Hi Everyone,
I'm from Germany, sorry for my not perfect english![Smile :) :)](/images/smilies/smile.png)
I have a problem with with this Audi A6 4G from 2011. After a litte crash we had to chance one headlight. I ordered a new headlight with used "control units".
I replaced this units:
AFS-Leistungsmodul / Power Module - 4H0 941 329
Tagfahrlicht / Day running light LTM-LL-TFL control unit 28297178/4G0.907.397.D
Xenon light Vorschaltgerät/ ballast 8K0941597 C
Now i wanted to recode my control unit "55" but I noticed, that it is now uncoded and I found this information:
http://wiki.ross-tech.com/wiki/index.php/Audi_A6_(4G/4H)_Advanced_Front_System
Coding is lost when the Subsystem/Slave Headlights are unplugged so it is necessary to save the complete Auto-Scan prior to repairs. If the original coding is unknown registered users can contact us directly on a case by case basis.
The problem is, there is no Auto-Scan before the headlight swap.
I was trying following codings for it:
11219E33101AE300
and
112196100002A300
But every time i will get an error message "Coding not accepted. Error 31: value range ivalid".
Now I started to search in this forum for A6 4G (non facelift) Autoscans to get some other codings for Adress 55.
I already found this (but I did not try all of them):
UK 2013:
112196101000A300
2012:
11226F601002A300
2012:
1221A6601002A400
2014:
112296101002A300
UK 2014:
112196101002A300
2014:
112196101002A300
2014:
1221A6101002A500
Here is the Auto-Scan (Sorry it is in german):
Translated (area of interest):
11219E33101AE300
and
112196100002A300
UK 2013:
112196101000A300
2012:
11226F601002A300
2012:
1221A6601002A400
2014:
112296101002A300
UK 2014:
112196101002A300
2014:
112196101002A300
2014:
1221A6101002A500
Dienstag,27,Februar,2018,13:35:27:04057
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x86
VCDS Version: PCI 17.8.1.0 HEX-V2 CB: 0.4409.4
Datenstand: 20180112 DS276.7
www.VCDSpro.de
Händler-/Werkstattname: CarCodingBremen
Fahrzeug-Ident.-Nr.: WAUZZZ4G1CN061645 KFZ-Kennzeichen:
Kilometerstand: 133616km Reparaturauftrag:
Fahrzeugtyp: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 28 36 3B 42 44 46 52 53
55 56 5F 62 6C 72 85 8F 90
Fahrzeug-Ident.-Nr.: WAUZZZ4G1CN061645 Kilometerstand: 133616km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: Fehler 0010
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: Fehler 0010
10-Einparkhilfe 2 -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
18-Standheizung -- Status: Fehler 0010
19-Diagnoseinterface -- Status: i.O. 0000
28-Heizung/Klima hi. -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
3B-Sensorelektronik -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: Fehler 0010
53-Feststellbremse -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: Fehler 0010
56-Radio -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
62-Türelektr. hi. li. -- Status: i.O. 0000
6C-Rückfahrkamera -- Status: i.O. 0000
72-Türelektr. hi. re. -- Status: i.O. 0000
85-Kamerasteuergerät -- Status: i.O. 0000
8F-Gurtstraffer links -- Status: i.O. 0000
90-Gurtstraffer rechts -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CGLC) Labeldatei:. DRV\03L-906-018-CGL.clb
Teilenummer SW: 03L 906 018 LB HW: 03L 906 018 JL
Bauteil: R4 2.0l TDI H25 9978
Revision: 45H25---
Codierung: 0A03401A232401080000
Betriebsnr.: WSC 15650 002 1048576
ASAM Datensatz: EV_ECM20TDI01103L906018LB 003012
ROD: EV_ECM20TDI01103L906018LB.rod
VCID: 75B616CAC541CB3F797-8020
Adresse 02: Getriebe (J217) Labeldatei:| DRV\0AW-927-156.clb
Teilenummer SW: 4G0 927 155 T HW: 0AW 927 156 K
Bauteil: 0AW 20TDI RdW H04 0005
Revision: --H04--- Seriennummer: 0000001383
Codierung: 000001
Betriebsnr.: WSC 02311 785 00200
ASAM Datensatz: EV_TCMVL381 A02430
ROD: EV_TCMVL381.rod
VCID: 3C20C3EEA6EB5A77469-8068
Adresse 03: Bremsenelektronik (J104) Labeldatei:. 4G0-907-379-V1.clb
Teilenummer SW: 4G0 907 379 F HW: 4G0 907 379 F
Bauteil: ESP PREMIUM H09 0250
Revision: -------- Seriennummer: --------------
Codierung: 06A187016085E180DB00
Betriebsnr.: WSC 02391 785 00200
ASAM Datensatz: EV_ESPPremiAU57X 004017
VCID: 3430EBCE8EBB92378E9-8060
2 Fehlercodes gefunden:
0782 - Funktionseinschränkung wegen unplausibler Botschaft
U1112 00 [009] - -
bestätigt - geprüft seit letzter Löschung
Umgebungsbedingungen:
Fehlerstatus: 00000001
Fehlerpriorität: 2
Fehlerhäufigkeit: 19
Verlernzähler: 213
Kilometerstand: 133376 km
Datum: 2018.02.20
Zeit: 08:36:16
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: DD
Uz: 98
0784 - Funktionseinschränkung wegen unplausibler Botschaft
U1112 00 [009] - -
Fehlerpriorität: 2
Verlernzähler: 213
Datum: 2018.02.20
Zeit: 08:36:16
VzRef: 00
Bit Info 1: 00
Bit Info 2: 00
Bit Info 3: 22
Bit Info 4: 1F
F-Path: 00
F-Type: DF
Uz: 98
Adresse 05: Zugangs-/Startber. (J393) Labeldatei:. DRV\8K0-907-064-05.clb
Teilenummer SW: 4H0 907 064 DP HW: 4H0 907 064 BP
Bauteil: BCM2 2.0 H31 0510
Codierung: 01A83006000000000000
Betriebsnr.: WSC 37904 000 1048576
VCID: 7AAC05F6ECDFA447145-802E
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei:| DRV\4G0-820-043-4Z.clb
Teilenummer SW: 4G0 820 043 L HW: 4G0 820 043 L
Bauteil: KLIMA 4 ZONEN H11 0062
Seriennummer: 28091100040160
Codierung: 3411007AA4
ASAM Datensatz: EV_AirCondiComfoUDS 002033
VCID: 28080FBE4273E6D7321-807C
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\4H0-907-063-V1.clb
Teilenummer SW: 4H0 907 063 BF HW: 4H0 907 063 F
Bauteil: BCM1 2.0 H12 0100
Revision: 20012002 Seriennummer: 00000001231435
Codierung: 0200201050B49FE0C1810080800019080F9CC3082E080105000008402101
VCID: 6D863EAAAD9103FF817-8038
Subsystem 1 - Teilenummer SW: 4G1 955 119 HW: 4G8 955 119 Labeldatei: DRV\1KX-955-119.CLB
Bauteil: WWS57X 110908 H35 0051
Seriennummer: 110919133516
Codierung: 0045F7
Subsystem 2 - Teilenummer SW: 8K0 955 559 HW: 8K0 955 559 Labeldatei: DRV\8K0-955-559.CLB
Bauteil: RLS H04 0003
Seriennummer: 11694671
Codierung: 02512B
Subsystem 3 - Teilenummer SW: 4G0 941 531 E HW: 4G0 941 531 E
Bauteil: E1 - LDS H07 0044
Seriennummer: 03 10 2011 00000534
Subsystem 4 - Teilenummer SW: 8K0 959 772 C HW: 8K0 959 772
Bauteil: SLR-B8 H05 0006
Seriennummer: 0014209322
Codierung: 853000
Subsystem 5 - Teilenummer SW: 4H0 907 658 HW: 4H0 907 658
Bauteil: AQ_Hum_Sensor H02 0002
Seriennummer: 11184AC5000000000001
1 Fehler gefunden:
01771 - Steuergerät für Leuchtweitenregelung (J431)
013 - bitte Fehlerspeicher auslesen
Fehlerstatus: 01101101
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 208
Zeitangabe: 0
Datum: 2018.02.20
Zeit: 08:36:00
Adresse 10: Einparkhilfe 2 (J446) Labeldatei:| DRV\4H0-919-475-7X2.clb
Teilenummer SW: 4H0 919 475 L HW: 4H0 919 475 C
Bauteil: PARKHILFE ACC H07 0043
Revision: 11001001 Seriennummer: 55901127100042
Codierung: 280305
ASAM Datensatz: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
VCID: 3B22C0F2A3E55D4F4F3-806E
Adresse 15: Airbag (J234) Labeldatei:| DRV\4H0-959-655.clb
Teilenummer SW: 4H0 959 655 C HW: 4H0 959 655 C
Bauteil: Airbag10.43 H40 0040
Revision: -------- Seriennummer: 003JG0049UZU
Codierung: 30323436313230303035554A304C34473053
ASAM Datensatz: EV_AirbaAU10BPAAU64X 001014
VCID: 3634D1C698C78027B0D-8062
Crashsensor für Seitenairbag Fahrerseite:
Seriennummer: 3575HRB405L0Q3SKAO9A
Crashsensor für Seitenairbag Beifahrerseite:
Seriennummer: 3585HRB405T0OPMG48A8
Crashsensor für Seitenairbag hinten Fahrerseite:
Seriennummer: 3515JRB405F0NHDG39AE
Crashsensor für Seitenairbag hinten Beifahrerseite:
Seriennummer: 3525JRB404R0Q8K448EJ
Crashsensor für Frontairbag Fahrerseite:
Seriennummer: 3554VRB40610M5SO8PQK
Crashsensor für Frontairbag Beifahrerseite:
Seriennummer: 3564VRB40610M5SOK9I9
Adresse 16: Lenkradelektronik (J527) Labeldatei:. DRV\4H0-953-568.clb
Teilenummer SW: 4G0 953 568 A HW: 4G0 953 568 A
Bauteil: Lenks.Modul H05 0201
Revision: 00000000 Seriennummer: 20111001000103
Codierung: 000014
VCID: 3038E7DE7A23AE17EA1-8064
Subsystem 1 - Teilenummer SW: 4G0 951 528 D HW: 4G0 951 528 D
Bauteil: E221 - MFL H09 0009
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\4H0-920-xxx-17.clb
Teilenummer SW: 4G8 920 931 E HW: 4G8 920 931 E
Bauteil: TDieRdw H79 0375
Revision: 26181120 Seriennummer: 658270911591024
Codierung: 13A609000B010008000000
ASAM Datensatz: EV_RBD4K 004040
ROD: EV_RBD4K.rod
VCID: 3038E7DE7AA3AE17EA1-8064
Adresse 18: Standheizung (J364) Labeldatei:. DRV\8R0-265-105.clb
Teilenummer SW: 4H0 265 105 E HW: 4H0 265 105 E
Bauteil: Standheizung H24 0250
Revision: 66006006 Seriennummer: 20110817033904
Codierung: 5D3B00
VCID: 24101B8E3EDB02B71E9-8070
1 Fehler gefunden:
00446 - Funktionseinschränkung durch Unterspannung
002 - unterer Grenzwert unterschritten - Sporadisch
Fehlerstatus: 00100010
Fehlerpriorität: 7
Fehlerhäufigkeit: 1
Verlernzähler: 251
Kilometerstand: 133477 km
Zeitangabe: 0
Datum: 2018.02.22
Zeit: 05:44:07
Temperatur: 0.0°C
Temperatur: 3.0°C
Spannung: 11.60 V
Start
Anzahl: 124
Temperatur: -1.0°C
Drehzahl: 1021 /min
Nein
Adresse 19: Diagnoseinterface (J533) Labeldatei:* Keine
Teilenummer SW: 4G0 907 468 E HW: 4G0 907 468 A
Bauteil: J533--Gateway H08 0213
Revision: -------- Seriennummer: 00000000258034
Codierung: 00CD074400
ASAM Datensatz: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 323CEDD674AF9C079C5-8066
Steuergerät für Batterieüberwachung:
Subsystem 1 - Teilenummer SW: 8X0 915 181 HW: 8X0 915 181
Bauteil: J367-BDM H07 0140
Seriennummer: 00000000005650620668
Spannungsstabilisator:
Adresse 28: Heizung/Klima hi. (E265) Labeldatei:* DRV\4G0-919-158.clb
Teilenummer SW: 4G0 919 158 C HW: 4G0 919 158 C
Bauteil: KLIMA FOND H07 0062
Seriennummer: 27091100040143
Codierung: 01
ASAM Datensatz: EV_ClimaContrUnitRearUDS 002015
VCID: 2F3AE4A2679DB1EFF3B-807A
Adresse 36: Sitzverst. Fahr. (J136) Labeldatei: Keine
Teilenummer SW: 4G8 959 760 A HW: 4G8 959 760 A
Bauteil: MEM-FS H03 0154
Revision: AA000000 Seriennummer: 00000011950807
Codierung: C05813008F006001000001010101102030303232203232
VCID: 3828DFFE92537657A21-806C
Adresse 3B: Sensorelektronik (J849) Labeldatei: 4G0-907-637.clb
Teilenummer SW: 4G0 907 637 B HW: 4G0 907 637 B
Bauteil: SARA 6D H02 0004
Revision: -------- Seriennummer: EJ1BPA42024BCT0
Betriebsnr.: WSC 00000 000 00000
ASAM Datensatz: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D06FEAA6D91C3FFC17-8078
Adresse 42: Türelektr. Fahrer (J386) Labeldatei: Keine
Teilenummer SW: 4G8 959 793 E HW: 4G8 959 793 A
Bauteil: TSG FA H05 0212
Codierung: 011C16205E00628002080002
Betriebsnr.: WSC 02312 785 00200
VCID: 42DCBD16C48F2C870C5-8016
Adresse 44: Lenkhilfe (J500) Labeldatei:| DRV\4G0-909-144.clb
Teilenummer SW: 4G0 909 144 L HW: 4G0 909 144 G
Bauteil: RCEPS H35 0010
Revision: 00001000 Seriennummer: 0019172122
Codierung: 101000010000
ASAM Datensatz: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
Adresse 46: Komfortsystem (J393) Labeldatei:. DRV\4H0-907-064-46.clb
Revision: 00002001 Seriennummer: 0160123326
Codierung: 0100062000B9058083200804080100000000000000000000000000000000
Adresse 52: Türelektr. Beifahr. (J387) Labeldatei: Keine
Teilenummer SW: 4G8 959 792 E HW: 4G8 959 792 A
Bauteil: TSG BF H05 0212
VCID: 41DEB21AC189379F15F-8014
1 Fehler gefunden:
00920 - beheizbare Außenspiegel (Z4/Z5)
012 - elektrischer Fehler im Stromkreis
Fehlerstatus: 01101100
Fehlerpriorität: 3
Fehlerhäufigkeit: 1
Verlernzähler: 212
Kilometerstand: 133538 km
Zeitangabe: 0
Datum: 2018.02.23
Zeit: 05:46:00
Adresse 53: Feststellbremse (----) Labeldatei: DRV\4H0-907-801.clb
Teilenummer SW: 4H0 907 801 E HW: 4H0 907 801 A
Bauteil: EPB-4 H03 0012
Revision: -------- Seriennummer: 00000000148108
ASAM Datensatz: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_AU57.rod
VCID: 2A0CF5B65C7FD4C7245-807E
Adresse 55: Leuchtweitenreg. (J431) Labeldatei:| 4H4-907-357-V1.clb
Teilenummer SW: 4H4 907 357 A HW: 4H4 907 357 A
Bauteil: ....AFS13.... H01 0012
Seriennummer: 110927-0004-050
Codierung: 0000020000020000
ASAM Datensatz: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
Leistungsmodul für Scheinwerfer links:
H02 0008
Codierung: 1D0000
Leistungsmodul für Scheinwerfer rechts:
H02 0003
Codierung: 1A0000
3 Fehlercodes gefunden:
266752 - Steuergerät nicht codiert
U1013 00 [137] - -
Warnleuchte EIN - bestätigt - geprüft seit letzter Löschung
Fehlerpriorität: 2
Fehlerhäufigkeit: 1
Verlernzähler: 208
Datum: 2018.02.20
Zeit: 08:37:03
393989 - Scheinwerfer
C107E 54 [137] - keine Grundeinstellung
Fehlerpriorität: 2
Verlernzähler: 213
Datum: 2018.02.20
Zeit: 08:37:03
680704 - Leistungsmodul für Scheinwerfer rechts
C1082 F1 [137] - falsch codiert
Fehlerpriorität: 6
Fehlerhäufigkeit: 1
Verlernzähler: 208
Datum: 2018.02.20
Zeit: 08:37:03
Adresse 56: Radio (R) Labeldatei:. DRV\4F0-035-0xx-56.clb
Teilenummer SW: 4G0 035 056 J HW: 4G0 035 056
Bauteil: Radio U STD H52 0133
Revision: AB001007 Seriennummer: 051I00B7536884
Codierung: 010003020100000001
VCID: 28080FBE42F3E6D7321-807C
Adresse 5F: Informationselek. I (J794) Labeldatei:. DRV\4E0-035-6xx-5F.clb
Teilenummer SW: 4G0 035 666 J HW: 4G0 035 666
Bauteil: H-BN-EU H47 0798
Revision: -------- Seriennummer: 426I%0B7614863
Codierung: 050100000003A3EF45108B3E00000003E00101020000000000
VCID: 2F3AE4A2671DB1EFF3B-807A
Subsystem 1 - Teilenummer: 8R0 060 884 BK
Bauteil: EUR 2014 1703
Subsystem 2 - Teilenummer SW: 4G0 919 605 A HW: 4G0 919 605 A
Bauteil: DU8 C7 SV H42 0021
Seriennummer: AUZ8ZDB1301MGS+
Subsystem 3 - Teilenummer SW: 4G1 919 610 C HW: 4G1 919 610 A
Bauteil: E380 BDT C7 H08 0204
Seriennummer: 90349KIJ000GP
Subsystem 4 - Teilenummer: 8R0 060 961 B
Bauteil: CD-Database 3371
Adresse 62: Türelektr. hi. li. (J388) Labeldatei: Keine
Teilenummer SW: 4G8 959 795 E HW: 4G8 959 795 A
Bauteil: TSG HL H04 0212
Codierung: 010814204000628002080002
VCID: 44D0BB0EDE9B22B73E9-8010
Adresse 6C: Rückfahrkamera (J928) Labeldatei:* Keine
Teilenummer SW: 4H0 907 428 HW: 7P6 907 441 D
Bauteil: TopView H05 0090
Revision: 11001001 Seriennummer: 82330JF0010194
Codierung: 0200000001010100000102000000
ASAM Datensatz: EV_CamerSysteTopViewAUDI 003019
ROD: EV_CamerSysteTopViewAUDI_003.rod
VCID: 6A8C35B69CFF14C7E45-803E
Adresse 72: Türelektr. hi. re. (J389) Labeldatei: Keine
Bauteil: TSG HR H04 0212
Adresse 85: Kamerasteuergerät (J852) Labeldatei:* Keine
Teilenummer SW: 4G0 907 217 HW: 4H0 907 217 A
Bauteil: DPC-SG H24 0036
Revision: -------- Seriennummer: 262130025421000
Codierung: 64040000
ASAM Datensatz: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 6596468A75E13BBFC97-8030
Adresse 8F: Gurtstraffer links (J854) Labeldatei:. 4H0-980-94x-RGS.clb
Teilenummer SW: 4H0 980 945 B HW: 4H0 980 945 B
Bauteil: RGS-VL H13 0080
Codierung: 00060000031F030000030801424CDA010000
ASAM Datensatz: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313EE2DA71A9A71FE5F-8064
Adresse 90: Gurtstraffer rechts (J855) Labeldatei:. 4H0-980-94x-RGS.clb
Teilenummer SW: 4H0 980 946 B HW: 4H0 980 946 B
Bauteil: RGS-VR H13 0080
ASAM Datensatz: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Ende----------------------------(Dauer: 02:04)-----------------------------
Address 55: Headlight Reg. (J431) Label file: | 4H4-907-357-V1.clb
***Part Number SW: 4H4 907 357 A HW: 4H4 907 357 A
***Component: .... AFS13 .... H01 0012
***Serial number: 110927-0004-050
***Coding: 0000020000020000
***Operating No .: WSC 02391 785 00200
***ASAM record: EV_AdvanFrontSyste 005001
***ROD: EV_AdvanFrontSyste_AU21.rod
***VCID: 3038E7DE7AA3AE17EA1-8064
***Power module for headlight left:
H02 0008
***Coding: 1D0000
***Power module for headlight right:
H02 0003
***Coding: 1A0000
3 error codes found:
266752 - Control unit not coded
**********U1013 00 [137] - -
**********Warning light ON - confirmed - checked since last deletion
*************Environmental conditions:
********************Error status: 00000001
********************Error priority: 2
********************Error rate: 1
********************Lost counter: 208
********************Mileage: 133376 km
********************Date: 2018.02.20
********************Time: 08:37:03
393989 - headlights
**********C107E 54 [137] - no default setting
********************Error rate: 19
********************Lost counter: 213
680704 - Right headlight power module
**********C1082 F1 [137] - incorrectly coded
********************Error priority: 6
