NEW TO AUDI NEW TO VCDS NEED SERIOUS HELP!!!
sheed44
C?ID=297477
If that's dead then a used CD unit will need component protection removed to work in your car. How desperate are you to have CDs? I ask because you can swap this for the AMI unit (ipod, USB MP3's etc..) which has no CP. Essentially a 10 minute job just by dropping the glove box and switching units and using the same connections.
Here's a used AMI, if a little overpriced... I have part number 4E0035785C AMI in my A8
http://www.ebay.com/itm/152345285646?
honestly I woud rather have the ipod usb and mp3 capability so maybe I would be wise to get on ebay and at least take a look, but again based off of my optical bus scan is that whats wrong with my system exactly? im new to all of this lol
   #22
sheed44
C?ID=297477
For the time being, add a MOST loop and bridge the media player. Then remove it from the installation list and you should be good to go. You can still install a new/used one or an aftermarket accessory later.
honestly I don't know how to do that? do I do it through VCDS? because I cant get any type of further display other than the Audi logo and then the MMI shuts down, the controls light up briefly then go dark also
   #23
sheed44
C?ID=297477
Like most people stated on your thread I would purchase at lease 2 Loops for your data bus it's nice to have an extra for the future but also great for running a diagnostics on the data bus. Erwin is your best friend for sure, I do have some PDF's I could share from Erwin when I purchased it Delete repeated word is expensive but much cheaper then going to the Stealers.... That is of course if that is OK with Uwe not sure if I'm allowed to share what I have from Erwin on the Thread?? Anyways for your Motor mount issue that was a problem from the start with the electronic Motor mounts and Audi created a plug special for them, I had to use a couple of them to get the codes replaced, I would just look at the mounts visually.. That is as far as I go for now until you get some progress on your data bus and I will continue to help...
This will help// Engine
1) Engine mount there is a plug that bypasses this DTC and if needed I can locate that part number for you tomorrow sometime.
please do and where is it located exactly? and do I hook up VCDS to it? and please share the PDF's if possible I just want the car to be the best it can be without the high dealership costs
   #24
sheed44
C?ID=297477
and this part will work in the 04?
   #26
BostonSlaya
Rhode Island, USA
C?ID=240768
I would start with buying two of the Fiber Optic Loop Part number 4E0-973-802
Once you get these in the mail your in business!!
   #27
sheed44
C?ID=297477
ok I have located a couple of the fiber Optic Loops,
   #29
sheed44
C?ID=297477
So I got the MMI to work all this time it was a 5a fuse in the passenger side fuse compartment that I didn't know existed smh rookie mistake, so now my next issue is how to access the battery management and ride suspension features and any other feature associated wit the MMI. And another issue I was having with the car is my battery drains after it sits for maybe over 5 hours and I hadn't had this problem the first 3 or four days I owned the car but I was checking some fuses in the back near the battery and may have put one back in the wrong place, not sure as I don't know what those fuses all go to in the first place. and just within the last couple of days the driver door lights up on the dash display as being open and dings when the door is clearly closed not sure what this is either I will rescan the vehicle and see what new codes pop up the MMI version I have is
SW:d3-HU 41.4.0 0709
BostonSlaya
Rhode Island, USA
C?ID=240768
New scan please after getting the MMI. there is a few reasons you got battery drain here but one known factor is the alarm horn. These are known for the batteries inside to leak into it. Check the wiring and if needed replace it. Open the drivers door and lock it manually with the door still open and see if it works first. Also for you fuses there is fuses on the drivers side panel left of the steering wheel and on the other side on the passenger side,they should have stickers of the fuse placements on the backside of the covers you remove unless yours are missing if they are Let me know
sheed44
C?ID=297477
I have those two figured out its the two rear fuse panels I don't know what they are, and I will scan everything in a sec and how would I get the MMi to show the battery level and suspension options as mine doesn't even have an option for them
   #32
BostonSlaya
Rhode Island, USA
C?ID=240768
Via VCDS go into
07-Controler Head
10-adaptation
Go into channel 2
In the new value location put in 35 and click test then Save and select yes done go back then restart the MMI then you should have it.
   #33
sheed44
C?ID=297477
here are the results after the re scan of the Optical Bus
Monday,30,January,2017,11:07:03:42098
VCDS Version: 17.1.2.0 (x64)  HEX-V2 CB: 0.4334.4
Data version: 20170127 DS267.1
Mileage: 227960km-141647mi   Repair Order: 3
Control Module Part Number: 4E0 910 468 A
  Component and/or Version: Gateway         H07 0030
Optical Bus Diagnostic : Standard
Controller          	Electrical          	Optical
19-CAN Gateway      	OK                  	OK
07-Control Head(High/D3)	OK                  	OK
0E-Media Player 1   	ERROR               	ERROR
47-Sound System     	OK                  	OK
56-Radio            	OK                  	OK
37-Navigation       	OK                  	OK
   #34
BostonSlaya
Rhode Island, USA
C?ID=240768
56-Radio            	OK                  	OK
37-Navigation       	OK                  	OK
Still would like to see a full AutoScan. Also looks like you still have a Data Bus issue so you would still need the loop, this will still keep your car from going nighty night
   #35
sheed44
C?ID=297477
and here is the scan and clearing and rescan done this am
0E-Media Player 1 -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 1010
Address 01: Engine        Labels: None
   Part No SW: 4E0 910 560 P    HW: 4E0 907 560
   Component: 4.2L V8/5V      G   0020
   Revision: --------    Serial number: AUX3Z0D0532489
   Coding: 0007773
   Shop #: WSC 24103 444 84355
   VCID: 2E06043A5C1D02578FF-807A
7 Faults Found:
18061 - Please check DTC Memory of ABS Controller
            P1653 - 008 -
                    Fault Status: 01101000
                    Mileage: 226778 km
                    Load: 0.0 %
                    Temperature: 4.0°C
                    Temperature: 6.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 11.557 V
17981 - Left Engine Mount Solenoid Valve (N144)
            P1573 - 004 - Open Circuit
                    Mileage: 226778 km
                    RPM: 141 /min
                    Load: 74.9 %
                    Temperature: 4.0°C
                    Temperature: 6.0°C
                    Voltage: 9.906 V
17831 - Secondary Air Injection System; Bank 1
            P1423 - 002 - Insufficient Flow - MIL ON
                    Fault Status: 11100010
                    Mileage: 227799 km
                    RPM: 1378 /min
                    Load: 18.4 %
                    Speed: 81.0 km/h
                    Temperature: 77.0°C
                    Temperature: 8.0°C
                    Voltage: 13.716 V
17819 - Secondary Air Injection System; Bank 2
            P1411 - 002 - Insufficient Flow - MIL ON
                    Mileage: 227799 km
                    RPM: 1378 /min
                    Load: 18.4 %
                    Speed: 81.0 km/h
                    Temperature: 77.0°C
                    Temperature: 8.0°C
                    Voltage: 13.716 V
                    Load: 0.0 %
                    Temperature: -40.0°C
                    Voltage: 0.000 V
17985 - Right Engine Mount Solenoid Valve (N145)
            P1577 - 004 - Open Circuit
                    Fault Frequency: 6
                    Mileage: 227802 km
                    RPM: 168 /min
                    Load: 72.5 %
                    Temperature: 27.0°C
                    Temperature: 27.0°C
                    Voltage: 9.144 V
16502 - Engine Coolant Temp. Sensor (G62)
            P0118 - 002 - Signal too High - Intermittent
                    Mileage: 227898 km
                    RPM: 1426 /min
                    Load: 27.0 %
                    Temperature: 44.0°C
                    Voltage: 10.668 V
Readiness: 0000 0101
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
   Component: AG6 09E 4,2L5V USA  0110
   Revision: 00000001    Serial number:        0028405
   Shop #: WSC 02313 785 00200
   VCID: 2412E61202D1B80769B-8070
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 N
   Component: ESP 5.7 allrad  H44 0500
   Coding: 0007597
   Shop #: WSC 24103 000 00000
   VCID: 221EE00A18C5B6371B7-8076
01200 - ABS Valves Supply Voltage
            000 -  -
            000 -  -  - Intermittent
00285 - ABS Wheel Speed Sensor; Front Right (G45)
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 A
   Component:     FBS AUDID3  H03 0140
   Revision: 01403903    Serial number: AUX3Z0D0532489
   Coding: 0263168
   Shop #: WSC 02311 785 00200
   VCID: 58EA82E20E192CE7353-800C
                    Reset counter: 241
                    Mileage: 226864 km
                    Date: 2003.10.09
                    Time: 03:41:12
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory BFS H07  0060
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 3940448
   VCID: 2310E50E07DFBF3F101-8076
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 732 B    HW: 4E0 035 729
   Component: Interfacebox    H43 4140
   Revision: 00000000    Serial number: 346AB047509000
   Coding: 0000000
   VCID: 211CEF061DC3AD2F02D-8074
   Subsystem 1 - Part No: 4E0 910 609 C
   Component: Bedienteil MMI  H42 0100
   Subsystem 2 - Serial number: 390FU057502768
   Subsystem 3 - Serial number: 7422.06.0500000000290B0023ÿ
   Subsystem 4 - Serial number: 0B0023ÿ
00384 - Optical Databus
                    Fault Status: 00101011
                    Fault Frequency: 216
                    Reset counter: 245
                    Time Indication: 15
            000 -  -
                    Time Indication: 15
00532 - Supply Voltage B+
                    Reset counter: 245
                    Time Indication: 15
   Part No SW: 4E0 910 043     HW: 4E0 820 043 B
   Component: KLIMAAUTOMAT    016 0240
   Revision: 00000022    Serial number: 00000000034086
   Coding: 1085761
   VCID: 5AEE98EA70153EF7037-800E
   Subsystem 1 - Part No: 4E0 910 772 A
   Component: Sitzluefter  FS H02  010
   Subsystem 2 - Part No: 4E0 910 772 A
   Component: Sitzluefter BFS H02  010
   Subsystem 3 - Serial number: 898053000
   Subsystem 4 - Serial number: HO16012004065A000000000424ÿ†89
   Subsystem 5 - Serial number: 000424ÿ†898053000      000-SHO
   Subsystem 6 - Serial number:     000-SHO16012004065A00000000
   Subsystem 7 - Serial number: 65A000000000467ÿ
01232 - A/C Compressor Regulator Valve (N280)
                    Fault Status: 00101010
                    Reset counter: 239
                    Mileage: 226779 km
                    Date: 2003.10.08
                    Time: 15:51:41
                    Load: 90.0 %
                    Current: 0.000 A
                    Reset counter: 242
                    Mileage: 226779 km
                    Date: 2003.10.08
                    Time: 15:51:51
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
   Component: ILM Fahrer      H11 0100
   Coding: 0111113
   VCID: 2A0E082A60F56E77537-807E
   Subsystem 1 - Part No: 4E1 910 113 B
   Component: Wischer WWS D3  H40 0380
   Coding: 00000036
   Shop #: WSC 02313
01498 - Bulb for Parking Lamps; Right (M3)
                    Fault Status: 01101010
                    Reset counter: 209
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 10:51:35
01494 - Bulb for Parking Lamps; Left (M1)
                    Reset counter: 209
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 10:51:36
                    Reset counter: 209
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 10:51:37
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111
   Component: CD-Changer      H43 0470
   Revision: 00000501    Serial number: AUZ5ZBC1022182
   VCID: 1C62DEF23AA180C7D1B-8048
02261 - Data Medium
                    Fault Status: 00101110
                    Fault Frequency: 81
                    Reset counter: 35
                    Mileage: 220150 km
                    Date: 2003.10.08
                    Time: 00:00:20
                    Text: 00000000
                    Reset counter: 171
                    Mileage: 220195 km
                    Date: 2003.11.18
                    Time: 13:51:43
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
   Component: Airbag 8.4E+    H10 0920
   Coding: 0530707
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549 A
   Component: Lenksäulenmodul H13 0040
   Coding: 0012241
   VCID: 6594BB16496B810FBE5-8030
   Component: Lenkradmodul    H04 0080
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 900     HW: 4E0 920 950 B
   Component: KOMBIINSTR. VDO H44 0090
   Revision: D15         Serial number: AUDID3D0006575
   Coding: 0016203
   VCID: 5CE29EF27A21C0C711B-8008
Address 19: CAN Gateway        Labels: 4E0-910-468.clb
   Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
   Component: Gateway         H07 0030
   Revision: 07          Serial number: 0200503C08128A
   Coding: FCFE7BDD1B2304
   VCID: 2616FC1A74ED4A1777F-8072
                    Fault Frequency: 50
                    Reset counter: 245
                    Mileage: 226778 km
                    Date: 2003.10.08
                    Time: 11:03:56
00465 - Control Module for Telephone/Telematic (J526)
                    Reset counter: 245
                    Mileage: 227837 km
                    Date: 2003.10.08
                    Time: 02:02:12
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0263168
   XXXXXXXXXXX ELV                 XXXX
                    Reset counter: 241
                    Mileage: 226864 km
                    Date: 2003.10.09
                    Time: 03:41:12
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
   Component: LUFTFDR.-CDC    H05 4290
   Coding: 0015510
   VCID: 2514FB1609EB410F7E5-8070
01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
                    Fault Status: 11101010
                    Fault Frequency: 19
                    Reset counter: 209
                    Fault Frequency: 18
                    Reset counter: 245
                    Mileage: 226778 km
                    Date: 2003.10.08
                    Time: 10:55:11
01772 - Signal from Level Control Pressure Sensor (G291)
                    Fault Frequency: 21
                    Reset counter: 249
                    Mileage: 226779 km
                    Date: 2003.10.08
                    Time: 15:50:58
01577 - Turn-Off due to Over-Temp
                    Fault Status: 00100001
                    Reset counter: 247
                    Mileage: 227372 km
                    Date: 2003.10.08
                    Time: 00:21:41
   Component: Sitzmemory FS  H07  0060
   Coding: 4071522
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
   Component: MNS US          H43 1100
   Revision: 00000000    Serial number: 355AM047515059
   VCID: 382A2262AE59CCE7D53-806C
7 Faults Found:
                    Reset counter: 245
                    Mileage: 221897 km
                    Date: 2003.10.10
                    Time: 16:30:47
                    Hex Value: 0x3F86
                    Hex Value: 0xDEB7
                    Hex Value: 0x004F
                    Reset counter: 245
                    Mileage: 221898 km
                    Date: 2003.10.08
                    Time: 00:00:11
                    Hex Value: 0x3F83
                    Hex Value: 0x538B
                    Hex Value: 0x009F
02445 - Disk Drive Initialization Error
                    Reset counter: 0
                    Mileage: 220193 km
                    Date: 2003.11.17
                    Time: 22:33:37
                    Hex Value: 0x3F9B
                    Hex Value: 0xB74E
                    Hex Value: 0x4E56
                    Hex Value: 0x0000
02444 - Disk Drive Load / Eject Malfunction
                    Reset counter: 171
                    Time Indication: 15
                    Reset counter: 171
                    Mileage: 221897 km
                    Date: 2003.10.10
                    Time: 16:22:03
                    Hex Value: 0x3F86
                    Hex Value: 0xDCAB
                    Hex Value: 0x004A
03183 - Data Media not Compatible
                    Reset counter: 171
                    Time Indication: 15
                    Hex Value: 0xFFFF
                    Hex Value: 0xFFFF
                    Hex Value: 0x0000
                    Hex Value: 0x9494
02927 - DVD Read Error
                    Fault Frequency: 255
                    Reset counter: 247
                    Mileage: 214703 km
                    Date: 2014.09.30
                    Time: 17:42:13
                    Hex Value: 0x588E
                    Hex Value: 0x92FF
                    Hex Value: 0x0401
                    Hex Value: 0x0000
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H01 0090
   Serial number: 00000334300180
   Coding: 0003989
   VCID: 1D64D3F621BB89CF265-8048
00410 - Pre-Selection Signal for Opening Sunroof
                    Fault Status: 00100111
                    Fault Frequency: 8
                    Reset counter: 243
                    Mileage: 227388 km
                    Date: 2003.10.08
                    Time: 01:10:00
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 801
   Component: Türsteuer.FS BRM005 0110
   Coding: 0028196
   VCID: 5EE694FA6C3DD2D77FF-800A
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H03 0030
   Revision: 00300003    Serial number:  W040312180022
   Coding: 0065150
   VCID: 2708F11E73E7531F4C9-8072
   Component: Heckdeckel      H06 0060
   Component: Neigungssensor  H02 0020
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 209
                    Mileage: 213427 km
                    Date: 2003.10.09
                    Time: 20:24:59
01134 - Alarm Horn (H12)
                    Fault Status: 01101100
                    Reset counter: 102
                    Mileage: 219722 km
                    Date: 2016.01.03
                    Time: 16:39:11
                    Reset counter: 102
                    Mileage: 219722 km
                    Date: 2016.01.03
                    Time: 16:39:11
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 M    HW: 4E0 035 223 B
   Component: DSP-High D3/AUX H13 0450
   Revision: Dev_D01     Serial number: 00000000674361
   Coding: 0000016
02084 - Component Protection
                    Fault Status: 01100101
                    Reset counter: 216
                    Mileage: 160971 km
                    Date: 2010.11.11
                    Time: 19:44:50
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H08 0020
   Revision:             Serial number: 00000000031180
   Coding: 0010111
   VCID: 1E66D4FA2CBD92D73FF-804A
   Subsystem 1 - Part No: 4E0 910 511 A
   Component: UGDO HL US      H02 0030
   Subsystem 2 - Serial number: VK4978T0B79E
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
                    Fault Frequency: 16
                    Reset counter: 209
                    Mileage: 227836 km
                    Date: 2003.10.08
                    Time: 02:08:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
                    Fault Status: 00110100
                    Fault Frequency: 6
                    Reset counter: 247
                    Mileage: 227836 km
                    Date: 2003.10.08
                    Time: 02:08:00
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 802
   Component: Türsteuer.BF BRM007 0110
   Coding: 0028196
                    Reset counter: 242
                    Mileage: 226768 km
                    Date: 2003.10.08
                    Time: 10:55:28
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revision: AV1C1010
   Coding: 0000532
   Shop #: WSC 24103 444 52497
02438 - Left Parking Brake Motor Hall Sensor
                    Fault Frequency: 18
                    Reset counter: 249
                    Mileage: 227392 km
                    Date: 2003.10.08
                    Time: 02:28:11
                    Voltage: 10.66 V
                    Count: 96
01316 - ABS Control Module
                    Fault Status: 00101101
                    Fault Frequency: 218
                    Reset counter: 249
                    Mileage: 226864 km
                    Date: 2003.10.09
                    Time: 04:01:54
                    Voltage: 12.84 V
                    Count: 236
02434 - Supply Voltage for Control Module for Left Channel
            006 - Short to Plus - MIL ON
                    Fault Status: 11110110
                    Fault Frequency: 25
                    Reset counter: 201
                    Voltage: 9.21 V
                    Count: 110
02596 - Rear Brake Pads Worn
                    Fault Status: 01111000
                    Reset counter: 201
                    Voltage: 9.21 V
                    Count: 61
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0040
   Coding: 0000001
   VCID: 629EA00A5845F6375B7-8036
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541
   Component: TUNER EU/US/RDW H41 0620
   Revision: 00000000    Serial number: 304AH047557504
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 B    HW: 4E0 915 181
   Component: ENERGIEMANAGER  H02 0240
   Revision: 00000000    Serial number: 00000006225939
   Shop #: WSC 24101 444 01039
   VCID: 1F18E9FE2BB79BDF349-804A
   Subsystem 1 - Part No: 000 915 105 AK
   Component: von VA0  1401010139
   Coding: 303030393135313035414B56413031343031303130313339
   Shop #: WSC 00000 128 00289
02273 - Quiescent Current Stage 2
                    Fault Frequency: 10
                    Mileage: 226778 km
                    Date: 2003.10.08
                    Time: 13:09:40
02276 - Quiescent Current Stage 5
                    Mileage: 226778 km
                    Date: 2003.10.08
                    Time: 15:11:20
02274 - Quiescent Current Stage 3
                    Mileage: 226778 km
                    Date: 2003.10.08
                    Time: 15:11:27
02277 - Quiescent Current Stage 6
                    Mileage: 226778 km
                    Date: 2003.10.08
                    Time: 15:11:37
02272 - Quiescent Current Stage 1
                    Mileage: 227902 km
                    Date: 2017.01.30
                    Time: 07:17:18
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 801 A
   Component: Türsteuer.HL BRM007 0110
   Coding: 0028196
   VCID: 5DE493F6613BC9CF665-8008
                    Fault Frequency: 6
                    Reset counter: 243
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273     HW: 4E0 907 273
   Component: Reifendruck 2   H01 0210
   Coding: 0212127
   VCID: 5F98A9FE6B37DBDF749-800A
01477 - System Switched Off
            000 -  -
                    Fault Frequency: 44
                    Reset counter: 209
                    Mileage: 226871 km
                    Date: 2003.10.09
                    Time: 03:52:04
                    Temperature: -6.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
            004 - No Signal/Communication - Intermittent - MIL ON
                    Fault Status: 10100100
                    Reset counter: 249
                    Mileage: 226860 km
                    Date: 2003.10.08
                    Time: 19:13:26
                    Speed: 90.0 km/h
                    Temperature: -3.0°C
                    Error Code: 32768
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 802 A
   Component: Türsteuer.HR BRM007 0110
   Coding: 0028196
Address 75: Telematics        Labels: None
   Part No SW: 4E0 910 616     HW: 4E0 035 616 A
   Component: Telematik USA1      0070
   Revision: 00000004    Serial number: 0000ATD3007687
   Coding: 0000005
   VCID: 609AAA025659E4274D3-513C
01531 - Emergency Battery
            002 - Lower Limit Exceeded - MIL ON
00003 - Control Module
            014 - Defective - MIL ON
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Component: Parkhilfe 8-Kan H11 0010
   Revision: --.--.--    Serial number: 00000400900020
   Coding: 0001208
End----------(Elapsed Time: 02:11, VBatt start/end: 11.2V/11.1V)-----------
   #36
sheed44
C?ID=297477
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 05: DTCs cleared
Address 06: DTCs cleared
Address 07: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 0E: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 25: DTCs cleared
Address 34: DTCs cleared
Address 36: DTCs cleared
Address 37: DTCs cleared
Address 38: DTCs cleared
Address 42: DTCs cleared
Address 46: DTCs cleared
Address 4F: DTCs cleared
Address 52: DTCs cleared
Address 53: DTCs cleared
Address 55: DTCs cleared
Address 61: DTCs cleared
Address 62: DTCs cleared
Address 65: DTCs cleared
Address 72: DTCs cleared
Address 75: DTCs cleared
Address 76: DTCs cleared
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
          47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E04N018154   Mileage: 227960km-141647miles
   Coding: 0007773
            P1653 - 008 -
                    Mileage: 227963 km
                    Load: 0.0 %
                    Temperature: 33.0°C
                    Temperature: 32.0°C
                    Voltage: 11.176 V
Readiness: 0110 1101
   Coding: 0007597
   Coding: 0263168
   Coding: 3940448
   Coding: 0000000
            000 -  -
                    Time Indication: 15
   Coding: 1085761
   Coding: 0111113
   Coding: 00000036
   Shop #: WSC 02313
                    Reset counter: 209
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 10:51:35
                    Reset counter: 209
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 10:51:36
                    Reset counter: 209
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 10:51:37
   Coding: 0530707
   Coding: 0012241
   Coding: 0016203
   Coding: 0263168
   Coding: 0015510
                    Reset counter: 209
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 10:59:57
   Coding: 4071522
   Coding: 0003989
   Coding: 0028196
   Coding: 0065150
                    Reset counter: 209
                    Mileage: 213427 km
                    Date: 2003.10.09
                    Time: 20:24:59
                    Reset counter: 102
                    Mileage: 219722 km
                    Date: 2016.01.03
                    Time: 16:39:11
                    Reset counter: 102
                    Mileage: 219722 km
                    Date: 2016.01.03
                    Time: 16:39:11
   Coding: 0010111
   Coding: 0028196
   Revision: AV1C1010
   Coding: 0000532
                    Fault Frequency: 25
                    Reset counter: 201
                    Voltage: 9.21 V
                    Count: 110
                    Reset counter: 201
                    Voltage: 9.21 V
                    Count: 61
   Coding: 0000001
Address 56: Radio
            000 -  -
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:00:50
   Coding: 0028196
   Coding: 0212127
            000 -  -
                    Reset counter: 209
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:01:00
                    Temperature: 10.0°C
                    Error Code: 32768
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0028196
   Coding: 0000005
   Subsystem 1 - Part No: 4E0 910 616
No Faults Found
   Coding: 0001208
End----------(Elapsed Time: 02:48, VBatt start/end: 11.1V/11.1V)-----------
   #37
sheed44
C?ID=297477
Monday,30,January,2017,11:38:27:42098
VIN: WAUML44E04N018154   License Plate:
   Coding: 0007773
            P1653 - 008 -
                    Mileage: 227963 km
                    Load: 0.0 %
                    Temperature: 33.0°C
                    Temperature: 32.0°C
                    Voltage: 11.176 V
                    Mileage: 227963 km
                    RPM: 1449 /min
                    Load: 37.2 %
                    Temperature: 33.0°C
                    Temperature: 31.0°C
                    Voltage: 9.779 V
                    Mileage: 227963 km
                    RPM: 1449 /min
                    Load: 37.2 %
                    Temperature: 33.0°C
                    Temperature: 31.0°C
                    Voltage: 9.779 V
   Coding: 0007597
            000 -  -
   Coding: 0263168
   Coding: 3940448
   Coding: 0000000
                    Reset counter: 249
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:03:35
02103 - Control Module 2 for Vehicle Electrical System (J520)
                    Reset counter: 249
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:03:35
                    Reset counter: 249
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:03:35
                    Reset counter: 249
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:03:35
                    Bin. Bits:       01
                    Reset counter: 249
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:03:35
            000 -  -
                    Time Indication: 15
   Coding: 1085761
   Coding: 0111113
   Coding: 00000036
   Shop #: WSC 02313
                    Reset counter: 209
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:33:38
                    Reset counter: 209
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:33:38
                    Reset counter: 209
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:33:39
   Coding: 0530707
   Coding: 0012241
   Coding: 0016203
   Coding: 0263168
   Coding: 0015510
                    Reset counter: 209
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:34:53
   Coding: 4071522
   Coding: 0003989
                    Reset counter: 249
                    Mileage: 227960 km
                    Date: 2017.01.30
                    Time: 11:07:00
   Coding: 0028196
   Coding: 0065150
                    Reset counter: 209
                    Mileage: 213427 km
                    Date: 2003.10.09
                    Time: 20:24:59
                    Reset counter: 102
                    Mileage: 219722 km
                    Date: 2016.01.03
                    Time: 16:39:11
                    Reset counter: 102
                    Mileage: 219722 km
                    Date: 2016.01.03
                    Time: 16:39:11
   Coding: 0000016
                    Reset counter: 216
                    Mileage: 160971 km
                    Date: 2010.11.11
                    Time: 19:44:50
   Coding: 0010111
                    Reset counter: 209
                    Mileage: 227960 km
                    Date: 2017.01.30
                    Time: 11:03:00
   Coding: 0028196
   Revision: AV1C1010
   Coding: 0000532
                    Reset counter: 249
                    Mileage: 227960 km
                    Date: 2017.01.30
                    Time: 11:33:40
                    Voltage: 11.59 V
                    Count: 96
                    Fault Frequency: 25
                    Reset counter: 201
                    Voltage: 9.21 V
                    Count: 110
                    Reset counter: 201
                    Voltage: 9.21 V
                    Count: 61
   Coding: 0000001
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:00:50
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:13:25
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:16:35
   Coding: 0028196
   Coding: 0212127
            000 -  -
                    Reset counter: 209
                    Mileage: 227963 km
                    Date: 2017.01.30
                    Time: 11:01:00
                    Temperature: 10.0°C
                    Error Code: 32768
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Coding: 0028196
   Coding: 0000005
   Coding: 0001208
End----------(Elapsed Time: 02:06, VBatt start/end: 11.1V/11.1V)-----------
rescan after reset
   #38
Eric
HC800000
What's with the weak battery voltages all over your scans?? I'm surprised nobody mentioned the possibility that your energy management might be shutting things down at 11V... Put a charger on it and give us a fresh baseline at 12.7+ volts.
   #39
sheed44
C?ID=297477
Via VCDS go into
07-Controler Head
10-adaptation
Go into channel 2
I did this and the battery level meter shows up but not the suspension, oil or anything else that might have shown up when doing this
   #40
sheed44
C?ID=297477
so the battery in the vehicle is not an Audi battery, and with the key turned on but not over before the complete scan is ran I get a energy management message on the dash display, or am I supposed to run it with the car started instead? and I took the battery to get tested and I keep getting told its a good battery and im not sure it was coded to the vehicle, its a Super Start Extreme battery and I was told its less than a year old after tracking down the last owner and asking him
