Updated to Release 23.11 and Having Trouble? Read This Thread
   #21
thanks but unfortunately I have not solved, the correct drivers where can I find them?
They are in your VCDS folder. Assuming your Windows is 64 bits, you should see:
rt-usb64.cat
RT-USB64.sys
RT-USB64.inf
but DPInst.EXE should not install the drivers?
Yes, it should.
My guess is that something is not quite right about your installation of Windows, because we have no other reports of problems like this.
Plumes
Italy
C?ID=241122
rt-usb64.cat
RT-USB64.sys
RT-USB64.inf
Yes, it should.
many thanks, but if I can not solve the problem how can I do?
   #24
Plumes
Italy
C?ID=241122
I tried but keep giving me error on installing the driver.
I do not know what else to do ...... I'm desperate ..... before it worked
   #25
Plumes
Italy
C?ID=241122
the problem is that it does not load the drivers
   #26
Plumes
Italy
C?ID=241122
Help me please
   #27
It works on another computer, ergo, your interface is OK.
The exact same drivers work fine for thousands of other people on Windows 10...
I suggest you either try re-installing Windows on that machine, or contact Microsoft for help.
Santos
I'm going to guess CCleaner is the culprit. The icon is visible in the taskbar during driver installation error, but not in the other screenshot. Is it automatically "Cleaning" while trying to install the USB driver?
   #29
Westbury, UK
I'm running CCleaner on my PCs including a tablet running W10 which I use with VCDS, so it's not fundamentally incompatible.
A customer recently reported this fix for Error 39 in Windows 10:
https://borncity.com/win/2018/07/06/windows-10-v1803-hcvi-causes-driver-error-code-39/
His issues prior to the reg edit:
media
The summary from the linked post is:
The workaround is to invoke the registry editor via Run as administrator and then navigate to the key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\DeviceGuard\
Scenarios\HypervisorEnforcedCodeIntegrity
Then set the DWORD value Enabled to 0 (see also this Microsoft article) and reboot Windows 10. After that HVCI should be disabled and the old drivers (or Virtualbox) should work again.
Please see the steps in post #31 as well!
Error 39 in Windows 10 without Reg edit
Update. Thanks to caller feedback today I can confirm the Core Isolation setting was responsible for Error 39 however you can easily turn it on/off without a editing the reg.
  • Go to Settings and select Windows Security. Screen shot #1
  • Click Device Security on the Right side.
  • From the Device Security screen click Core Isolation. Screen shot #2
  • Changing the setting to Off resolves the Error 39 problem and the registry entry changes (without manually editing it) . Screen shot #3
You can wreck a PC by tweaking the registry so I would strongly recommend using the Core Isolation steps above.
I'll speak to the developers to see if we can change things on the VCDS side so this isn't necessary in the future.
Internal ref to C?ID=178513
   #32
lclerc69
France
C?ID=169317
hi i try to scan a 2016 audi A4 and i have this issue : Status: INTERFACE NOT COMPATIBLE
here is the start of the log :
Wednesday,21,November,2018,11:06:19:18831
VCDS Version: 18.9.0.2 (x64)
VIN: WAUZZZF43HAxxxxxx License Plate:
Chassis Type F4-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 42 44 46 52 5F 6D 81 A5 AC BB BC
CA
VIN: WAUZZZF43HAxxxxxx Mileage: 102289km-63559miles
46-Central Conv. -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
do you know what's happening my interface is a HEX + CAN
thank you
best regards
   #33
Bogdan.audi
Ukraine
C?ID=90275
Good day to all. I want to know when there will be support for auto audi a8(4N)and audi Q8?
Monday,19,November,2018,20:24:10:62465
VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
Dealer/Shop Name: Bogdan
Workshop Code: 790 31414 000001
VIN: WAUZZZF13         License Plate:
Mileage: 404km-251mi   Repair Order:
Chassis Type: F1-AU58 (4N2)
Scan: 01 02 03 06 09 15 16 17 18 19 36 3C 42 44 46 47 52 5F 61 6C
          6D 74 81 A5 AC BB BC C4 CB CF D6 D7 DB DC
VIN:    Mileage: 404km-251miles
C4-DC/DC Converter -- Status: OK 0000
CB-Rear Axle Steering -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (J623-DHXA)       Labels: Redir Fail!
   Part No SW: 4M8 907 401     HW: 059 907 309 L
   Component: 3.0l V6 TDI   H26 0001
   Revision: CAH26---
   Coding: 2A2A403A032E050334286000000400000000000000000000
   Shop #: WSC 31414 041 00001
   ASAM Dataset: EV_ECM30TDI0114M8907401 001002
   ROD: EV_ECM30TDI0114M8907401.rod
   VCID: 6E902A22B163043A37-803A
   Part No SW: 4M8 927 158 G    HW: 0D5 927 156 P
   Component: 0D5  30TDIRdW H05 1001
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002014
   ROD: EV_TCMALX52011.rod
   VCID: 40CCA49ADB77C24A95-8014
   Automatic Transmission Fluid Pump:
   Component: V552 ATFP  H01
   Serial number: 180028100045
   Part No SW: 4M6 907 379 N    HW: 4M6 907 379
   Component: ESP9 Premium  H06 0850
   Coding: 24AA329631A20B9D93A75C971886D6D2F5BAC8244C8CD0C93A186B4BAF5D13
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 48DCBCBAF347FA0A5D-801C
   Part No SW: 4M4 959 760 E    HW: 4M4 959 760 E
   Component: MEM-BFS       009 0042
   Serial number: 00000339879608
   Coding: 001010000000B0410000010101010000810000212100000000000000000000
   Shop #: WSC 31414 049 00001
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006009
   ROD: EV_SCMPasseSideCONTIAU736_AU58.rod
   VCID: 3E30DA62A183B4BAE7-806A
   Part No SW: 4N0 907 063 DG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0652
   Coding: 07000943C13900DD070C57889C2F0C78130B331000060097010108003B3216810A4509320257050800000100004108091800000044010104000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 014010
   ROD: EV_BCM1BOSCHAU651_014.rod
   VCID: 76A00242C9333CFAFF-8022
   Subsystem 1 - Part No SW: 4M8 955 119     HW: 4N1 955 119
   Component: J400FRWISCH  052 0997
   Serial number: 904753F0401820600967
   Coding: 7DC727
   Serial number: 21791640X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4K1 941 501     HW: 4K1 941 501
   Component: E1 - LTM  H05 0053
   Serial number: 16S07.06.1800300639
   Serial number: GX1CE122051823811852
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135     HW: 4K0 947 135
   Component: Dachmodul  H42 0413
   Serial number: Q00608411
   Coding: 010104
393831 - Motor for Left Footwell Flap
          B10B9 07 [008] - Mechanical Failure
                    Reset counter: 46
                    Mileage: 244 km
                    Date: 2018.11.17
                    Time: 10:24:31
                    average_Voltage_terminals: 12.70 V
                    Outside air temperature sensor-Resistance: 2.56 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 4.50 °C
                    interior_temperature: 15.00 °C
                    Vehicle speed: 0.00 km/h
                    Terminal control-Terminal 75 status: On
                    Terminal control-Terminal 15 status signal: On
                    Terminal control-Terminal 15 via CAN: On
                    Terminal control-Term 75: qualification: OFF
   Part No SW: 4N0 959 655 Q    HW: 4N0 959 655 Q
   Component: AirbagVW31    H09 2710
   Serial number: 003YZM00MSY6
   Coding: AACCF00000C000009800003FF00D010000C5
   Shop #: WSC 31414 029 00001
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_AU58.rod
   VCID: 4AD886B2ED4B081A4B-801E
   Belt Pretensioner left:
   Serial number: 00AI2018229337200000
   Coding: 03F001
   Belt Pretensioner right:
   Serial number: 00AI2018221629600000
   Coding: 03F001
   Subsystem 3 - Part No SW: -----------    HW: 480 002 908 18
   Serial number: 3570000000035424B135
   Subsystem 4 - Part No SW: -----------    HW: 480 002 908 18
   Serial number: 35800000000070FC713I
   Subsystem 5 - Part No SW: -----------    HW: 480 031 908 18
   Serial number: 351001C14A8586D0C80B
   Subsystem 6 - Part No SW: -----------    HW: 480 030 708 18
   Serial number: 352001C147104DB0DC7A
   Subsystem 7 - Part No SW: -----------    HW: 480 030 708 18
   Serial number: 355001C147104941498Z
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 480 030 708 18
   Serial number: 356001C1440349C07892
   Side Sensor B-Pillar Driver Front:
   Subsystem 9 - Part No SW: -----------    HW: 480 031 908 18
   Component: SideSens_B_Df  002 0149
   Serial number: 352001C14A858C10D9BJ
   Side Sensor B-Pillar Passenger Front:
   Subsystem 10 - Part No SW: -----------    HW: 480 030 708 18
   Component: SideSens_B_Pf  002 0149
   Serial number: 355001C147104E71294.
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 4N0 907 129 AB    HW: 4N0 907 129 AB
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 71AA315EA05D1BC22A-8024
   Part No SW: 4K0 920 790 C    HW: 4K0 920 790 C
   Component: FBenRDWACC--- H11 0153
   Coding: 85A410E6388800082B03E1609080080008003000
   ROD: EV_DashBoardAU65X_001_AU58.rod
   VCID: 2D12ED2E7CE53F224E-8078
Address 18: Aux. Heat (J364)       Labels:* None
   Part No SW: 4M0 265 105 E    HW: 4M0 265 105 E
   Component: HSG           H11 0090
   Coding: 0D0A01
   ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
   ROD: EV_AuxilParkHeateEBEAU736.rod
   VCID: 291A193E480D2302A2-807C
   Part No SW: 4N2 907 468 AA    HW: 4N2 907 468 A
   Component: Gateway       H07 0036
   Revision: 9A030002    Serial number: 0249A02CC18726
   Coding: 02010005000406408C960000005B0132CC9A00071C0000000900000000000000
   ASAM Dataset: EV_GatewCONTIAU736 003150
   ROD: EV_CGateCONTIAU491_AU58.rod
   VCID: 78BC0C7AC3274A8AED-802C
   Subsystem 1 - Part No SW: 4M8 951 523     HW: 4M8 951 523
   Component: J453 MFL  H03 0004
   Serial number: 20180905011112 30103
   Subsystem 2 - Part No SW: 4K0 915 181 A    HW: 4K0 915 181 A
   Serial number: 758852020018090500A8
   Component: MEM-FS        009 0042
   Serial number: 00000339846423
   Coding: 00181A400000B4410003010101010000810000212100000000000000004000
   ROD: EV_SCMDriveSideCONTIAU736_AU58.rod
   Part No SW: 4N0 907 566 E    HW: 4N0 907 566 A
   Component: MRR_HR H12 0265
   Coding: 0FFB00
   ASAM Dataset: EV_RearRadarS1DelphAU651 001018
   ROD: EV_RearRadarS1DelphAU651_VW53.rod
   VCID: 383CCC7A83A78A8A2D-806C
   Part No SW: 4M1 959 793 D    HW: 4M1 959 793 D
   Component: TSG FS001 0188
   Serial number: YE007RH900233
   Coding: 001DDB4252000480A009B430
   Shop #: WSC 31414 243 00001
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0504
   Coding: 92000001010000
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 312AF15E60DD5BC26A-8064
   Part No SW: 8W0 907 064 FP    HW: 8W0 907 064 DP
   Component: BCM2 MLBevo   025 0406
   Coding: 01340000002000E0630980000C00880003004000804B02502F0400200504823F001F0100000F01
   ASAM Dataset: EV_BCM2HellaAU736 015015
   ROD: EV_BCM2HellaAU736_015_AU58.rod
   VCID: 0F6E57A6D6A96D325C-805A
   Rear Light Left 1:
   Subsystem 1 - Part No SW: 4M8 945 069 B    HW: 4M8 945 069 B
   Component: SHL_li1  H04 0004
   Serial number: 069B1808160000008100
   Subsystem 2 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11175122
   Rear Light Left 2:
   Subsystem 3 - Part No SW: 4M8 945 217 F    HW: 4M8 945 217 F
   Component: SHL_li2  H04 0004
   Serial number: 217F1808070000005872
   Rear Light Right 1:
   Subsystem 4 - Part No SW: 4M8 945 070 B    HW: 4M8 945 070 B
   Component: SHL_re1  H04 0004
   Serial number: 070B1808280000010100
   Rear Light Right 2:
   Subsystem 5 - Part No SW: 4M8 945 218 F    HW: 4M8 945 218 F
   Component: SHL_re2  H04 0004
   Serial number: 218F1808070000005872
   Part No SW: 4N0 035 223 B    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0150
   Revision: 00000001    Serial number: AUZ8ZAJ6S008XDK
   Coding: 0135360A00AAAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001010
   ROD: EV_AMPMst16C1Gen2pALPI_AU58.rod
   VCID: 23060B162A21F952E8-8076
   Part No SW: 4M1 959 792 D    HW: 4M1 959 792 D
   Component: TSG BFS001 0188
   Serial number: YE007RH308757
   Coding: 001DDB025E000480A009B430
   VCID: 3FCEA766A689BDB2EC-806A
   Part No SW: 4K0 035 064 A    HW: 4K0 035 064 A
   Component: MU-H-LN-EU    046 2470
   Coding: 013536010000000083110002000800102F0001E401F00800CE
   ROD: EV_MUHigGen2pALPI.rod
   VCID: 22080E12353BF05AE3-8076
   Subsystem 1 - Part No: V03 959 804 BB
   Component: MIB2P_EU_Q317  0240
   Subsystem 2 - Part No SW: 4M8 919 605 A    HW: 4M8 919 605
   Component: DU AU536 High  H41 0144
   Serial number: INX00123071800100803
   Compact Disc Database:
   Component: Gracenote2  1008
   Volume Control 1:
   Subsystem 4 - Part No SW: 4N1 919 616 A    HW: 4N1 919 616
   Component: LSR-D5/C8  H33 0108
   Serial number: 00004418000172764022
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4N0 919 603 B    HW: 4N0 919 603
   Component: DU AU651 Bot  H41 0144
   Serial number: INX00103071800050028
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051800502854004
Address 61: Battery Regul.
   Component: RVC Compact   H15 0250
   Coding: 0235360102002001C20040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
   VCID: 3326FB569AC169D218-8066
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C737-6252-2
   Coding: 2870
   Shop #: WSC 31414 047 00001
   VCID: 3424F84A9FCF6EEA01-8060
Address 74: Chassis Control (J775)       Labels: None
   Part No SW: 4M8 907 777 N    HW: 4M8 907 777
   Component: Fahrwerk-SG   H51 2031
   Serial number: 2708180056
   Coding: 385C5848F800
   ASAM Dataset: EV_ChassContrContiAU651 001011
   ROD: EV_ChassContrContiAU651_001_AU58.rod
   VCID: 4CD480AAE73F162A79-8018
   Air Suspension Compressor:
   Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
   Component: V66LFKompOLV  H06 0013
   Serial number: 00000000004130381589
   Coding: 303030
   Part No SW: 4N1 713 041 D    HW: 4N1 713 041 C
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 18071348276382
   ROD: EV_GSMWaehlZFAU736_VW53.rod
   VCID: 271E1F065E191572B4-8072
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 B    HW: 4N0 907 107 G
   Component: zFAS Var B    H09 0290
   Coding: 040184000000000000F0060000D0C42C19995600000000000000000000000000001900000000000000000000000000000000000000000000F980800000000000000070D00080003000000000000000000080400000F0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_AU58.rod
2117690 - Unknown Error Code
          U1434 00 [008] - -
          [Databus_Ethernet_electrical_Error]
                    Reset counter: 50
                    Mileage: 401 km
                    Date: 2018.11.19
                    Time: 09:23:23
                    Ethernet signal quality: good: link available
65537 - Unknown Error Code
          C12D8 F0 [008] - Unknown Error Elaboration
                    Reset counter: 50
                    Mileage: 224 km
                    Date: 2018.11.16
                    Time: 16:25:47
                    Profile master status intersection assistant-Nominal status: OFF
                    Profile master status intersection assistant-Actual status:: Initializing
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0006
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736.rod
   VCID: 3228FE5265DB60DA13-8066
   Part No SW: 4M1 959 795 D    HW: 4M1 959 795 D
   Component: TSG HFS003 0188
   Serial number: YE007RGS06585
   Coding: 000DD90200000480A008B020
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   VCID: 42C8AE92D57BD05A83-8016
   Component: TSG HBFS003 0188
   Serial number: YE007RGS0640A
   ROD: EV_DCU2RearPasseMAXHCONT.rod
196665 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Reset counter: 50
                    Mileage: 404 km
                    Date: 2018.11.19
                    Time: 10:16:31
Address C4: DC/DC Converter (A7)       Labels: 4M0-959-663.clb
   Part No SW: 4M0 959 663 C    HW: 4M0 959 663 C
   Component: PCU10         022 0324
   ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
   ROD: EV_DCDC48V210ABOSCHAU736.rod
   VCID: 3A38D672BDAB989ADB-806E
Address CB: Rear Axle Steering (J1019)       Labels:* None
   Part No SW: 4M0 909 145 AA    HW: 4M0 909 145 E
   Component: HAL_MLBevoH08 0698
   Revision: --------    Serial number: CCC_098_B_1122_
   Coding: 42240A00
   ASAM Dataset: EV_RearAxleSteerZFAU736 010018
   ROD: EV_RearAxleSteerZFAU736_010.rod
   VCID: 6FAE3726B6690D323C-803A
0248 - Unknown Error Code
          C11D1 F3 [008] - Unknown Error Elaboration
                    Reset counter: 45
                    Mileage: 221 km
                    Date: 2018.11.16
                    Time: 15:26:44
                    Expanded ambient data 1-Terminal 75 status: 0
                    Expanded ambient data 1-Internal voltage supply 5V: 3.75 V
                    Expanded ambient data 1-Vehicle speed: 0.00 km/h
                    Expanded ambient data 1-Steering angle sensor: -800.00 °
                    Expanded ambient data 1-Internal malfunction: 0
                    Expanded ambient data 1-Nominal angle: -8.19 °
                    Expanded ambient data 1-Terminal 15 signal: 1
                    Expanded ambient data 1-Power reduction: 100 %
                    Expanded ambient data 1-Restart: 0
                    Expanded ambient data 1-Terminal 30 voltage filtered: 11.62 V
                    Expanded ambient data 1-Power reduction due to overvoltage: 100 %
                    Expanded ambient data 1-Power reduction due to undervoltage: 100 %
                    Expanded ambient data 1-Internal voltage supply 1.2V: 1.20 V
                    Expanded ambient data 1-Current_system_status: 6
Address CF: Lane Chge Asst 2 (J770)       Labels:* None
   Component: MRR_HL H12 0265
   Coding: 0FFB00
   ASAM Dataset: EV_RearRadarS2DelphAU651 001018
   ROD: EV_RearRadarS2DelphAU651_VW53.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 592 BC    HW: 4K0 941 592 B
   Component: LMS_MLBevo    H11 0030
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 72A83E52A55B20DAD3-8026
Address D7: Light Ctrl Right 2 (A27)       Labels: None
Address DB: Frt Corner Rdar 1 (J1089)       Labels:* None
   Part No SW: 4N0 907 669 E    HW: 4N0 907 669 A
   Component: MRR_VR H12 0265
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
   ROD: EV_FrontCorneRadarS1AU651.rod
   VCID: 3C34D06AB79FA6AAC9-8068
Address DC: Frt Corner Rdar 2 (J1088)       Labels:* None
   Component: MRR_VL H12 0265
   Coding: 003000
   ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
   ROD: EV_FrontCorneRadarS2AU651_AU58.rod
End----------(Elapsed Time: 01:56, VBatt start/end: 11.9V/12.0V)-----------
   #34
CA
thank you
best regards
Yes, there are two control modules in this car (46-Central Conv. and CA-Sunroof) that a HEX+CAN cannot talk to. Please contact the distributor you bought your HEX+CAN from and ask about upgrading to a current interface.
These cars have just been released. Support for them will improve with subsequent versions.
icardiag
Europe
C?ID=113031
Some news about upcoming VCDS release? It's been 3 months since last version, still no even beta available although in the discussions there were some fixes announced...
   #37
hadez16
C?ID=289891
Any interesting release notes on 18.9.1? :)
   #39
pierreb
C?ID=39895
was prompted to update to 19.6 today and VCDS.exe now crashes on start 10/10 times. Win 10 1803 build 17134.765. Reverted back to an older version (17.8) so I could work on my car. I think I had 18.9 until today's update and that seemed to work fine.
have windows defender active and defs are 1.295.90.0 from today June 4. It reports no threats from the .exe during manual scan. My work won't allow me to add exceptions or disable AV.
   #40
Hmm.. We haven't had any other reports like that (at least so far). Can you send whatever crash reports Windows will give you to Support please?
