
                    Mileage: 103364 km
                    Date: 2018.12.15
                    Time: 14:54:48
                    System run time: 221.7 s
                    mid: 01 E8
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
1122597 - Local Data Bus
          U1169 00 [009] - Missing Message
                    Reset counter: 196
                    Mileage: 103364 km
                    Date: 2018.12.15
                    Time: 14:54:48
                    mid: 01 42
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
1122649 - Databus
          [Timeout_SWA_01]
                    Reset counter: 196
                    Mileage: 103364 km
                    Date: 2018.12.15
                    Time: 14:54:48
                    mid: 02 0B
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
End----(Elapsed Time: 02:40, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
darkchina811
ITALY
C?ID=333184
when a communication error occurs between two modules, it can flag DTCs in other modules as well. that's because everybody talks and listen to everybody else on the network.
save the scan, clear DTCs and let's see what stays.
siLc
Tallinn, Estonia
C?ID=330192
Yeah, I already cleared the DTC-s and only the SVM fault in 5F and expected faults in A5 came back right away.
siLc
Tallinn, Estonia
C?ID=330192
The problem with the incorrect coding DTC in module 17 seems to have disappeared on its own. Now after many CAN sleeps 5F has "Lane Assist" available as a driver aid system in SETUP menu, I'm guessing module 17 was dependent on 5F's adaptations to take effect. What do others think?
In the following weeks, the car goes to the dealer to have the calibration done on the camera and other safety systems.
siLc
Tallinn, Estonia
C?ID=330192
In the meantime, I investigated the DTC-s that remained in the A5 module.
I`ve found the A5 coding needed changing and I was able to reduce the faults to just two:
          B2010 00 [009] -  -
                    Reset counter: 230
                    Mileage: 106547 km
                    Date: 2019.01.31
                    Time: 16:21:57
                    Control Module temperature: 21 °C
                    Outside air temperature: -1.5 °C
                    System run time: 194.6 s
                    Voltage terminal 15: 11.8 V
                    mid: 00 52
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
                    Reset counter: 230
                    Mileage: 106547 km
                    Date: 2019.01.31
                    Time: 16:21:57
                    System run time: 195.0 s
                    mid: 01 42
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
I had connected the Sensor Fusion CAN to the ACC radar´s wiring loom. I added the checkbox in ACC radar´s coding that A5 camera is installed. After saving the coding, MFA declared that ACC was unavailable and the following DTC appeared in ACC.
                Address 13: Auto Dist. Reg       Labels: 3Q0-907-572.clb
Control Module Part Number: 3Q0 907 572 A    HW: 3Q0 907 572 A
  Component and/or Version: ACC BOSCH MQB H04 0126
           Software Coding: 3260674B10FFC428949C804C
            Work Shop Code: WSC 12345 123 98765
              ASAM Dataset: EV_ACCBOSCHVW48X 001007 (VW48)
                      VCID: 3333E27C7A3E26CF53F-8066
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 230
                    Mileage: 106586 km
                    Date: 2019.02.01
                    Time: 09:50:34
                    Control Module temperature: 6 °C
                    Voltage terminal 15: 12.0 V
What is this DTC? Google only revealed one thread on RT and one in German forum. See below...
https://forums.ross-tech.com/showthread.php?14848-Missing-adaptation-channel-in-BCM-after-changes
https://www.google.com/url?sa=t&rct...entId=767078&usg=AOvVaw0aT8Rv_QvhiTdGRQAFuwKr
On the positive side, the local databus error in the A5 module disappeared, leaving only the basic settings error. The previous SWA error was banished with the help of experimental coding because in the normal label file, the Blind Spot Monitoring was missing its description and so I didn't know it was there.
After thinking about it, should the coded ACC still work after clearing the ACC error? Is the ACC error there because the A5 camera is uncalibrated? I uncoded the A5 from the ACC and ACC function returned after erasing the DTC.
Edit: I coded the ACC again, fault appeared, tried to clear it but it returned immediately. Ignition cycle had no effect.
Here is also the very latest autoscan with the ACC coded and fault apparent.
Friday,01,February,2019,15:21:32:46309
Workshop Code: 123 12345 098765
          6C A5
VIN: WVWZZZ3CZFE429445   Mileage: 106613km-66246miles
   Revision: B5H21---
   VCID: 00597DB07A884D579ED-8054
   VCID: 16753BE8080CD3E7541-8042
          P1734 00 [002] - -
   VCID: 45D7ACA4252AA87FEDB-8010
   Coding: 000F0F0703
   VCID: 77AB166C2F460AEFAF7-8022
   Revision: 00001K10
   VCID: 70B92D704A285DD76ED-8024
                    Reset counter: 237
                    Mileage: 104872 km
                    Date: 2019.01.09
                    Time: 08:38:36
                    Outside air temperature: -3.0 °C
                    Interior temperature: 0.3 °C
                    Right temperature flap: actual value: 234
   VCID: 7DA704440D7A20BFF5B-8028
   Coding: 00A8DD
   Light switch:
   Coding: 0471161151
   VCID: 3FDBBE4C47F6F2AFA77-806A
   Shop #: WSC 12345 123 98765
   VCID: 3333E27C7BBE26CF53F-8066
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 231
                    Mileage: 106613 km
                    Date: 2019.02.01
                    Time: 15:14:43
                    Control Module temperature: 5 °C
   VCID: 015F78B47182445F913-8054
   Coding: 80000A
   Coding: 80000A
   Coding: 0410
   VCID: 3C21C94056E0E9B7825-8068
   VCID: 619F583491C2E45FF13-8034
   Coding: 9309
   VCID: 3635DB6868CC33E7741-8062
   VCID: 72BD277844246FC7989-8026
   Coding: 2CFFFF
   Analog clock:
   VCID: 71BF2874412254DF613-8024
   VCID: 42DDB7B834049F47C89-8016
          B122D 29 [008] - Signal Implausible
                    Reset counter: 254
                    Time: 00:00:00
   VCID: 3B23CA5C53EEEE8F8BF-806E
   VCID: 41DFB8B43102845FD13-8014
   Coding: 090000
   Coding: E02400
   Coding: E02400
   Coding: E02400
   Coding: E02400
   VCID: 6A8D3F186CF4A707209-803E
          B201A 00 [009] -  -
                    Reset counter: 196
                    Mileage: 104865 km
                    Date: 2019.01.08
                    Time: 15:46:39
                    Voltage terminal 30: 11.6 V
   VCID: 3829D55062D8C59766D-806C
   VCID: 7AAD0F581C541787D09-802E
   Coding: 000408020000040100260045C040A10084000E200000
   VCID: 3A2DCF585CD4D787909-806E
          B2010 00 [009] -  -
                    Reset counter: 231
                    Mileage: 106613 km
                    Date: 2019.02.01
                    Time: 15:14:27
                    Outside air temperature: -2.0 °C
                    System run time: 127.6 s
                    mid: 00 52
                    Status of camera: operational
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
End----------(Elapsed Time: 02:15, VBatt start/end: 12.2V/12.1V)-----------
siLc
Tallinn, Estonia
C?ID=330192
This thread is finished. The car went into the dealership with the ACC error and came out calibrated with Lane Assist working. I coded DLA in 09, 55 and A5 and both are working good.
symb
C?ID=354278
"Only thing left to complete is to connect the Sensor Fusion CAN to the ACC coupling point under the hood. "
Is this mandatory if there is only front assist radar and no ACC? Going for the DLA and lane assist.
Windscreen changed, camera installed and wiring waiting to be plugged. And ofc calibration after that.
apial
Germany, Erfurt
C?ID=125504
already had A5 installed in my 2019 Passat and successfully activated Lane Assist and VZE as well.
Only thing which was different from this and all manuals I found on the internet:
I had to recode STG 10 (parking assist, have auto park), there is a labeled byte "Lane Assist fitted". Without that, i couldn't activate lane assist.
I had that same issue with a 2017 Passat, which had also auto park. Just wanted to let everyone knows in case someone runs in this issue.
rhinopower
C?ID=58979
I did a retrofit on a b8 recently but we couldn’t enable steering wheel vibration :(
siLc
Tallinn, Estonia
C?ID=330192
Isn't steering wheel vibration applicable to Side Assist, not Lane Assist?
My patient had PLA 3.0 but it was not the newer 5QA module. Don't remember changing its coding...
apial
Germany, Erfurt
C?ID=125504
to my understanding (and test) the steering Wheel will not vibrate if you just get over the lane. It only vibrates when you have active steering on and the car cannot take a curve while steering itself and crosses the lane, than the Wheel vibrates. Works fine in my 2019 B8 and a 2017 B8 I also coded.
