Suspension fault code 2017 MK7 GOLF R
fm812
C?ID=352796
Part two of the issues, got all the airbag fault code disabled. Now i need to get the suspension faults disabled. The dealer said that replacing the acceleration sensors will fix this problem. That being said I'm not trying to spend 2k to fix that. Does anyone know a work around? Code it out. I don't mind the suspension being stiff, i like the suspension to be tight. Here is the log. Any help is appreciated! Thank you! 2017 VW Golf R
Saturday,08,December,2018,13:26:27:36703
VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4436.4
VIN: WVWWF7AU1HW166331   License Plate:
                Address 14: Susp. Elect.       Labels: 5Q0-907-376.clb
Control Module Part Number: 5Q0 907 376 B    HW: 5Q0 907 376 A
  Component and/or Version: DAEMPFUNGS-SG H17 0121
           Software Coding:
            Work Shop Code:
              ASAM Dataset: EV_DRCONTITEMIC 001019 (VW37)
                       ROD: EV_DRCONTITEMIC_VW37.rod
                      VCID: 38292AC2A2DB7E3766B-806C
835584 - MIL Request Signal Active (Check TCM for errors too!)
          P1624 00 [137] - -
                    Reset counter: 149
                    Mileage: 22091 km
                    Date: 2018.12.08
                    Time: 13:25:24
380680 - System Function Test; Wheel Diameter Implausible
          C102A 29 [137] - Signal Implausible
                    Reset counter: 149
                    Mileage: 22091 km
                    Date: 2018.12.08
                    Time: 13:25:24
35593 - Chassis Acceleration Sensor; Front Left
          C10B8 01 [009] - Electrical Failure
                    Reset counter: 149
                    Mileage: 22091 km
                    Date: 2018.12.08
                    Time: 13:25:24
35849 - Chassis Acceleration Sensor; Front Right
          C10B9 01 [009] - Electrical Failure
                    Reset counter: 149
                    Mileage: 22091 km
                    Date: 2018.12.08
                    Time: 13:25:24
36105 - Chassis Acceleration Sensor; Rear
          C10BA 01 [009] - Electrical Failure
                    Reset counter: 149
                    Mileage: 22091 km
                    Date: 2018.12.08
                    Time: 13:25:24
The chance that all three of these sensors have failed strikes me as slim. Check wiring diagrams to see what they might have in common.
fm812
C?ID=352796
The car was in an accident before i bought it and i could see that they arent a thing in this car. i also dont have a lift to be able to go inspect it, its also super snowy muddy and cold here in wisconsin so i dont really feel like doing it in the driveway. I tried finding a way to disable it but ive had no luck. I wonder if anyone many know of a way that i havent tried to get them disabled. It dosent let me turn the tranction control off it just turns it right back on after because of the fault code being related to suspension. I really need to be able to do this becuase in wisconsin were getting plenty of snow and having traction control on dosent really help me ever. If anyone knows what i should do i really would appreicate the help greatly!!!!! thanks again!!!!
siLc
Tallinn, Estonia
C?ID=330192
The front sensors are on top of the front damper towers and the rear sensor is under the left luggage compartment trim - you obviously don't need a lift to check those. If the sensors themselves are inop or plain missing, their replacement shouldn't cost this much. All three of the sensors are part number 5Q0907651 and cost some 20-40$ used on ebay.
The sensors have one thing in common - they are directly wired to the DCC controller under the left luggage compartment trim, close to the hatch opening. If the car was rear-ended, the controller or wiring could be damaged.
fm812
C?ID=352796
So I finally got around to working on these sensors since it's been really nice out. Found out both sensors are there but not sure if the rear one is installed correctly, it's just kinda sitting on top of the wheel well, it's plugged in but I'm not sure if it's reading anything? Also the module is smashed to hell. So gonna replace that. Wiring harness is kinda f***d so gotta figure that out too. Are there diagrams anywhere online that would so me how these are installed?
darkchina811
ITALY
C?ID=333184
buy one hour access on erWin and you'll be able to print-to-PDF all wiring diagrams related to your VIN.
siLc
Tallinn, Estonia
C?ID=330192
The rear DCC sensor should be bolted down. If the DCC controller plug is smashed up, you can probably salvage the connector pins inside it and buy a new plug. Wiring itself should be doable with a WD.
