- May 2, 2014
- 167
- 83
- Alexandria/fairfax county VA
- C?ID=99408
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75
VIN: Mileage: 57759km-35889miles
5F-Information Electr. -- Status: Malfunction 0010 (I recently disconnected the battery so suspect that is what caused this error)
Address 01: Engine (J623-CRUA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 D HW: 04L 907 309
Component: R4 2,0L EDC H23 8278
Revision: 85H23---
Coding: 011D0012032410080000
Shop #: WSC 48433 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906021D 001013
ROD: EV_ECM20TDI01104L906021D.rod
VCID: 2649DBDD59710172E6-8072
5188 - Diesel Particle Filter
P2463 00 [167] - Excessive Soot Accumulation
Mileage: 57759 km
Date: 2016.11.20
Time: 20:53:25
Engine speed: 0.00 /min
Coolant temperature: 26 °C
Intake air temperature: 21 °C
Voltage terminal 30: 11.860 V
Counter for regeneration time of diesel particle filter: 0.00 s
Particle filter: kilometers since last regeneration: 155077 m
Particle filter: soot mass measured: 0.62 g
Particle filter: soot mass calculated: 60.00 g
Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 2 hPa
Readiness: 0 0 0 1 1
auto-scan segment above.
note that the measured soot is reasonable, while calculated soot is above spec.
car was rebuilt for some body damage. owner is chasing down possible boost leak
in order to reset the calculated soot mass, should http://wiki.ross-tech.com/wiki/index.php/2.0L_CR_TDI work?
Adaptation of Carbon Mass (after DPF Replacement)
Prerequisites:
Ignition ON
Engine OFF
[Security Access -16]
Enter the code shown in the VCDS pop-up balloon for "Adaptation Enabling"
[Do It!]
[Adaptation - 10]
From the pulldown menu, select the entry for "Carbon Mass (DPF Replacement)" or "Particle filter initialization".
Save a new value of 1 to reset the learned Carbon Mass. It's normal for that value to automatically change to 0 after it has been successfully saved. Check and clear fault codes to make sure none are present.
Prerequisites:
Ignition ON
Engine OFF
[Do It!]
[Adaptation - 10]
owner report here http://forums.tdiclub.com/showpost.php?p=5182952&postcount=35
