Tuesday,03,December,2019,20:28:30:57784
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 19.6.2.0 (x64) HEX-V2 : 0.4513.4
Dealer/Shop Name: LeVWFreaks.eu
VIN: WUAZZZ4G3GN License Plate:
Mileage: 40878km-25400mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 1B 22 28 36 3B 3C 42
44 46 52 53 55 5F 62 65 6C 6D 72 82 84 85 8B 8E 8F 90 BA
VIN: WUAZZZ4G3GN Mileage: 40878km-25400miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
Address 01: Engine (------CWUB) Labels: Redir Fail!
Part No SW: 4G0 906 560 F HW: 4H0 906 014
Component: V8 4.0l TFSI H63 0005
Revision: NCH63---
Coding: 122A00326546090B3000
Shop #: 57251 003 1048576
Dataset: EV_ECM40TFS0114G0906560F 001006
ROD: EV_ECM40TFS0114G0906560F.rod
VCID: 2B000D0F638B2BDF4C5-807E
5270 - Output for Starter Relay
P0615 00 [032] - Open Circuit
Mileage: 40609 km
Date: 2019.12.01
Time: 11:12:28
Engine speed: 664.00 /min
Normed load value: 7.1 %
Coolant temperature: 56 °C
Intake air temperature: 16 °C
Voltage terminal 30: 14.347 V
Unlearning counter according OBD: 26
Engine status: COENG_RUNNING
Part No SW: 4G0 927 158 AN HW: 0BK 927 156 AM
Component: 0BK 40TFSIRdW H19 1002
Revision: --H19---
Shop #: 00000 000 00000
Dataset: EV_TCMAL551211 002022
VCID: 7AAEF84BDC514257873-802E
Address 03: Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 T HW: 4G0 907 379 T
Component: ESP9 Premium H01 0100
Coding: 64BF994926FD99929F00
Shop #: 02391 785 00200
Dataset: EV_ESP9BOSCHAU57X 004018
ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
VCID: 42DE40ABF401CA979F3-8016
Address 05: /Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 GP HW: 4H0 907 064 GP
Component: BCM2 2.0 H37 0572
Coding: 05A96F0E000000000000
VCID: 7DA4F357CDFF756FA21-8028
Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
Coding: 680210B8150000
Dataset: EV_AirCondiComfoUDS 003008
VCID: 6A8EC80BACF1F2D7773-803E
Part No SW: 4H0 907 063 EK HW: 4H0 907 063 EK
Component: BCM1 2.0 H20 0367
Revision: 25020001 Serial number:
Coding: 0105001440349FF2F90140C7A0001800CF9CC7082E08020180000894E101130200400019010000
VCID: 75B4EB77F5CF2D2FEA1-8020
Component: WWS57X 151018 H38 0080
Coding: 0045F7
Component: G397_RLFS H06 0004
Coding: 0200FD
Subsystem 3 - Part No SW: 4G0 941 531 BH HW: 4G0 941 531 BH
Component: E1 - H07 0044
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Address 10: Park/Steer Assist (J791) Labels:| 4H0-919-475-7X5.clb
Part No SW: 4G0 919 475 H HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0080
Coding: B82B27
Dataset: EV_EPHVA2CAU64X0000 001014
ROD: EV_EPHVA2CAU64X0000.rod
VCID: 36362C7BA8C9663723B-8062
Component: ACC3 H21 0055
Coding: 7E04010102
Dataset: EV_AdaptCruisContrAU57X 002015
VCID: 290CF707697739CFBE9-807C
Address 14: Susp. Elect. Labels: None
Part No SW: 4G0 907 376 HW: 4G0 907 376 A
Component: J250 DRC FahrwerH02 0040
Revision: 00000000 Serial number:
Coding: 0000000
VCID: 6B80CD0FAF8BEBDF0C5-803E
Coding: 30333130313730323630554A304C34473053
Dataset: EV_AirbaAU10BPAAU64X 001014
VCID: 3B203D4F93EBBB5FDC5-806E
Serial number: /
Serial number: .
Coding: 0000FD
VCID: 3728217FAF439F3F38D-8062
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Part No SW: 4G0 920 931 M HW: 4G0 920 931 M
Component: TBenRdwAccNv H11 0106
Revision: 08001098 Serial number:
Coding: 138F110BAFD50008000400
Dataset: EV_RBD4K 004055
ROD: EV_RBD4K_AU57.rod
VCID: 303A1A634AAD4807797-8064
Part No SW: 4G8 907 468 F HW: 4G8 907 468
Component: J533--Gateway H14 0083
Coding: C0ED07481C
Dataset: EV_GatewPkoUDS 001028
Voltage stabilizer:
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
Component: DYNAMIKLENK. H06 0740
Revision: 52001005 Serial number: --------------
Coding: 010100
VCID: 3A2E384B9C518257C73-806E
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H17 0200
Dataset: EV_AllWheelDiffeQSPFR 003026
VCID: 280AF203727D00C7A17-807C
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0112
Coding: 20
Dataset: EV_ClimaContrUnitRearUDS 003004
VCID: 3E26345B80F9AE77FBB-806A
Component: MEM-FS H03 0157
Revision: AA000000 Serial number:
VCID: 77A8E17FEFC35F3FF8D-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3728217FAFC39F3F38D-8062
Component: Master H08 0060
Coding: 040311
Dataset: EV_LaneChangAssis 001028
VCID: 392C274799D7894FCE9-806C
Lane Change Assistant 2:
Component: Slave H08 0060
Coding: 040311
Component: FA H04 0511
Coding: 011F16015E00628002080013
VCID: 45D45BB7E5AFFDAFBA1-8010
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H53 0202
Revision: 00000003 Serial number:
Coding: 011101010001
Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2E384B9CD18257C73-806E
Revision: 00002001 Serial number:
Coding: 013A0E20A0B93081C33009840C0312470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 A
Component: Sensor, DWA 005 0002
Component: BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
Subsystem 4 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: BF H03 0511
Coding: 011F16015E00628002080002
VCID: 46D65CBBD8A9F6B7B3B-8012
Component: -4 H04 0015
Dataset: EV_ParkiBrake 001028
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D0403175D9F25EF521-8078
Component: - 001 0100
Coding: 04FA0A202A1F0200
Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
VCID: 34321673BEB574271DF-8060
Coding: E01F00
Coding: E01F00
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo li. H03 0031
Coding: E01F00
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: LeiMo re. H03 0031
Coding: E01F00
Part No SW: 4G1 035 021 N HW: 4G1 035 021 D
Component: MU-H-LND-EU 051 1425
Coding: 017562010000000013111102000A00132F0008E5F17001009F
Dataset: EV_MUHig6C3Gen2HBAS 001115
VCID: 2514FB37056F1DAF9A1-8070
Subsystem 1 - Part No SW: V03 959 802 DD HW: -----------
Component: ECE 2018/2019 --- 0169
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Multimedia Operating Unit:
Compact Disc Database:
Component: Gracenote2 --- 1017
B2000 87 [009] - Missing message
Reset counter: 137
Mileage: 40878 km
Date: 2019.12.03
Time: 20:26:17
Voltage terminal 30: 14.9 V
Software module: status-SW_Status_Consistency: 00 28 13
Software module: status-SW_Status_Device: Mmx2Mmx2Mmx2M
Component: HL H03 0511
Coding: 010F14014000628002080002
VCID: 49CC5787C9B719CF5E9-801C
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 B HW: 4H0 907 273 B
Component: RDKBERU25 H10 0820
Dataset: EV_RDKBERU25 003014
ROD: EV_RDKBERU25_AU57.rod
VCID: 2A0E080B6C7132D7B73-807E
Address 6C: Back-up Cam. (J772) Labels:| 4S0-980-556.clb
Part No SW: 4S0 980 556 HW: 4M0 980 556
Component: RVC Compact H08 0140
Coding: 027500010A002003000040
Dataset: EV_CamSysRVRVCPANAAU57X 001001
ROD: EV_CamSysRVRVCPANAAU57X_001_AU57.rod
VCID: 78AAE243E25D5047F17-802C
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0151
Revision: 14005001 Serial number:
Coding: 093205C030
Dataset: EV_HDSGAu572 001022
ROD: EV_HDSGAu571.rod
Component: HR H03 0511
Address 82: Heads Up Display (J898) Labels:| 4G0-919-604.clb
Part No SW: 4G0 919 604 M HW: 4G0 919 604 M
Component: HeadUpDisplay H08 0306
Coding: D70000
Dataset: EV_HUDContiC7 001027
ROD: EV_HUDContiC7.rod
VCID: 35342B77B5CF6D2F2A1-8060
Address 84: Night Vision (J853) Labels:* None
Part No SW: 4G0 907 547 A HW: 4G0 907 547
Component: NV--Gen3 H08 0107
Coding: 301100
Dataset: EV_NightVisioGen3AE4AU64X 001001
ROD: EV_NightVisioGen3AE4AU64X.rod
VCID: 2C020E1366852CE745F-8078
Camera For Night Vision System:
Subsystem 1 - Part No SW: 4G0 980 552 HW: 4G0 980 552
Component: NV-CAM-Gen3 H03 0006
Component: DPC-SG H27 0081
Coding: 6A160000
Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
Coding: 7E04010102
Dataset: EV_AdaptCruisContr2AU57X 002013
VCID: 2708F13F7F630FBFA8D-8072
Component: BV-SG H33 0090
Coding: 04C0BB1B1111
Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Component: RGS-VL H14 0080
Coding: 0066E608031F0376070308014240C0010000
Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313C1F6741A7410F769-8064
Component: RGS-VR H14 0080
Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323E106B44A17A170F3-8066
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H10 0008
Revision: 00001001 Serial number:
Dataset: EV_AEMLearAU64X 002016
ROD: EV_AEMLearAU64X_AU57.rod
End----------(Elapsed Time: 02:39, VBatt start/end: 14.7V/14.7V)-----------
