2007 Passat 4motion Awd not working
Inspector359
C?ID=217054 (NRRT)
So my AWD isn't working and these are the codes I'm getting. When I start the car my ESP light is not on and my AWD works, I know this because I tried it on a nice, wet road one night and it worked like a charm. The light will come on by itself at seemingly random times after starting, anywhere between 30 seconds to 20 minutes after I have started driving. I have done an oil and filter change on my haldex coupling, checked my connections to the coupling and put some di-electric grease on them while I had it off. Since everything functions normally before the light comes on then it can't really be a control module or clutch pump failure, can it?*
Address 03: ABS Brakes*1 Fault Found:01324 - Control Module for All Wheel Drive (J492)*013 - Check DTC Memory - Intermittent
Address 22: AWD*1 Fault Found:00448 - Haldex Clutch Pump (V181)*014 - Defective - Intermittent
I also have a code for my front right parking light, it may or may not have anything to do but I have heard some weird things causing other codes to be thrown.
1 Fault Found:02395 - Parking Light Front Right (M3)*012 Electrical Fault in Circuit.Any and all help is appreciated!
Please post a real Auto-Scan rather than snippets.
Inspector359
C?ID=217054 (NRRT)
Friday,08,August,2014,01:34:58:35742
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVWFU93C87PXXXXXXXXX   License Plate: B6PASSAT
Mileage: 141870km-88153mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 22 25 36 42 44 46 47 52 53 55
          56 62 72 77
VIN: WVWFU93C87PXXXXXXXXXX   Mileage: 141870km/88153miles
25-Immobilizer -- Status: Not registered 0001
47-Sound System -- Status: Cannot be reached 1100
77-Telephone -- Status: Not registered 0001
Address 01: Engine        Labels: 03H-906-032-BLV.lbl
   Part No SW: 03H 997 033 M    HW: Hardware No
   Component: P3.6-FSI-LEV2   G00 2370
   Revision: --H11---    Serial number: VWZCZ000000000
   Coding: 0000175
   Shop #: WSC 00028 028 00001
   VCID: 377D3F7A46C61AA66AD-8062
006481 - Radiator Fan 2 (V177)
               P1951 - 002 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 39
                    Mileage: 137722 km
                    Date: 2014.06.21
                    Time: 18:39:34
                    RPM: 917 /min
                    Load: 32.1 %
                    Speed: 13.0 km/h
                    Temperature: 95.0°C
                    Temperature: 61.0°C
                    Absolute Pres.: 880.0 mbar
                    Voltage: 13.081 V
Address 02: Auto Trans        Labels: 09G-927-750.lbl
   Part No SW: 09G 927 750 HK    HW: 09G 927 750 FR
   Component: AQ 250 6F           1091
   Revision: 00H38000    Serial number:
   Coding: 0000072
   Shop #: WSC 91511 999 84621
   VCID: 810911A2D8821416149-80D4
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 S    HW: 3C0 614 095 S
   Component: ESP 440 C2     H015 0004
   Revision:  H015       Serial number: 0667540883
   Coding: 0046544
   VCID: 326B0E6EADA4FF8E5D3-8067
                    Fault Status: 00101101
                    Fault Frequency: 44
                    Reset counter: 61
                    Mileage: 141044 km
                    Date: 2014.07.25
                    Time: 15:15:40
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 AH    HW: 3C0 907 044 AH
   Component: ClimatronicPQ46 050 0505
   Revision: 00050005    Serial number: 00000000000000
   VCID: 67DDAF3A56E64A263AD-8032
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000005710911
   Coding: F7848F0340041A00470000000F000000002A5D435C0000
   Subsystem 1 - Part No: 3C1 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer VW461 001   0101
   Coding: 00063445
   Shop #: WSC 00028
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     230506 014  1201
   Coding: 00208933
   Shop #: WSC 00028
                    Fault Status: 00101100
                    Fault Frequency: 17
                    Reset counter: 99
                    Mileage: 139017 km
                    Date: 2014.07.08
                    Time: 00:57:00
                    Voltage: 12.40 V
   Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
   Component: 0H AIRBAG VW8R  029 2521
   Revision: 10029000    Serial number: 003A3P93ED4+
   Coding: 0012360
   VCID: 2E531A1EB99CDB6E39B-807B
   Subsystem 1 - Serial number: 6332MSME0F1D6117F
   Subsystem 2 - Serial number: 6342MSME0F1D3442E
   Subsystem 3 - Serial number: 6351HTS6QLL68PI27
   Subsystem 4 - Serial number: 6361HTS6OLLMOIM2Z
   Subsystem 5 - Serial number: 63727TS6OLLIC7C2X
   Subsystem 6 - Serial number: 63827TS63IKQSI63$
   Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
   Component: J0527               0015
   Revision: 00005000    Serial number: 3C5953507P
   Coding: 0002211
   Part No SW: 3C0 920 871 A    HW: 3C0 920 871 A
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: X0006000    Serial number: 00000000000000
   Coding: 0007305
   Shop #: WSC 91511 999 54557
   VCID: 224BFE2EFD446F0EAD3-8077
Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
   Part No SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Component: Gateway         007 0040
   Revision: 00007000    Serial number: 0700C06513052E
   Coding: FFFD0D10D21002
   Shop #: WSC 91505 999 16662
   VCID: 2149F122F8427416B49-8074
                    Reset counter: 48
                    Mileage: 141412 km
                    Date: 2014.07.31
                    Time: 19:31:28
                    Reset counter: 48
                    Mileage: 141412 km
                    Date: 2014.07.31
                    Time: 19:31:28
   Part No SW: 3C0 919 965     HW: 3C0 919 965
   Component: Kompass         005 0002
   Revision: 00005000    Serial number: 1166279TQL8F05
   VCID: EDD15D12F41AE076C01-80B8
Address 22: AWD        Labels: 1K0-907-554.lbl
   Part No: 1K0 907 554 E
   Component: HALDEX 4Motion      0110
   Coding: 0000001
   VCID: 2F6D071ABE96D26632D-807A
   Part No SW: 3C0 959 433 S    HW: 3C0 959 433 S
   Component:    IMMO         041 0383
   Revision: 00041000    Serial number: VWZCZ000000000
   Shop #: WSC 91505 999 18452
   VCID: 3A7B264E75D407CE953-806F
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 C    HW: 3C0 959 760 C
   Component: Sitzverstellung     1001
   Revision: 00004000    Serial number: 00000000000000
   VCID: 2D511D12B49AA076001-8078
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1123
   Revision: 11007001    Serial number: 00000013768908
   Coding: 0001463
   Shop #: WSC 90956 999 51625
   VCID: 3C7720567FE039FE87F-8069
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
                    Reset counter: 100
                    Mileage: 140433 km
                    Date: 2014.07.15
                    Time: 00:53:43
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.137 H07 1806
   VCID: 3467087657B0F1BE4FF-8061
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 041 0472
   Coding: 13910F8001862E521004141FF08A8F0E087800
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1123
   Revision: 11007001    Serial number: 00000025468908
   Coding: 0001462
   VCID: 3D712D5264FA30F6B01-8068
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
                    Reset counter: 100
                    Mileage: 140433 km
                    Date: 2014.07.15
                    Time: 00:53:43
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0000013
Address 55: Xenon Range        Labels: 5M0-907-357-V1.lbl
   Part No SW: 5M0 907 357     HW: 5M0 907 357
   Component: AFS-Steuergeraet    0003
   Revision:   H09       Serial number:
   Coding: 0000001
   Shop #: WSC 91511 999 59107
   VCID: F1E94162E8220496E49-80A4
   Subsystem 1 - Part No: 7L6 941 329
   Component: AFS-Lst.-Modul l    X018
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000035
   Part No SW: 1K0 035 180 H    HW: 1K0 035 180 H
   Component: Radio PM6       165 0018
   Revision: 00165000    Serial number: VWZ5Z7F2079303
   Coding: 0040401
   VCID: 2541E532EC6A9836C81-8070
   Component: J388   TUER-SG HL   1110
   Revision: 12004001    Serial number: 00000000112239
   Coding: 0001168
   VCID: 3E732A5E69FC2BEEA9B-806B
00934 - Electric Window Motor; Rear Left (V26)
                    Fault Status: 00111100
                    Reset counter: 84
                    Mileage: 141306 km
                    Date: 2014.07.29
                    Time: 13:46:32
                    Fault Status: 00100101
                    Reset counter: 85
                    Mileage: 138913 km
                    Date: 2014.07.06
                    Time: 16:41:15
   Component: J389   TUER-SG HR   1110
   Revision: 12004001    Serial number: 00000000110448
   Coding: 0001168
   VCID: 3F8D575A6EF622E6A2D-806A
Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
   Part No SW: 1K8 051 730 D    HW: 1K8 051 730 D
   Component: Telefon       H03 6900
   Revision: 00003000    Serial number: 00000A07790538
   Coding: 402120
   Shop #: WSC 91505 999 11172
   VCID: 285FEC065B78855EF37-807D
Inspector359
C?ID=217054 (NRRT)
Also, why does it list my transmission as an 09G when it is an 09M?
rhinopower
C?ID=58979
Coding: 0001463
Coding: 0001462
This coding worked for folding mirrors, so the label file is wrong
I corrected the coding for the puddle lights etc after and mirrors still worked, but the label file saying add 4096 is incorrect
MasterTommy
Amsterdam
C?ID=295586
Well haldex pumps fail often on this generation, so I wouldnt be suprised if it is really defective. That being said, there are always things you can rule out before reaching that conclusion.
