Results 1 to 2 of 2
Thread: 2007 Audi A6 Left side DRL not working
    May 2018
    Cool 2007 Audi A6 Left side DRL not working
    1st, I LOVE working on cars.. (and do own a VCDS kits..etc)
    2nd I NEVER ask for help, until I spends hours trying to get it to work..etc.. ha ha ha.
    ok, Here is what i have done. The Left side light assembly (LA) using VCDS did show a short in the system (also when i start the car is showed I had a error at left light) also the main light would not move.(but ALL lights work (Just not DRL on left side).
    I took off light and looked inside and see LOTS of wires that are shorted because the outer covers of the wires are missing (I here this is a normal issue with older Audi's (like my model).I tried for hours using liquid tape to cover all the wires..and then after that.. it still didn't fix the system.
    So I googled/ebay/letgo/junk yard..etc for DAYS and also found some money "after selling my newborn" j/k yes, these LIGHTS COST A LOT!!!! i bought it for $299. free shipping (but didn't come with the 2 outside modules)
    so then i swapped out the used light with my broken one. put both 2 modules on the used light assembly.... and BINGO it fixed my error that showed I HAD a error with my Adaptive light (the motor did work with this "used one I bough)t.. and also doesn't show any SHORTS on VCDS) i also cleared all codes...
    BUT still i don't have a working left DRL.
    So then I replaced the bulb with a new one form Walmart ( :O) )... that still didnt fix the issue.
    then I SWAP the right DRL bulb with the left one.. and NOPE... it didn't work.. but the RIGHT DRL still does work.
    Then I looked at the part numbers of the 2 outside mods (from the right light and the left light.. saw they are the same part numbers).. and then SWAP them..... Still NO left DRL light BUT the right DRL one still works....
    i even swapped the DRL bulb black adapter with the right side and it STILL didn't fix the issue... but the right side DRL still works with the parts from the "used left light kit)
    measured 13V from Pin 12 on Wire adapter that fits onto the light kit when DRL is set to on... I also measure 9V on the SAME pin when the car is OFF (and the Key is out of the car)
    I even made a new Ground on PIN 7 from the adapter.. I still get 9V when car is off and 13V when DRL is on (BUT still not DRL light ONLY on the left side of car)
    I even clean most of the Ground point on front of the car (where there is mostly Brown cables for ground)
    then I went into the car and turned off the DRL feature and coming home and leaving home...etc to see if would just confused and still didn't fix the issue.
    So i am asking for help, please, what do I do next??? i have checked for broken pins on the LA to see if anything was bent on it...but there wasn't.
    here is what I HAVE NOT DONE.... is to SWAP out the WHOLE LA with right and left.. and see if the RIGHT side DRL does not work.. and the left DRL does... but iI am scared that the Audi will freak out that it has left and right lights swapped... and the HID mod some the right is a different part number. i didn't want to this until I see what you pros thinks I should do.
    I also have NOT check any fuses... but why would a fuse only control ONE of the DRL??? BUT MAYBE on a Audi it does....
    So guys and girls... Please help me on what I should do next....
    thanks
    Marco
    Saturday,12,May,2018,12:31:10:44412
    VIN: WAUAH74F37N101029   License Plate: NOCODE_CLEAN_AFTER_LIGHT
    Mileage: 216040km-134241mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
              53 55 56 61 62 65 72 77
    VIN: WAUAH74F37N101029   Mileage: 216040km-134241miles
    Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
       Part No SW: 4F2 910 559 C    HW: 4F1 907 559 E
       Component: 3.2l V6 FSI         0020
       Revision: --H19---    Serial number:
       Coding: 0105010902070120
       Shop #: WSC 02325 785 00200
       VCID: 2C01F8EADA01E0A7FE0-8078
    Readiness: 0010 0101
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 4F2 910 155 B    HW: 01J 927 156 JG
       Component: V30 01J 3.2l 4V USA 0010
       Revision: --H03---    Serial number: 00000000000395
       VCID: 231313D6B7DF2FDF4FA-8076
       Part No SW: 4F0 910 517 AC    HW: 4F0 614 517 T
       Component: ESP8 front      H01 0070
       Coding: 0020826
       VCID: 65974DCEF96B11EFE1E-8030
       Part No SW: 4F0 910 852 A    HW: 4F0 905 852 C
       Component: FBSAUDIC6 ELVSG H01 0030
       Revision: 31050601    Serial number: 10601200621875
       Coding: 0000003
       Shop #: WSC 02323 785 00200
       VCID: 241110CAB2D128E7360-8070
       Subsystem 1 - Part No: 4F0 910 131 J
       Subsystem 2 - Part No: 4F0 910 220 A
       Component: FBSAUDIC6 IDG   H01 0040
       Part No SW: 4F0 910 732 Q    HW: 4E0 035 729
       Component: Interfacebox    H43 4610
       Revision: 00000000    Serial number: 303LF067532011
       Coding: 0000003
       Shop #: WSC 02335 785 00200
       VCID: 313FE99EFD238D4FCD6-8064
       Subsystem 2 - Serial number: 00000000615471
       Subsystem 3 - Serial number: 0112.12.060000000100011079ÿ
       Subsystem 4 - Serial number: 011079ÿ
       Part No SW: 4F0 910 043 A    HW: 4F1 820 043 AG
       Component: KLIMABETAETIGUNGH30 0020
       Revision: 00000052    Serial number: 00000000338856
       Coding: 0524326
       VCID: 1C61282A8AA110278E0-8048
       Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
       Coding: 0114123
       VCID: 3039EC9AF6298447C28-8064
       Subsystem 1 - Part No: 4F1 910 113 C  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0210
       Coding: 00064784
       Shop #: WSC 02335
       Coding: 00146221
       Shop #: WSC 02335
       Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
       Component: MP3-Changer     H44 0390
       Revision: 00044000    Serial number: AUZ5ZBF3129593
       VCID: 1A6D2E3280956E179CC-804E
    Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
       Part No SW: 4E0 910 593 H    HW: 4E0 035 593 D
       Component: SDAR SIRIUS     H06 0080
       Revision: 00000000    Serial number: AUZ4Z7G0066561
       Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
       Component: 66 AIRBAG AUDI8RH30 0300
       Revision: 15H30000    Serial number: 00359D0F0LH/
       Coding: 0013878
       VCID: 2A0DFEF2D0F5FE970CC-807E
       Subsystem 1 - Part No: 4F0 910 339 A
       Component: BF-Gewichtsens. H02 0050
       Subsystem 2 - Serial number: 6332CSME14494A092
       Subsystem 3 - Serial number: 6342CSME15467027.
       Subsystem 4 - Serial number: 6352QSME1C581741G
       Subsystem 5 - Serial number: 6362QSME1A68355DT
       Subsystem 6 - Serial number: 63734SME196D274FF
       Subsystem 7 - Serial number: 63834SME1C442F579
       Revision: 00H08000    Serial number: 90026063420160
       Coding: 0012041
       VCID: 66954AC2046D1AF7E84-8032
       Part No SW: 4F0 910 930 C    HW: 4F0 920 981 G
       Component: KOMBIINSTR. M73 H19 0120
       Revision: 00000000    Serial number: 5FG3294D6
       Coding: 2129268
       Shop #: WSC 25166 444 105619
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 1300806C088315
       Coding: 6CFE73CD1B3904
       Shop #: WSC 25169 444 54100
       VCID: 270B07C6C3E7C3FF132-8072
       Coding: 0082946
       Shop #: WSC 02334 785 00200
       VCID: 619F59DEED437DCF1D6-8034
       Part No SW: 4E0 910 888 D    HW: 4E0 919 887 L
       Component: MNS US          H48 0970
       Revision: 00000000    Serial number: 381LZ067515627
       VCID: 2F3BEFE6EB179BBFDB2-807A
       Component: TSG FA          H12 0120
       Revision: 00000000    Serial number: t
    )[1]
       Coding: 0035563
       Shop #: WSC 02327 785 00200
       Component: Komfortgeraet   H22 0170
       Revision: 01700022    Serial number: 01027947830000
       Coding: 4618269
       VCID: 2E05F2E2EC1D92B7D04-807A
       Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
       Component: DSP-High C6     H10 0240
       Revision: PROD_01     Serial number: 00000000009663
       Coding: 0000016
       VCID: 25170DCEB9EBD1EF21E-8070
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Revision:             Serial number: 00000000065477
       Coding: 0002014
       VCID: 5EE56222DC3D4237204-800A
       Component: TSG BF          H12 0120
       Revision: 00000000    Serial number: ‡S([1]
       Coding: 0035563
       Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
       Component: EPB  CDEC0080   H04 0080
       Revision: --H04---
       Coding: 0005032
       Shop #: WSC 00000 785 00200
       VCID: 20191CDAA6C934C7528-8074
       Coding: 0000016
       VCID: 290F01FED5F3F58F056-807C
       Subsystem 1 - Part No: 4F0 941 329 B
       Component: AFS-Modul links H02 0020
       Subsystem 2 - Part No: 4F0 941 329 B
       Component: AFS-Modul rechtsH02 0020
       Part No SW: 4E0 910 541 T    HW: 4F0 035 541 H
       Revision: 00000000    Serial number: 394LP06B001106
       Revision: 00000000    Serial number: 00000000167435
       Shop #: WSC 00000 384 00290
       Component: von VA0  2612120059
       Coding: 344630393135313035442056413032363132313230303539
       Coding: 0035370
       Revision: 00050100    Serial number: 00000700038363
       Coding: 0062221
       VCID: 221D16D2A8C526D744C-8076
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Coding: 0035370
       Component: Handyvorb2      H16 1130
       Revision: 00000000    Serial number: 00000007559484
       Coding: 0010900
       VCID: 280904FACEF9CC871A8-807C
    End----------(Elapsed Time: 01:57, VBatt start/end: 12.9V/12.7V)-----------
  2. Likes Uwe, Bruce liked this post
  3. #2
    Mar 2014
    Slovenia
    First try to check the wiring from J519 to your faulty headlight connector.(Central electric->output test->left DRL )This will confirm that the output from the J519 is OK or NOT.At first try to trigg the working right DRL light so that you would know which output to test on the left side.If the wiring from light to module is OK than probably your J519 is fried.There is no fuses for drl lights.
