hd7993
- Joined
- Apr 29, 2018
- Messages
- 25
- Reaction score
- 3
- Location
- Norway
- VCDS Serial number
- 7F23E21B2EBEC9BEF3-802A
steering column/imobilizer
Hello. still waithing for my account to get verified, so tought i give it a go here..
I got a problem with my Passat lately, and it seems this is/was a rather common problem?
It happend usually when the engine/car is warm. when try start the car it dies after like a sec and there is a beep and a message "steering column defective"
so need to try a few times and it will eventually start as normal.
Today it behaved a little diferent, as it started normal, and did not stop, but there was a beep and a message about steering column.. stopped the car with the key and started it again and all was normal, except the radio was dead.. it was also not possible to run diagnostic on it.. after disconect battery for a few minutes, it was back to normal with working radio and no message in display.. then also possible to run diagnostic.
The fault code is
02823 - Requirements for Locking the Steering Column Lock not met 000 - - - Intermittent
02861 - Electronic Steering Column Lock Check Sum Error 008 - Implausible Signal - Intermitten
02818 - Steering Column Lock; Enabling for Electronic Ignition Lock 009 - Open or Short to Ground - Intermittent
02811 - Control Module for Electronic Steering Column Lock (J764) 014 - Defective - Intermittent
So what better do first? i saw a while ago there is some repair kit on ebay with some relays and switches.. is this smth might work?
or change complete control module 764? whole steering column..? can i install used parts?
other "fix" who would work? take it to a dealer is out of the question for the moment..
thx
The fault code is
thx
