Golf 6 GTI Rear LED Long Coding help and hello
carlab
South Africa
C?ID=251490
Hi All
My 1st post and a hello to all of you, My names angus im from cape town south africa. I do electronics on cars and auto electrical work. shout if you need help
Im battling with a golf 6 gti i am trying to retro fit. I believe it is a 2011 model golf 6 gti. The customer wants to fit a full set of led lights in the rear. I have tried to do long coding from the internet but its still not working right. Ive erased page 18 and used 40 , 04 but no luck. Is there anyone that can point me in the right direction.
I am fitting original lights and i have no plugs so i am joining wires
Thanks in advance
carlab
South Africa
C?ID=251490
hi
attached or see below the auto scan
thanks for the reply
i have fitted the lights. The park and brake lights work so does the indicators. i havent changed any coding. the inner lights do not work. The right inner light comes on with rear fog activated via the switch. The reverse does not work. My understanding is that the inner lights (on tailgate) are supposed to work like the outer and without the wiring mod the inner rear fog will not work.
Right now customer is driving with lamp failure warning on. And the odd light that does not work. This is due to time constraints
Please help i need to sort it as a personal challenge and as a vote of confidence to customer.
See attached
Friday,18,November,2016,20:02:21:20626
VCDS Version: 16.8.2.3
Data version: 20160926 DS261.0
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
          77
VIN: WVWZZZ1KZCW077619   Mileage: 80080km-49759miles
2E-Media Player 3 -- Status: Cannot be reached 1100
Address 01: Engine (CCZ)       Labels: 06J-907-115-CCZ.clb
   Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
   Component: 2.0l R4/4V TFSI     0050
   Revision: AAH18---    Serial number:
   Coding: 0403000C1C070160
   Shop #: WSC 66565 257 00032
   VCID: 67DB5AA4563D467A15-8032
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early
                    Date: 2047.15.31
                    Time: 31:63:63
                    Load: 0.0 %
                    Temperature: 46.0°C
                    Temperature: 38.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 7.366 V
   Part No SW: 02E 300 057 C    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2727
   Revision: 05351113    Serial number: 00001107081968
   VCID: 193F2C5CD0C9208A53-804C
   Revision: 00H31001
   Coding: 163B600D09298001681106E590220181310800
   VCID: 7BF316D4FAB5F29AE1-802E
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001003
   Coding: 0000001002
   VCID: 000961389B539142B4-8054
   Part No SW: 1K0 937 086 M    HW: 1K0 937 086 M
   Component: BCM PQ35  M   110 0651
   Revision: 00110 AC
   Coding: 48180A3A8825F1C0400800C0340009E449554088736D8D20E48400240040
   VCID: 3A7DD3D0B50F0B92BA-806E
   Subsystem 1 - Part No: 5K2 955 119
   Component: Wischer 22071  26  0512
   Coding: 009795
   Component: RLS 280711 05  54  0403
   Coding: 0230AD
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
00984 - Left Tail Light (M4)
                    Fault Status: 00101010
                    Reset counter: 21
                    Mileage: 80086 km
                    Date: 2016.11.18
                    Time: 17:59:23
                        Term 15 On
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 21
                    Mileage: 80086 km
                    Date: 2016.11.18
                    Time: 17:59:35
                        Term 15 On
                    Voltage: 14.45 V
                        Term 50 Off
00985 - Right Tail Light (M2)
                    Reset counter: 21
                    Mileage: 80086 km
                    Date: 2016.11.18
                    Time: 18:57:18
                        Term 15 On
                    Voltage: 12.00 V
                        Term 50 Off
                    Fault Status: 01101010
                    Reset counter: 236
                    Mileage: 80086 km
                    Date: 2016.11.18
                    Time: 19:17:29
                        Term 15 On
                    Voltage: 11.90 V
                        Term 50 Off
                    Reset counter: 236
                    Mileage: 80086 km
                    Date: 2016.11.18
                    Time: 19:17:31
                        Term 15 On
                    Voltage: 11.90 V
                        Term 50 Off
                    Reset counter: 21
                    Mileage: 80086 km
                    Date: 2016.11.18
                    Time: 19:17:56
                        Term 15 On
                    Voltage: 11.85 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0012
   Revision: --------    Serial number: 12561120002709
   Coding: 108103
   VCID: 3879C9D88B0319824C-806C
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RA8BL8N
   Coding: 00003958
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 316FF4FC6079C8CA0B-8064
   Serial number: 3572MSME4E770542ZZZ-
   Serial number: 3582MSME03271142ZZZE
   Serial number: 3512QSME52160A65ZZZQ
   Serial number: 3522QSME5C131D5DZZZ2
   Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
   Revision: --------    Serial number:  90440KGT00071
   Coding: 1892140000
   ROD: EV_SMLSNGKUDS_VW36.rod
   VCID: 76E507E0C997AFF29E-8022
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H08 0010
   Serial number: 0070415
   Coding: 830000
   Part No SW: 5K6 920 872     HW: 5K6 920 872
   Coding: 170F00
   VCID: 72ED3BF0A5FFB3D2B2-8026
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 210711F2002197
   Coding: 350003
   VCID: 3567C0EC9C11E4EA57-8060
                    Reset counter: 159
                    Mileage: 44692 km
                    Date: 2014.02.24
                    Time: 10:57:20
03272 - Control Module for Audio Interface
                    Reset counter: 159
                    Mileage: 44692 km
                    Date: 2014.02.24
                    Time: 10:57:20
   Component: IMMO          H03 0607
   VCID: 6ADD23908D2F7B120A-803E
Address 2E: Media Player 3
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2106
   Coding: 0000692
   VCID: 377BCAE4461D16FA45-8062
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 74     3201
   Revision: 00H20000
   VCID: 3461FDE8576BFDE260-8060
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 7.9 V
                        PD
                    Temperature: 30.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Component: Tuer-SG         009 2120
   Coding: 0000948
   VCID: 3363FEF45265FADA79-8066
   Coding: 1443164
   Coding: 00000022
   Coding: 00000022
02988 - Left-Hand/Right-Hand Traffic Switchover Active
            000 -  -
                    Reset counter: 50
                    Mileage: 12420 km
                    Date: 2012.02.07
                    Time: 17:46:17
                    Voltage: 12.21 V
                        ABS 1
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: RCD310 EU     H03 5004
   Revision: -----04S    Serial number: VWZ4Z2L1321023
   Coding: 05000400040005
   VCID: 72ED3BF0ADFFB3D2B2-8026
7 Faults Found:
                    Reset counter: 236
                    Mileage: 44692 km
                    Date: 2014.02.24
                    Time: 12:04:57
                    Reset counter: 236
                    Mileage: 44692 km
                    Date: 2014.02.24
                    Time: 12:04:57
00874 - Treble Speaker Front Left (R20)
                    Fault Status: 01101011
                    Reset counter: 254
                    Mileage: 20105 km
                    Date: 2012.05.28
                    Time: 13:29:46
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 254
                    Mileage: 20105 km
                    Date: 2012.05.28
                    Time: 13:29:46
00876 - Treble Speaker Rear Left (R14)
                    Reset counter: 254
                    Mileage: 20105 km
                    Date: 2012.05.28
                    Time: 13:29:46
00877 - Treble Speaker Rear Right (R16)
                    Reset counter: 254
                    Mileage: 20105 km
                    Date: 2012.05.28
                    Time: 13:29:46
03138 - Input AUX IN
                    Reset counter: 254
                    Mileage: 20105 km
                    Date: 2012.05.28
                    Time: 13:29:44
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   VCID: 3567C0EC5C11E4EA57-8060
   Coding: 0000144
   VCID: 3665C7E04117EFF25E-8062
Address 77: Telephone
End-------------------------(Elapsed Time: 02:51)--------------------------
carlab
South Africa
C?ID=251490
bump
anyone help
Have you tried 21 in Byte 18?
carlab
South Africa
C?ID=251490
Hi
i will get car back and attempt thanks
GaryM
Oxford, UK
C?ID=226919
See the video linked to in this post.
As Uwe said, 21 seems to be the magic number :)
carlab
South Africa
C?ID=251490
Hi
