George Smooth
Hi,
Helping a friend code his transmission. Its a hybrid EA888 Gen 3 with DQ500. Is it possible?
Sunday,20,March,2016,18:56:53:46690
VCDS Version: 15.7.4.1 (x64)
Data version: 20160216
VIN: WVWZZZAUZFW049392 License Plate: NEWRS390%
Mileage: 15628km-9710mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 22 42 44 52 55 5F A9
VIN: WVWZZZAUZFW049392 Mileage: 15628km-9710miles
Address 01: Engine (J623-CJXC) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 E HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0005
Revision: --H13---
Coding: 091D00322466050B2000
ASAM Dataset: EV_ECM20TFS0205G0906259E 001005
ROD: EV_ECM20TFS0205G0906259E_VW37.rod
VCID: 306F2CA96B9531BECE-8064
16837 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 00 [038] - Signal too High
Mileage: 15628 km
Date: 2016.03.12
Time: 16:39:15
15170 - Engine Oil Temp. Sensor (G8)
P0198 00 [039] - Signal too High
Mileage: 15628 km
Date: 2016.03.20
Time: 11:54:37
15171 - Engine Oil Temp. Sensor (G8)
P0196 00 [038] - Implausible Signal
Mileage: 15628 km
Date: 2016.03.20
Time: 11:54:07
15187 - Park/Neutral Switch Input Circuit
P0850 00 [039] - Open or Short to Plus
Mileage: 15628 km
Date: 2016.03.20
Time: 00:00:23
21654 - No Communication with Transmission Control Module
U0101 00 [038] - -
Mileage: 15628 km
Date: 2016.03.12
Time: 16:39:14
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0DL 300 011 D HW: 0BH 927 711 F
Component: GSG DQ500 H10 4796
Revision: 00H10V01
ROD: EV_TCMDQ500021_SE36.rod
VCID: 2959C1CD484F407609-807C
Part No SW: 5Q0 907 379 M HW: 5Q0 907 379 H
Component: ESC H31 0571
Revision: 00000000 Serial number: 61824000000509
Coding: 01FA93A154242975037A070941C56980C92A94C0E08296F7F84250F8C208
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 46836A71F9118F0E04-8012
0297 - Steering angle sensor
B1168 16 [137] - Voltage Too Low
Reset counter: 10
Date: 2016.03.20
Time: 12:19:19
8277 - Databus
Reset counter: 10
Date: 2016.03.20
Time: 12:19:19
8299 - Databus
Reset counter: 10
Date: 2016.03.20
Time: 12:19:19
C1146 02 [137] - Signal Failure
Reset counter: 10
Mileage: 15628 km
Date: 2016.03.20
Time: 12:19:31
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 AN HW: 5G0 907 044 AN
Component: Climatronic H03 0907
Revision: 00001K08
Coding: 00120004200100011005000000101000
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 73E5E3A5DA034AA673-8026
590082 - Control Circuit for A/C Compressor
B10A9 15 [009] - Open or Short to Plus
Reset counter: 10
Mileage: 15628 km
Date: 2016.03.20
Time: 12:19:19
262658 - High Pressure Sensor
B10AE 31 [009] - No Signal
Reset counter: 10
Mileage: 15628 km
Date: 2016.03.20
Time: 12:19:18
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
Component: BCM MQBAB H H18 0134
Serial number: 01011418400086
Coding: 03001A46C20122F30B244080B11C07281000000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 000FBC699BB5613E7E-8054
Slave 1:
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140630 042 0551
Serial number: 140702085730
Slave 2:
Component: RLHS 037 0059
Serial number: S4Y14M07D14H04M31S35
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY141552E2V
Serial number: 00000000000030026810
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39331419004164
Coding: 0071050011
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 3D71059DACC7CCD655-8068
13637426 - Databus
Reset counter: 10
Mileage: 15628 km
Date: 2016.03.20
Time: 12:19:18
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Serial number: 05071476510058
Coding: 001C1300FE0739
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 387F148983E5E9FE86-806C
1058 - Databus
Reset counter: 10
Mileage: 15628 km
Date: 2016.03.20
Time: 12:19:18
1059 - Databus
Reset counter: 10
Mileage: 15628 km
Date: 2016.03.20
Time: 12:19:18
1078 - Databus
Reset counter: 10
Mileage: 15628 km
Date: 2016.03.20
Time: 12:19:18
1043 - Automatic Distance Control
B10E7 F0 [009] - Disconnected
Reset counter: 10
Mileage: 15628 km
Date: 2016.03.20
Time: 12:19:18
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 HW: 5Q0 907 376
Component: DAEMPFUNGS-SG H15 0115
Serial number: 22051441350265
ROD: EV_DRCONTITEMIC.rod
VCID: 76E3DAB1C9715F8E54-8022
835328 - MIL Request Signal Active (Check TCM for errors too!)
P1624 00 [008] - -
Reset counter: 50
Mileage: 15628 km
Date: 2016.03.20
Time: 12:19:19
198666 - Front Left Ride-Height Sensor
C1034 15 [008] - Open or Short to Plus
Reset counter: 50
Mileage: 15628 km
Date: 2016.03.20
Time: 12:19:18
452874 - Front Right Ride-Height Sensor
C1035 15 [008] - Open or Short to Plus
Reset counter: 50
Mileage: 15628 km
Date: 2016.03.20
Time: 12:19:18
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR06VRV$
VCID: 7F0D3F95E64B1EC607-802A
Seat belt tensioner; left:
Component: BeltPretRevFL H35 0341
Serial number: 34169661C30061490001
Coding: 333135
Seat belt tensioner; right:
Component: BeltPretRevFR H35 0341
Serial number: 34169662C30061490367
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 407 14
Serial number: 35767000000BA329301O
Subsystem 4 - Part No SW: ----------- HW: 480 002 706 14
Serial number: 358670000004677D001O
Subsystem 5 - Part No SW: ----------- HW: 480 400 207 14
Serial number: 3516502AF1656B82614B
Subsystem 6 - Part No SW: ----------- HW: 480 400 207 14
Serial number: 3526502AF1656B80518D
Subsystem 7 - Part No SW: ----------- HW: 480 400 207 14
Serial number: 3556502A31656B845111
1050117 - Databus
Reset counter: 10
Mileage: 15628 km
Date: 2016.03.20
Time: 12:19:18
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 03071408490560
Coding: 0C10
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 7BF5CB85F25302E62B-802E
Part No SW: 5G1 920 958 HW: 5G1 920 958
Component: KOMBI 304 4270
Coding: 27AD00083F80260001886A011400000000000000
VCID: 6ED3F2D1B121674E9C-803A
Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
Component: GW MQB High 128 1188
Revision: -------- Serial number: 0002130815
Coding: 030100042B085900EF00027E9C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 011016
ROD: EV_GatewLear.rod
VCID: 428B7661D539B32E28-8016
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N
Component: E221__MFL-DC1 H07 0038
Serial number: 29140001363750054273
Coding: 2DFFFF
197175 - Control unit for battery monitoring
U1050 00 [009] - No Communication
Reset counter: 10
Mileage: 15628 km
Date: 2016.03.20
Time: 12:19:19
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Component: Haldex4Motion H52 7081
Serial number: HA1-00027.05.14
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002011
ROD: EV_AllWheelContrHA1VW37X_AU21.rod
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 21061403110245
Coding: 003F0220D001048100001000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 408F7C69DB35A13E3E-8014
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 0002
ROD: EV_SteerAssisMQB.rod
VCID: 35611DBD94F714969D-8060
16135 - Steering Angle Sensor
B1168 F2 [008] - Not Initialized
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 23061403110729
Coding: 003F0020DE01048100801000
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 3F8D7F95A6CBDEC647-806A
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 02A602000B010000
ROD: EV_HeadlRegulVWAFS_SE26.rod
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
13705990 - Databus
Reset counter: 50
Mileage: 15628 km
Date: 2016.03.20
Time: 12:19:18
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-HGH1.clb
Part No SW: 5G0 035 020 D HW: 5G0 035 020 D
Component: MU-H-ND-EU H43 0362
Serial number: A310G0EB003307
Coding: 06730001FF00000011111201000800031F0207C60100010057
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_VW37.rod
VCID: 1A3BEE011D29DBEE90-804E
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H60 0030
Serial number: VWZ8Z9PS10059V
Engine Control Module 2:
Subsystem 2 - Part No SW: ----------- HW: -----------
Component: ECE 2014/2015 --- 0086
Door Electronics Rear Left:
Component: Gracenote --- 1010
Part No SW: 5G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 140514200026
VCID: 2D5135DD7CA75C56E5-8078
End-------------------------(Elapsed Time: 04:50)--------------------------
