hi folks just bought a ross tech lead after mucking about with bluetooth units for a few years. i have bought a 2003 tdi multitronic a4 (uk car) thats having gearbox issues (surprise surprise ) i have no service history with it but once communicating will oil and filter change the box.
my lead is not having any luck in communicating with the gearbox at all and this inability to talk to the tcu is causing a multitude of faults with various systems. i have found the ecu that is under the scuttle panel on left hand side of the car appears dry but the relays underneath it were all wet as was the wiring.
i have removed the relays and took the covers off them to make sure there is no internal damage to them and have allowed them to dry out.
i am going to look for the fuse for the tcu (in the passenger side fuse panel ? if i am correct )
any other suggestions of what to look for and or ideas would be greatly appreciated and i have included what vcds fault sheet some of these might clear easily as the battery was dead due to fan sometimes coming on when car locked ?
other than that the cars great and once these electrical faults are dealt with will be nice car as body work etc etc all good
Saturday,02,July,2016,18:52:48:44553
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WAUZZZ8E84A046688 License Plate: ML53ORH
Mileage: 187230km-116339mi Repair Order:
67 69 75 76 77
VIN: WAUZZZ8E84A046688 Mileage: 187230km-116339miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 LJ
Component: 1,9l R4 EDC 0000AG 4910
Coding: 00001
Shop #: WSC 63351
VCID: 6ADBBA4F16D1E06EC0-4AE8
WAUZZZ8E84A046688 AUZ6Z0C0205287
18034 - Powertrain Data Bus
P1626 - 35-00 - Missing Message from TCU
17994 - Engine Mount Solenoid Valves (N144/N145)
P1586 - 35-10 - Short to Plus - Intermittent
18080 - Coolant Fan Control 1
P1672 - 35-00 - Open or Short to Ground
Readiness: 1 1 0 0 1
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04259
Shop #: WSC 06435
VCID: 65C1C973FFCFCF16ED-5140
35-00 - -
18055 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 35-00 -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63351
VCID: 60CFD867E0EDAA3E1E-5140
30-00 - Open or Short to Plus
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
VCID: 346764370495669EAA-4B00
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 B
Component: Airbag 8.4EP 3002
Coding: 0010602
Shop #: WSC 63351 000 00000
VCID: 36635E3F42E9748E94-515E
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 F
Component: Lenksáulenmodul 0308
Coding: 01011
Shop #: WSC 63351
VCID: 36635E3F12E9748E94-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 J
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 00400
Shop #: WSC 00048
VCID: 306F6827F08D5ABECE-5140
01039 - Coolant Temperature Sensor (G2)
49-00 - No Communications
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
VCID: 6BD5BF4B192BF966BB-5140
01462 - Anti-theft alarm ultra sonic Sensor (G209)
53-00 - Supply Voltage Too Low
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BC
Component: Komfortgerát T3B 1311
Coding: 06859
Shop #: WSC 63351
VCID: 73E5A72B411B21A673-4B00
Subsystem 1 - Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0003
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0003
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0003
10 Faults Found:
01616 - Signal Wire to Interior Monitor
00956 - Key 2
35-00 - -
01561 - Rear left door
61-10 - Won't De-Safe - Intermittent
