Audi A6 4G 2011 - Uncoded Adress 55 - Headlight Range - After Headlight swap
take_me_sfz
C?ID=327281
Hi Everyone,
I'm from Germany, sorry for my not perfect english :)
I have a problem with with this Audi A6 4G from 2011. After a litte crash we had to chance one headlight. I ordered a new headlight with used "control units".
I replaced this units:
AFS-Leistungsmodul / Power Module - 4H0 941 329
Tagfahrlicht / Day running light LTM-LL-TFL control unit 28297178/4G0.907.397.D
Xenon light Vorschaltgerät/ ballast 8K0941597 C
Now i wanted to recode my control unit "55" but I noticed, that it is now uncoded and I found this information:
http://wiki.ross-tech.com/wiki/index.php/Audi_A6_(4G/4H)_Advanced_Front_System
Coding is lost when the Subsystem/Slave Headlights are unplugged so it is necessary to save the complete Auto-Scan prior to repairs. If the original coding is unknown registered users can contact us directly on a case by case basis.
The problem is, there is no Auto-Scan before the headlight swap.
I was trying following codings for it:
11219E33101AE300
and
112196100002A300
But every time i will get an error message "Coding not accepted. Error 31: value range ivalid".
Now I started to search in this forum for A6 4G (non facelift) Autoscans to get some other codings for Adress 55.
I already found this (but I did not try all of them):
UK 2013:
112196101000A300
2012:
11226F601002A300
2012:
1221A6601002A400
2014:
112296101002A300
UK 2014:
112196101002A300
2014:
112196101002A300
2014:
1221A6101002A500
Here is the Auto-Scan (Sorry it is in german):
Dienstag,27,Februar,2018,13:35:27:04057
VCDS -- Windows-basierter VAG/VAS-Emulator läuft auf Windows 10 x86
VCDS Version: PCI 17.8.1.0  HEX-V2 CB: 0.4409.4
Datenstand: 20180112 DS276.7
www.VCDSpro.de
Händler-/Werkstattname: CarCodingBremen
Fahrzeug-Ident.-Nr.: WAUZZZ4G1CN061645   KFZ-Kennzeichen:
Kilometerstand: 133616km   Reparaturauftrag:
Fahrzeugtyp: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 28 36 3B 42 44 46 52 53
          55 56 5F 62 6C 72 85 8F 90
Fahrzeug-Ident.-Nr.: WAUZZZ4G1CN061645   Kilometerstand: 133616km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: Fehler 0010
04-Lenkwinkelsensor -- Status: i.O. 0000
05-Zugangs-/Startber. -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: Fehler 0010
10-Einparkhilfe 2 -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
16-Lenkradelektronik -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
18-Standheizung -- Status: Fehler 0010
19-Diagnoseinterface -- Status: i.O. 0000
28-Heizung/Klima hi. -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
3B-Sensorelektronik -- Status: i.O. 0000
42-Türelektr. Fahrer -- Status: i.O. 0000
44-Lenkhilfe -- Status: i.O. 0000
46-Komfortsystem -- Status: i.O. 0000
52-Türelektr. Beifahr. -- Status: Fehler 0010
53-Feststellbremse -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: Fehler 0010
56-Radio -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
62-Türelektr. hi. li. -- Status: i.O. 0000
6C-Rückfahrkamera -- Status: i.O. 0000
72-Türelektr. hi. re. -- Status: i.O. 0000
85-Kamerasteuergerät -- Status: i.O. 0000
8F-Gurtstraffer links -- Status: i.O. 0000
90-Gurtstraffer rechts -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CGLC)       Labeldatei:. DRV\03L-906-018-CGL.clb
   Teilenummer SW: 03L 906 018 LB    HW: 03L 906 018 JL
   Bauteil: R4 2.0l TDI   H25 9978
   Revision: 45H25---
   Codierung: 0A03401A232401080000
   Betriebsnr.: WSC 15650 002 1048576
   ASAM Datensatz: EV_ECM20TDI01103L906018LB 003012
   ROD: EV_ECM20TDI01103L906018LB.rod
   VCID: 75B616CAC541CB3F797-8020
Kein(e) Fehlercode(s) gefunden.
Adresse 02: Getriebe (J217)       Labeldatei:| DRV\0AW-927-156.clb
   Teilenummer SW: 4G0 927 155 T    HW: 0AW 927 156 K
   Bauteil: 0AW 20TDI RdW H04 0005
   Revision: --H04---    Seriennummer: 0000001383
   Codierung: 000001
   Betriebsnr.: WSC 02311 785 00200
   ASAM Datensatz: EV_TCMVL381 A02430
   ROD: EV_TCMVL381.rod
   VCID: 3C20C3EEA6EB5A77469-8068
Adresse 03: Bremsenelektronik (J104)       Labeldatei:. 4G0-907-379-V1.clb
   Teilenummer SW: 4G0 907 379 F    HW: 4G0 907 379 F
   Bauteil: ESP PREMIUM   H09 0250
   Revision: --------    Seriennummer: --------------
   Codierung: 06A187016085E180DB00
   Betriebsnr.: WSC 02391 785 00200
   ASAM Datensatz: EV_ESPPremiAU57X 004017
   VCID: 3430EBCE8EBB92378E9-8060
2 Fehlercodes gefunden:
0782 - Funktionseinschränkung wegen unplausibler Botschaft
          U1112 00 [009] - -
          bestätigt - geprüft seit letzter Löschung
             Umgebungsbedingungen:
                    Fehlerstatus: 00000001
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 19
                    Verlernzähler: 213
                    Kilometerstand: 133376 km
                    Datum: 2018.02.20
                    Zeit: 08:36:16
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DD
                    Uz: 98
0784 - Funktionseinschränkung wegen unplausibler Botschaft
          U1112 00 [009] - -
                    Fehlerpriorität: 2
                    Verlernzähler: 213
                    Datum: 2018.02.20
                    Zeit: 08:36:16
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: DF
                    Uz: 98
Adresse 05: Zugangs-/Startber. (J393)       Labeldatei:. DRV\8K0-907-064-05.clb
   Teilenummer SW: 4H0 907 064 DP    HW: 4H0 907 064 BP
   Bauteil: BCM2 2.0      H31 0510
   Codierung: 01A83006000000000000
   Betriebsnr.: WSC 37904 000 1048576
   VCID: 7AAC05F6ECDFA447145-802E
Adresse 08: Klima-/Heizungsel. (J255)       Labeldatei:| DRV\4G0-820-043-4Z.clb
   Teilenummer SW: 4G0 820 043 L    HW: 4G0 820 043 L
   Bauteil: KLIMA 4 ZONEN H11 0062
   Seriennummer: 28091100040160
   Codierung: 3411007AA4
   ASAM Datensatz: EV_AirCondiComfoUDS 002033
   VCID: 28080FBE4273E6D7321-807C
Adresse 09: Zentralelektrik (J519)       Labeldatei:. DRV\4H0-907-063-V1.clb
   Teilenummer SW: 4H0 907 063 BF    HW: 4H0 907 063 F
   Bauteil: BCM1 2.0      H12 0100
   Revision: 20012002    Seriennummer: 00000001231435
   Codierung: 0200201050B49FE0C1810080800019080F9CC3082E080105000008402101
   VCID: 6D863EAAAD9103FF817-8038
   Subsystem 1 - Teilenummer SW: 4G1 955 119     HW: 4G8 955 119   Labeldatei: DRV\1KX-955-119.CLB
   Bauteil: WWS57X 110908  H35 0051
   Seriennummer:         110919133516
   Codierung: 0045F7
   Subsystem 2 - Teilenummer SW: 8K0 955 559     HW: 8K0 955 559   Labeldatei: DRV\8K0-955-559.CLB
   Bauteil: RLS  H04 0003
   Seriennummer: 11694671
   Codierung: 02512B
   Subsystem 3 - Teilenummer SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Bauteil: E1 - LDS  H07 0044
   Seriennummer: 03 10 2011  00000534
   Subsystem 4 - Teilenummer SW: 8K0 959 772 C    HW: 8K0 959 772
   Bauteil: SLR-B8  H05 0006
   Seriennummer:           0014209322
   Codierung: 853000
   Subsystem 5 - Teilenummer SW: 4H0 907 658     HW: 4H0 907 658
   Bauteil: AQ_Hum_Sensor  H02 0002
   Seriennummer: 11184AC5000000000001
1 Fehler gefunden:
01771 - Steuergerät für Leuchtweitenregelung (J431)
            013 - bitte Fehlerspeicher auslesen
                    Fehlerstatus: 01101101
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 208
                    Zeitangabe: 0
                    Datum: 2018.02.20
                    Zeit: 08:36:00
Adresse 10: Einparkhilfe 2 (J446)       Labeldatei:| DRV\4H0-919-475-7X2.clb
   Teilenummer SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Bauteil: PARKHILFE ACC H07 0043
   Revision: 11001001    Seriennummer: 55901127100042
   Codierung: 280305
   ASAM Datensatz: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   VCID: 3B22C0F2A3E55D4F4F3-806E
Adresse 15: Airbag (J234)       Labeldatei:| DRV\4H0-959-655.clb
   Teilenummer SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Bauteil: Airbag10.43   H40 0040
   Revision: --------    Seriennummer: 003JG0049UZU
   Codierung: 30323436313230303035554A304C34473053
   ASAM Datensatz: EV_AirbaAU10BPAAU64X 001014
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 3634D1C698C78027B0D-8062
   Crashsensor für Seitenairbag Fahrerseite:
   Seriennummer: 3575HRB405L0Q3SKAO9A
   Crashsensor für Seitenairbag Beifahrerseite:
   Seriennummer: 3585HRB405T0OPMG48A8
   Crashsensor für Seitenairbag hinten Fahrerseite:
   Seriennummer: 3515JRB405F0NHDG39AE
   Crashsensor für Seitenairbag hinten Beifahrerseite:
   Seriennummer: 3525JRB404R0Q8K448EJ
   Crashsensor für Frontairbag Fahrerseite:
   Seriennummer: 3554VRB40610M5SO8PQK
   Crashsensor für Frontairbag Beifahrerseite:
   Seriennummer: 3564VRB40610M5SOK9I9
Adresse 16: Lenkradelektronik (J527)       Labeldatei:. DRV\4H0-953-568.clb
   Teilenummer SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Bauteil: Lenks.Modul   H05 0201
   Revision: 00000000    Seriennummer: 20111001000103
   Codierung: 000014
   VCID: 3038E7DE7A23AE17EA1-8064
   Subsystem 1 - Teilenummer SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Bauteil: E221 - MFL  H09 0009
Adresse 17: Schalttafeleinsatz (J285)       Labeldatei:| DRV\4H0-920-xxx-17.clb
   Teilenummer SW: 4G8 920 931 E    HW: 4G8 920 931 E
   Bauteil: TDieRdw       H79 0375
   Revision: 26181120    Seriennummer: 658270911591024
   Codierung: 13A609000B010008000000
   ASAM Datensatz: EV_RBD4K 004040
   ROD: EV_RBD4K.rod
   VCID: 3038E7DE7AA3AE17EA1-8064
Adresse 18: Standheizung (J364)       Labeldatei:. DRV\8R0-265-105.clb
   Teilenummer SW: 4H0 265 105 E    HW: 4H0 265 105 E
   Bauteil: Standheizung  H24 0250
   Revision: 66006006    Seriennummer: 20110817033904
   Codierung: 5D3B00
   VCID: 24101B8E3EDB02B71E9-8070
1 Fehler gefunden:
00446 - Funktionseinschränkung durch Unterspannung
            002 - unterer Grenzwert unterschritten - Sporadisch
                    Fehlerstatus: 00100010
                    Fehlerpriorität: 7
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 251
                    Kilometerstand: 133477 km
                    Zeitangabe: 0
                    Datum: 2018.02.22
                    Zeit: 05:44:07
                    Temperatur: 0.0°C
                    Temperatur: 3.0°C
                    Spannung: 11.60 V
                        Start
                    Anzahl: 124
                    Temperatur: -1.0°C
                    Drehzahl: 1021 /min
                        Nein
Adresse 19: Diagnoseinterface (J533)       Labeldatei:* Keine
   Teilenummer SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Bauteil: J533--Gateway H08 0213
   Revision: --------    Seriennummer: 00000000258034
   Codierung: 00CD074400
   ASAM Datensatz: EV_GatewUDS 001025
   ROD: EV_GatewUDS_AU57.rod
   VCID: 323CEDD674AF9C079C5-8066
   Steuergerät für Batterieüberwachung:
   Subsystem 1 - Teilenummer SW: 8X0 915 181     HW: 8X0 915 181
   Bauteil: J367-BDM  H07 0140
   Seriennummer: 00000000005650620668
   Spannungsstabilisator:
Adresse 28: Heizung/Klima hi. (E265)       Labeldatei:* DRV\4G0-919-158.clb
   Teilenummer SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Bauteil: KLIMA FOND    H07 0062
   Seriennummer: 27091100040143
   Codierung: 01
   ASAM Datensatz: EV_ClimaContrUnitRearUDS 002015
   VCID: 2F3AE4A2679DB1EFF3B-807A
Adresse 36: Sitzverst. Fahr. (J136)       Labeldatei: Keine
   Teilenummer SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Bauteil: MEM-FS        H03 0154
   Revision: AA000000    Seriennummer: 00000011950807
   Codierung: C05813008F006001000001010101102030303232203232
   VCID: 3828DFFE92537657A21-806C
Adresse 3B: Sensorelektronik (J849)       Labeldatei: 4G0-907-637.clb
   Teilenummer SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Bauteil: SARA 6D       H02 0004
   Revision: --------    Seriennummer: EJ1BPA42024BCT0
   Betriebsnr.: WSC 00000 000 00000
   ASAM Datensatz: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D06FEAA6D91C3FFC17-8078
Adresse 42: Türelektr. Fahrer (J386)       Labeldatei: Keine
   Teilenummer SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Bauteil: TSG FA        H05 0212
   Codierung: 011C16205E00628002080002
   Betriebsnr.: WSC 02312 785 00200
   VCID: 42DCBD16C48F2C870C5-8016
Adresse 44: Lenkhilfe (J500)       Labeldatei:| DRV\4G0-909-144.clb
   Teilenummer SW: 4G0 909 144 L    HW: 4G0 909 144 G
   Bauteil: RCEPS         H35 0010
   Revision: 00001000    Seriennummer: 0019172122
   Codierung: 101000010000
   ASAM Datensatz: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
Adresse 46: Komfortsystem (J393)       Labeldatei:. DRV\4H0-907-064-46.clb
   Revision: 00002001    Seriennummer: 0160123326
   Codierung: 0100062000B9058083200804080100000000000000000000000000000000
Adresse 52: Türelektr. Beifahr. (J387)       Labeldatei: Keine
   Teilenummer SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Bauteil: TSG BF        H05 0212
   VCID: 41DEB21AC189379F15F-8014
1 Fehler gefunden:
00920 - beheizbare Außenspiegel (Z4/Z5)
            012 - elektrischer Fehler im Stromkreis
                    Fehlerstatus: 01101100
                    Fehlerpriorität: 3
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 212
                    Kilometerstand: 133538 km
                    Zeitangabe: 0
                    Datum: 2018.02.23
                    Zeit: 05:46:00
Adresse 53: Feststellbremse (----)       Labeldatei: DRV\4H0-907-801.clb
   Teilenummer SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Bauteil: EPB-4         H03 0012
   Revision: --------    Seriennummer: 00000000148108
   ASAM Datensatz: EV_ParkiBrake 001022
   ROD: EV_ParkiBrake_AU57.rod
   VCID: 2A0CF5B65C7FD4C7245-807E
Adresse 55: Leuchtweitenreg. (J431)       Labeldatei:| 4H4-907-357-V1.clb
   Teilenummer SW: 4H4 907 357 A    HW: 4H4 907 357 A
   Bauteil: ....AFS13.... H01 0012
   Seriennummer: 110927-0004-050
   Codierung: 0000020000020000
   ASAM Datensatz: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
   Leistungsmodul für Scheinwerfer links:
H02 0008
   Codierung: 1D0000
   Leistungsmodul für Scheinwerfer rechts:
H02 0003
   Codierung: 1A0000
3 Fehlercodes gefunden:
266752 - Steuergerät nicht codiert
          U1013 00 [137] - -
          Warnleuchte EIN - bestätigt - geprüft seit letzter Löschung
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 208
                    Datum: 2018.02.20
                    Zeit: 08:37:03
393989 - Scheinwerfer
          C107E 54 [137] - keine Grundeinstellung
                    Fehlerpriorität: 2
                    Verlernzähler: 213
                    Datum: 2018.02.20
                    Zeit: 08:37:03
680704 - Leistungsmodul für Scheinwerfer rechts
          C1082 F1 [137] - falsch codiert
                    Fehlerpriorität: 6
                    Fehlerhäufigkeit: 1
                    Verlernzähler: 208
                    Datum: 2018.02.20
                    Zeit: 08:37:03
Adresse 56: Radio (R)       Labeldatei:. DRV\4F0-035-0xx-56.clb
   Teilenummer SW: 4G0 035 056 J    HW: 4G0 035 056
   Bauteil: Radio U STD   H52 0133
   Revision: AB001007    Seriennummer: 051I00B7536884
   Codierung: 010003020100000001
   VCID: 28080FBE42F3E6D7321-807C
Adresse 5F: Informationselek. I (J794)       Labeldatei:. DRV\4E0-035-6xx-5F.clb
   Teilenummer SW: 4G0 035 666 J    HW: 4G0 035 666
   Bauteil: H-BN-EU       H47 0798
   Revision: --------    Seriennummer: 426I%0B7614863
   Codierung: 050100000003A3EF45108B3E00000003E00101020000000000
   VCID: 2F3AE4A2671DB1EFF3B-807A
   Subsystem 1 - Teilenummer: 8R0 060 884 BK
   Bauteil: EUR 2014  1703
   Subsystem 2 - Teilenummer SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Bauteil: DU8 C7 SV  H42 0021
   Seriennummer: AUZ8ZDB1301MGS+
   Subsystem 3 - Teilenummer SW: 4G1 919 610 C    HW: 4G1 919 610 A
   Bauteil: E380 BDT C7  H08 0204
   Seriennummer: 90349KIJ000GP
   Subsystem 4 - Teilenummer: 8R0 060 961 B
   Bauteil: CD-Database  3371
Adresse 62: Türelektr. hi. li. (J388)       Labeldatei: Keine
   Teilenummer SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Bauteil: TSG HL        H04 0212
   Codierung: 010814204000628002080002
   VCID: 44D0BB0EDE9B22B73E9-8010
Adresse 6C: Rückfahrkamera (J928)       Labeldatei:* Keine
   Teilenummer SW: 4H0 907 428     HW: 7P6 907 441 D
   Bauteil: TopView       H05 0090
   Revision: 11001001    Seriennummer: 82330JF0010194
   Codierung: 0200000001010100000102000000
   ASAM Datensatz: EV_CamerSysteTopViewAUDI 003019
   ROD: EV_CamerSysteTopViewAUDI_003.rod
   VCID: 6A8C35B69CFF14C7E45-803E
Adresse 72: Türelektr. hi. re. (J389)       Labeldatei: Keine
   Bauteil: TSG HR        H04 0212
Adresse 85: Kamerasteuergerät (J852)       Labeldatei:* Keine
   Teilenummer SW: 4G0 907 217     HW: 4H0 907 217 A
   Bauteil: DPC-SG        H24 0036
   Revision: --------    Seriennummer: 262130025421000
   Codierung: 64040000
   ASAM Datensatz: EV_OnBoardCamerDPC 001007
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6596468A75E13BBFC97-8030
Adresse 8F: Gurtstraffer links (J854)       Labeldatei:. 4H0-980-94x-RGS.clb
   Teilenummer SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Bauteil: RGS-VL        H13 0080
   Codierung: 00060000031F030000030801424CDA010000
   ASAM Datensatz: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313EE2DA71A9A71FE5F-8064
Adresse 90: Gurtstraffer rechts (J855)       Labeldatei:. 4H0-980-94x-RGS.clb
   Teilenummer SW: 4H0 980 946 B    HW: 4H0 980 946 B
   Bauteil: RGS-VR        H13 0080
   ASAM Datensatz: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
Ende----------------------------(Dauer: 02:04)-----------------------------
Translated (area of interest):
Address 55: Headlight Reg. (J431) Label file: | 4H4-907-357-V1.clb
***Part Number SW: 4H4 907 357 A HW: 4H4 907 357 A
***Component: .... AFS13 .... H01 0012
***Serial number: 110927-0004-050
***Coding: 0000020000020000
***Operating No .: WSC 02391 785 00200
***ASAM record: EV_AdvanFrontSyste 005001
***ROD: EV_AdvanFrontSyste_AU21.rod
***VCID: 3038E7DE7AA3AE17EA1-8064
***Power module for headlight left:
H02 0008
***Coding: 1D0000
***Power module for headlight right:
H02 0003
***Coding: 1A0000
3 error codes found:
266752 - Control unit not coded
**********U1013 00 [137] - -
**********Warning light ON - confirmed - checked since last deletion
*************Environmental conditions:
********************Error status: 00000001
********************Error priority: 2
********************Error rate: 1
********************Lost counter: 208
********************Mileage: 133376 km
********************Date: 2018.02.20
********************Time: 08:37:03
393989 - headlights
**********C107E 54 [137] - no default setting
********************Error rate: 19
********************Lost counter: 213
680704 - Right headlight power module
**********C1082 F1 [137] - incorrectly coded
********************Error priority: 6
iichel
Eindhoven, NB, NL
C?ID=284912
maybe it helps to first code the headlight on the right hand side and then code the AFS module?
also, you can simply install the english version besides the german version. they can happily co-exist.
take_me_sfz
C?ID=327281
The car is from a friend of me and he lifes about 50km / 31miles away from me. So he could not visit me for each single test :)
I have added a translated "part" of the Auto-Scan
EDIT:
It is not possible to code any of the Power module for headlight
NEtech
Denmark
C?ID=56995
Try: 11219633F91AEB00
Should be as PR codes show from the VIN of this car.
First write numbers for wsc, importer, device no. described here
[Save]
[Close VCDS]
Start VCDS
Use Secure Access before coding.
Power module coding is done automatically, after coding of Headlight Range Control unit.
take_me_sfz
C?ID=327281
Thanks,
I'm not sure if I undestand everything completly.
Could you explain "PR codes"?
About this:
[Save]
[Close VCDS]
Start VCDS
I have to check my settings. But what numbers I have to take? As described in your link I have to set "0000" or "000" if I'am not an officially VW/Audi workshop.
I already used "20103" as Secure Access code (this was suggested from VCDS in the tooltip)
iichel
Eindhoven, NB, NL
C?ID=284912
ah there is your problem. you'll have to set these numbers to anything other than zero. with all zeros, the interface will reject the codes.
downtime
Finland
C?ID=280813
But again, you cannot code the slave power modules independently. They are automatically coded when the master module 55 is coded correctly. Shadow mode should work for this car as the headlight module is not brand new.
If you cannot find correct coding for the car, the dealer can. They can code the headlight module through factory connection automatically. As the parts are same parts as the original ones except used, I would take the car to authorized workshop and let them do the coding and adjustment. Does not take that long and is not very expensive. As the lights need to be adjusted after coding anyway this is a good option.
NEtech
Denmark
C?ID=56995
Configuration of the equipment when the car was produced.
What I mean, I take the light system is original, and you have not changed/upgraded light system.
Just use some numbers, that is not all zeros.
Yes, I don't know you did that, just wanted to mention it.
take_me_sfz
C?ID=327281
OK thanks,
i will test that.
Yes the light system is 100% original not upgraded to a higher version.
