Friday,08,August,2014,01:34:58:35742
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVWFU93C87PXXXXXXXXX License Plate: B6PASSAT
Mileage: 141870km-88153mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 22 25 36 42 44 46 47 52 53 55
56 62 72 77
VIN: WVWFU93C87PXXXXXXXXXX Mileage: 141870km/88153miles
25-Immobilizer -- Status: Not registered 0001
77-Telephone -- Status: Not registered 0001
Address 01: Engine Labels: 03H-906-032-BLV.lbl
Part No SW: 03H 997 033 M HW: Hardware No
Component: P3.6-FSI-LEV2 G00 2370
Revision: --H11--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 00028 028 00001
VCID: 377D3F7A46C61AA66AD-8062
006481 - Radiator Fan 2 (V177)
P1951 - 002 - Movement Restricted / Jammed - Intermittent
Fault Frequency: 39
Mileage: 137722 km
Date: 2014.06.21
Time: 18:39:34
RPM: 917 /min
Load: 32.1 %
Speed: 13.0 km/h
Temperature: 95.0°C
Temperature: 61.0°C
Absolute Pres.: 880.0 mbar
Voltage: 13.081 V
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 HK HW: 09G 927 750 FR
Component: AQ 250 6F 1091
Revision: 00H38000 Serial number:
Coding: 0000072
Shop #: WSC 91511 999 84621
VCID: 810911A2D8821416149-80D4
Address 03: ABS Brakes Labels: 3C0-614-095-C2.clb
Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
Component: ESP 440 C2 H015 0004
Revision: H015 Serial number: 0667540883
Coding: 0046544
VCID: 326B0E6EADA4FF8E5D3-8067
Fault Status: 00101101
Fault Frequency: 44
Reset counter: 61
Mileage: 141044 km
Date: 2014.07.25
Time: 15:15:40
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
Component: ClimatronicPQ46 050 0505
Revision: 00050005 Serial number: 00000000000000
VCID: 67DDAF3A56E64A263AD-8032
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000005710911
Coding: F7848F0340041A00470000000F000000002A5D435C0000
Subsystem 1 - Part No: 3C1 955 419 Labels: 1KX-955-119.CLB
Component: Wischer VW461 001 0101
Coding: 00063445
Shop #: WSC 00028
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 230506 014 1201
Coding: 00208933
Shop #: WSC 00028
Fault Status: 00101100
Fault Frequency: 17
Reset counter: 99
Mileage: 139017 km
Date: 2014.07.08
Time: 00:57:00
Voltage: 12.40 V
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 K HW: 3C0 909 605 K
Component: 0H AIRBAG VW8R 029 2521
Revision: 10029000 Serial number: 003A3P93ED4+
Coding: 0012360
VCID: 2E531A1EB99CDB6E39B-807B
Subsystem 1 - Serial number: 6332MSME0F1D6117F
Subsystem 2 - Serial number: 6342MSME0F1D3442E
Subsystem 3 - Serial number: 6351HTS6QLL68PI27
Subsystem 4 - Serial number: 6361HTS6OLLMOIM2Z
Subsystem 5 - Serial number: 63727TS6OLLIC7C2X
Subsystem 6 - Serial number: 63827TS63IKQSI63$
Part No SW: 3C0 953 549 E HW: 3C0 953 549 E
Component: J0527 0015
Revision: 00005000 Serial number: 3C5953507P
Coding: 0002211
Component: E0221 002 0010
Part No SW: 3C0 920 871 A HW: 3C0 920 871 A
Component: KOMBIINSTRUMENT VD1 1614
Revision: X0006000 Serial number: 00000000000000
Coding: 0007305
Shop #: WSC 91511 999 54557
VCID: 224BFE2EFD446F0EAD3-8077
Address 19: CAN Gateway Labels: 3C0-907-530-V1.clb
Part No SW: 3C0 907 530 C HW: 3C0 907 951 A
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C06513052E
Coding: FFFD0D10D21002
Shop #: WSC 91505 999 16662
VCID: 2149F122F8427416B49-8074
Reset counter: 48
Mileage: 141412 km
Date: 2014.07.31
Time: 19:31:28
Reset counter: 48
Mileage: 141412 km
Date: 2014.07.31
Time: 19:31:28
Part No SW: 3C0 919 965 HW: 3C0 919 965
Component: Kompass 005 0002
Revision: 00005000 Serial number: 1166279TQL8F05
VCID: EDD15D12F41AE076C01-80B8
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 E
Component: HALDEX 4Motion 0110
VCID: 2F6D071ABE96D26632D-807A
00448 - Haldex Clutch Pump (V181)
Part No SW: 3C0 959 433 S HW: 3C0 959 433 S
Component: IMMO 041 0383
Revision: 00041000 Serial number: VWZCZ000000000
Shop #: WSC 91505 999 18452
VCID: 3A7B264E75D407CE953-806F
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 C HW: 3C0 959 760 C
Component: Sitzverstellung 1001
Revision: 00004000 Serial number: 00000000000000
VCID: 2D511D12B49AA076001-8078
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 Q HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1123
Revision: 11007001 Serial number: 00000013768908
Coding: 0001463
Shop #: WSC 90956 999 51625
VCID: 3C7720567FE039FE87F-8069
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
Reset counter: 100
Mileage: 140433 km
Date: 2014.07.15
Time: 00:53:43
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.137 H07 1806
VCID: 3467087657B0F1BE4FF-8061
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 041 0472
Coding: 13910F8001862E521004141FF08A8F0E087800
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 Q HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1123
Revision: 11007001 Serial number: 00000025468908
Coding: 0001462
VCID: 3D712D5264FA30F6B01-8068
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
Reset counter: 100
Mileage: 140433 km
Date: 2014.07.15
Time: 00:53:43
Address 53: Parking Brake Labels: 3C0-907-801-53.clb
Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
Component: EPB VC8HC001 013 0001
Revision: 013
Coding: 0000013
Address 55: Xenon Range Labels: 5M0-907-357-V1.lbl
Part No SW: 5M0 907 357 HW: 5M0 907 357
Component: AFS-Steuergeraet 0003
Revision: H09 Serial number:
Shop #: WSC 91511 999 59107
VCID: F1E94162E8220496E49-80A4
Subsystem 1 - Part No: 7L6 941 329
Component: AFS-Lst.-Modul l X018
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X018
Coding: 00000035
Part No SW: 1K0 035 180 H HW: 1K0 035 180 H
Component: Radio PM6 165 0018
Revision: 00165000 Serial number: VWZ5Z7F2079303
Coding: 0040401
VCID: 2541E532EC6A9836C81-8070
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1110
Revision: 12004001 Serial number: 00000000112239
Coding: 0001168
VCID: 3E732A5E69FC2BEEA9B-806B
00934 - Electric Window Motor; Rear Left (V26)
Fault Status: 00111100
Reset counter: 84
Mileage: 141306 km
Date: 2014.07.29
Time: 13:46:32
Fault Status: 00100101
Reset counter: 85
Mileage: 138913 km
Date: 2014.07.06
Time: 16:41:15
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1110
Revision: 12004001 Serial number: 00000000110448
Coding: 0001168
VCID: 3F8D575A6EF622E6A2D-806A
Address 77: Telephone (J738) Labels: 1K8-035-730.clb
Part No SW: 1K8 051 730 D HW: 1K8 051 730 D
Component: Telefon H03 6900
Revision: 00003000 Serial number: 00000A07790538
Coding: 402120
Shop #: WSC 91505 999 11172
VCID: 285FEC065B78855EF37-807D
End ---------------------------------------------------------------------
