Steering light on causing stiff steering, ABS problem???
birdxr
C?ID=214827
My steering,abs & esp lights are on whilst my steering is also stiff
There is still some steering assistance but not as it should be, I have tried the normal adaptation procedures and still wont clear the problem
I am thinking it could be due to a faulty abs unit but would like a second opinion, thanks
Friday,06,June,2014,18:36:31:21058
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WVWZZZ1KZ5W120531   License Plate: VA04
Mileage: 155310km-96505mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: WVWZZZ1KZ5W120531   Mileage: 155310km/96505miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 FM    HW: 028 101 190 3
   Component: R4 2,0L EDC 0000SG  6179
   Revision: 12345678    Serial number: VWZ7Z0D0720737
   Coding: 0000072
   Shop #: WSC 66565 257 00032
   VCID: 73E5C8FF12E76A86965-8026
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0103
   Coding: 0023170
   Shop #: WSC 01279 785 00200
   VCID: 3A7B25DB750DDBCE953-806F
01486 - System Function Test Activated
   Part No: 1K0 907 044 K
   Component: ClimatronicPQ35 061 0201
   VCID: 2F6D048FBE4F0E6632D-807A
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000703403
   Coding: E5894F0600041800001400001400000000
   VCID: 408F573313D1811EDB7-8015
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 12345
01835 - Bulb for Side-Blinkers; Right (M19)
01834 - Bulb for Side-Blinkers; Left (M18)
   Part No SW: 1K0 909 605 D    HW: 1K0 909 605 D
   Component: 02 AIRBAG VW8   022 0600
   Revision: 05022000    Serial number: 0033JD0CU6GG
   Coding: 0012338
   Shop #: WSC 01268 785 00200
   VCID: 2D511E87B4437C76001-8078
   Subsystem 1 - Serial number: 6332MSME0F627302
   Subsystem 2 - Serial number: 6342MSME54592903
   Subsystem 3 - Serial number: 6351HSME39133102
   Subsystem 4 - Serial number: 6361HSME14422E02
   Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
   Component: Lenksäulenmodul 012 0030
   Coding: 0000012
   VCID: 306F07F3A371119E2B7-8065
   Part No: 1K0 920 961 B
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0003403
   Shop #: WSC 00680 210 92290
   VCID: 2959EA9780AB6056EC9-807C
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 260010450501D1
   Coding: 3D3F0B40070003
   VCID: 275DECAF96BF5626FAD-8072
   Component: IMMO            VDD 0814
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0148
   Coding: 0000052
   Part No: 1K2 909 144 F
   Component: EPS_ZFLS Kl.3       1301
02546 - Steering Limit Stop
                    Mileage: 4720 km
                    Temperature: 27.0°C
                    Voltage: 13.90 V
                    Voltage: 13.80 V
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 T
   Component: 0W KSG              0560
   Coding: 99E802087F2D8505485FC61000
   Shop #: WSC 12345 785 00200
   VCID: 4189523718DB8816D49-8014
   Subsystem 1 - Part No: 1K0 951 605 A
   Component: LIN BACKUP HORN H01 1201
   Subsystem 2 - Part No: 1K0 907 719
   Component: Neigungssensor  003 0003
   Subsystem 3 - Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
   VCID: 316902F7A87B1896249-8064
   Part No: 1K0 035 186 J
   Component: Radio BNO           0016
   Coding: 0040400
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0202
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 D    HW: 1K0 963 235 D
   Component: PTC-Element         0404
   Revision: 00700000    Serial number:
   VCID: 2C5713838F59757E17F-8079
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
birdxr
C?ID=214827
The fault code "03-ABS '01486 - System Function Test Activated" only appeared after I had been into the output test
This was the original log which includes "01276 - ABS Hydraulic Pump (V64)
012 - Electrical Fault in Circuit"
Wednesday,28,May,2014,18:30:55:21058
Control Module Part Number: 03G 906 016 FM    HW: 028 101 190 3
  Component and/or Version: R4 2,0L EDC 0000SG  6179
           Software Coding: 0000072
            Work Shop Code: WSC 00000 028 00001
17056 - Cylinder 2 Glow Plug Circuit (Q11)
            P0672 - 000 - Electrical Fault
                    RPM: 819 /min
                    Torque: 52.0 Nm
                    Voltage: 14.14 V
                    Bin. Bits: 11000100
                    Temperature: 16.2°C
                    Bin. Bits: 10110000
17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault
                    RPM: 819 /min
                    Torque: 52.0 Nm
                    Voltage: 14.14 V
                    Bin. Bits: 11000100
                    Temperature: 16.2°C
                    Bin. Bits: 10110000
Friday,30,May,2014,21:18:23:21058
                    RPM: 924 /min
                    Torque: 66.0 Nm
                    Voltage: 14.44 V
                    Bin. Bits: 11000100
                    Temperature: 10.8°C
                    Bin. Bits: 10110000
                    RPM: 924 /min
                    Torque: 66.0 Nm
                    Voltage: 14.44 V
                    Bin. Bits: 11000100
                    Temperature: 10.8°C
                    Bin. Bits: 10110000
Friday,30,May,2014,21:18:39:21058
Readiness Status: 00000000 00000110 10000000 10000000
MIL Status: MIL OFF
Comprehensive Components: Passed
Fuel System: Passed
Exhaust Gas Recirculation: Failed or Incomplete
Number of EOBD-related DTC(s): 0
Friday,30,May,2014,21:19:13:21058
Control Module Part Number: 1K0 907 379 K
  Component and/or Version: ESP FRONT MK60      0103
           Software Coding: 0023170
            Work Shop Code: WSC 01279 785 00200
Friday,30,May,2014,21:19:38:21058
Control Module Part Number: 1K2 909 144 F
  Component and/or Version: EPS_ZFLS Kl.3       1301
           Software Coding:
            Work Shop Code: WSC 00000 000 00000
                    Mileage: 4640 km
                    Temperature: 31.0°C
                    Voltage: 13.80 V
                    Voltage: 13.70 V
Saturday,31,May,2014,16:44:23:21058
Adaptation Channel 050:
Stored value
  ERROR:
  Channel 50
  Not
  Available
Saturday,31,May,2014,19:18:50:21058
akersgarage
C?ID=179893
We had a similar issue as above, and the small plug behind the headlight for the steering rack loom had cut/broken wires
