Golf 6 replaced h/lights from Xenon to standard
RyMar
South Africa
C?ID=133909
Panelbeaters replaced Zenon headlight with standard halogen lights. Zenon too expensive!
The headlights work, Is there some coding I can change?
Tuesday,26,June,2018,13:31:28:48706
VCDS Version: 18.2.1.2 (x64)  HEX-NET CB: 0.4411.4
Dealer/Shop Name: RyMar Auto
Workshop Code: 000 00000 001753
VIN: WVWZZZ1KZBW066521   License Plate: FOSMAN GP
Mileage: 182080km-113139mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZBW066521   Mileage: 182080km-113139miles
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0040
   Revision: AAH18---    Serial number:
   Coding: 0403000C18070160
   VCID: 679E5E7156D3967C86-8032
Readiness: 1110 0101
   Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 163B600D09280000681006E6901A0081310800
   VCID: 044469FD87A55D6403-8050
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000001002
   VCID: 7EB01B15E14937B455-802A
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 48180A3A8025F1C0408800843400092441550088736D8D60648000200040
   VCID: 383CCD0D8BEDC984DF-806C
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 12081  26  0512
   Coding: 009795
   Component: RLS 070810 05  54  0403
   Coding: 0330AD
   Component: LIN BACKUP HO  H11 9004
            000 -  -
                    Reset counter: 68
                    Mileage: 182089 km
                    Date: 2012.11.16
                    Time: 23:09:32
                    Voltage: 11.40 V
                        Term 50 Off
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRAB46U/
   Coding: 00003135
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3B36D201B2DBE29C32-806E
   Serial number: 3572MSME2B4A7055ZZZ.
   Serial number: 3582MSME4D201656ZZZV
   Serial number: 3512QSME184C603EZZZ$
   Serial number: 3522QSME1824691FZZZ
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90422JH5000ND
   Coding: 1082140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 72A83F25A51163D421-8026
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0006798
   Coding: 820000
   Part No SW: 5K6 920 871     HW: 5K6 920 871
   Component: KOMBI         H04 0406
   Coding: 170F00
   VCID: 71AA3029A01758CCD8-8024
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 020810F1000015
   Coding: E9817F0600020200000003
   VCID: 6D922C59742FBC2CFC-8038
   Component: IMMO          H04 0406
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A9827458DC1AB1499-803E
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2152
   Coding: 0000692
   VCID: 3326FA21528B2ADCEA-8066
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   VCID: 312AF029A89718CC98-8064
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Component: Tuer-SG         009 2120
   Coding: 0000692
   VCID: 3228FF25AD9123D4E1-8066
   Component: AFS-Steuergeraet    0142
   Coding: 1443164
   VCID: 3424F93D57852DE4F3-8060
   Subsystem 1 - Part No: ID-L fehlt    Labels: ID-55-01.CLB
   Component: AFS-Lst.-Modul l    ....
   Coding: 00000255
   Subsystem 2 - Part No: ID-R fehlt    Labels: ID-55-02.CLB
   Component: AFS-Lst.-Modul r    ....
   Coding: 00000255
02233 - Left Headlight Power Output Stage (J667)
                    Fault Status: 11100100
                    Reset counter: 68
                    Mileage: 182089 km
                    Date: 2012.11.16
                    Time: 23:08:33
                    Voltage: 11.22 V
                        ABS 1
02234 - Right Headlight Power Output Stage (J668)
                    Reset counter: 68
                    Mileage: 182089 km
                    Date: 2012.11.16
                    Time: 23:08:33
                    Voltage: 11.22 V
                        ABS 1
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 68
                        Invalid
                        Invalid
                        Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 -  -  - MIL ON
                    Reset counter: 68
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 -  -  - MIL ON
                    Reset counter: 68
                        Invalid
                        Invalid
                        Invalid
                    Fault Status: 11100101
                    Reset counter: 68
                        Invalid
                        Invalid
                        Invalid
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2K8262995
   Coding: 0500040004
   VCID: 658254796CDF846CB4-8030
03138 - Input AUX IN
                    Reset counter: 68
                    Mileage: 182089 km
                    Date: 2012.11.16
                    Time: 23:08:54
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 3522C4395CFF34ECC4-8060
   Coding: 0000144
   VCID: 3620C33541F93FF4CD-8062
End----(Elapsed Time: 01:08, VBatt start/end: 11.4V/11.3V. VIgn 11.3V)-----
Start by disconnecting the 55-Headlight range module and remove it from the Gateway's Installation List. The clear all the fault codes and post a new scan.
I would suppose there will also be coding changes needed in 09. Unfortunately, your Byte 18 is '00' so it's not going to be straightforward.
RyMar
South Africa
C?ID=133909
Disconnected headlight range control and removed from Gateway installation list, no fault codes logged.
Wednesday,27,June,2018,10:13:40:48706
VCDS Version: 18.2.0.3 (x64)  HEX-NET CB: 0.4411.4
Dealer/Shop Name: RYMAR AUTO
VIN: WVWZZZ1KZBW066521   License Plate: FORSMAN HARRY
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
   VCID: 679E5E7156D3967CB9-8032
   Revision: 00H30001
   VCID: 044469FD87A55D643C-8050
   Revision: 00003001
   Coding: 0000001002
   VCID: 7EB01B15E14937B46A-802A
   Revision: 00103 AD
   VCID: 383CCD0D8BEDC984E0-806C
   Coding: 009795
   Coding: 0330AD
   Coding: 00003135
   VCID: 3B36D201B2DBE29C0D-806E
   Coding: 1082140000
   VCID: 72A83F25A51163D41E-8026
   Coding: 820000
   Coding: 170F00
   VCID: 71AA3029A01758CCE7-8024
   Coding: E9807F0600020200000003
   VCID: 6D922C59742FBC2CC3-8038
   VCID: 6A9827458DC1AB14A6-803E
   Coding: 0000692
   VCID: 3326FA21528B2ADCD5-8066
   Revision: 00H17000
   VCID: 312AF029A89718CCA7-8064
   Coding: 0000692
   VCID: 3228FF25AD9123D4DE-8066
   Coding: 0500040004
   VCID: 658254796CDF846C8B-8030
                    Reset counter: 68
                    Mileage: 182089 km
                    Date: 2012.11.16
                    Time: 23:08:54
   Coding: 0000144
   VCID: 3522C4395CFF34ECFB-8060
   Coding: 0000144
   VCID: 3620C33541F93FF4F2-8062
End----------(Elapsed Time: 01:04, VBatt start/end: 14.0V/14.1V)-----------
iichel
Eindhoven, NB, NL
C?ID=284912
How is the lighting now? Does everything work as it should?
PS, it's xenon, not Zenon :-)
RyMar
South Africa
C?ID=133909
Everything works as it should with no warning lights coming on. The wiring of the headlight connector was modified from aftermarket connector to OE to fit the OE connector engine side.
iichel
Eindhoven, NB, NL
C?ID=284912
Excellent, good job!
