Tuesday,31,July,2018,12:02:22:53577
VCDS Version: 18.2.1.5 (x64) HEX-V2 CB: 0.4411.4
VIN: WVWZZZ3CZHE064587 License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44 52
55 5F 6C A5 BB BC CF
VIN: WVWZZZ3CZHE064587 Mileage: 18494km-11491miles
Address 01: Engine (J623-CJXA) Labels:. 06K-907-425-V1.clb
Part No SW: 3G0 906 259 B HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00322466050B3004
Shop #: WSC 05311 115 00311
ASAM Dataset: EV_ECM20TFS0203G0906259B 001003
ROD: EV_ECM20TFS0203G0906259B.rod
VCID: 2B03FB49238824CFF46-807E
30258 - Exhaust Pressure Control Valve
P0475 00 [039] - Electrical Malfunction
Mileage: 18466 km
Date: 2018.07.31
Time: 10:47:32
Engine speed: 1531.75 /min
Normed load value: 34.5 %
Vehicle speed: 52 km/h
Coolant temperature: 104 °C
Intake air temperature: 39 °C
Voltage terminal 30: 14.199 V
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 1638 s
MAP_MES_SAE: 108 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.968 V
FAC_TPS_1_SAE: 62.500000 %
FUP_H_SAE: 14160.0 kPa
30259 - Exhaust Pressure Control Valve 2
P049F 00 [039] - Malfunction
Mileage: 18466 km
Date: 2018.07.31
Time: 10:47:32
STATE_LS_SAE[1]: CL
T_AST_SAE: 1638 s
14916 - Catalyst System; Bank 1
P0420 00 [039] - Efficiency Below Threshold
Mileage: 18450 km
Date: 2018.07.31
Time: 10:26:46
Engine speed: 1751.50 /min
Normed load value: 31.0 %
Vehicle speed: 46 km/h
Coolant temperature: 106 °C
Intake air temperature: 36 °C
Voltage terminal 30: 14.257 V
TEMP_CAT_UP_1_SAE: 577.3 °C
Cat. ageing: bank 1: actual: 1.813
LAMB_DELTA_I_LAM_ADJ[1]: 0.00000
Lambda probes actual: bank1: 1.0430
VLS_DOWN_SAE[1]: 0.175 V
T_AST_SAE: 392 s
Readiness: 0000 0001
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A TVS H54 4999
Revision: 06354004 Serial number: TFK01608060079
Shop #: WSC 05311 115 12345
ROD: EV_TCMDQ250021.rod
VCID: 53F383A95B785C0F9C6-8006
12 Faults Found:
21153 - Gear 1
P072C 00 [002] - Not Selectable
21154 - Gear 2
P072D 00 [002] - Not Selectable
21155 - Gear 3
P072E 00 [002] - Not Selectable
21156 - Gear 4
P072F 00 [002] - Not Selectable
21157 - Gear 5
P073A 00 [002] - Not Selectable
21158 - Gear 6
P073B 00 [002] - Not Selectable
21159 - Gear R
10732 - Valve 3 in Transmission Part 2
P174E 00 [002] - Electrical malfunction
10657 - RPM Signal from ECU
P0726 00 [002] - Implausible Signal
10909 - Cooling Oil Valve
10906 - Cooling Oil Valve
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 62366000003171
Coding: 0EEC938F54261B70477C070841CA6970C92AD8E2E0829675384250B8C2A902
Shop #: WSC 00015 115 08193
ROD: EV_Brake1UDSContiMK100IPB_035_VW27.rod
VCID: 7BA30B099368744F246-802E
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0415541556
Coding: 0F2000070F
Shop #: WSC 05311 000 00150
VCID: 3C21C815D6E6B3776DC-8068
Part No SW: 5G0 907 044 BP HW: 5G0 907 044 BP
Component: Climatronic H04 1601
Revision: 00001K10
Coding: 1112000420010001111550000010182A
ROD: EV_ACClimaBHBVW37X_006_VW27.rod
VCID: 76B51A3DA84A29275B8-8022
Air quality sensor:
Part No SW: 5Q0 937 086 BH HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 032 0222
Revision: -------- Serial number: 865806081601DO
ROD: EV_BCMBOSCH_017.rod
VCID: 015F79E1F1841E9F7EA-8054
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160723 043 0607
Serial number: 160730130427
Component: RLHS 042 0105
Serial number: S4Y16M08D30H05M30S21
Coding: 00A8DD
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 31 05 2016 10000617
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY162041D5B
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000066540919
589592 - Databus
U1201 00 [008] - No Communications
[CAN Keine Kommunikation]
Reset counter: 232
Mileage: 18249 km
Date: 2018.07.29
Time: 10:51:20
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 0
Mileage: 18240 km
Date: 2018.07.29
Time: 08:29:39
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183616238
Coding: 0371167851
Shop #: WSC 05311 115 00084
ASAM Dataset: EV_EPHVA2CAU3700000 009017
VCID: 0D4755D1BDDC4AFF0A2-8058
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0194
Coding: 320467D359FFC428949C8045
Shop #: WSC 00015 115 00001
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3431E035FEB67B37A5C-8060
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 14081641350236
ROD: EV_DRCONTITEMIC_VW27.rod
VCID: 3829D405E2DE9F57894-806C
Part No SW: 3Q0 959 655 BB HW: 3Q0 959 655 BB
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003STPFUCZTY
Coding: 98FCC0C0000000005C540000008800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F5BFF198770686F08E-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 508 16
Serial number: 3576U00000029C757C1K
Subsystem 2 - Part No SW: ----------- HW: 454 000 508 16
Serial number: 3586U000000620557C14
Subsystem 3 - Part No SW: ----------- HW: 454 800 608 16
Serial number: 3516R716F040C0000001
Subsystem 4 - Part No SW: ----------- HW: 454 800 608 16
Serial number: 3526R732A2D0C0000006
Subsystem 5 - Part No SW: ----------- HW: 454 803 107 16
Serial number: 3556V42A1650B0000003
Part No SW: 3Q0 953 521 DA HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20160806501742
Coding: 0810
ROD: EV_SMLSVALEOMQB.rod
VCID: 72BD262DC4223507770-8026
Part No SW: 3G0 920 791 B HW: 3G0 920 791 B
Component: KOMBI 404 2153
Coding: 27A40018FF88000801886B0B1001000000000000
ROD: EV_DashBoardVDDMQBAB_VW48.rod
VCID: 28090445327E0FD7194-807C
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
Fault Frequency: 7
Reset counter: 239
Mileage: 18429 km
Date: 2018.07.31
Time: 07:32:41
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 26081610520303
Coding: 030300347F085900FB00025A9C0F00010001070000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: 7CA10815966673772DC-8028
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160001656180096344
Coding: 2DFFFF
Serial number: 75410803001608302422
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Serial number: HA1-00001.08.16
Coding: 0301
VCID: 4ACD9ECD8C321DC7EF0-801E
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBB H05 0032
Serial number: 16000193219014
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BF2921C1240E1F8EA-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 3Q0 959 760 B HW: 3Q0 959 760 B
Component: Sitzmemory H05 0020
Serial number: Y0006PHP14224
Coding: 0014000000000500818280808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002021
VCID: 3A2DCE0DDCD28D477F0-806E
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 C HW: 3Q0 907 566
Component: MRR1Rear H16 0310
Revision: --------
Coding: 44C002
Component: TSG FS 020 0041
Serial number: 051116EK416027
Coding: 003F1A20D201020000000000
VCID: 43D3B3E9AB18CC8F2C6-8016
65593 - Switch for Central Locking
B122D 29 [008] - Signal Implausible
Reset counter: 231
Mileage: 1048574 km
Time: 00:00:00
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9307
Shop #: WSC 00015 115 00311
ROD: EV_SteerAssisMQB_013.rod
Component: TSG BFS 020 0041
Serial number: 170616EFH03214
Coding: 003F1020DE01020200001000
VCID: 42DDB6EDB402C587270-8016
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0120
Coding: 03A603000F210200
Shop #: WSC 05311 000 08193
VCID: 3FDBBF19C7F0A86F48E-806A
Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0003
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0003
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
Part No SW: 3G0 035 045 C HW: 3G0 035 045
Component: MU-H-N-RW H51 0687
Serial number: A688E0G7503256
Coding: 02840108FF00000051510001000808001F0106E601200002DF
VCID: 1E65229D603AC167638-804A
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL03A0P
Subsystem 2 - Part No SW: V03 959 801 EB HW: -----------
Component: ROW 2016/2017 --- 0058
Component: Gracenote2--- --- 4009
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H09 0170
Coding: 0184010162002017000040
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
VCID: 77AB1739AF40502F40E-8022
Part No SW: 3Q0 980 654 F HW: 3Q0 980 654
Component: MQB_B_MFK H06 0220
Serial number: 29081611P12051
Coding: 000408010000010100022346C050410084000E300000
ROD: EV_MFKBoschMQBB_VW27.rod
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 120816DH704787
Coding: 000E10200101020000000000
VCID: 45D7ADF1A52CF2BF022-8010
Component: TSG HBFS 020 0041
Serial number: 120816DH70478A
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 C HW: 3Q0 907 590
Revision: --------
Coding: 44C002
VCID: 3537DD31F5CC623F922-8060
End----------(Elapsed Time: 02:43, VBatt start/end: 13.9V/13.9V)-----------
