ETKA equipment decode request
chaosb
New Member
Poland
Hello mates
Maybe some1 have etka and can decode equipment of golf sportsvan 2016? WVWZZZAUZGW567564
chaosb
New Member
Poland
i dont see anything in spare wheel and dont have vehicle data sheet
Bruce
Near Philadelphia, PA, USA
siLc
Tallinn, Estonia
C?ID=330192
Don't have a sticker like this? This is the data sheet mentioned.
Jacek
Poland
C?ID=360566
The sticker with PR codes should be behind the plastic cover of the rear trunk strap.
downtime
C?ID=280813
No need to pay until there are free VW PR code decoders such as this http://igorweb.org/equidec.aspx
Write the three-letter codes from the vehicle's data sheet into it as instructed. Vehicle's data sheet can be found in the service handbook and spare wheel well.
Only issue is that the trunk PR code sheet is not complete list of cars equipment. It only has the major things. Erwin list is complete list down to handbook PR code :)
And of course during that one hour you'll get to see all the TSB's for your car and if there are pending SW updates plus as a sugar on top, you can download repair guides, wiring diagrams etc.
naushad2982
Kenya
C?ID=58306
There you go
Special editionsE15Club & Lounge
Lockable wheel bolts1PFStandard wheel bolts
Vehicle class differentiation units/platform components7LXVehicle class differentiation -5GP-
tail pipe0P7Rear side exhaust tailpipe
Emission standard7MMEmission standard EU6 plus
Trailer hitch1D0Without trailer hitch
airbag4UPAirbag for driver and front passenger with knee airbag and front passenger airbag deactivation
Aktivkohlebehälter / Ottopartikelfilter1E1Activated carbon canister
Storage compartment packageQE0Without storage compartment package/box
Storage compartment7N3Comfort overhead storage compartment
Aerials8ZHAntenna for AM/FM reception, "diversity"
Exterior mirror setting6XQExterior mirrors with memory feature, power-folding/adjustable, separately heated
Follow-on warrantyEA83 years follow-on warranty, max. 100 000 km
Left exterior mirror5SLLeft exterior mirror, aspherical
Electronic engine sound measuresGM1Standard electronic engine sound
Right exterior mirror5RQRight exterior mirror: convex
Alternative drive system0K0Without alternative drive system
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WCWithout "Multimedia" in vehicle
Equipment levelsA8CComfort equipment
Area monitoring systems6K2Forward collision warning incl. autonomous emergency braking, without adaptive cruise control
Brake type in rear1KEDisc brakes in rear
batteriesJ0SBattery 320 A (59 Ah)
Brake type, front1ZFDisc brakes in front (Geomet D)
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0Abuild parts set without county specific documentatio
vehicle tools and jack1S1vehicle tools and jack
Brake systems1AZElectronic stability control (ESC)
Owner's manuals0VCInformation kit in German
Operating voltage9Z0Operating voltage 12 V
Brake pad wear indicator9U1Brake pad wear indicator
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
"Charism"2H0Without "drive select"
Chrome packageQJ1Chrome package
General operating permit, alterationsC16Operating permit, alteration
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FAWithout roof insert (standard roof)
Suspension system in rear1JARear shock absorption, basic version 1
Suspension system in frontG05Shock absorption in front
Insert for the filling up of unleaded fuel/fuel type2G7Filler neck module 1 with insert
ECO function for driving profiles and Drive selectEF0without ECO function
Installation differentiation for components0ECInstallation differentiation for transmission MQ 200_GA -- vehicle components --
Theft protection system7AAElectronic immobilizer
Inserts7TNDecorative inserts
Scuff platesVT9Sill trim strips campaign versions
Park distance control7X2Park distance control in front and rear
Extended safety system7W0Without extended safety system
Electric interface for external use UF0Without electric interface
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
Pedal clusterVF0Standard pedal cluster
Headlight activation8K3Separate daytime running light with automatic headlight control and Coming Home feature
Fresh air intake for passenger compartment (with particulate filter)2V5Fresh air intake system with combination filter
Parking brakeUH2Parking brake
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category rear axle0YFWeight range 6 installation control only, no requirement forecast
Weight category front axleL04Suspension range 04 installation control only, no requirement forecast
Base engineTP14-cylinder SI engine 1.2 l unit 04E.B
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
Luggage compartment cover3U1Folding trunk cover
cruise control system8T6Cruise control system plus speed limiter
Transmission specificationsG0K6-speed manual transmission
handle for hand brake lever6PBWithout hand brake lever handle
Rear spoiler5J0Without rear spoiler
Rear window wiper and washer system8M1Rear window wiper washer system with intermittent wipe
Rear axle0N1Standard rear axle
Molded headliner6NAUnsplit molded headliner
Rear seats5KRRear seat bench/backrest, split folding
Heating and air-conditioning system9AKClimatronic with impact pressure control, CFC-free
Headlamps8IGGas discharge headlamp (D1/D3 system)
Customized installationFC0Without customized installation
Interior light in footwell6T0Without interior light in footwell
Instrument clustersU5AInstrument cluster, km/h speedometer
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
Body styleK8Pmpv
Camera/distance sensorQK0Without camera without distance sensor (driver assistance system)
Refrigerator1W2Glove compartment cooling system
child safety4H3Manual child safety lock
Folding table1U9Folding table on front seat backrests
Climatic zones0Y1Standard climatic zones
Compass/road sign displayQR8without road sign recognition
Rear head restraints3T2Three rear head restraints
Head restraints5ZFFront head restraints
Fuel quantity for initial filling1Z0Initial standard fuel filling
Tire categorizationA63Category 3
Fuel systems1A5Fuel system for fuel-injected SI engine
Body measures5C0Without special body measures
Camera systems/accident sensorsKA0without camera systems/environment sensors
Radiator grille6KCRadiator grille
refrigerantKK1Refrigerant R134a
License plate carrier31FFront license plate carrier (large)
Paint preservative/transit coating5K7Transport protection film (minimum protection) with additional transport protection measures
Paint coatingFB0standard paint coating
Rear cargo area3GNVariable luggage/load compartment floor
Light package (lighting)QQ0Without add. lights (interior lighting)
Steering system arrangementL0LLeft-hand drive
Reading lamp8S4Two reading lights in front, two in rear
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Light control systems8G1High-beam assistant
Lumbar support7P4Manually adjustable lumbar support in front seats
steering wheels2ZHLeather-wrapped multi-function steering wheel
Driving on the left/on the rightAV1Driving on the right
Speaker installation8RM8 speakers (passive)
Headlight range control8Q3Dynamic headlight range control (self-adjusting while driving)
Center armrest6E3Center armrest in front
VersionsFM0Basic equipment variant
Multi-function display/trip computer9S5Multi-function display/trip computer "Medium"
Center console3D1Center console
Driver alert systemEM1Driver alert system
Engine cooling8Z5not hot country
Engine specificationsDB84-cylinder SI engine 1.2 l/ 81 kW TSI base engine is TP1/T7I
Navigation device7Q0without navigation system
rear fog lamp8TBrear fog lamp
Front fog lamp/additional headlamp8WHFront fog lamp and cornering lamp
Online servicesEL0Without online service
Rear of platform module base4P2Rear floor panel module, type 3
Hubcaps1NLTrims for alloy wheels
WheelsU30Alloy wheels 6.5J x 16
RadiosI7YMIB Entry Plus (Gen2)
Smoker's/non-smoker's package9JBSmoker's package, ashtrays in front and rear
Regional code for radioER1Regional code " ECE " for radio
Tire pressure monitoring system7K1Tire pressure monitoring system
tireH4JAll-season tires 205/55 R16 94V xl
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G6Space-saving spare wheel
Wheelbases0B3Wheelbase
Restraint systems, front3QT3-point seat belts in front, with pretensioner and height adjustment
PLDLights&Vision package
PXAXenon headlamps
WSM"LOUNGE"
ZBBSystem radiowy "Composition Colour"
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates2KWLabels in German, French and Dutch
Tail lamp assemblies8SARear combination lamp, standard design
Service indicatorQI6Service indicator 30 000 km or 2 years ( variable )
Seat belt check9P9Seat belt reminder, electric contact in the buckle, advanced safety equipment
Outer rear seat belts3ZB3-point seat belts, outer rear with ECE label
Center rear seat belts3C73-point seat belt for center rear seat
seat coversN2ZSeat trim covers for special editions
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A3seat heating for front seats separat controlable
Start-stop system/regenerative braking7L6Start-stop system with regenerative braking
Horns8Y1Two-tone horn
sun visors5XISun visors with mirror, illuminated, airbag label on sun visor
Audio-response system/voice controlQH0without voice control
Lane change assist/lane keeping system7Y0no lane change assistant
Side and rear windows4KFheat protective glass for door, side and rear windows, darkened from b-pillar
power outlet7B212 volt socket in luggage compartment
Bumper2JDSports bumpers
Rear stabilizer bar0BAWithout rear stabilizer
Front stabilizer bar0AEFront stabilizer bar
Drawers under front seatsQN3Drawers under front seats
Headlamp washer system8X1Headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N6Windshield wiper intermittent control with light/rain sensor
Special approval measures3M0Without special measures
Nameplate set0NWNameplate set "TSI"
Mass damper for steering wheels1Q0steering wheel without balance weight
Door and lid locking system4I2Central locking w/ radio remote control, interior controls, without SAFELOCK
Type approval countries/countries with special requirementsB01Type approval country Germany
Carrier frequency for remote control5D1Carrier frequency 433.92 to 434.42 Mhz
Partition3CAwithout partition
Door and side trim panels4AFDoor and side trim panel in foam film and woven fabric
doors0A24 doors
TV reception/digital radio receptionQV0Without TV reception/digital radio reception
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EXSpecial identification label for EC for M1 passenger vehicles
Delivery equipment2A0Without delivery equipment
First aid kit / warning triangle1T9First aid kit with warning triangle and safety vest
Front seatsQ2JComfort seats in front
Rear seat catchUK5Mechanical rear seat release
Telephone / telematics9W0Without car phone preparation/ installation
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG1LongLife Service Regime
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TPFront and rear floor mats
Decorative trims4ZEBlack decorative trims
Additional child seat anchors3B4Child seat anchors for child seat system ISOFIX
Auxiliary heating system9M0Without auxiliary heater/parking heater
