Module BF02, does VCDS show this?
golfi_vend
Tartu, Estonia
C?ID=195131
Hello
During AID retrofits I've encountered a module BF02 not being registred when identifying with ODIS.
Is this something that's hidden somewhere or can VCDS also show this?
When doing AID retrofit i always use ODIS - You know, immobiliser and stuff... and i think that is the reason I've never encounter such thing in VCDS.
gif upload
What kind of car is this?
golfi_vend
Tartu, Estonia
C?ID=195131
MasterTommy
Amsterdam
C?ID=295586
Nice one, didnt spot that module yet.
Would it be possible to add a tree-type control module list at some point? Could be handy, since most cars now have two masters; 19 for CAN networks and 5F as MOST-busmaster.
Would also make entire networks not communicating more obvious.
golfi_vend
Tartu, Estonia
C?ID=195131
Today I encountered similar "problem" with Audi A6 MY2016. If You take any autoscan of this car it doesn't show amplifer, because it is installed in MOST bus from MIB and not GW.
Tuesday,03,December,2019,20:28:30:57784
VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4513.4
Dealer/Shop Name: LeVWFreaks.eu
VIN: WUAZZZ4G3GN   License Plate:
Mileage: 40878km-25400mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 1B 22 28 36 3B 3C 42
          44 46 52 53 55 5F 62 65 6C 6D 72 82 84 85 8B 8E 8F 90 BA
VIN: WUAZZZ4G3GN   Mileage: 40878km-25400miles
Address 01: Engine (------CWUB)       Labels: Redir Fail!
   Part No SW: 4G0 906 560 F    HW: 4H0 906 014
   Component: V8 4.0l TFSI  H63 0005
   Revision: NCH63---
   Coding: 122A00326546090B3000
   Shop #: WSC 57251 003 1048576
   ASAM Dataset: EV_ECM40TFS0114G0906560F 001006
   ROD: EV_ECM40TFS0114G0906560F.rod
   VCID: 2B000D0F638B2BDF4C5-807E
5270 - Output for Starter Relay
          P0615 00 [032] - Open Circuit
                    Mileage: 40609 km
                    Date: 2019.12.01
                    Time: 11:12:28
                    Engine speed: 664.00 /min
                    Normed load value: 7.1 %
                    Coolant temperature: 56 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 14.347 V
                    Unlearning counter according OBD: 26
                    Engine status: COENG_RUNNING
   Part No SW: 4G0 927 158 AN    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIRdW H19 1002
   Revision: --H19---
   VCID: 7AAEF84BDC514257873-802E
   Part No SW: 4G0 907 379 T    HW: 4G0 907 379 T
   Component: ESP9 Premium  H01 0100
   Coding: 64BF994926FD99929F00
   Shop #: WSC 02391 785 00200
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 42DE40ABF401CA979F3-8016
   Part No SW: 4H0 907 064 GP    HW: 4H0 907 064 GP
   Coding: 05A96F0E000000000000
   VCID: 7DA4F357CDFF756FA21-8028
   Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
   Coding: 680210B8150000
   VCID: 6A8EC80BACF1F2D7773-803E
Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 EK    HW: 4H0 907 063 EK
   Component: BCM1 2.0      H20 0367
   Revision: 25020001    Serial number:
   Coding: 0105001440349FF2F90140C7A0001800CF9CC7082E08020180000894E101130200400019010000
   VCID: 75B4EB77F5CF2D2FEA1-8020
   Component: WWS57X 151018  H38 0080
   Coding: 0045F7
   Coding: 0200FD
   Subsystem 3 - Part No SW: 4G0 941 531 BH    HW: 4G0 941 531 BH
   Component: E1 - LDS  H07 0044
   Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Coding: 020300
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 H    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0080
   Coding: B82B27
   ASAM Dataset: EV_EPHVA2CAU64X0000 001014
   ROD: EV_EPHVA2CAU64X0000.rod
   VCID: 36362C7BA8C9663723B-8062
   Component: ACC3          H21 0055
   Coding: 7E04010102
   ASAM Dataset: EV_AdaptCruisContrAU57X 002015
   VCID: 290CF707697739CFBE9-807C
Address 14: Susp. Elect.        Labels: None
   Part No SW: 4G0 907 376     HW: 4G0 907 376 A
   Component: J250 DRC FahrwerH02 0040
   Coding: 0000000
   VCID: 6B80CD0FAF8BEBDF0C5-803E
   Coding: 30333130313730323630554A304C34473053
   VCID: 3B203D4F93EBBB5FDC5-806E
   Serial number: /
   Serial number: .
   Coding: 0000FD
   VCID: 3728217FAF439F3F38D-8062
   Part No SW: 4G0 920 931 M    HW: 4G0 920 931 M
   Component: TBenRdwAccNv  H11 0106
   Revision: 08001098    Serial number:
   Coding: 138F110BAFD50008000400
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K_AU57.rod
   VCID: 303A1A634AAD4807797-8064
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Coding: C0ED07481C
   ASAM Dataset: EV_GatewPkoUDS 001028
   Voltage stabilizer:
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Coding: 010100
   VCID: 3A2E384B9C518257C73-806E
Address 22: AWD (J492)       Labels: 4H0-907-163.clb
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H17 0200
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
   VCID: 280AF203727D00C7A17-807C
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0112
   Coding: 20
   VCID: 3E26345B80F9AE77FBB-806A
   Revision: AA000000    Serial number:
   VCID: 77A8E17FEFC35F3FF8D-8022
   Component: SARA 6D red   H04 0056
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3728217FAFC39F3F38D-8062
   Component: SWA Master    H08 0060
   Coding: 040311
   VCID: 392C274799D7894FCE9-806C
   Component: SWA Slave  H08 0060
   Coding: 040311
   Component: TSG FA        H04 0511
   Coding: 011F16015E00628002080013
   VCID: 45D45BB7E5AFFDAFBA1-8010
   Part No SW: 4G0 909 144 T    HW: 4G0 909 144 Q
   Component: RCevo         H53 0202
   Revision: 00000003    Serial number:
   Coding: 011101010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A2E384B9CD18257C73-806E
   Revision: 00002001    Serial number:
   Coding: 013A0E20A0B93081C33009840C0312470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Subsystem 4 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Coding: 011F16015E00628002080002
   VCID: 46D65CBBD8A9F6B7B3B-8012
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D0403175D9F25EF521-8078
   Coding: 04FA0A202A1F0200
   VCID: 34321673BEB574271DF-8060
   Coding: E01F00
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
   Part No SW: 4G1 035 021 N    HW: 4G1 035 021 D
   Component: MU-H-LND-EU   051 1425
   Coding: 017562010000000013111102000A00132F0008E5F17001009F
   VCID: 2514FB37056F1DAF9A1-8070
   Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
   Multimedia Operating Unit:
   Component: Gracenote2  --- 1017
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [009] - Missing message
                    Reset counter: 137
                    Mileage: 40878 km
                    Date: 2019.12.03
                    Time: 20:26:17
                    Voltage terminal 30: 14.9 V
                    Software module: status-SW_Status_Consistency: 00 28 13
                    Software module: status-SW_Status_Device: Mmx2Mmx2Mmx2M
   Component: TSG HL        H03 0511
   Coding: 010F14014000628002080002
   VCID: 49CC5787C9B719CF5E9-801C
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0820
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 2A0E080B6C7132D7B73-807E
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0140
   Coding: 027500010A002003000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 001001
   ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
   VCID: 78AAE243E25D5047F17-802C
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number:
   Coding: 093205C030
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0511
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
   Component: HeadUpDisplay H08 0306
   Coding: D70000
   ASAM Dataset: EV_HUDContiC7 001027
   ROD: EV_HUDContiC7.rod
   VCID: 35342B77B5CF6D2F2A1-8060
Address 84: Night Vision (J853)       Labels:* None
   Part No SW: 4G0 907 547 A    HW: 4G0 907 547
   Component: NV-ECU-Gen3   H08 0107
   Coding: 301100
   ASAM Dataset: EV_NightVisioGen3AE4AU64X 001001
   ROD: EV_NightVisioGen3AE4AU64X.rod
   VCID: 2C020E1366852CE745F-8078
   Camera For Night Vision System:
   Subsystem 1 - Part No SW: 4G0 980 552     HW: 4G0 980 552
   Component: NV-CAM-Gen3  H03 0006
   Component: DPC-SG        H27 0081
   Coding: 6A160000
   ROD: EV_OnBoardCamerDPC.rod
   Coding: 7E04010102
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
   VCID: 2708F13F7F630FBFA8D-8072
   Component: BV-SG         H33 0090
   Coding: 04C0BB1B1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H14 0080
   Coding: 0066E608031F0376070308014240C0010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313C1F6741A7410F769-8064
   Component: RGS-VR        H14 0080
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323E106B44A17A170F3-8066
Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H10 0008
   Revision: 00001001    Serial number:
   ROD: EV_AEMLearAU64X_AU57.rod
End----------(Elapsed Time: 02:39, VBatt start/end: 14.7V/14.7V)-----------
It is reachable directly though.
Tuesday,03,December,2019,20:28:51:57784
VCDS Version: Release 19.6.2 (x64)
                Address 47: Sound System
Control Module Part Number: 4G5 035 223 E
  Component and/or Version: MIB2_amp_P    H02 0440
           Software Coding: 01756208018AF02A5A0000010000
            Work Shop Code: WSC 02391
                      VCID: 2412E6330E55E4A78DF-8070
Advanced Identification/FAZIT
     Identification: BGE-001
     Date: 10.01.16
     Manufacturer number: 0233
     Test stand number: 1784
Flash Status
     Programming Attempts(data): 3/3/3/0
     Successful Attempts(data): 3/3/3/3
     Flash Tool Code(data): 00200 785 02391
Misc.
     Hardware number: 4G5 035 223
     Workshop System Name: J525
     Equipment/PR Code: 00000000000000000000000B
     Dataset Number: 4G1909510L
     Dataset Version: 0011
     ASAM Dataset: EV_AMPMst16C4Gen2BOSE
     ASAM Dataset Revision: 001001
Car Info
     Chassis Number: WUAZZZ4G3GN
VCDS Info:
       Labels: None
       ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
Tuesday,03,December,2019,20:29:12:57784
VCDS Version: Release 19.6.2 (x64) Running on Windows 10 x64
LeVWFreaks.eu
                Address 47: Sound System       Labels: None
Control Module Part Number: 4G5 035 223 E    HW: 4G5 035 223
            Work Shop Code: WSC 02391 785 00200
              ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001 (AU57)
