SOLVED 2014 Jetta TPMS Activation Questions / Help Needed
So I followed the steps to code the ABS with 5140022 at the end. Changed Instrument cluster to ending with 01. Restarted ignition, TPMS light came on and off like it should. So far so good. Here are my questions,
1. Where can I find the Tire Pressure II (4C)? It's not in the installation list of the gateway. Only 65, tire pressure is there. (Active system?)
2. When I try to contact the tire pressure 65, it says no response from controller. Again, because it's the active system? I unchecked 65.
3. Doing all this is supposed to add the tire pressure info of some kind in the Multifunction thing in the cluster? I don't get anything for tire pressure info?
Below is the current coding, after doing all the changes above.
Monday,14,November,2016,21:48:02:51584
VCDS Version: 16.8.3.1 (x64)
VIN: 3VWWL7AJ8EM307340 License Plate: 2014
Mileage: 114160km-70935mi Repair Order: After TPMS MOD
Chassis Type: AJ (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 77
aa
VIN: 3VWWL7AJ8EM307340 Mileage: 114160km-70935miles
Part No SW: 03L 906 019 KD HW: 03L 907 309 AA
Component: R4 2,0L EDC G000SG 7553
Revision: 12H16--- Serial number:
Coding: 0050072
Shop #: WSC 00066 000 00000
VCID: 77FD226C0604C4FA8D-8022
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C49220001850E02E892190042A5140022
Shop #: WSC 55543 001 104857
VCID: 040745A087D29F6298-8050
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 BL HW: 5C0 820 047 BL
Component: J301 Klimaanlage 0204
Revision: 2001001S Serial number: 00000002153112
VCID: 6BD50E1C4A4C701A79-803E
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 5C0 937 086 J HW: 5C0 937 086 A
Component: BCM25 JLB M3 H34 0411
Revision: B0034001 Serial number: 06013141140001
Coding: 7B994B1808AB0B0000382000240884C50082502E60000000300010002000
Shop #: WSC 00066 123 12345
VCID: 3365D67C92FCE8DA71-8066
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Serial number: 14202585140501131429
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Serial number: 14102584140424150356
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C
Component: E221__MFL-TAS H31 0037
Serial number: 0303213 FLE 20140417
Coding: 020000
Subsystem 4 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587140425150712
Coding: 800000
Subsystem 5 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14202586140505172223
Coding: 800000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 AD HW: 5C0 959 655 AD
Component: AirbagVW10 102 0912
Serial number: 003MVD04KF4Q
Coding: 00004138
Shop #: WSC 00066 790 00013
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 74E71560DF72AFE2A8-8020
Serial number: 6940000Y1400014Z4E0U
Coding: 303053
Serial number: 3572MSME61315842ZZZN
Serial number: 3582MSME50305842ZZZL
Serial number: 3516KSME4646542CZZZW
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME1667542CZZZX
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME6C0A7C2CZZZC
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME4A2C7C2CZZZD
Part No SW: 5C6 920 853 A HW: 5C6 920 853 A
Component: KOMBI H04 0809
Coding: 170A01
Shop #: WSC 00066 123 00119
VCID: 2A5BCB184D36A912C2-807E
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 086 A
Component: GW-K-CAN TP20 H34 0411
Revision: B0034001
Coding: 102200
VCID: 70EF1970A36A93C24C-8024
Component: IMMO H04 0809
VCID: 6ADB0B188DB6691202-803E
Address 2E: Media Player 3
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 HW: 1K0 035 274
Component: RNS315-NAR H05 0011
Serial number: VWZAZ2L8450501
Coding: 040004610100000400001000
ASAM Dataset: EV_RNS315VWNARV1UDS A01005
ROD: EV_RNS315VWNARV1UDS.rod
VCID: 61C96C3470802A4AD3-8034
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 3979E4547090128ABB-806C
Address 77: Telephone (J412) Labels: 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007665916340
Coding: 0210030080010110
Shop #: WSC 01383 790 50316
ROD: EV_UHVUMI.rod
VCID: 2E53C70871DEC5321E-807A
End-------------------------(Elapsed Time: 02:27)--------------------------
