- Jun 6, 2014
- 2
- 0
- C?ID=214827
My steering,abs & esp lights are on whilst my steering is also stiff
There is still some steering assistance but not as it should be, I have tried the normal adaptation procedures and still wont clear the problem
I am thinking it could be due to a faulty abs unit but would like a second opinion, thanks
Friday,06,June,2014,18:36:31:21058
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVWZZZ1KZ5W120531 License Plate: VA04
Mileage: 155310km-96505mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ5W120531 Mileage: 155310km/96505miles
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FM HW: 028 101 190 3
Component: R4 2,0L EDC 0000SG 6179
Revision: 12345678 Serial number: VWZ7Z0D0720737
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 73E5C8FF12E76A86965-8026
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023170
Shop #: WSC 01279 785 00200
VCID: 3A7B25DB750DDBCE953-806F
Part No: 1K0 907 044 K
Component: ClimatronicPQ35 061 0201
VCID: 2F6D048FBE4F0E6632D-807A
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
Component: Bordnetz-SG 1.0 H30 0704
Revision: 00030000 Serial number: 00000000703403
Coding: E5894F0600041800001400001400000000
Shop #: WSC 12345 123 12345
VCID: 408F573313D1811EDB7-8015
Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 12345
01835 - Bulb for Side-Blinkers; Right (M19)
01834 - Bulb for Side-Blinkers; Left (M18)
Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
Component: 02 AIRBAG VW8 022 0600
Revision: 05022000 Serial number: 0033JD0CU6GG
Coding: 0012338
Shop #: WSC 01268 785 00200
VCID: 2D511E87B4437C76001-8078
Subsystem 1 - Serial number: 6332MSME0F627302
Subsystem 2 - Serial number: 6342MSME54592903
Subsystem 3 - Serial number: 6351HSME39133102
Subsystem 4 - Serial number: 6361HSME14422E02
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000012
VCID: 306F07F3A371119E2B7-8065
Part No: 1K0 920 961 B
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0003403
Shop #: WSC 00680 210 92290
VCID: 2959EA9780AB6056EC9-807C
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 C HW: 1K0 907 951
Component: Gateway H08 0080
Revision: 08 Serial number: 260010450501D1
Coding: 3D3F0B40070003
VCID: 275DECAF96BF5626FAD-8072
Component: IMMO VDD 0814
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0148
Coding: 0000052
Part No: 1K2 909 144 F
Component: EPS_ZFLS Kl.3 1301
02546 - Steering Limit Stop
Mileage: 4720 km
Temperature: 27.0°C
Voltage: 13.90 V
Voltage: 13.80 V
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 T
Component: 0W KSG 0560
Coding: 99E802087F2D8505485FC61000
Shop #: WSC 12345 785 00200
VCID: 4189523718DB8816D49-8014
Subsystem 1 - Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 003 0003
Subsystem 3 - Part No: 1K0 951 177
Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
VCID: 316902F7A87B1896249-8064
Part No: 1K0 035 186 J
Component: Radio BNO 0016
Coding: 0040400
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0202
Coding: 0000016
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Coding: 0000016
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
Revision: 00700000 Serial number:
VCID: 2C5713838F59757E17F-8079
014 - Defective
