2014 Jetta TPMS Activation Questions / Help Needed
rjsummer
Canada
C?ID=21159
SOLVED 2014 Jetta TPMS Activation Questions / Help Needed
So I followed the steps to code the ABS with 5140022 at the end. Changed Instrument cluster to ending with 01. Restarted ignition, TPMS light came on and off like it should. So far so good. Here are my questions,
1. Where can I find the Tire Pressure II (4C)? It's not in the installation list of the gateway. Only 65, tire pressure is there. (Active system?)
2. When I try to contact the tire pressure 65, it says no response from controller. Again, because it's the active system? I unchecked 65.
3. Doing all this is supposed to add the tire pressure info of some kind in the Multifunction thing in the cluster? I don't get anything for tire pressure info?
Below is the current coding, after doing all the changes above.
Monday,14,November,2016,21:48:02:51584
VCDS Version: 16.8.3.1 (x64)
VIN: 3VWWL7AJ8EM307340   License Plate: 2014
Mileage: 114160km-70935mi   Repair Order: After TPMS MOD
Chassis Type: AJ (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56 77
aa
VIN: 3VWWL7AJ8EM307340   Mileage: 114160km-70935miles
   Part No SW: 03L 906 019 KD    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000SG  7553
   Revision: 12H16---    Serial number:
   Coding: 0050072
   Shop #: WSC 00066 000 00000
   VCID: 77FD226C0604C4FA8D-8022
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: A14B400C49220001850E02E892190042A5140022
   Shop #: WSC 55543 001 104857
   VCID: 040745A087D29F6298-8050
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 BL    HW: 5C0 820 047 BL
   Component: J301  Klimaanlage   0204
   Revision: 2001001S    Serial number: 00000002153112
   VCID: 6BD50E1C4A4C701A79-803E
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 5C0 937 086 J    HW: 5C0 937 086 A
   Component: BCM25 JLB M3  H34 0411
   Revision: B0034001    Serial number: 06013141140001
   Coding: 7B994B1808AB0B0000382000240884C50082502E60000000300010002000
   Shop #: WSC 00066 123 12345
   VCID: 3365D67C92FCE8DA71-8066
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Serial number: 14202585140501131429
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 5461
   Serial number: 14102584140424150356
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Serial number: 0303213 FLE 20140417
   Coding: 020000
   Subsystem 4 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Serial number: 14102587140425150712
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Serial number: 14202586140505172223
   Coding: 800000
   Part No SW: 5C0 959 655 AD    HW: 5C0 959 655 AD
   Component: AirbagVW10    102 0912
   Serial number: 003MVD04KF4Q
   Coding: 00004138
   Shop #: WSC 00066 790 00013
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 74E71560DF72AFE2A8-8020
   Serial number: 6940000Y1400014Z4E0U
   Coding: 303053
   Serial number: 3572MSME61315842ZZZN
   Serial number: 3582MSME50305842ZZZL
   Serial number: 3516KSME4646542CZZZW
   Serial number: 3526KSME1667542CZZZX
   Serial number: 3556LSME6C0A7C2CZZZC
   Serial number: 3566LSME4A2C7C2CZZZD
   Part No SW: 5C6 920 853 A    HW: 5C6 920 853 A
   Component: KOMBI         H04 0809
   Coding: 170A01
   Shop #: WSC 00066 123 00119
   VCID: 2A5BCB184D36A912C2-807E
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 5C0 937 086 A
   Component: GW-K-CAN TP20 H34 0411
   Revision: B0034001
   Coding: 102200
   VCID: 70EF1970A36A93C24C-8024
   Component: IMMO          H04 0809
   VCID: 6ADB0B188DB6691202-803E
Address 2E: Media Player 3
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 1K0 035 274     HW: 1K0 035 274
   Component: RNS315-NAR    H05 0011
   Serial number: VWZAZ2L8450501
   Coding: 040004610100000400001000
   ASAM Dataset: EV_RNS315VWNARV1UDS A01005
   ROD: EV_RNS315VWNARV1UDS.rod
   VCID: 61C96C3470802A4AD3-8034
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 70     3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3979E4547090128ABB-806C
Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
   Part No SW: 5N0 035 729 A    HW: 5N0 035 729 A
   Component: TELEFON       H05 0592
   Revision: 1B001001    Serial number: 00007665916340
   Coding: 0210030080010110
   Shop #: WSC 01383 790 50316
   ROD: EV_UHVUMI.rod
   VCID: 2E53C70871DEC5321E-807A
End-------------------------(Elapsed Time: 02:27)--------------------------
Spacewalker
Poland
C?ID=159607
I think PQ25 jetta not support it
In a fact , if you code cluster to 170A01 how you wnat to reset TPMS warning from cluster menu if you have Lowline cluster w/o any MFA settings ?
As far as I know you can only do that via ABS
thy that ABS coding A14B400C49220001850E02E892190042A1100021
rjsummer
Canada
C?ID=21159
Another TPMS tutorial said after doing the coding's that " Tire Pressure" function would be added to the MFI list. I have MFI. ( the info where you can scroll through and see fuel consumption, DTE, temp, etc).
What exactly are you saying changing 22 to 21 will do for me?
Spacewalker
Poland
C?ID=159607
LowLine cluster show some extra menu ?
5C6 920 853 A that cluster ?
rjsummer
Canada
C?ID=21159
Looks like the post I was referring to was a different cluster than mine so it appears that no info is supposed to appear in my MFI, so I'm good for now.
rjsummer
Canada
C?ID=21159
Spacewalker, can you tell me what the last 2 digits do in each case? 10?( original coding) 21? And 22?
Also, what do these codes do?
X5 14 xx 22? I'm asking about the 5,1 and 4.
The Long Coding Helper has the TPMS bits documented so I'm concerned about the coding modifications. Please post the factory condition scan in addition to the latest condition.
rjsummer
Canada
C?ID=21159
I really need to stop answering my own posts. Anyway, did some messing around just now and here's what i found.
Byte 16, came with A1, checking box "Tire Pressure Monitoring (TPMS/PR-7K6) installed changes it to A5.
Byte 17, came with 10, checking box Tire Pressure Monitoring (TPMS/PR-7K6) via Instrument Cluster (MY 2011+) changes it to 14.
I changed byte 19. It came with 10, but changing it to 22 made the TPMS work. I changed it to 21 for fun and it still works, I can't tell the difference from 22 to 21.
So.... question..... Do I need both byte 16 and 17 checked on TPMS or just one? And what difference does 22 make compared to 21?
rjsummer
Canada
C?ID=21159
Dana, I don't know that I have a scan from when I first bought the car back in JULY, but here's a scan from before I tried to change anything to activate the TPMS.
Thursday,10,November,2016,23:40:57:51584
VIN: 3VWWL7AJ8EM307340   Mileage: 113840km-70736miles
   Coding: 0050072
   Revision: 00H46001
   Coding: A14B400C49220001850E02E892190042A1100010
   Coding: 820000
   Coding: 820000
   Coding: 020000
   Coding: 800000
   Coding: 800000
   Coding: 00004138
   Coding: 303053
   Coding: 370A00
   Shop #: WSC 00066 000 00119
   Revision: B0034001
   Coding: 102200
   Revision: 00H22000
   ROD: EV_UHVUMI.rod
End-------------------------(Elapsed Time: 02:30)--------------------------
Here's the latest Dana, I've changed byte 19 in ABS to 21 instead of 22. It seems to make no difference, it works as before. Any comment on that?
I'd like to know how to recode to take out the MFD info since I have the basic cluster. I don't know what code does that.
Wednesday,23,November,2016,18:51:39:51584
VIN: 3VWWL7AJ8EM307340   License Plate: BZRZ
Mileage: 114370km-71066mi   Repair Order: After ABS coded 21
VIN: 3VWWL7AJ8EM307340   Mileage: 114370km-71066miles
   Coding: 0050072
   Revision: 00H46001
   Coding: A14B400C49220001850E02E892190042A5140021
   Coding: 820000
   Coding: 820000
   Coding: 020000
   Coding: 800000
   Coding: 800000
   Coding: 00004138
   Coding: 303053
   Coding: 370A01
   Revision: B0034001
   Coding: 102200
   Revision: 00H22000
   ROD: EV_UHVUMI.rod
End-------------------------(Elapsed Time: 02:26)--------------------------
Thanks for the original coding. The 17-Instrument cluster coding appears to be correct.
All 2011+ Mk6 Jettas had indirect TPMS in the US but 2014 was a problematic year. My mother in law has a 2014 2.slow gas that was born like:
Tuesday,29,July,2014,18:40:21:59530
Mileage: 250km-155mi   Repair Order:
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: A14B200C512208FE851304E88A201061A1100012
   VCID: FEB0BF60691F7FCA71-80AB
.. and ended up as:
Thursday,28,July,2016,18:49:13:08929
Mileage: 52710km-32752mi   Repair Order:
   Revision: 00H46001
   Shop #: WSC 61253 000 1048576
   VCID: 844B8FB507397E0B61D-80D0
after a TPMS recall which was a flash update. I see TPMS coding discrepancies in the early 2014 scans we have and I suspect VW not only had problems with those modules that the flash resolved but the coding charts may be different as well? alternativesurfer has a scan from his girlfriends car with similar A1100012 coding pre-recall/flash in the thread linked above.
Due to the discrepancies I'm not entirely sure if our Long Code Helper information is correct for this application. The actual installed switch may even be related, I didn't get into the wiring diagrams or parts catalog. If our customer use data is correct, that would have changed your factory code from/to:
A14B400C49220001850E02E892190042A5100010
Instead, I suspect you should try from/to:
A14B400C49220001850E02E892190042A7100010
You may want to just revert the ABS to the factory value and make sure Basic Setting Group 042 shows Error (NA) as expected. Providing it does, I'd run a pair of control module maps in the factory condition: http://wiki.ross-tech.com/wiki/index.php/Control_Module_Maps
After saving that baseline information try one of the above coding variants, preferably the 1st to test our documentation and repeat checking BS 042 in addition to a pair of maps.
If you want to continue testing it wouldn't hurt to try the 2nd coding suggestion and repeat the extra steps. It you run control module maps they can be opened with notepad and pasted like the scan files wrapped in [CODE] before and [/CODE] after.
-- Ignore these notes --
A1__40__49__00__85__02__92__0042A1100010
rjsummer
Canada
C?ID=21159
Interesting. The codes you posted show a110 but if I do that coding in mine it unchecked the 2 TPMS boxes. How can a US car come from the factory with that turned off. TPMS is mandatory, so I'm confused.
As far as the code you proposed, I tried the A7 instead of A5 and it seemed to make no difference. The hill hold and TPMS stayed checked as in A5.
As well, I tried 12 as in the 2.0 code you showed, my TPMS light still functioned but caused coding errors faults after for the ABS so I went back to A514xx21.
I still would like if someone could tell me, WHAT DIFFERENCE DOES 21 DO VS 22 at the end of the coding? Both seem to work but there must be some effect??
Exactly, which is why the factory condition maps and confirmation basic setting group 042 is not available followed by the maps and BS 042 status with my alternative coding strings would be helpful.
There isn't much documentation for the higher bytes (18 and 19 when supported) but those should apply to things like WSS type, ACC, Blind Spot Detection and Park Assist.
Since we have not determined the bits in Bytes 18+ are related to indirect TPMS directly I would not modify them until the baseline map information from this vehicle in addition to the alternative TPMS coding has been evaluated and we exhaust all other ideas.
rjsummer
Canada
C?ID=21159
Are you asking me to try those alternate codes I tried again with results of the 042 status (epromm reset)? If I'm understanding you let me know and I can do that for you.
However, about bytes 18, and 19, there must be some correlation with the TPMS in byte 19, the FIRST digit in particular because it seems clear that.....
0 - is out of range.
1 - creates the 7K0 condition... no cluster icon light functionality for TPMS
2 - causes the cluster icon TPMS light to function
Second digit in byte 19 is of course my question, 0 causes a DTC fault when used as in "20", but 1 and 2 both work. So tell me, is there anything I can do to help determine what the 1 and 2 do? If so, I'll be the guinea pig, just let me know what to do.
rjsummer
Canada
C?ID=21159
Just a further update, tonight I went out to the car again and returned the ABS coding to factory, no TPMS, and error on 42, to reset the eprom, coding... A1100010. I then took the advice a couple posts back and tried leaving the A11000 the same, which the controller map shows the TPMS as all unchecked. The last 2 digits I changed to 12 as in the posts earlier. TPMS works, and 42 works to reset. No ABS error codes, all seems to work fine. It seems that the controller map is indeed wrong for the BS module. So, if you have a 2014 Jetta NAR with the BS module and your car is Canadian, just change the last digit to 2 and it's all good. Ignore the long coding helper as it is wrong for the BS module.
