- Joined
- Apr 17, 2015
- Messages
- 279
- Reaction score
- 88
- Location
- South Africa
- VCDS Serial number
- C?ID=133909
Panelbeaters replaced Zenon headlight with standard halogen lights. Zenon too expensive!
The headlights work, Is there some coding I can change?
Tuesday,26,June,2018,13:31:28:48706
VCDS Version: 18.2.1.2 (x64) HEX-NET CB: 0.4411.4
Dealer/Shop Name: RyMar Auto
Workshop Code: 000 00000 001753
VIN: WVWZZZ1KZBW066521 License Plate: FOSMAN GP
Mileage: 182080km-113139mi Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZBW066521 Mileage: 182080km-113139miles
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 5K0 907 115 HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0040
Revision: AAH18--- Serial number:
Coding: 0403000C18070160
VCID: 679E5E7156D3967C86-8032
Readiness: 1110 0101
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 163B600D09280000681006E6901A0081310800
VCID: 044469FD87A55D6403-8050
Part No SW: 5K0 907 044 BT HW: 5K0 907 044 BT
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000001002
VCID: 7EB01B15E14937B455-802A
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AD
Coding: 48180A3A8025F1C0408800843400092441550088736D8D60648000200040
VCID: 383CCD0D8BEDC984DF-806C
Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 12081 26 0512
Coding: 009795
Component: RLS 070810 05 54 0403
Coding: 0330AD
Subsystem 4 - Part No: 1K8 951 605 A
Component: LIN BACKUP HO H11 9004
Reset counter: 68
Mileage: 182089 km
Date: 2012.11.16
Time: 23:09:32
Voltage: 11.40 V
Term 50 Off
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKRAB46U/
Coding: 00003135
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B36D201B2DBE29C32-806E
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME2B4A7055ZZZ.
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME4D201656ZZZV
Serial number: 3512QSME184C603EZZZ$
Serial number: 3522QSME1824691FZZZ
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90422JH5000ND
Coding: 1082140000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 72A83F25A51163D421-8026
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Serial number: 0006798
Coding: 820000
Part No SW: 5K6 920 871 HW: 5K6 920 871
Component: KOMBI H04 0406
Coding: 170F00
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 71AA3029A01758CCD8-8024
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 5603
Revision: H27 Serial number: 020810F1000015
Coding: E9817F0600020200000003
VCID: 6D922C59742FBC2CFC-8038
Component: IMMO H04 0406
VCID: 6A9827458DC1AB1499-803E
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2152
Coding: 0000692
VCID: 3326FA21528B2ADCEA-8066
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
VCID: 312AF029A89718CC98-8064
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Component: Tuer-SG 009 2120
Coding: 0000692
VCID: 3228FF25AD9123D4E1-8066
Component: AFS-Steuergeraet 0142
Coding: 1443164
VCID: 3424F93D57852DE4F3-8060
Subsystem 1 - Part No: ID-L fehlt Labels: ID-55-01.CLB
Component: AFS-Lst.-Modul l ....
Coding: 00000255
Subsystem 2 - Part No: ID-R fehlt Labels: ID-55-02.CLB
Component: AFS-Lst.-Modul r ....
Coding: 00000255
6 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
Fault Status: 11100100
Reset counter: 68
Mileage: 182089 km
Date: 2012.11.16
Time: 23:08:33
Voltage: 11.22 V
ABS 1
Reset counter: 68
Mileage: 182089 km
Date: 2012.11.16
Time: 23:08:33
Voltage: 11.22 V
ABS 1
000 - - - MIL ON
Fault Status: 11100000
Reset counter: 68
Invalid
Invalid
Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
000 - - - MIL ON
Reset counter: 68
Invalid
Invalid
Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
000 - - - MIL ON
Reset counter: 68
Invalid
Invalid
Invalid
Fault Status: 11100101
Reset counter: 68
Invalid
Invalid
Invalid
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2K8262995
Coding: 0500040004
VCID: 658254796CDF846CB4-8030
03138 - Input AUX IN
Reset counter: 68
Mileage: 182089 km
Date: 2012.11.16
Time: 23:08:54
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: 3522C4395CFF34ECC4-8060
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0000144
VCID: 3620C33541F93FF4CD-8062
End----(Elapsed Time: 01:08, VBatt start/end: 11.4V/11.3V. VIgn 11.3V)-----
