Part two of the issues, got all the airbag fault code disabled. Now i need to get the suspension faults disabled. The dealer said that replacing the acceleration sensors will fix this problem. That being said I'm not trying to spend 2k to fix that. Does anyone know a work around? Code it out. I don't mind the suspension being stiff, i like the suspension to be tight. Here is the log. Any help is appreciated! Thank you! 2017 VW Golf R
Saturday,08,December,2018,13:26:27:36703
VCDS Version: 18.9.0.4 (x64) HEX-V2 CB: 0.4436.4
Data version: 20181017 DS296.0
VIN: WVWWF7AU1HW166331 License Plate:
Address 14: Susp. Elect. Labels: 5Q0-907-376.clb
Control Module Part Number: 5Q0 907 376 B HW: 5Q0 907 376 A
Component and/or Version: DAEMPFUNGS-SG H17 0121
Software Coding:
Work Shop Code:
ASAM Dataset: EV_DRCONTITEMIC 001019 (VW37)
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 38292AC2A2DB7E3766B-806C
835584 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [137] - -
Reset counter: 149
Mileage: 22091 km
Date: 2018.12.08
Time: 13:25:24
380680 - System Function Test; Wheel Diameter Implausible
C102A 29 [137] - Signal Implausible
Reset counter: 149
Mileage: 22091 km
Date: 2018.12.08
Time: 13:25:24
35593 - Chassis Acceleration Sensor; Front Left
C10B8 01 [009] - Electrical Failure
Reset counter: 149
Mileage: 22091 km
Date: 2018.12.08
Time: 13:25:24
35849 - Chassis Acceleration Sensor; Front Right
C10B9 01 [009] - Electrical Failure
Reset counter: 149
Mileage: 22091 km
Date: 2018.12.08
Time: 13:25:24
36105 - Chassis Acceleration Sensor; Rear
C10BA 01 [009] - Electrical Failure
Reset counter: 149
Mileage: 22091 km
Date: 2018.12.08
Time: 13:25:24
