long code for abs golf mk vii gti
euro1
UAE
C?ID=221840
Dear All i need a long coding for abs module
VCDS Version: Release 15.7.4 (x64) Running on Windows 8.1 x64
Data version: 20160216
euro
Saturday,19,March,2016,20:02:31:05701
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW4T7AUXFM004160   Mileage: 11786km-7323miles
03-ABS Brakes -- Status: Not registered 0011
Address 01: Engine (J623-CNTA)       Labels: 06K-907-425-V1.clb
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 091D00124424000F0000
   Shop #: WSC 00066 790 00202
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
   ROD: EV_ECM20TFS0205G0906259A_VW37.rod
   VCID: 2C571AF2471D725EF2-8078
17178 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 9813 km
                    Date: 2016.01.25
                    Time: 17:05:41
   Part No SW: 0D9 300 040 S    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H52 4310
   Revision: 05852204    Serial number: TFK01403011556
   Shop #: WSC 00066 790 07031
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 275DE5DE5EFB51061F-8072
          P1734 00 [002] - -
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 51744000001209
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
   VCID: 44875252CF8D9A1E1A-8010
12 Faults Found:
0038 - Front Left Wheel Speed Sensor
          C101A 29 [008] - Signal Implausible
                    Reset counter: 82
                    Mileage: 11161 km
                    Date: 2016.03.17
                    Time: 17:20:11
0054 - Front Right Wheel Speed Sensor
          C101B 29 [008] - Signal Implausible
                    Reset counter: 82
                    Mileage: 11161 km
                    Date: 2016.03.17
                    Time: 17:20:10
0070 - Rear Left Wheel Speed Sensor
          C101C 29 [008] - Signal Implausible
                    Reset counter: 82
                    Mileage: 11161 km
                    Date: 2016.03.17
                    Time: 17:20:11
0086 - Rear Right Wheel Speed Sensor
          C101D 29 [008] - Signal Implausible
                    Reset counter: 82
                    Mileage: 11161 km
                    Date: 2016.03.17
                    Time: 17:20:11
0195 - Control module not coded
          U1013 00 [137] - -
                    Reset counter: 27
                    Date: 2016.01.25
                    Time: 17:05:49
0212 - Longitudinal Acceleration Sensor
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 27
                    Date: 2016.01.25
                    Time: 17:05:49
0270 - Lateral Acceleration Sensor
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 27
                    Date: 2016.01.25
                    Time: 17:05:49
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 27
                    Date: 2016.01.25
                    Time: 17:05:49
0295 - Steering angle sensor
                    Reset counter: 27
                    Date: 2016.01.25
                    Time: 17:05:49
4161 - Coding invalid
          U10DA 00 [009] - -
                    Reset counter: 48
                    Mileage: 9856 km
                    Date: 2016.01.25
                    Time: 20:50:35
8290 - Coding Not Possible
          U10BC 00 [137] - -
                    Reset counter: 27
                    Mileage: 9813 km
                    Date: 2016.01.25
                    Time: 17:05:54
8306 - Databus
          U1122 00 [137] - Implausible Message
                    Reset counter: 27
                    Mileage: 9813 km
                    Date: 2016.01.25
                    Time: 17:05:54
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5G0 907 426 N    HW: 5G0 907 426 N
   Component: AC Manuell    H01 0705
   Revision: 00001K06
   Coding: 00020004200100000000000000000000
   ROD: EV_ACManueBHBVW37X_SE37.rod
   VCID: 3663389A8951388E94-8062
   Part No SW: 5Q0 937 087 K    HW: 5Q0 937 087 K
   Component: BCM PQ37BOSCH 026 0097
   Revision: --------    Serial number: 86580704141031
   Coding: 000018464041804969E44000001407201000000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 4385514ECA839D2623-8016
   Slave 1:
   Component: WWS    140224  043 0581
   Serial number:         140422135735
329480 - Heated Passenger Seat
          B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
                    Fault Frequency: 17
                    Reset counter: 88
                    Mileage: 9856 km
                    Date: 2016.01.25
                    Time: 18:22:40
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM004CLF
   VCID: 51A96B0600FF7FB6A1-8004
   Seat occupant detection; front passenger side:
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  005 0016
   Serial number: IBH0000J140000MXMZ0A
   Coding: 30325A
   Subsystem 2 - Part No SW: -----------    HW: 480 002 901 14
   Serial number: 3570000000087028BE0M
   Subsystem 3 - Part No SW: -----------    HW: 480 003 101 14
   Serial number: 35800000000B503D9E0S
   Subsystem 4 - Part No SW: -----------    HW: 480 400 302 14
   Serial number: 3510002AB12AB1B5D0FF
   Subsystem 5 - Part No SW: -----------    HW: 480 400 302 14
   Serial number: 3520002B313013F1A1EW
   Subsystem 6 - Part No SW: -----------    HW: 480 402 002 14
   Serial number: 3550002C7107DB44218%
   Subsystem 7 - Part No SW: -----------    HW: 480 402 002 14
   Serial number: 3560002C7107DB42D213
          B13BC F2 [137] - No function
                    Mileage: 9856 km
                    Date: 2016.01.25
                    Time: 21:07:53
   Part No SW: 5Q0 953 507 DB    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 21031404220259
   Coding: 0410
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 79F9F3A6F8CF17F639-802C
   Part No SW: 5G6 920 970 C    HW: 5G6 920 970 C
   Component: KOMBI         316 2210
   Coding: 0BBD090A2180CF0502086A00000000
   VCID: 306F0E826B3516BECE-8064
16776973 - Databus
                    Reset counter: 27
                    Mileage: 9813 km
                    Date: 2016.01.25
                    Time: 17:05:48
   Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2163
   Revision: --------    Serial number: 17021410000843
   Coding: 0101000820085900EF000028180F00000001000000000000000000000000
   Shop #: WSC 00066 790 07026
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti.rod
   VCID: 3E7320BAA161F0CE4C-806A
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q
   Component: E221__MFL-DC1  H06 0101
   Serial number: 29140000273350094134
   Coding: 29FFFF
66304 - Databus
          U1124 00 [009] - Additional Installations Detected
                    Reset counter: 48
                    Mileage: 9813 km
                    Date: 2016.01.25
                    Time: 17:05:49
   Serial number: 220414060502AY
   Coding: 003E03200000040000000000
   VCID: 408F5E42DB95863E3E-8014
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000001873215
   Coding: 011000
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8102
   ROD: EV_SteerAssisMQB.rod
   VCID: 35613F96945733969D-8060
19204 - Databus
                    Reset counter: 88
                    Mileage: 9813 km
                    Date: 2016.01.25
                    Time: 17:05:47
   Serial number: 090414060502SV
   VCID: 3F8D5DBEA66BF9C647-806A
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000001850857
   Coding: 191000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     013 0645
   Serial number: V7B02303141921
   Coding: 02730000FF00000021220001001800001F0203040100010002
   ROD: EV_MUStd4CPASE_SK37.rod
   VCID: 64C7B2D26F4DFA1EFA-8030
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS50020B
          B11CF 53 [009] - Deactivated
                    Reset counter: 27
                    Mileage: 9813 km
                    Date: 2016.01.25
                    Time: 17:05:25
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   Coding: 02730002C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
   VCID: 020B944A9519542E68-8056
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 0
   Part No SW: 5G0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0013
   Serial number: 140207200004
   VCID: 6BD5D9EE8293B566BB-803E
End-------------------------(Elapsed Time: 03:16)--------------------------
DV52
C?ID=194404
Euro1. hello. Here's some information from my database. It's from an Autobahn (NAR)
;SW:5Q0-907-379-K HW:5Q0-907-379-F --- ABS Brakes
;Component: ESC H31 0371
;EV_Brake1UDSContiMK100ESP
Coding:01FA6BA13420096C007C020881C52980D62C9000408194B400430050C009
Hope that it is of use
Would you mind telling us how it got to be all zeros?
Considering the complexity of the coding in the previous generation of ABS modules (MK60EC1), I doubt this one will be any easier.
euro1
UAE
C?ID=221840
Thanks Mate i will try with that code today although i have tried already with some us specs codes before with no luck.
i have bought the car like this with an abs problem the original module in the car didnt have any communication it was completely dead i can say so i swap it with a good one now but i need to coded obviously
thanks
automech
C?ID=14925
I'll try to calc the coding for you but it will take some time since this ABS is really complicated to code and I don't have much info for US models.
automech
C?ID=14925
01fa6ba1342009700378060681c32980d62c90c0608294b402030030c002
01fa6ba1342009700378060681c32980d62c90c0608294b402030050c002
01fa6ba1342009700378060681c32980d62c90c0608294b400430050c002
NEtech
C?ID=56995
I would try this:
01FA6BA1342009700078020681C32980D62C9000408194B400430050C009
euro1
UAE
C?ID=221840
Thanks guys i will try all the codes and i will let u know
DV52
C?ID=194404
Not sure what it means, but here's a comparison of all the suggestions thus far. Can someone explain the significance of the differences - please?
automech
C?ID=14925
Many of this bytes are still not fully described, nor by me or RT or anyone, that's why you need to try couple of options. I can tell that the last byte corresponds to modes which the "ESP OFF" button on centre console works. I still miss precise data on bytes 02,04,06,17,18,24-28, (work in still process), so you need to look at the people scans with similar car to match some bytes.
euro1
UAE
C?ID=221840
I would try this:
NEtech i tried this code it accepted but it wont let me do the adaption for steering angle sensor ? any thoughs on this so now i have 2 warning lights remaining the traction and steering
thanks guys
euro1
UAE
C?ID=221840
those are the faults i get now once i am going to do the calibration for steering angle sensor it just keeps says running not stopped or anything that seems strange to me
Thursday,31,March,2016,18:26:31:05701
euro
Address 03: ABS Brakes Labels: 5Q0-907-379-ESP-V1.clb
Control Module Part Number: 5Q0 907 379 K HW: 5Q0 907 379 F
Component and/or Version: ESC H31 0371
Software Coding: 01FA6BA1342009700078020681C32980D62C9000408194B400430050C009
Work Shop Code: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001 (VW37)
Reset counter: 78
Date: 2016.03.31
Time: 18:05:22
8277 - Databus
Reset counter: 78
Date: 2016.03.31
Time: 18:05:22
16390 - Display for Tire Pressure Monitoring
Reset counter: 78
Mileage: 13884 km
Date: 2016.03.31
Time: 18:05:31
DV52
C?ID=194404
thanks guys
euro1: I doubt that there is anyone more knowledgeable than NEtech when it comes to there's matters (certainly not me), but the problem may be the security code that you are using to access the steering angle sensor. My understanding is that there is a different SA for different bunches of adaptation channels in the ABS. Here's a list of the SAs that I'm aware-of for you to try
25004
11966
15081
18573
20103
24435
25004
28183
31857
37202
40168
44595
10505
But remember that if the SA code is not accepted, you might need to wait a while (with the ignition switched-on) before you will be allowed to re-enter another SA
NEtech
C?ID=56995
How does the Autoscan look like, do you still have several U112x DTC ?
If so I would search for that.
automech
C?ID=14925
Did your car accepted my code??? I just want to know for my knowledge.
euro1
UAE
C?ID=221840
no i will post a full autoscan again
automech i havent tried your code
thanks guys
euro1
UAE
C?ID=221840
scan
this is my latest scan pls have a look
Tuesday,12,April,2016,17:26:52:05701
VCDS Version: 15.7.4.1 (x64)
Dealer/Shop Name: euro
VIN: 3VW4T7AUXFM004160   License Plate: HA
Mileage: 15542km-9657mi   Repair Order:
VIN: 3VW4T7AUXFM004160   Mileage: 15542km-9657miles
   Revision: --H13---
17178 - Databus
                    Mileage: 12645 km
                    Date: 2016.03.22
                    Time: 19:04:17
          P1734 00 [002] - -
                    Reset counter: 78
                    Date: 2016.03.31
                    Time: 18:05:22
8277 - Databus
                    Reset counter: 78
                    Date: 2016.03.31
                    Time: 18:05:22
                    Reset counter: 78
                    Mileage: 13884 km
                    Date: 2016.03.31
                    Time: 18:05:31
   Revision: 00001K06
   Slave 1:
                    Fault Frequency: 44
                    Reset counter: 148
                    Mileage: 12645 km
                    Date: 2016.03.22
                    Time: 19:13:56
   Coding: 30325A
   Coding: 0410
   Coding: 29FFFF
   Coding: 011000
65588 - Motor for Window Regulator
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 142
                    Mileage: 13993 km
                    Date: 2016.04.02
                    Time: 11:47:11
   Coding: 0002
15873 - Steering angle sensor
                    Reset counter: 78
                    Mileage: 13884 km
                    Date: 2016.03.31
                    Time: 18:13:43
   Coding: 191000
                    Reset counter: 58
                    Mileage: 12645 km
                    Date: 2016.03.22
                    Time: 19:04:43
                    Fault Priority: 8
                    Reset counter: 108
                    Mileage: 1048574 km
                    Time: 00:00:00
End-------------------------(Elapsed Time: 03:15)--------------------------
-3VW4T7AUXFM004160-15542km-9657mi.txt
Displaying Log--3VW4T7AUXFM004160-15542km-9657mi.txt.
Dana
Western PA, USA
I believe the current coding
is correct. I would reset the TPMS, take that car for a short test drive, turn the steering lock to lock at a standstill and clear codes to see which return. The G85 calibration would be completed in Address 44 (instead of 03 or 16 like other cars).
DV52
C?ID=194404
OK, I've been following this thread with more than a modicum of interest, but the multiple suggestions is making progress difficult to follow! So using my handy-dandy "code string to Byte list converter" this is the current state-of-play- I think:
If my converter is working properly, it appears that the only live suggestion is from NEtech
euro1
UAE
C?ID=221840
guys finally the long code worked i would like to thank everyone in here for the great support,the only thing i had to do it was to reset the tpms and then all went good
thanks
