Golf V 1.6 BSE unstable idle
blueman07
Pirate
Walking the Plank
Romania
Hi. I have a 2007 VW Golf 1.6 BSE and idle is not stable. I get random misfire on all cylinder. I also have a black spark on cylinder 4. No fault codes. Some time ago I got misfire on only no. 3 cylinder. Changed plug wire and spark on that one. Nothing changed. I also tested with other 2 ignition coil - block type (used) and no change in idle. On 032 block I have around 8.5% on first field. I don't know what to do.
siLc
Tallinn, Estonia
C?ID=330192
Unfortunately such is life with this 1.6 BGU/BSE engine. I suffered the same problem with no reasonable solution until I sold my Golf V.
blueman07
Pirate
Walking the Plank
Romania
It's strange nobody found a solution to this strange problem...
blueman07
Pirate
Walking the Plank
Romania
VW Golf 1.6 BSE idle problem
No fault codes.
Changed spark plug wires, sparks, coil. Nothing changed.
On 032 block I have around 7.5% on first field. I don't know what to do.
No fault codes.
Please don't start multiple threads regarding the same problem in the same car; it just makes work for me to merge them.
blueman07
Pirate
Walking the Plank
Romania
Sorry Uwe, thought it's better.
Here is the scan:
Removed.   Data from pirated copies of VCDS is not welcome here.
iichel
Netherlands, eastern part
C?ID=284912
maybe it's better to update to VCDS version 17.8?
blueman07
Pirate
Walking the Plank
Romania
Realy? What if I post a scan from a legal copy? Then will you be able to help me?
PetrolDave
Westbury, UK
C?ID=1423
If/when you register yourself as the owner of a legal VCDS lead purchased from Ross-Tech or one of their distributors...
This forum is maintained by Ross-Tech, the creators of VCDS, so this forum is only for registered owners of VCDS.
