Tire Pressure Monitor System TPMS Install on 2005 Audi A6 C6
bernstma
New York, USA
C?ID=355771
Hi Everyone,
I have a 2005 Audi A6 C6 3.2L that doesn't seem to have the TPMS installed or at least I am not sure. It is available in my MMI but whenever I turn it on, it just defaults to off. I assume the module and the tire sensors were not installed in my car. I am looking to purchase a module and sensors and activate this in the VCDS for my car. Does anyone have any pointers on how I can first determine if I even have TPMS in my vehicle along with the steps to purchase the module and activate it?
Thank you for all the support.:)
Dana
Western PA, USA
Please do check or post the PR-codes but PartsLink24 shows: 7K0 Without tyre pressure monitor That isn't uncommon for a 2005 MY car.
My guess is someone enabled the MMI menu in AW 07 at one point when is shouldn't be enabled. Retrofitting Direct TPMS would require a 65 module, LIN antenna and 4 sensors. If you decide to get into that I would want to check both the parts catalog in addition to factory wiring diagrams for US market (4F) A6 models with TPMS. ErWin Audi and PartsLink24 are linked from the Wiki page in Uwe's reply.
P.S. 4F0 910 273 B appears to be pretty common and this 2007 has that controller: https://forums.ross-tech.com/showthread.php?14298-2007-Audi-A6-Left-side-DRL-not-working
bernstma
New York, USA
C?ID=355771
Thanks for the reply. Attached is my PR-Codes. I have to cross reference to see what codes means it came from the factory. I would also have to see what the 65 module and LIN antenna is according to what you referenced. Is there a place I can see what these parts are or references to the? The 4 sensors are easy those go inside the wheels when I have the tires replaced or mounted and balanced.
I have posted the PR-Codes here. https://drive.google.com/file/d/1jY2npO77-YYsGvDyTUnquOqHA4FY_ddz/view?usp=sharing
It matches what Dana found, so I think we can be confident that this car did not come with TPMS from the factory.
Official factory repair info should document that somehow.
If it were just a matter of plugging in the module and antenna, it wouldn't be too terrible a job. But, VW/Audi has made a science of not putting any wires in their cars that aren't needed for a particular build configuration, and if you have to add the wiring for the module and antenna(s), then that would increase the difficulty by at least an order of magnitude.
