Dear All i need a long coding for abs module
VCDS Version: Release 15.7.4 (x64) Running on Windows 8.1 x64
Data version: 20160216
euro
Saturday,19,March,2016,20:02:31:05701
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW4T7AUXFM004160 Mileage: 11786km-7323miles
03-ABS Brakes -- Status: Not registered 0011
Address 01: Engine (J623-CNTA) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 A HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0004
Revision: --H13---
Coding: 091D00124424000F0000
Shop #: WSC 00066 790 00202
ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
ROD: EV_ECM20TFS0205G0906259A_VW37.rod
VCID: 2C571AF2471D725EF2-8078
17178 - Databus
U1123 00 [047] - Received Error Message
Mileage: 9813 km
Date: 2016.01.25
Time: 17:05:41
Part No SW: 0D9 300 040 S HW: 02E 927 770 AQ
Component: DQ250-6F MQB H52 4310
Revision: 05852204 Serial number: TFK01403011556
Shop #: WSC 00066 790 07031
ROD: EV_TCMDQ250021_AU37.rod
VCID: 275DE5DE5EFB51061F-8072
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 K HW: 5Q0 907 379 F
Component: ESC H31 0371
Revision: 00000000 Serial number: 51744000001209
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_VW37.rod
VCID: 44875252CF8D9A1E1A-8010
12 Faults Found:
0038 - Front Left Wheel Speed Sensor
C101A 29 [008] - Signal Implausible
Reset counter: 82
Mileage: 11161 km
Date: 2016.03.17
Time: 17:20:11
0054 - Front Right Wheel Speed Sensor
C101B 29 [008] - Signal Implausible
Reset counter: 82
Mileage: 11161 km
Date: 2016.03.17
Time: 17:20:10
0070 - Rear Left Wheel Speed Sensor
C101C 29 [008] - Signal Implausible
Reset counter: 82
Mileage: 11161 km
Date: 2016.03.17
Time: 17:20:11
0086 - Rear Right Wheel Speed Sensor
C101D 29 [008] - Signal Implausible
Reset counter: 82
Mileage: 11161 km
Date: 2016.03.17
Time: 17:20:11
0195 - Control module not coded
U1013 00 [137] - -
Reset counter: 27
Date: 2016.01.25
Time: 17:05:49
C1017 54 [137] - Missing Calibration / Basic Setting
Reset counter: 27
Date: 2016.01.25
Time: 17:05:49
C1079 54 [137] - Missing Calibration / Basic Setting
Reset counter: 27
Date: 2016.01.25
Time: 17:05:49
0279 - Brake Pressure Sensor 1
C107A 54 [137] - Missing Calibration / Basic Setting
Reset counter: 27
Date: 2016.01.25
Time: 17:05:49
0295 - Steering angle sensor
B1168 54 [137] - Missing Calibration / Basic Setting
Reset counter: 27
Date: 2016.01.25
Time: 17:05:49
4161 - Coding invalid
U10DA 00 [009] - -
Reset counter: 48
Mileage: 9856 km
Date: 2016.01.25
Time: 20:50:35
8290 - Coding Not Possible
U10BC 00 [137] - -
Reset counter: 27
Mileage: 9813 km
Date: 2016.01.25
Time: 17:05:54
8306 - Databus
U1122 00 [137] - Implausible Message
Reset counter: 27
Mileage: 9813 km
Date: 2016.01.25
Time: 17:05:54
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5G0 907 426 N HW: 5G0 907 426 N
Component: AC Manuell H01 0705
Revision: 00001K06
Coding: 00020004200100000000000000000000
ROD: EV_ACManueBHBVW37X_SE37.rod
VCID: 3663389A8951388E94-8062
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 K HW: 5Q0 937 087 K
Component: BCM PQ37BOSCH 026 0097
Revision: -------- Serial number: 86580704141031
Coding: 000018464041804969E44000001407201000000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
ROD: EV_BCMBOSCH_AU37.rod
VCID: 4385514ECA839D2623-8016
Slave 1:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 140224 043 0581
Serial number: 140422135735
Fault Frequency: 17
Reset counter: 88
Mileage: 9856 km
Date: 2016.01.25
Time: 18:22:40
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM004CLF
VCID: 51A96B0600FF7FB6A1-8004
Seat occupant detection; front passenger side:
Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A
Component: BF-Gewichtss. 005 0016
Serial number: IBH0000J140000MXMZ0A
Coding: 30325A
Subsystem 2 - Part No SW: ----------- HW: 480 002 901 14
Serial number: 3570000000087028BE0M
Subsystem 3 - Part No SW: ----------- HW: 480 003 101 14
Serial number: 35800000000B503D9E0S
Subsystem 4 - Part No SW: ----------- HW: 480 400 302 14
Serial number: 3510002AB12AB1B5D0FF
Subsystem 5 - Part No SW: ----------- HW: 480 400 302 14
Serial number: 3520002B313013F1A1EW
Subsystem 6 - Part No SW: ----------- HW: 480 402 002 14
Serial number: 3550002C7107DB44218%
Subsystem 7 - Part No SW: ----------- HW: 480 402 002 14
Component: FrontSensor_P 001 6149
Serial number: 3560002C7107DB42D213
B13BC F2 [137] - No function
Mileage: 9856 km
Date: 2016.01.25
Time: 21:07:53
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 DB HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 21031404220259
Coding: 0410
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 79F9F3A6F8CF17F639-802C
Part No SW: 5G6 920 970 C HW: 5G6 920 970 C
Component: KOMBI 316 2210
Coding: 0BBD090A2180CF0502086A00000000
VCID: 306F0E826B3516BECE-8064
16776973 - Databus
Reset counter: 27
Mileage: 9813 km
Date: 2016.01.25
Time: 17:05:48
Part No SW: 5Q0 907 530 P HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2163
Revision: -------- Serial number: 17021410000843
Coding: 0101000820085900EF000028180F00000001000000000000000000000000
Shop #: WSC 00066 790 07026
ASAM Dataset: EV_GatewConti 010015
ROD: EV_GatewConti.rod
VCID: 3E7320BAA161F0CE4C-806A
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H06 0101
Serial number: 29140000273350094134
Coding: 29FFFF
66304 - Databus
U1124 00 [009] - Additional Installations Detected
Reset counter: 48
Mileage: 9813 km
Date: 2016.01.25
Time: 17:05:49
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 220414060502AY
Coding: 003E03200000040000000000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 408F5E42DB95863E3E-8014
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000001873215
Coding: 011000
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8102
ROD: EV_SteerAssisMQB.rod
VCID: 35613F96945733969D-8060
19204 - Databus
Reset counter: 88
Mileage: 9813 km
Date: 2016.01.25
Time: 17:05:47
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 090414060502SV
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 3F8D5DBEA66BF9C647-806A
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000001850857
Coding: 191000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 844 HW: 5G0 035 844
Component: MU-S-S-US 013 0645
Serial number: V7B02303141921
Coding: 02730000FF00000021220001001800001F0203040100010002
ROD: EV_MUStd4CPASE_SK37.rod
VCID: 64C7B2D26F4DFA1EFA-8030
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 605 H HW: 5G0 919 605 H
Component: ABT_Std_Plus H60 0030
Serial number: VWZ8Z9PS50020B
0020 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Reset counter: 27
Mileage: 9813 km
Date: 2016.01.25
Time: 17:05:25
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 HW: 5QE 035 285
Component: OCULowMQBUS 006 0528
Coding: 02730002C2821A017F1E06000000
ROD: EV_OCULowMQB.rod
VCID: 020B944A9519542E68-8056
2103041 - Control Module
Fault Priority: 8
Reset counter: 0
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0013
Serial number: 140207200004
VCID: 6BD5D9EE8293B566BB-803E
End-------------------------(Elapsed Time: 03:16)--------------------------
