Updated to Release 23.11 and Having Trouble? Read This Thread
   #41
Mike@Gendan
Swansea, UK
C?ID=57030
4) Start up VCDS (it may have already started at the end of the installation, which is fine). If VCDS won't start up at all after updating, make sure that Zone Alarm or your virus scanner are not blocking/quarantining the file. Make sure it says Release 18.9 at the top of the screen. If says an older version then something didn't go right. Check the shortcut on your desktop to make sure it's for Release 19.6. If needed, exit out of VCDS then repeat steps 1-3.
I'm guessing that should be 19.6 now?
bobbik
C?ID=50728
Thursday,18,July,2019,11:33:50:22340
VCDS Version: 19.6.1.0
Workshop Code: 000 11618 000000
Gateway Installation List:  3Q0 907 530 L
2B-Steer. Col. Lock -- Status: Malfunction 0010
3C-Lane Change -- Status: Cannot be reached 0100
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
D8-LED HeadL. Pwr Left -- Status: INTERFACE NOT COMPATIBLE
D9-LED HeadL. Pwr Right -- Status: INTERFACE NOT COMPATIBLE
Does it mean my interface is too obsolete?
   #44
There are at least four control modules in that car that your "legacy" interface can't communicate with. So yes, an interface upgrade would be recommended.
graaja
India
C?ID=298731
Recently, I had upgraded to a new laptop that runs Windows 10 64 bit version. I installed VCDS version 19.6.1. When I launch VCDS from desktop shortcut, the program does not launch. Following are the checks I have performed.
1. When I check the task manager, the program is not listed in the processes.
2. Tried running the program in Administrator mode.
3. Tried troubleshooting compatibility issues and ran in Win8 and Win7 compatibility modes.
4. Checked that firewall has been configured to allow VCDS.
5. Added VCDS.exe as an exception in the antivirus software.
None of these work. Any pointers to what could be the problem?
Thanks in advance.
Edit: I have the Hex-V2 interface with a 3-VIN license.
   #46
At this point, I think there are more people running Windows 10 and the x64 version of VCDS than any other combination, so there has to be something peculiar about your computer.
Try the "Install 32-bit EXE on 64-bit System" option in the installer to see if that helps.
If that still doesn't work, I would suggest uninstalling and and all bloatware and nannyware that came pre-installed on this computer.
daniser
Russia
C?ID=197049
Possible bug?
Hello!
I have a problem with latest version of VCDS (19.6.1). When I try to access some of control modules of my car (for example, ABS and steering angle sensor), the error balloon above "Advanced ID" button is shown: "Vehicle is unsupported". Every other button stays disabled.
I know about legacy interfaces and 2019+ cars... BUT! My car is 2013 Polo sedan (russian market model), my interface is HEX-USB+CAN, OS is Windows 10 x64. When I've reinstalled previous version (19.6.0 - thank God I kept distro) - all work fine again.
Here is the log from the "Advanced ID" window (sorry don't know how exactly it's called):
Wednesday,21,August,2019,20:57:06:05202
VCDS Version: 19.6.1.0 (x64)
                Address 03: ABS Brakes
Control Module Part Number: 6R0 907 379 AQ
  Component and/or Version: ABS9.0 front  H01 0003
           Software Coding: 50DD2F64212504C10A18F472845720000000
            Work Shop Code: WSC 01530
                      VCID: 0D115EF2DC450C27E2-8058
Advanced Identification/FAZIT
     Serial number: --------------
     Identification: BPA-085
     Date: 08.08.13
     Manufacturer number: 0040
     Test stand number: 2660
Flash Status
     Programming Attempts(application): 1/0
     Flash Date: 00.01.01
Misc.
     Hardware number: 6R0 907 379 AQ
     Workshop System Name: J104
     ASAM Dataset: EV_Brake1ABS90BOSCH
     ASAM Dataset Revision: 003017
VCDS Info:
       Labels: Redir Fail!
       ROD: ERROR - EV_Brake1ABS90BOSCH 003017 (VN75)
Of course, I will post full scan if needed.
   #49
Yes, please do post a full scan, including the VIN as reported by VCDS.
daniser
Russia
C?ID=197049
Ok, nevermind, here's a bunch of errors mainly in BCM and Discover Media :) Need to find a time to kill most of them ("echoes" of retrofitting ;)...
Wednesday,21,August,2019,20:40:26:05202
VIN: XW8ZZZ61ZEG021496   License Plate:
Chassis Type: 61-VW25 (7E0)
Scan: 01 03 04 09 15 17 19 25 37 44 56 5F 77
VIN: XW8ZZZ61ZEG021496   Mileage: 69210km-43005miles
Address 01: Engine
   Part No SW: 6R0 907 379 AQ    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0003
   Shop #: WSC 01530 935 00200
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 20111813470008
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF3093EE1E327BFEB-802A
1140738 - Steering angle sensor
                    Reset counter: 29
                    Mileage: 69219 km
                    Date: 2019.08.21
                    Time: 18:54:01
                    Voltage terminal 15: 11.20 V
                    Voltage terminal 30: 11.40 V
                    Terminal 15 status: On
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Serial number: 0771 029160357
   Coding: 62904ABF08A10840000800002C0B049000C0414F60040000200000000000
   VCID: 68DF4F669B67890F31-803C
   Subsystem 1 - Part No SW: 5G0 959 442 L    HW: 5G0 959 442 L
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29170001546230087311
   Coding: A5FFFF
03303 - Response Closing Status of Rear Left Door
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 29
                    Mileage: 69219 km
                    Date: 2019.08.21
                    Time: 20:14:00
01516 - Terminal 30; Left
                    Fault Status: 01101011
                    Reset counter: 29
                    Mileage: 69219 km
                    Date: 2019.08.21
                    Time: 18:54:02
00927 - Terminal 30 (Right)
                    Reset counter: 29
                    Mileage: 69219 km
                    Date: 2019.08.21
                    Time: 18:54:02
01748 - Switch for Tiptronic in Steering Wheel (E438); Up
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 29
                    Mileage: 69219 km
                    Date: 2019.08.21
                    Time: 18:54:02
01749 - Switch for Tiptronic in Steering Wheel (E439); Down
            014 - Defective
                    Reset counter: 29
                    Mileage: 69219 km
                    Date: 2019.08.21
                    Time: 18:54:02
   Part No SW: 6R0 959 655 J    HW: 6R0 959 655 J
   Component: VW10AirbagU05 H10 0020
   Revision: --------    Serial number: 003GW00LMTVP
   Coding: 003035
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999AAE2E8AD50070E-801C
   Part No SW: 6R0 920 870 FX    HW: 6R0 920 870 FX
   Component: KOMBI         H04 0709
   Coding: 140E00
   Shop #: WSC 00180 935 00000
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
   VCID: 102F4786CB7721CF09-8044
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0736
   Revision: B9080001
   Coding: 002200
   Component: IMMO          H04 0709
   VCID: 6ADB356E8D6BBB1F27-803E
Address 37: Navigation
Address 44: Steering Assist (J792)       Labels:* 6Rx-909-144-V1.clb
   Part No SW: 6RU 909 144 J    HW: 6RU 909 144 J
   Component: EPS_ECU       H18 0401
   Coding: 0000
   ASAM Dataset: EV_SteerAssisUDSNSK 005005
   ROD: EV_SteerAssisUDSNSK.rod
   VCID: 62CB5D4E755BE35FEF-8036
Address 56: Radio
   Part No SW: 5C0 035 684 D    HW: 5C0 035 684
   Component: MU-S-NS-US    H22 0468
   Serial number: VWZAZ2S0252925
   Coding: 02570001FF00000011110004000908001F0100C4002001004E
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 2643015E59F35F7FC3-8072
   Subsystem 1 - Part No SW: 5NA 919 866 J    HW: -----------
   Component: ECE2 2019/20  --- 1115
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 29
                    Mileage: 69219 km
                    Date: 2019.08.21
                    Time: 18:54:00
                    Voltage terminal 30: 11.3 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
13697024 - Component Protection
          U1100 00 [009] - No Basic Setting
                    Reset counter: 29
                    Mileage: 69219 km
                    Date: 2019.08.21
                    Time: 18:54:00
15361024 - Component Protection
          U1101 00 [009] - Active
                    Reset counter: 29
                    Mileage: 69219 km
                    Date: 2019.08.21
                    Time: 18:54:00
0009 - Antenna for Satellite Radio
          B10F4 13 [009] - Open Circuit
                    Reset counter: 29
                    Mileage: 69219 km
                    Date: 2019.08.21
                    Time: 20:15:43
                    Voltage terminal 30: 11.4 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Channel selection for satellite radio: 0
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 1 mA
                    SDARS_tuner_status_2-Reception quality: No_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 29
                    Mileage: 69219 km
                    Date: 2019.08.21
                    Time: 18:54:03
                    BAP-BAP_Function_ID: 02
0003 - Antenna 2 for radio
          B111A 13 [009] - Open Circuit
                    Reset counter: 29
                    Mileage: 69219 km
                    Date: 2019.08.21
                    Time: 18:54:00
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 0 dBµV
Address 77: Telephone
End-------------------------(Elapsed Time: 02:09)--------------------------
   #51
There are several modules with "Status: OK 0000" but then shown as "Cannot be reached" - something isn't right here :confused:
   #52
daniser
Russia
C?ID=197049
Modules ## 37, 56 and 77 are not "real", i.e. their functions is handled by 5F - Information Electr. (Discover Media). When I've tried to remove them from gateway's installation list - there was an "module incorrectly coded" error.
But "Cannot be reached" on engine is a different story... I think it may be related to low battery charge... It discharged right after the scan, when I tried to start the vehicle with no success. I've recharged it but I think it's dying and I need to replace it ASAP.
Can it be related to "Unsupported vehicle" error in 19.6.1? But why there's no such error in 19.6.0 and earlier versions? I've tried two versions (19.6.1 and 18.9.0 RUS) one after another, in one shot, with different results. Then, after battery recharging, I've tried 19.6.0, and it worked fine, like 18.9.0 before.
   #53
Spacewalker
C?ID=159607
Not sure about that , but can not do any more UDS cluster output test
who can confirm ?
no matter what i select , always rejected
   #54
Jacek
C?ID=360566
Download ver. 20.4.1
Spacewalker
C?ID=159607
yep, fixed,
but why VCDS not detect new update ?
I always select - check Beta version too
and did not even know there is 20.4.1
   #56
Looks like someone forgot to tell the server. :facepalm:
hadez16
C?ID=289891
I get a strange message since 20.4.2 in the german VCDS version (english not tested)
When I click OK, everything goes on fine...
   #58
Hmm... Which German version are you using, exactly?
Do me a favor and bump this thread tomorrow. I have 600 miles to drive today....
