Dealer wants that I come more often for service
gabrjel
Luxembourg
C?ID=306473
Hi
I just made Oil Service by 150000km...
And after driving 400km I looked when I will need to go again to service.
And surprise in 365days or 14700km...
Then put some 10w30 oil or what ? I see on invoice HelixUltra 0w30 Pro AV-L
So I compared adaptation channels i found 3 differences:
Old/New
IDE00515-ESI: oil quality,good oil quality /IDE00515-ESI: oil quality,poor oil quality ,0
IDE00517-ESI: soot entry,9100 km / IDE00517-ESI: soot entry,400 km,2
IDE00518-ESI: thermal load,5300 km / IDE00518-ESI: thermal load,0 km
So my question which one made a magic of LongLife service become "fixed one" (I still believe that I have LongLife but shortened by 15000km)
golfi_vend
Tartu, Estonia
C?ID=195131
Hi
Old/New
And that's a bad thing because? Shorter service intervals are better for Your car engine health in general.
Anyhow, this is a question You should really ask Your dealer, why they changed Your service interval and not notifying the user. It also may be that the technician selected wrong option when resetting.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Which car are we talking about? Please include both a scan and a control module map (instruments/#17, adaptation).
gabrjel
Luxembourg
C?ID=306473
The answer to your question is IDE00515 .
Thank You Eric
I dropped the email to dealer.
I did not realized that one option can shorten interval by 50%.
HelixUltra 0w30 Pro AV-L is not poor oil ? - it has 507 norm... anyhow saw also oild with 508 or 509 - higher means better ?
golfi_vend
Tartu, Estonia
C?ID=195131
Thank You Eric
According to VW, using 508 and 509 oils in engine that wasn't designed for it, can damage the engine.
Dana
Western PA, USA
gabrjel
Luxembourg
C?ID=306473
gabrjel
Luxembourg
C?ID=306473
Unfortunately this did not help either.
I have some assumptions
(like IDE697, IDE1153)
I made SRI reset - with good oil quality (just before ADMAP and BLOCKMAP)
Here are the actual ones (STG17):
ADMAP Now
;SW:4G9-920-950-T   HW:4G9-920-950-T ---  Instruments
;Component:TDieRdwAccNv  H07 0043, Coding:138F23081F550008070000
;EV_RBD4K,004048,EV_RBD4K.rod
;Wednesday,26,September,2018,20:29:37:45479
;VCDS Version: Beta 18.7.2 (x64)  Data version: 20180808 DS295.0
;VCID: 41DC4CADA102D07FDEC-8014
IDE00301-Distance,150498 km,3
IDE00342-ESI: Resetting ESI,no warning ,1
IDE00343-Language version,Polish ,1
IDE00499-Display correction of consumptions and operating range,100 %,1
IDE00500-Hour,20 H,1
IDE00501-Minute,29 min,1
IDE00502-Year,2018 ,2
IDE00503-Month,9 ,1
IDE00504-Day,26 ,1
IDE00510-ESI: distance driven from inspection,0 km,2
IDE00511-ESI: time from inspection,0 Days,2
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
IDE00514-ESI: maximum value of time between inspections,730 Days,2
IDE00515-ESI: oil quality,good oil quality ,1
IDE00517-ESI: soot entry,0 km,2
IDE00518-ESI: thermal load,0 km,2
IDE00819-Day counter,1342 Days,2
IDE00827-ESI: minimum value of time between inspections,730 Days,2
IDE00859-Counter of sporadic MOST-ring disruptions,0 ,3
IDE00860-Timer of sporadic MOST-ring disruptions,15000 ms,2
IDE01153-SIA: maximum value of distance to service,15000 km,2
IDE01154-SIA: maximum value of time to service,365 Days,2
IDE01863-MOST light performance,Decrease 0 dB ,1
IDE02494-Automatic door locking,Display ,1
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,0.9 l,5
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.8 l,5
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
IDE03329-Driving profiled for range remaining,9.5 ,2
IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,2
IDE03346-IDE00316-Units adjusted-Time,24h ,2
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,2
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,2
IDE03346-MAS02201-Units adjusted-Temperature,°C ,2
IDE03346-MAS03032-Units adjusted-Volume,Liter ,2
IDE03346-MAS03033-Units adjusted-Consumption,Liters per 100 km ,2
IDE03346-MAS03034-Units adjusted-Pressure,bar ,2
IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,2
IDE03347-MAS00360-Configuration of driver information system-Oil temperature,not active ,3
IDE03347-MAS03190-Configuration of driver information system-Range 2,active ,3
IDE03347-MAS03191-Configuration of driver information system-current consumption 2,active ,3
IDE03347-MAS03192-Configuration of driver information system-Driving time 2,active ,3
IDE03347-MAS03193-Configuration of driver information system-Average speed 2,active ,3
IDE03347-MAS03194-Configuration of driver information system-Average consumption 2,active ,3
IDE03347-MAS03195-Configuration of driver information system-Average consumption 1,active ,3
IDE03347-MAS03196-Configuration of driver information system-Menu,active ,3
IDE03347-MAS03197-Configuration of driver information system-Average speed 1,active ,3
IDE03347-MAS03198-Configuration of driver information system-Daily distance driven 1,active ,3
IDE03347-MAS03199-Configuration of driver information system-Range 1,active ,3
IDE03347-MAS03200-Configuration of driver information system-Driving time 1,active ,3
IDE03347-MAS03201-Configuration of driver information system-Current consumption 1,active ,3
IDE03347-MAS03202-Configuration of driver information system-Menu 2,active ,3
IDE03347-MAS03203-Configuration of driver information system-Daily distance driven 2,active ,3
IDE03347-MAS03204-Configuration of driver information system-Digital tachometer,active ,3
IDE03347-MAS03205-Configuration of driver information system-Stopwatch,not active ,3
IDE03348-MAS01456-Speed warning-Speed,170 ,2
IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour ,2
IDE03348-MAS03206-Speed warning-Speed warning,active ,2
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,580 Days,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,600 km,2
IDE03352-FIX: Time since last time-dependent inspection,22 Days,2
IDE03360-Upshift display in center panel,active ,1
IDE03372-Source for synchronization of time,GPS ,1
IDE03867-Deactivate seat belt warning,No ,1
IDE05193-Expanded display of traffic sign detection,On ,1
IDE06922-No-voltage display,No ,1
IDE07517-MAS05838-Limits for consumption and efficiency statistics-Liters per 100 km: max.value,20 l/100km,4
IDE07517-MAS05839-Limits for consumption and efficiency statistics-km per liter: min.value,3.3 l/100km,4
IDE07517-MAS05840-Limits for consumption and efficiency statistics-Miles per gallon: minimum value (UK),4.0 l/100km,4
IDE07517-MAS05841-Limits for consumption and efficiency statistics-Miles per gallon: minimum value (US),3.3 l/100km,4
ENG105180-ENG100564-animation_speeds-BC_p_t_bc_scroll,1 ms,42
ENG105180-ENG103320-animation_speeds-p_cursor_change_speed,100 ms,42
ENG105180-ENG101602-animation_speeds-p_dssa_fadeout_time,100 ms,42
ENG105180-ENG101285-animation_speeds-p_kopplung_reiter_contentfading,0 ms,42
ENG105180-ENG103573-animation_speeds-p_NV_,300 ms,42
ENG105180-ENG103843-animation_speeds-p_pt1_compass_T,1500 ms,42
ENG105180-ENG101188-animation_speeds-p_t_cursor_fade,75 ms,42
ENG105180-ENG102900-animation_speeds-p_t_fade_in_time_content,200 ms,42
ENG105180-ENG103453-animation_speeds-p_t_fade_out_time_content,100 ms,42
ENG105180-ENG103126-animation_speeds-p_t_fast_caroutline_fading,150 ms,42
ENG105180-ENG99905-animation_speeds-p_t_listcursor,100 ms,42
ENG105180-ENG101794-animation_speeds-p_t_load_icon_rotate,2000 ms,42
ENG105180-ENG102812-animation_speeds-p_t_MOST_fadein_time,300 ms,42
ENG105180-ENG103005-animation_speeds-p_t_MOST_fadeout_time,250 ms,42
ENG105180-ENG101575-animation_speeds-p_t_pageflip,350 ms,42
ENG105180-ENG100187-animation_speeds-p_t_reiteranim_sandstill,200 ms,42
ENG105180-ENG101920-animation_speeds-p_t_RGI_fade,250 ms,42
ENG105180-ENG102716-animation_speeds-p_t_small_bc_scroll,175 ms,42
ENG105180-ENG101185-animation_speeds-p_t_tpafade,300 ms,42
ENG105180-ENG100349-animation_speeds-WARN_p_t_small_bc_scroll,250 ms,42
ENG105180-ENG104074-animation_speeds-WURM_p_t_reiteranim_duration,100 ms,42
ENG105181-ENG100045-animation_speeds_engine_maps_1-p_t_bc_scroll_X1,0 %,36
ENG105181-ENG104265-animation_speeds_engine_maps_1-p_t_bc_scroll_X2,20 %,36
ENG105181-ENG104096-animation_speeds_engine_maps_1-p_t_bc_scroll_X3,40 %,36
ENG105181-ENG100747-animation_speeds_engine_maps_1-p_t_bc_scroll_X4,60 %,36
ENG105181-ENG99307-animation_speeds_engine_maps_1-p_t_bc_scroll_X5,90 %,36
ENG105181-ENG103266-animation_speeds_engine_maps_1-p_t_bc_scroll_X6,100 %,36
ENG105181-ENG103814-animation_speeds_engine_maps_1-p_t_bc_scroll_Y1,0 %,36
ENG105181-ENG100302-animation_speeds_engine_maps_1-p_t_bc_scroll_Y2,10 %,36
ENG105181-ENG102404-animation_speeds_engine_maps_1-p_t_bc_scroll_Y3,35 %,36
ENG105181-ENG101913-animation_speeds_engine_maps_1-p_t_bc_scroll_Y4,70 %,36
ENG105181-ENG104060-animation_speeds_engine_maps_1-p_t_bc_scroll_Y5,85 %,36
ENG105181-ENG101807-animation_speeds_engine_maps_1-p_t_bc_scroll_Y6,100 %,36
ENG105181-ENG99762-animation_speeds_engine_maps_1-p_t_reiteranim_duration_X1,0 %,36
ENG105181-ENG100506-animation_speeds_engine_maps_1-p_t_reiteranim_duration_X2,20 %,36
ENG105181-ENG100951-animation_speeds_engine_maps_1-p_t_reiteranim_duration_X3,40 %,36
ENG105181-ENG103649-animation_speeds_engine_maps_1-p_t_reiteranim_duration_X4,60 %,36
ENG105181-ENG99306-animation_speeds_engine_maps_1-p_t_reiteranim_duration_X5,90 %,36
ENG105181-ENG102619-animation_speeds_engine_maps_1-p_t_reiteranim_duration_X6,100 %,36
ENG105181-ENG100533-animation_speeds_engine_maps_1-p_t_reiteranim_duration_Y1,0 %,36
ENG105181-ENG101841-animation_speeds_engine_maps_1-p_t_reiteranim_duration_Y2,10 %,36
ENG105181-ENG101957-animation_speeds_engine_maps_1-p_t_reiteranim_duration_Y3,35 %,36
ENG105181-ENG99888-animation_speeds_engine_maps_1-p_t_reiteranim_duration_Y4,70 %,36
ENG105181-ENG102943-animation_speeds_engine_maps_1-p_t_reiteranim_duration_Y5,85 %,36
ENG105181-ENG101160-animation_speeds_engine_maps_1-p_t_reiteranim_duration_Y6,100 %,36
ENG105181-ENG99808-animation_speeds_engine_maps_1-p_t_small_bc_scroll_X1,0 %,36
ENG105181-ENG99177-animation_speeds_engine_maps_1-p_t_small_bc_scroll_X2,20 %,36
ENG105181-ENG102433-animation_speeds_engine_maps_1-p_t_small_bc_scroll_X3,40 %,36
ENG105181-ENG99473-animation_speeds_engine_maps_1-p_t_small_bc_scroll_X4,60 %,36
ENG105181-ENG102704-animation_speeds_engine_maps_1-p_t_small_bc_scroll_X5,90 %,36
ENG105181-ENG100825-animation_speeds_engine_maps_1-p_t_small_bc_scroll_X6,100 %,36
ENG105181-ENG99111-animation_speeds_engine_maps_1-p_t_small_bc_scroll_Y1,0 %,36
ENG105181-ENG100818-animation_speeds_engine_maps_1-p_t_small_bc_scroll_Y2,10 %,36
ENG105181-ENG104111-animation_speeds_engine_maps_1-p_t_small_bc_scroll_Y3,35 %,36
ENG105181-ENG100149-animation_speeds_engine_maps_1-p_t_small_bc_scroll_Y4,70 %,36
ENG105181-ENG103051-animation_speeds_engine_maps_1-p_t_small_bc_scroll_Y5,85 %,36
ENG105181-ENG101698-animation_speeds_engine_maps_1-p_t_small_bc_scroll_Y6,100 %,36
ENG105182-ENG101999-animation_speeds_engine_maps_2-p_t_listcursor_X1,0 %,24
ENG105182-ENG101642-animation_speeds_engine_maps_2-p_t_listcursor_X2,20 %,24
ENG105182-ENG101933-animation_speeds_engine_maps_2-p_t_listcursor_X3,40 %,24
ENG105182-ENG101081-animation_speeds_engine_maps_2-p_t_listcursor_X4,60 %,24
ENG105182-ENG102803-animation_speeds_engine_maps_2-p_t_listcursor_X5,90 %,24
ENG105182-ENG100062-animation_speeds_engine_maps_2-p_t_listcursor_X6,100 %,24
ENG105182-ENG100259-animation_speeds_engine_maps_2-p_t_listcursor_Y1,0 %,24
ENG105182-ENG101184-animation_speeds_engine_maps_2-p_t_listcursor_Y2,10 %,24
ENG105182-ENG100229-animation_speeds_engine_maps_2-p_t_listcursor_Y3,35 %,24
ENG105182-ENG100581-animation_speeds_engine_maps_2-p_t_listcursor_Y4,70 %,24
ENG105182-ENG100070-animation_speeds_engine_maps_2-p_t_listcursor_Y5,85 %,24
ENG105182-ENG103392-animation_speeds_engine_maps_2-p_t_listcursor_Y6,100 %,24
ENG105182-ENG100295-animation_speeds_engine_maps_2-p_t_pageflip_X1,0 %,24
ENG105182-ENG102358-animation_speeds_engine_maps_2-p_t_pageflip_X2,20 %,24
ENG105182-ENG99509-animation_speeds_engine_maps_2-p_t_pageflip_X3,40 %,24
ENG105182-ENG104131-animation_speeds_engine_maps_2-p_t_pageflip_X4,60 %,24
ENG105182-ENG101148-animation_speeds_engine_maps_2-p_t_pageflip_X5,90 %,24
ENG105182-ENG100512-animation_speeds_engine_maps_2-p_t_pageflip_X6,100 %,24
ENG105182-ENG103174-animation_speeds_engine_maps_2-p_t_pageflip_Y1,0 %,24
ENG105182-ENG101066-animation_speeds_engine_maps_2-p_t_pageflip_Y2,10 %,24
ENG105182-ENG101166-animation_speeds_engine_maps_2-p_t_pageflip_Y3,35 %,24
ENG105182-ENG99308-animation_speeds_engine_maps_2-p_t_pageflip_Y4,70 %,24
ENG105182-ENG99517-animation_speeds_engine_maps_2-p_t_pageflip_Y5,85 %,24
ENG105182-ENG102725-animation_speeds_engine_maps_2-p_t_pageflip_Y6,100 %,24
ENG113352-Calculation_consumption_efficiency_history,5 min,1
ENG105816-ENG98401-Development_Mode_Message-Block 1,OFF ,10
ENG105816-ENG98402-Development_Mode_Message-Block 10,OFF ,10
ENG105816-ENG98445-Development_Mode_Message-Block 11,OFF ,10
ENG105816-ENG98403-Development_Mode_Message-Block 12,OFF ,10
ENG105816-ENG98446-Development_Mode_Message-Block 13,OFF ,10
ENG105816-ENG98447-Development_Mode_Message-Block 14,OFF ,10
ENG105816-ENG98448-Development_Mode_Message-Block 15,OFF ,10
ENG105816-ENG98404-Development_Mode_Message-Block 16,OFF ,10
ENG105816-ENG98449-Development_Mode_Message-Block 17,OFF ,10
ENG105816-ENG98450-Development_Mode_Message-Block 18,OFF ,10
ENG105816-ENG98451-Development_Mode_Message-Block 19,OFF ,10
ENG105816-ENG98452-Development_Mode_Message-Block 2,OFF ,10
ENG105816-ENG98408-Development_Mode_Message-Block 3,OFF ,10
ENG105816-ENG98410-Development_Mode_Message-Block 4,OFF ,10
ENG105816-ENG98460-Development_Mode_Message-Block 5,OFF ,10
ENG105816-ENG98461-Development_Mode_Message-Block 6,OFF ,10
ENG105816-ENG98462-Development_Mode_Message-Block 7,OFF ,10
ENG105816-ENG98411-Development_Mode_Message-Block 8,OFF ,10
ENG105816-ENG98463-Development_Mode_Message-Block 9,OFF ,10
ENG105816-ENG99285-Development_Mode_Message-send messages,active ,10
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,0 ,15
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,180 ,15
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,200 ,15
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,220 ,15
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,253 ,15
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,0 ,15
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,0 ,15
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,200 ,15
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,700 ,15
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,1000 ,15
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,0 ,15
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,76 ,15
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,127 ,15
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,147 ,15
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,253 ,15
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,0 ,15
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,50 ,15
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,300 ,15
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,800 ,15
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,1000 ,15
ENG105833-ENG101574-dimming_characteristic_curve_adjustment_extra_field-X1,0 ,15
ENG105833-ENG99557-dimming_characteristic_curve_adjustment_extra_field-X2,76 ,15
ENG105833-ENG102140-dimming_characteristic_curve_adjustment_extra_field-X3,127 ,15
ENG105833-ENG102936-dimming_characteristic_curve_adjustment_extra_field-X4,147 ,15
ENG105833-ENG103548-dimming_characteristic_curve_adjustment_extra_field-X5,253 ,15
ENG105833-ENG99777-dimming_characteristic_curve_adjustment_extra_field-Y1,0 ,15
ENG105833-ENG100480-dimming_characteristic_curve_adjustment_extra_field-Y2,30 ,15
ENG105833-ENG100773-dimming_characteristic_curve_adjustment_extra_field-Y3,240 ,15
ENG105833-ENG100631-dimming_characteristic_curve_adjustment_extra_field-Y4,500 ,15
ENG105833-ENG102174-dimming_characteristic_curve_adjustment_extra_field-Y5,1000 ,15
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,0 ,15
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,25 ,15
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,50 ,15
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,75 ,15
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,100 ,15
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,0 ,15
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,250 ,15
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,500 ,15
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,750 ,15
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,1000 ,15
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,0 ,15
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,76 ,15
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,127 ,15
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,147 ,15
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,253 ,15
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,0 ,15
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,50 ,15
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,150 ,15
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,300 ,15
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,1000 ,15
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,0 ,15
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,76 ,15
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,127 ,15
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,147 ,15
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,253 ,15
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,0 ,15
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,9 ,15
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,141 ,15
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,200 ,15
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1000 ,15
ENG107749-NightVision_video_image_shift,0 ,2
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,5 ,21
ENG102605-ENG99610-outside_temperature-p_blocking_time_status,0 ,21
ENG102605-ENG102545-outside_temperature-p_engine_on_detection,500 ,21
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 ,21
ENG102605-ENG103384-outside_temperature-p_kmt_switch,active ,21
ENG102605-ENG103462-outside_temperature-p_kmt_threshold,80 ,21
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,5.0 ,21
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20 ,21
ENG102605-ENG102132-outside_temperature-p_storage_time_display_off,10 ,21
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 ,21
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15 ,21
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 ,21
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40 ,21
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,21
ENG103701-Shift_by_wire,active ,1
ENG109340-tank_validation,validation_deactivated ,1
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.25 ,3
ENG109442-ENG103975-time_parameter_display-tDD15_on,1.0 s,3
ENG109442-ENG100026-time_parameter_display-tDDWUP,1.0 s,3
Elapsed Time: 00:31
BLOCKMAP Now
;Wednesday,26,September,2018,20:29:12:45479
Group,Description,Actual
IDE00019,Voltage terminal 30,14.4, V
IDE00021,Engine speed,780.00, /min
IDE00025,Coolant temperature,69.75, °C
IDE00075,Vehicle speed,0, km/h
IDE00301,Distance,150498, km
IDE00304,Fuel level,45, l
IDE00310,Outside air temperature,14.5, °C
IDE00316-MAS00109,Time-Hours,20, H
IDE00316-MAS00110,Time-Minutes,29, min
IDE00316-MAS00111,Time-Seconds,8, s
IDE00317-MAS00106,Date-Year,2018,
IDE00317-MAS00107,Date-Month,9,
IDE00317-MAS00108,Date-Day,26,
IDE00510,ESI: distance driven from inspection,0, km
IDE00511,ESI: time from inspection,0, Days
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, Days
IDE00515,ESI: oil quality,good oil quality,
IDE00517,ESI: soot entry,0, km
IDE00518,ESI: thermal load,0, km
IDE00520,Phototransistor,0.0, %
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, Days
IDE00697,ESI: remaining distance,15000, km
IDE00698,ESI: remaining running time,730, Days
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,1342, Days
IDE00827,ESI: minimum value of time between inspections,730, Days
IDE00845-MAS04317,Wheel circ.-Average wheel speed,2200,
IDE00845-MAS04318,Wheel circ.-Maximum wheel speed,2214,
IDE00928,ESI: Year's amount of driving,27600, km
IDE00935,ESI: Theoretical service interval,9700, km
IDE01076,Time since ignition off,14644, s
IDE01153,SIA: maximum value of distance to service,15000, km
IDE01154,SIA: maximum value of time to service,365, Days
IDE01285,Counter of component protection malfunctions,1,
IDE02642,Outside temp.: displayed value,14.0, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,105,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,52,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,52,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,0,
IDE03349,FIX: Max. distance until next mileage-related inspection,30000, km
IDE03350,FIX: Maximum time until next time-dependent inspection,580, Days
IDE03351,FIX: Distance covered since last mileage-dependent inspection,600, km
IDE03352,FIX: Time since last time-dependent inspection,22, Days
IDE03470-IDE00500,Parking heater-Hour,0, H
IDE03470-IDE00501,Parking heater-Minute,0, min
IDE03470-IDE00502,Parking heater-Year,2000,
IDE03470-IDE00503,Parking heater-Month,0,
IDE03470-IDE00504,Parking heater-Day,0,
IDE03470-MAS01632,Parking heater-Status,not active,
IDE03470-MAS03217,Parking heater-Time reference,absolute date,
IDE03471-MAS00582,Vehicle configuration-Automatic front-lighting system (AFS) text,No,
IDE03471-MAS00802,Vehicle configuration-Control module for distance control,No,
IDE03471-MAS00805,Vehicle configuration-Directional stabilization assistance control module,No,
IDE03471-MAS00809,Vehicle configuration-Electro-Mechanical Parking Brake Control Module,No,
IDE03471-MAS00811,Vehicle configuration-Active steering control module,No,
IDE03471-MAS00826,Vehicle configuration-Tire Pressure Monitoring Control Module,No,
IDE03471-MAS01108,Vehicle configuration-Steering,No,
IDE03471-MAS01895,Vehicle configuration-Electronically controlled damping,No,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,No,
IDE03471-MAS02569,Vehicle configuration-All-wheel electronics,No,
IDE03471-MAS02948,Vehicle configuration-Rear spoiler control module,No,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,40.6, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,65.0, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,65.1, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,39.6, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,36.2, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,56.2, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,56.2, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,36.2, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,16.5, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,37.9, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,38.7, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,15.7, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,36.2, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,47.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,49.1, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,34.1, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03473-IDE00730,Fuel tank sens-Fuel level sensor 1 including soiling resistance,88, Ohm
IDE03473-IDE00731,Fuel tank sens-Fuel level sensor 2 including soiling resistance,225, Ohm
IDE03473-IDE00732,Fuel tank sens-Fuel level sensor 1 soiling resistance,2, Ohm
IDE03473-IDE00733,Fuel tank sens-Fuel level sensor 2 soiling resistance,1, Ohm
IDE03473-IDE03494,Fuel tank sens-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,Fuel tank sens-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,Fuel tank sens-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,Fuel tank sens-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,Fuel tank sens-Raw value sensor 1 resistor 1,317,
IDE03473-MAS03799,Fuel tank sens-Raw value sensor 1 resistor 2,580,
IDE03473-MAS03800,Fuel tank sens-Raw value sensor 2 resistor 1,545,
IDE03473-MAS03801,Fuel tank sens-Raw value sensor 2 resistor 2,380,
IDE03473-MAS03802,Fuel tank sens-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,Fuel tank sens-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,Fuel tank sens-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,Fuel tank sens-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,44.6, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,84, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,224, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,41.9, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,2.8, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,6553.5, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,6553.5, l
IDE03474-MAS03826,Calculated volume-Quality sensor 1,10,
IDE03474-MAS03827,Calculated volume-Quality sensor 2,10,
IDE03474-MAS03828,Calculated volume-Quality sensor 3,not installed,
IDE03474-MAS03829,Calculated volume-Quality sensor 4,not installed,
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000,
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000,
IDE03474-ENG102894,Calculated volume-averaged_volume,44.6, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,44.6, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,44.7, l
IDE03474-ENG99553,Calculated volume-linking,0.0000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,-0.06250, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,-0.00,
IDE03474-ENG101623,Calculated volume-reference_volume,44.7, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000,
IDE03474-ENG99154,Calculated volume-uncalibrated_volume_G1,41.0, l
IDE03474-ENG100033,Calculated volume-uncalibrated_volume_G2,2.8, l
IDE03474-ENG99708,Calculated volume-uncalibrated_volume_G3,-3276.8, l
IDE03474-ENG101774,Calculated volume-uncalibrated_volume_G4,-3276.8, l
IDE03474-ENG99683,Calculated volume-version_of_application,246,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0008316,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03477-IDE00500,GPS time-Hour,20, H
IDE03477-IDE00501,GPS time-Minute,16, min
IDE03477-IDE00501,GPS time-Minute,29, min
IDE03477-IDE00502,GPS time-Year,2018,
IDE03477-IDE00503,GPS time-Month,9,
IDE03477-IDE00504,GPS time-Day,26,
IDE03477-MAS00111,GPS time-Seconds,7, s
IDE03477-MAS00111,GPS time-Seconds,26, s
IDE03477-MAS03493,GPS time-last synchronization year,2018,
IDE03506,Distance: high resolution,00 5D CC 67 5E 01,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,00,
IDE03880-MAS03425,MOST address-Physical address,40 01,
IDE03881-MAS02200,MOST Transceiver Status-Highest measured temperature,0, °C
IDE03881-MAS02201,MOST Transceiver Status-Temperature,0, °C
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,CF F0 00 00,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,8F F0 00 09,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,4F F0 00 00,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,0F F0 00 09,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,3F F0 75 F8,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,BF F0 75 F8,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,4F F0 00 FB,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,0F F0 78 9E,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,8F F0 78 9E,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,CF F0 00 FB,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,4F F0 01 DB,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,0F F0 E4 AB,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,8F F0 E4 AB,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,CF F0 01 DB,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,4F F0 02 B3,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,0F F1 56 F5,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,8F F1 56 F5,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,CF F0 02 B3,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,0F F1 CB C4,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,4F F0 03 93,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,8F F1 CC C1,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,CF F0 03 93,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF F0 04 5F,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,CF F0 04 8A,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,3F F2 41 BC,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,4F F0 05 28,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,0F F2 47 AD,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,CF F0 05 28,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,8F F2 47 AD,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,6F F0 05 38,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,2F F2 4A E8,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,4F F0 05 38,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,0F F2 4A E9,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,6F F0 05 3A,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,2F F2 4B 1B,
IDE03913-MAS01393,Service -interval- display: history 3-Block 4,4F F0 05 3E,
IDE03913-MAS01394,Service -interval- display: history 3-Block 5,0F F2 4B E4,
IDE03913-MAS01395,Service -interval- display: history 3-Block 6,FF FF FF FF,
IDE03913-MAS01396,Service -interval- display: history 3-Block 7,FF FF FF FF,
IDE03913-MAS01397,Service -interval- display: history 3-Block 8,FF FF FF FF,
IDE03913-MAS01398,Service -interval- display: history 3-Block 9,FF FF FF FF,
IDE03913-MAS01399,Service -interval- display: history 3-Block 10,FF FF FF FF,
IDE03913-MAS01400,Service -interval- display: history 3-Block 11,FF FF FF FF,
IDE03913-MAS01401,Service -interval- display: history 3-Block 12,FF FF FF FF,
IDE03913-MAS01402,Service -interval- display: history 3-Block 13,FF FF FF FF,
IDE03913-MAS01403,Service -interval- display: history 3-Block 14,FF FF FF FF,
IDE03913-MAS01404,Service -interval- display: history 3-Block 15,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01390,Service -interval- display: history 4-Block 1,FF FF FF FF,
IDE03914-MAS01391,Service -interval- display: history 4-Block 2,FF FF FF FF,
IDE03914-MAS01392,Service -interval- display: history 4-Block 3,FF FF FF FF,
IDE03914-MAS01393,Service -interval- display: history 4-Block 4,FF FF FF FF,
IDE03914-MAS01394,Service -interval- display: history 4-Block 5,FF FF FF FF,
IDE03914-MAS01395,Service -interval- display: history 4-Block 6,FF FF FF FF,
IDE03914-MAS01396,Service -interval- display: history 4-Block 7,FF FF FF FF,
IDE03914-MAS01397,Service -interval- display: history 4-Block 8,FF FF FF FF,
IDE03914-MAS01398,Service -interval- display: history 4-Block 9,FF FF FF FF,
IDE03914-MAS01399,Service -interval- display: history 4-Block 10,FF FF FF FF,
IDE03914-MAS01400,Service -interval- display: history 4-Block 11,FF FF FF FF,
IDE03914-MAS01401,Service -interval- display: history 4-Block 12,FF FF FF FF,
IDE03914-MAS01402,Service -interval- display: history 4-Block 13,FF FF FF FF,
IDE03914-MAS01403,Service -interval- display: history 4-Block 14,FF FF FF FF,
IDE03914-MAS01404,Service -interval- display: history 4-Block 15,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE06927-MAS05362,Fuel economy and efficiency history-Current average fuel consumption,300.82, l/100km
IDE06927-MAS05363,Fuel economy and efficiency history-Last average fuel consumption,655.33, l/100km
IDE06927-MAS05364,Fuel economy and efficiency history-Cycle counter: consumption history,3,
IDE06927-MAS05365,Fuel economy and efficiency history-Driving cycle counter: consumption history,184,
IDE06927-MAS05366,Fuel economy and efficiency history-Current sum of efficiencies,0, %
IDE06927-MAS05367,Fuel economy and efficiency history-Last sum of efficiencies,0, %
IDE06927-MAS05368,Fuel economy and efficiency history-Cycle counter: efficiency history,3,
IDE06927-MAS05369,Fuel economy and efficiency history-Driving cycle counter: efficiency history,184,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG105830-ENG99108,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_additional_displays,52,
ENG105830-ENG101233,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_analogue_clock_night,0,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,0,
ENG105830-ENG100577,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial_day,0,
ENG105830-ENG100248,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_extra_field,19,
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,15,
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,10,
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,8,
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,not active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG99439,Instrument_recorder,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 25 00 01 00 00 51 02 00 00 0E 20 00 01 0A 96 18 06 00 00 10 51 02 00 00 09 3B 00 01 00 C8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 02 03 04 05 06 07 08 02 03 04 05 06 07 08 09 03 04 05 06 07 08 09 0A 04 05 06 07 08 09 0A 0B 05 06 07 08 09 0A 0B 0C 06 07 08 09 0A 0B 0C 0D 07 08 09 0A 0B 0C 0D 0E 08 09 0A 0B 0C 0D 0E 0F 09 0A 0B 0C 0D 0E 0F 10 0A 0B 0C 0D 0E 0F 10 11,
ENG107920-ENG100914,onboard_computer-current_consumption,8,
ENG107920-ENG100319,onboard_computer-operating_range_average_consumption,95,
ENG107920-ENG99269,onboard_computer-operating_range_average_consumption_high,95,
ENG107920-ENG99551,onboard_computer-operating_range_average_consumption_low,120,
ENG107920-ENG103254,onboard_computer-operating_range_display_value,430,
ENG107920-ENG102385,onboard_computer-operating_range_R,437,
ENG107953-ENG100377,outside_temp_algorithm_group-algorithm,not active,
ENG107953-ENG99726,outside_temp_algorithm_group-blocking_period_after_display_on_active,not active,
ENG107953-ENG101365,outside_temp_algorithm_group-blocking_period_after_V_bigger_0_active,active,
ENG107953-ENG100938,outside_temp_algorithm_group-coolant_temperature_outdated_bit,not active,
ENG107953-ENG101136,outside_temp_algorithm_group-distance_threshold_not_yet_reached,active,
ENG107953-ENG99778,outside_temp_algorithm_group-downward_tendency,not active,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,active,
ENG107953-ENG102553,outside_temp_algorithm_group-engine_stopped,not active,
ENG107953-ENG102352,outside_temp_algorithm_group-ice_warning_symbol,not active,
ENG107953-ENG99896,outside_temp_algorithm_group-KMT-threshold_exceeded,active,
ENG107953-ENG101086,outside_temp_algorithm_group-mileage_after_start,0,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,128,
ENG107953-ENG99258,outside_temp_algorithm_group-outside_temperature_filtered_error_state_bit,not active,
ENG107953-ENG102589,outside_temp_algorithm_group-outside_temperature_old,not active,
ENG107953-ENG102387,outside_temp_algorithm_group-outside_temperature_raw_score_error_state_bit,not active,
ENG107953-ENG100486,outside_temp_algorithm_group-raw_above_display_value,active,
ENG107953-ENG101082,outside_temp_algorithm_group-s_active_blocking 1°C/min,not active,
ENG107953-ENG100980,outside_temp_algorithm_group-s_active_blocking PT1,not active,
ENG107953-ENG102364,outside_temp_algorithm_group-s_active_blocking_blockage,active,
ENG107953-ENG100183,outside_temp_algorithm_group-s_active_blocking_fault,not active,
ENG107953-ENG102388,outside_temp_algorithm_group-sensor_error_value,not active,
ENG107953-ENG104032,outside_temp_algorithm_group-sensor_not_installed,not active,
ENG107953-ENG99521,outside_temp_algorithm_group-speed_undershot,active,
ENG107953-ENG99899,outside_temp_algorithm_group-vehicle_standing,active,
ENG103405,read_out_measured_value_block,150500,
ENG109340-ENG104056,tank_validation-s_vali_abs_active,not active,
ENG109340-ENG102652,tank_validation-s_vali_abs_display_0,not active,
ENG109340-ENG102994,tank_validation-s_vali_abs_distance/mileage,not active,
ENG109340-ENG101149,tank_validation-s_vali_abs_rough,not active,
ENG109340-ENG101740,tank_validation-s_vali_active,not active,
ENG109340-ENG101355,tank_validation-s_vali_consumption_deq,0.0, l
ENG109340-ENG100596,tank_validation-s_vali_consumption_deq_abs,0.0, l
ENG109340-ENG102770,tank_validation-s_vali_display_0,not active,
ENG109340-ENG99133,tank_validation-s_vali_needle_vol_ref,not active,
ENG109340-ENG99562,tank_validation-s_vali_rough,not active,
ENG109340-ENG100160,tank_validation-s_vali_status,0,
ENG109340-ENG103691,tank_validation-s_vali_vol_delta_gef,0.0, l
ENG109340-ENG100615,tank_validation-s_vali_vol_delta_roh,0.0, l
ENG109340-ENG99506,tank_validation-s_vali_vol_g1_vg,0.0, l
ENG109340-ENG103928,tank_validation-s_vali_vol_g2_vg,0.0, l
ENG109340-ENG101476,tank_validation-s_vali_vol_g3_vg,0.0, l
ENG109340-ENG101237,tank_validation-s_vali_vol_g4_vg,0.0, l
ENG109340-ENG101103,tank_validation-s_vali_vol_ref_gew,0.0, l
ENG109340-ENG100543,tank_validation-s_vali_vol_ref_vg,0.0, l
ENG109340-ENG100079,tank_validation-s_vali_vol_total_vg,0.0, l
Elapsed Time: 00:25
ADMAP before service
;Component:TDieRdwAccNv  H07 0043, Coding:138622081F550008000600
;Wednesday,04,April,2018,14:17:15:45479
;VCDS Version: Release 18.2.0 (x64)  Data version: 20180212 DS287.0
;VCID: 41DC4CADA102D07F3D6-8014
IDE00301-Distance,125472 km,3
IDE00500-Hour,14 H,1
IDE00501-Minute,17 min,1
IDE00503-Month,4 ,1
IDE00504-Day,4 ,1
IDE00510-ESI: distance driven from inspection,7500 km,2
IDE00511-ESI: time from inspection,253 Days,2
IDE00517-ESI: soot entry,9100 km,2
IDE00518-ESI: thermal load,5300 km,2
IDE00819-Day counter,1168 Days,2
IDE02494-Automatic door locking,No display ,1
IDE03329-Driving profiled for range remaining,8.3 ,2
IDE03347-MAS03190-Configuration of driver information system-Range 2,not active ,3
IDE03347-MAS03191-Configuration of driver information system-current consumption 2,not active ,3
IDE03347-MAS03192-Configuration of driver information system-Driving time 2,not active ,3
IDE03347-MAS03193-Configuration of driver information system-Average speed 2,not active ,3
IDE03347-MAS03194-Configuration of driver information system-Average consumption 2,not active ,3
IDE03347-MAS03199-Configuration of driver information system-Range 1,not active ,3
IDE03347-MAS03203-Configuration of driver information system-Daily distance driven 2,not active ,3
IDE03349-FIX: Max. distance until next mileage-related inspection,32000 km,2
IDE03350-FIX: Maximum time until next time-dependent inspection,730 Days,2
IDE03351-FIX: Distance covered since last mileage-dependent inspection,7500 km,2
IDE03352-FIX: Time since last time-dependent inspection,6 Days,2
Elapsed Time: 00:30
;Wednesday,04,April,2018,15:09:35:45479
IDE00500-Hour,15 H,1
IDE00501-Minute,9 min,1
IDE00503-Month,4 ,1
IDE00504-Day,4 ,1
Elapsed Time: 00:30
BLOCKMAP before service
;Wednesday,04,April,2018,14:16:48:45479
IDE00019,Voltage terminal 30,12.0, V
IDE00021,Engine speed,0.00, /min
IDE00025,Coolant temperature,70.50, °C
IDE00301,Distance,125472, km
IDE00304,Fuel level,73, l
IDE00310,Outside air temperature,10.5, °C
IDE00316-MAS00109,Time-Hours,14, H
IDE00316-MAS00110,Time-Minutes,16, min
IDE00316-MAS00111,Time-Seconds,49, s
IDE00317-MAS00107,Date-Month,4,
IDE00317-MAS00108,Date-Day,4,
IDE00510,ESI: distance driven from inspection,7500, km
IDE00511,ESI: time from inspection,253, Days
IDE00517,ESI: soot entry,9100, km
IDE00518,ESI: thermal load,5300, km
IDE00520,Phototransistor,6.0, %
IDE00697,ESI: remaining distance,22500, km
IDE00698,ESI: remaining running time,477, Days
IDE00819,Day counter,1168, Days
IDE00928,ESI: Year's amount of driving,10660, km
IDE00935,ESI: Theoretical service interval,41300, km
IDE01076,Time since ignition off,118568, s
IDE01285,Counter of component protection malfunctions,0,
IDE02642,Outside temp.: displayed value,10.0, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,160,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,0,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,90,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,30,
IDE03349,FIX: Max. distance until next mileage-related inspection,32000, km
IDE03350,FIX: Maximum time until next time-dependent inspection,730, Days
IDE03351,FIX: Distance covered since last mileage-dependent inspection,7500, km
IDE03352,FIX: Time since last time-dependent inspection,6, Days
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,26.9, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,73.0, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,76.0, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,25.5, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,6.4, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,33.3, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,34.5, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,5.2, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,23.0, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,73.0, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,76.0, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,22.5, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,33.7, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,73.0, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,76.0, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,33.6, l
IDE03473-IDE00730,Fuel tank sens-Fuel level sensor 1 including soiling resistance,55, Ohm
IDE03473-IDE00731,Fuel tank sens-Fuel level sensor 2 including soiling resistance,77, Ohm
IDE03473-IDE00733,Fuel tank sens-Fuel level sensor 2 soiling resistance,4, Ohm
IDE03473-MAS03798,Fuel tank sens-Raw value sensor 1 resistor 1,229,
IDE03473-MAS03799,Fuel tank sens-Raw value sensor 1 resistor 2,607,
IDE03473-MAS03800,Fuel tank sens-Raw value sensor 2 resistor 1,290,
IDE03473-MAS03801,Fuel tank sens-Raw value sensor 2 resistor 2,595,
IDE03474-IDE00304,Calculated volume-Fuel level,73.0, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,53, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,73, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,45.0, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,31.0, l
IDE03474-ENG102894,Calculated volume-averaged_volume,76.0, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,76.0, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,76.0, l
IDE03474-ENG101623,Calculated volume-reference_volume,76.0, l
IDE03474-ENG99154,Calculated volume-uncalibrated_volume_G1,51.7, l
IDE03474-ENG100033,Calculated volume-uncalibrated_volume_G2,33.2, l
IDE03474-ENG99683,Calculated volume-version_of_application,245,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0024939,
IDE03477-IDE00500,GPS time-Hour,14, H
IDE03477-IDE00501,GPS time-Minute,5, min
IDE03477-IDE00501,GPS time-Minute,17, min
IDE03477-IDE00503,GPS time-Month,4,
IDE03477-IDE00504,GPS time-Day,4,
IDE03477-MAS00111,GPS time-Seconds,29, s
IDE03506,Distance: high resolution,44 EB 23 23 24 01,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01393,Service -interval- display: history 3-Block 4,FF FF FF FF,
IDE03913-MAS01394,Service -interval- display: history 3-Block 5,FF FF FF FF,
IDE06927-MAS05362,Fuel economy and efficiency history-Current average fuel consumption,0.00, l/100km
IDE06927-MAS05363,Fuel economy and efficiency history-Last average fuel consumption,0.00, l/100km
IDE06927-MAS05365,Fuel economy and efficiency history-Driving cycle counter: consumption history,207,
IDE06927-MAS05369,Fuel economy and efficiency history-Driving cycle counter: efficiency history,207,
ENG105830-ENG99108,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_additional_displays,90,
ENG105830-ENG100248,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_extra_field,0,
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,56,
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,38,
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,29,
ENG107920-ENG100914,onboard_computer-current_consumption,0,
ENG107920-ENG100319,onboard_computer-operating_range_average_consumption,83,
ENG107920-ENG99269,onboard_computer-operating_range_average_consumption_high,83,
ENG107920-ENG99551,onboard_computer-operating_range_average_consumption_low,82,
ENG107920-ENG103254,onboard_computer-operating_range_display_value,840,
ENG107920-ENG102385,onboard_computer-operating_range_R,843,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
ENG107953-ENG102553,outside_temp_algorithm_group-engine_stopped,active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,120,
ENG107953-ENG102388,outside_temp_algorithm_group-sensor_error_value,active,
ENG103405,read_out_measured_value_block,125400,
ENG109340-ENG100160,tank_validation-s_vali_status,2,
ENG109340-ENG99506,tank_validation-s_vali_vol_g1_vg,45.0, l
ENG109340-ENG103928,tank_validation-s_vali_vol_g2_vg,31.0, l
ENG109340-ENG101103,tank_validation-s_vali_vol_ref_gew,76.0, l
ENG109340-ENG100543,tank_validation-s_vali_vol_ref_vg,75.7, l
ENG109340-ENG100079,tank_validation-s_vali_vol_total_vg,76.0, l
Elapsed Time: 00:26
;Wednesday,04,April,2018,15:09:09:45479
IDE00019,Voltage terminal 30,11.7, V
IDE00025,Coolant temperature,64.50, °C
IDE00316-MAS00109,Time-Hours,15, H
IDE00316-MAS00110,Time-Minutes,9, min
IDE00316-MAS00111,Time-Seconds,9, s
IDE00520,Phototransistor,9.0, %
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,174,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,91,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,46,
IDE03473-IDE00730,Fuel tank sens-Fuel level sensor 1 including soiling resistance,56, Ohm
IDE03473-IDE00731,Fuel tank sens-Fuel level sensor 2 including soiling resistance,76, Ohm
IDE03473-IDE00733,Fuel tank sens-Fuel level sensor 2 soiling resistance,3, Ohm
IDE03473-MAS03798,Fuel tank sens-Raw value sensor 1 resistor 1,230,
IDE03473-MAS03799,Fuel tank sens-Raw value sensor 1 resistor 2,608,
IDE03473-MAS03800,Fuel tank sens-Raw value sensor 2 resistor 1,291,
IDE03473-MAS03801,Fuel tank sens-Raw value sensor 2 resistor 2,593,
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,72, Ohm
IDE03474-ENG99154,Calculated volume-uncalibrated_volume_G1,51.3, l
IDE03474-ENG100033,Calculated volume-uncalibrated_volume_G2,32.9, l
IDE03477-IDE00500,GPS time-Hour,15, H
IDE03477-IDE00501,GPS time-Minute,9, min
IDE03477-MAS00111,GPS time-Seconds,27, s
IDE03506,Distance: high resolution,86 F4 23 23 24 01,
IDE06927-MAS05364,Fuel economy and efficiency history-Cycle counter: consumption history,13,
IDE06927-MAS05368,Fuel economy and efficiency history-Cycle counter: efficiency history,13,
ENG105830-ENG99108,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_additional_displays,91,
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,62,
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,47,
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,39,
Elapsed Time: 00:26
I suppose you could try increasing:
'IDE01153-SIA: maximum value of distance to service' to 30,000 km
and
'IDE01154-SIA: maximum value of time to service' to 720 days
to see what happens?
gabrjel
Luxembourg
C?ID=306473
and
Hi Uwe
Thanks for effort but I'm on ESI... SIA did not change anything....
But I managed, it looks like a software bug.
I changed days/km from service (from IDE00510, IDE00511) to 729days (enforcing 1 day to service), and 29000km + soft reset
Warning came, then I changed back to 23 days and 1000km and it came to real results....
So now it's working as it should be
@Uwe is it intended to not have rights to edit posts ?
There is a time limit for users to edit posts. I think it is 24h. This is because early on, one user made a huge mess of a thread.
