'04 Touareg, new key?
Flaps10
C?ID=219700
Any chance I can use VCDS to "marry" a new key to our '04 Touareg?
It's done everything else I've asked of it.
Long story short, someone busted the left rear passenger window yesterday and stole a binder which had a key, not for the VW but for our volvo. It brought to light that we have only one key for each car (story of my life).
At this very moment there is what looks to be a brand new Touareg key on eBay. It is a blank blade but previously used "fob" (dying to know where that word came from). The ad states that you'd need the key to be reprogrammed.
First off, is the dude huffing paint? Can a previously used key be re-purposed?
Second, can VCDS be used to initiate a key to my ECU?
If the above two questions are "no joy" then what should I expect to be reamed for at a stealership?
Keithuk
Stoke on Trent, England
C?ID=122432
It can providing you know the Secret Key Code (SKC) but you will need to use VAG-TACHO for that.
golfi_vend
Tartu, Estonia
C?ID=195131
Doesn't T'Reg also need preprogrammed chip before it can introduced to car?
Spacewalker
Poland
C?ID=159607
Must be precode / dealer key first.
I'm not 100% certain, but I don't think a 2004 (first generation Touareg) needs a pre-coded key. However, one absolutely would need the vehicle-specific security (PIN) code, which VCDS cannot provide.
People generally do not have the best of luck with keys purchased on fleaBay.
Spacewalker
Poland
C?ID=159607
2004 is a model up 2007 and Kessy module is this same
Curtis
Botswana
C?ID=260764
I know this is an old thread, but I am in the same position as the owner of the thread (Flaps10). I have gone over the key-matching procedure for the Touareg 7L over and over and over.
What I have:
1) 2004 V6 Touareg with only one key.
2) Genuine Hex-Usb + Can Interface
3) The SKC for the T1
4) Second key ordered & cut from the dealer (not programmed)
What I need:
1) To programme the new key (both the remote and the immo.)
My questions:
1) Is it going to be as easy as I have read?
2) Has anyone done it successfully or are there hiccups in the process, or anything to look out for?
3) If I don't have a battery charger (as recommended in the procedure), would it be risky/how risky would it be to do it on battery power only?
Thanks a lot.
If you have the correct PIN/SKC, it should be doable, but it's rather fidgety. Does the Touareg in question have a full-up Kessy system? An Auto-Scan would tell us that. ;)
Please get a battery charger.
Curtis
Botswana
C?ID=260764
Wednesday,25,August,2016,18:20:36:61415
VCDS Version: 15.7.4.1
Data version: 20160216
VIN: WVGZZZ7LZ4D054403   License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ4D054403   Mileage: 71140km-44204miles
Address 01: Engine        Labels: 022-906-032-BMX.lbl
   Part No SW: 022 906 032 BE    HW:
   Component: MOTRONIC ME7.1.1G   0008
   Coding: 0000133
   Shop #: WSC 31414 000 00000
   VCID: 4FAB9255DD32CB46B7-5154
   Part No: 09D 927 750 A
   Component: AL 600 6Q           0360
   Coding: 0012328
   VCID: 2C51E5D98CE4D05EF2-5154
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 D
   Component: ESP ALLRAD MK25     0108
   Coding: 0014337
   VCID: 3A7DD38176B07EEE70-5154
   Part No SW: 3D0 909 135 K    HW: 5WK 470 25
   Component:    Kessy            6400
   Coding: 0008424
   VCID: 2D57E8DDB7FED956E5-5170
00955 - Key 1
            002 - Lower Limit Exceeded
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 H
   Component: CLIMAtronic R/L   X 3716
   Coding: 0000030
   VCID: 3567C0BD5FAE91969D-5170
            010 - Open or Short to Plus
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 K
   Component:                     2703
   Coding: 0232700
   VCID: 4481AD790474381E1A-5170
   Part No: 3D0 909 601 E
   Component: 0C Airbag 8.4E+ H10 0952
   Coding: 0012355
   VCID: 254710FDEF0EE1162D-5170
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000031
   VCID: 4089A169106C243E3E-5170
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 870 J
   Component: KOMBIINSTRUMENT RB4 1821
   Coding: 0007511
   VCID: 3D77D89D679E49D655-5170
01304 - Radio
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70E931A9604CF4BE8E-5170
01304 - Radio
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F0BE2952D129BC607-5170
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  X012
   VCID: 66C557F152882A0EE4-5154
   Part No: 7L0 959 933 H
   Component:    HSG              0400
   Coding: 0000069
   Shop #: WSC 77330 981 93570
   VCID: 418FA46D1B662D3631-4B48
   Subsystem 1 - Part No: 7L0 959 701 D
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 D
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703
   Subsystem 4 - Part No: 7L0 959 704
   Subsystem 5 - Part No: 7L0 907 719
   Component:    Neigungssensor   0020
   Subsystem 6 - Part No: 7L6 951 171
   Component: A  Innenraumsensor  0019
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
Address 68: Wiper Electr.        Labels: None
   Part No: 7L0 955 119 G
   Component: Front Wiper         2416
   Coding: 0000004
   Shop #: WSC 31414 000 376832
   VCID: 3879C98948BC6CFE86-5154
End-------------------------(Elapsed Time: 09:01)--------------------------
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Thanks a lot.
The KESSY architecture, in fact many of the same KESSY P/Ns, are shared with Phaetons. I've done it. It's not hard, I don't remember any major hiccups.
In fact, I need to do it again at some point. My 2006 Phaeton will be in the garage anyway this weekend for its biannual B-check and attack on certain persistent DTCs, and I only had 3 of my 4 keys with me last time I reconfigured my Immobilizer. If you can wait a few days, I'll capture the process on video.
Jason
Curtis
Botswana
C?ID=260764
jyoung8607, that would be great!!:thumbs: I will wait for that video. Considering I love my Treg, I think it's worth the wait, :popcorn:it's worth the research. Thanks again.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Still working on getting this for you. I actually went through the process successfully last night, but I goofed up the video capture. I'll try it again sometime in the next couple days.
Jason
Curtis
Botswana
C?ID=260764
Jason
Thanks once more. I'm in no rush. Only curiosity is getting the better of me... but it's worth the wait.
