Results 1 to 9 of 9
Thread: Audi A6 C6 (2005) - Cannot Remove Speed Warning 2 80MPH
    Dec 2018
    New York, USA
    I have a 2005 Audi A6 C6 with 63K miles. It has the speed warning 2 set on it when I hit 81 mph it goes off. The manual says to remove it through the MMI under the instrument option which is not available in my MMI. The speed warning 1 is set when you hold down the "Check" button on the dash, which is working. However the Speed Warning 2 is not anywhere available. I have enabled the Service Menu also using VCDS and I cannot find anything in here to remove it. I have googled a ton of searches and have tried everything but have been unsuccessful. I am hoping this is somewhere under the Instrument (17) but not sure. Looking for any other suggestions as I cannot remove this warning.
    Below is a copy of my lastest autoscan. It is a 2005 Audi A6 Quattro with the 4F in the VIN number.
    Thursday,27,December,2018,22:20:39:05694
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4437.4
    VIN: WAUDG74F95N096996   License Plate: JAZ1013
    Mileage: 109950km-683336mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F
              52 53 55 56 61 62 67 72 76 77
    VIN: WAUDG74F95N096996   Mileage: 109950km-68319miles
    0F-Digital Radio -- Status: Cannot be reached 1100
    Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
       Part No SW: 4F1 910 559 B    HW: 4F1 907 559 A
       Component: 3.2l V6 FSI         0050
       Revision: --H15---    Serial number:
       Coding: 01050106190F0120
       Shop #: WSC 02325 785 00200
       VCID: 2A0D00C930FE4AB7E01-807E
    18975 - Low Pressure Fuel Sensor (G410)
                P2543 - 009 - Intermittent - Intermittent
                        Fault Frequency: 183
                        Reset counter: 34
                        Mileage: 100758 km
                        Date: 2018.09.07
                        Time: 16:30:08
                        RPM: 2496 /min
                        Mass Air / Rev.: 457.8 mg/str
                        Temperature: 81.0°C
                            Part Throttle
                        Pressure: 4.2 bar
                        Speed: 29.0 km/h
       Part No SW: 4F1 910 156 H    HW: 09L 927 156
       Component: AG6 09L 3.2 FSI USA 0020
       Revision: --H01---    Serial number:        4000308
       Shop #: WSC 02327 785 00200
       VCID: 290FFFC535F841AFE9B-807C
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H05 0090
       Coding: 0020895
       Shop #: WSC 15789 002 1048576
       VCID: 2D070BD501105D8F053-8078
                        Fault Status: 00101101
                        Reset counter: 111
                        Mileage: 108191 km
                        Date: 2018.11.30
                        Time: 06:49:09
                        Hex Value: 0x0000
                        Hex Value: 0x4002
                        Hex Value: 0x0025
                        Hex Value: 0x01AA
                        Hex Value: 0x00FF
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
       Component: FBSAUDIC6 ELV   H05 0130
       Revision: 00H05000    Serial number: 10603401783859
       Coding: 0000011
       Shop #: WSC 10939 002 1048576
       VCID: 2517F3F559E065CFCD3-8070
       Subsystem 1 - Part No: 4F0 910 131 J
       Component: FBSAUDIC6 EZS   H43 0070
       Subsystem 2 - Part No: 4F0 910 220 A
       Component: FBSAUDIC6 IDG   H36 0040
       Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 360BR057518747
       Coding: 0000003
       Shop #: WSC 07157 002 1048576
       VCID: 313F17A51D28396F21B-8064
       Subsystem 1 - Part No: 4F0 910 609 B
       Component: Bedienteil MMIC6H07 0010
       Subsystem 2 - Serial number: 00000000101313
       Subsystem 3 - Serial number: 0124.01.050000000100010295ÿ
       Subsystem 4 - Serial number: 010295ÿ
                        Reset counter: 151
                        Mileage: 100695 km
                        Date: 2018.09.07
                        Time: 07:47:29
       Part No SW: 4F0 910 043     HW: 4F1 820 043 J
       Component: KLIMABETAETIGUNGH11 0150
       Revision: 00000025    Serial number: 00000000108247
       Coding: 0524326
       VCID: 5BE3950D2F24E33FAB7-800E
       Part No SW: 4F0 910 279     HW: 4F0 907 279
       Component: ILM Fahrer      H14 0080
       Coding: 0013123
       Shop #: WSC 02335 785 00200
       VCID: 6695B4F9E466AED7049-8032
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBF8037941
       VCID: 1C61D6116AAAA40762D-8048
    Address 0F: Digital Radio
       Part No SW: 4F0 910 655 B    HW: 4F0 959 655 A
       Component: 56 AIRBAG AUDI8RH29 0310
       Revision: 10H29000    Serial number: 00359D086R4W
       Coding: 0013622
       Shop #: WSC 08213 444 58939
       VCID: 2615F4F924E66ED7C49-8072
       Subsystem 1 - Part No: 4F0 910 339
       Component: BF-Gewichtsens. 002 0040
       Subsystem 2 - Serial number: 6332CSME08383E3DD
       Subsystem 3 - Serial number: 6342CSME080C3B073
       Subsystem 4 - Serial number: 6351HSME0623464D5
       Subsystem 5 - Serial number: 6361HSME06242527$
       Subsystem 6 - Serial number: 6371VSME062B117BM
       Subsystem 7 - Serial number: 6381VSME0621073CF
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90026050280275
       Coding: 0002041
       Shop #: WSC 02323 785 00200
       Component: Lenkradmodul    H02 0100
       Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
       Component: KOMBIINSTR. M73 H10 0570
       Revision: 00200000    Serial number: 4R873NT15
       Coding: 2048223
       VCID: 1E65DC197CB6B6178C9-804A
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
       Component: Gateway         H09 0030
       Revision: 09          Serial number: 08008051280018
       Coding: ECFE73CC3B7904
       Shop #: WSC 08213 444 58012
       VCID: 270BF9FD23EC77DFFFF-8072
    02230 - Digital Radio (DAB) (R147)
                        Reset counter: 151
                        Mileage: 100695 km
                        Date: 2018.09.06
                        Time: 15:52:58
    Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
       Part No SW: 4E0 035 785 F    HW: 4E0 035 785 B
       Component: SG ext.Player H15 0850
       Revision: 00000000
       VCID: 2B0305CD330453BF1B7-807E
       Coding: 0082946
       VCID: 619FA7E50D48C9EFF1B-8034
       Part No SW: 4E0 910 887 K    HW: 4E0 919 887 C
       Component: MNS US          H44 0570
       Revision: 00000000    Serial number: 378AV057515647
       VCID: 353723B5E940154F7D3-8060
    00003 - Control Module
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 0
                        Mileage: 100695 km
                        Date: 2018.09.07
                        Time: 07:46:53
                        Bin. Bits:     0100
       Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
       Component: TSG FA          H11 0040
       Revision: 00000000    Serial number: F—A
       Coding: 0035563
       Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
       Component: Komfortgeraet   H15 0100
       Revision: 01000015    Serial number: 01002495750000
       Coding: 0423997
       VCID: 2C0106D13A0A548712D-8078
       Component: LIN BACKUP HORN H02 1301
    01699 - Motor for Central Locking; Hatch/Trunk (V53)
                        Fault Status: 00101110
                        Reset counter: 145
                        Mileage: 109299 km
                        Date: 2018.12.19
                        Time: 07:50:29
    Address 47: Sound System        Labels: None
       Part No SW: 4F5 910 223 F    HW: 4F5 035 223 E
       Component: DSP-High C6     H14 0330
       Revision: PROD_01     Serial number: 00000000024635
       Coding: 0000026
       Component: ILM Beifahrer   H09 0050
       Revision:             Serial number: 00000000061437
       Coding: 0001114
       VCID: 5EE59C193C36F617CC9-800A
       Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
       Component: TSG BF          H11 0040
       Revision: 00000000    Serial number: ‘A
       Coding: 0035563
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0005022
       Shop #: WSC 02334 785 00200
       VCID: 5DE79B153130ED0FD53-8008
       Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
       Coding: 0000016
       Subsystem 1 - Part No: 4F0 941 329 A
       Component: AFS-Modul links H05 0010
       Subsystem 2 - Part No: 4F0 941 329 A
       Component: AFS-Modul rechtsH05 0010
    02627 - Dynamic Cornering Light Motor; Left (V318)
                        Fault Status: 11101010
                        Fault Frequency: 98
                        Reset counter: 109
                        Mileage: 108408 km
                        Date: 2018.12.06
                        Time: 18:27:20
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 B
       Revision: 00000000    Serial number: 394AN057513544
       Component: ENERGIEMANAGER  H12 0470
       Revision: 00000000    Serial number: 00000000009204
       Shop #: WSC 08213 444 57146
       VCID: 2313EDED57D49BFFA37-8076
       Component: von VA0  9998787876
       Coding: 344630393135313035442056413039393938373837383736
    02479 - Partial Consumer Shut-Off Active
                000 -  -  - Intermittent
                        Fault Frequency: 14
                        Mileage: 101642 km
                        Date: 2018.09.21
                        Time: 18:25:53
                        Mileage: 109954 km
                        Date: 2018.12.27
                        Time: 17:13:48
                        Mileage: 109954 km
                        Date: 2018.12.27
                        Time: 17:02:42
    02276 - Quiescent Current Stage 5
                        Mileage: 109954 km
                        Date: 2018.12.27
                        Time: 17:02:22
    02274 - Quiescent Current Stage 3
                        Mileage: 109954 km
                        Date: 2018.12.27
                        Time: 17:02:32
       Part No SW: 4F0 910 795     HW: 4F0 959 795
       Component: TSG HL          H09 0010
       Coding: 0035370
       VCID: 698FBFC5F57881AF29B-803C
       Component: SDS 3501 US     H45 0630
       Revision: 00000000    Serial number: 00000502020059
       Shop #: WSC 12336 024 394758
       VCID: 34311EB1E23A0C474AD-8060
       Part No SW: 4F0 910 795     HW: 4F0 959 794
       Component: TSG HR          H09 0010
       Coding: 0035370
       Part No SW: 4F0 910 283     HW: 4F0 919 283
       Component: Parkhilfe 4-Kan H09 0030
       Revision: --.--.--    Serial number: 11720502600697
       Coding: 0001206
       Component: Handyvorb2      H10 1130
       Revision: 00000000    Serial number: 00000007514494
       Coding: 0010900
       VCID: 2809FAC12EF278A7F65-807C
    End----(Elapsed Time: 01:56, VBatt start/end: 11.4V/11.4V. VIgn 11.5V)-----
    Intresting. I do not see explicitly pertaining to the speed warning in the cluster.
    My daughter drives a very similar car. I'm trying to figure out why the first four digits of your instrument cluster's coding are:
    2048223
    2048 is an "adder" for "Switch Option for Bord Computer Levels (MY 2006+)", which this is clearly not (unless perhaps it's had a newer cluster swapped in at some point)..
    Hers is:
    0065201, which is "+0001 = Quattro" and "+0064 = Advanced Frontlighting System (AFS) installed".
    You might try changing your instrument cluster's coding to: 0065223 just to see if it has an effect.
  3. Likes jyoung8607 liked this post
    Dec 2018
    New York, USA
    Hi Uwe,
    So I finally figured it out after a long while of research and common sense. I was able to use the VCDS to open the Hidden Menu option which was not setup on my car. Once I opened the Hidden Menu, I went into the DIAG SETTINGS and the Second Option which is APK 0x01, 0x0B, 0x0C. From there I went into the menu option and selected Bordcomputer. This put back the Instrument Cluster Menu back into my main MMI menus options. Once I rebooted the MMI, Instrument Cluster then allowed me to turn off the Speed Warning 2 and allowed me to see the other Trip Monitor settings. Something must have happened because there are menu options in my MMI which did not exist that should like the Air Conditioning options that are now controllable through the MMI. I am now trying to figure out how to get a few other things to work. For example I don't see the option to run the needle sweep on my model year.
  5. Likes jyoung8607, Jack@European_Parts, Uwe liked this post
  6. #4
    So force induced FOD?
    Quote Originally Posted by bernstma View Post
    I do not think the C6 instrument clusters support that.
    Dec 2018
    New York, USA
    Looking at my car manual for the 2005 Quattro it says to select the instrument cluster menu to turn on/off speed warning. If I go into the VCDS and I change the coding to what you suggested what will happen? Can it make the car inoperable?
    Dec 2018
    New York, USA
    What is FOD?
  10. #8
    Tartu, Estonia
    Pre-FL doesn't support that.
    The world is my oyster...
  12. #9
