newbie issue with 2003 audi a4 multitronic p1626 issues
starkie
C?ID=279996
hi folks just bought a ross tech lead after mucking about with bluetooth units for a few years. i have bought a 2003 tdi multitronic a4 (uk car) thats having gearbox issues (surprise surprise ) i have no service history with it but once communicating will oil and filter change the box.
my lead is not having any luck in communicating with the gearbox at all and this inability to talk to the tcu is causing a multitude of faults with various systems. i have found the ecu that is under the scuttle panel on left hand side of the car appears dry but the relays underneath it were all wet as was the wiring.
i have removed the relays and took the covers off them to make sure there is no internal damage to them and have allowed them to dry out.
i am going to look for the fuse for the tcu (in the passenger side fuse panel ? if i am correct )
any other suggestions of what to look for and or ideas would be greatly appreciated and i have included what vcds fault sheet some of these might clear easily as the battery was dead due to fan sometimes coming on when car locked ?
other than that the cars great and once these electrical faults are dealt with will be nice car as body work etc etc all good
Saturday,02,July,2016,18:52:48:44553
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WAUZZZ8E84A046688   License Plate: ML53ORH
Mileage: 187230km-116339mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8E84A046688   Mileage: 187230km-116339miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 LJ
   Component: 1,9l R4 EDC 0000AG  4910
   Coding: 00001
   Shop #: WSC 63351
   VCID: 6ADBBA4F16D1E06EC0-4AE8
   WAUZZZ8E84A046688     AUZ6Z0C0205287
18034 - Powertrain Data Bus
            P1626 - 35-00 - Missing Message from TCU
17994 - Engine Mount Solenoid Valves (N144/N145)
            P1586 - 35-10 - Short to Plus - Intermittent
18080 - Coolant Fan Control 1
            P1672 - 35-00 - Open or Short to Ground
Readiness: 1 1 0 0 1
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517
   Component: ABS/ESP front       3429
   Coding: 04259
   Shop #: WSC 06435
   VCID: 65C1C973FFCFCF16ED-5140
            35-00 -  -
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 35-00 -
   Part No: 8E0 820 043 AA
   Component:   A4 Klimaautomat   1219
   Coding: 00000
   Shop #: WSC 63351
   VCID: 60CFD867E0EDAA3E1E-5140
            30-00 - Open or Short to Plus
            27-00 - Implausible Signal
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 E
   Component: int. Lastmodul  RDW 0305
   Coding: 00001
   VCID: 346764370495669EAA-4B00
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 B
   Component: Airbag 8.4EP        3002
   Coding: 0010602
   Shop #: WSC 63351 000 00000
   VCID: 36635E3F42E9748E94-515E
   Part No: 8E0 953 549 F
   Component: Lenksáulenmodul     0308
   Coding: 01011
   Shop #: WSC 63351
   VCID: 36635E3F12E9748E94-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 950 J
   Component: KOMBI+WEGFAHRS. RB4 D36
   Coding: 00400
   Shop #: WSC 00048
   VCID: 306F6827F08D5ABECE-5140
01039 - Coolant Temperature Sensor (G2)
            49-00 - No Communications
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0604
   Coding: 00001
   VCID: 6BD5BF4B192BF966BB-5140
01462 - Anti-theft alarm ultra sonic Sensor (G209)
            53-00 - Supply Voltage Too Low
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 BC
   Component: Komfortgerát T3B    1311
   Coding: 06859
   Shop #: WSC 63351
   VCID: 73E5A72B411B21A673-4B00
   Subsystem 1 - Part No: 8E2959802B
   Component: Tõrsteuer.FS BRM 0003
   Subsystem 2 - Part No: 8E2959801B
   Component: Tõrsteuer.BF BRM 0003
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0003
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0003
10 Faults Found:
01616 - Signal Wire to Interior Monitor
00956 - Key 2
            35-00 -  -
01561 - Rear left door
            61-10 - Won't De-Safe - Intermittent
Given that both the ECU and the ABS module both have faults stating that they can't talk to the TCU either, I'd say chances are good that the TCU is out to lunch. Whether that's due to an internal fault in the 13 year old TCU or some external problem such as lack of power or wiring issues is rather difficult to ascertain remotely, but I'm reasonably confident it isn't a fault with VCDS or your HEX+CAN interface. ;)
I would indeed go through and clear fault codes in every module, then cycle the key, start the car, and see what comes back.
starkie
C?ID=279996
Is the tcu the ecu that's in the scuttle panel or the one at the gearbox
On the 01J Multitronic, the TCU is is part of the "Mechatronic" bolted right into the transmission.
starkie
C?ID=279996
Are these extremely difficult to open solder and reseal or best to pay to have done I am mechanical engineer and work with industrial sparkies so can turn hand to most jobs or have done
starkie
C?ID=279996
Other thing I have read is one of the 4 relays that are in scuttle panel and got wet is for the ecu so will check it's operation as that might not allow power to the ecu
starkie
C?ID=279996
anyone repaired the ecu one of these themselves ?
starkie
C?ID=279996
what i have also discovered is the prds lights are not on at the dash so this might be that the ecu side of things is not getting powered up does anyone know where i can get wiring diagrams for these cars.
i have opened the relay 219 (due to the area getting wet) and cleaned all the contacts and tried on a battery to make sure its working will clean all the spade connections and see if the unit gets power now but failing that i will have to trace the wiring
starkie
C?ID=279996
could the engine ecu coding being at 000001 be an issue ?
