Hi all,
I installed a cruise control and handles from an A7 4G in hopes to get CC to work. But when I try to activate it in the engine module I get the following error code:
This error seems to be messing with the start/stop system
Also in the instruments module I activated the Cruise Control Option installed
But I am not able to change the option in the steering wheel module
Byte02 bit 2-3. If I change this to CCS installed I get an error: Coding rejected, Error 31: Request out of range.
Here is a scan of my car before messing with the coding .
My verification process is pending, but I hope I could already get some support from you guys, thanks in advance.
Thursday,31,December,2015,10:26:23:64893
VCDS Version: Release 15.7.3 (x64) Running on Windows 7 x64
Address 01: Engine Labels: 03L-906-018-CGL.clb
Control Module Part Number: 03L 906 018 GT HW: 03L 906 018 JL
Component and/or Version: R4 2,0L EDC H23 0757
Software Coding: 0A194012232401080000
Work Shop Code: WSC 02311 785 00200
ASAM Dataset: EV_ECM20TDI01103L906018GT 003005 (AU57)
ROD: EV_ECM20TDI01103L906018GT.rod
VCID: 020BEAE095F26C2E67-8056
4332 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [167] - -
Mileage: 55444 km
Date: 2015.12.31
Time: 11:10:36
Thursday,31,December,2015,10:06:55:64893
VCDS Version: 15.7.3.0 (x64)
Data version: 20151216
VIN: WAUZZZ4G6BN028655 License Plate:
Mileage: 55444km-34451mi Repair Order:
Chassis Type: 4G (4G0)
Scan: 01 03 05 08 09 15 16 17 19 3B 42 44 46 52 53 5F 62 72
VIN: WAUZZZ4G6BN028655 Mileage: 55444km-34451miles
Address 01: Engine (J623-CGLD) Labels: 03L-906-018-CGL.clb
Part No SW: 03L 906 018 GT HW: 03L 906 018 JL
Component: R4 2,0L EDC H23 0757
Revision: 45H23---
Coding: 0A194012230401080000
Shop #: WSC 02311 785 00200
Address 03: ABS Brakes (J104) Labels: 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 HW: 4G0 907 379
Component: ESP PREMIUM H08 0190
Coding: 06A087006005E1008B00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_AU57.rod
VCID: 6ED3AE50B16A784E93-803A
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 AG HW: 4H0 907 064 AG
Component: BCM2 2.0 H24 0217
Coding: 03A83000000000000000
VCID: 6ED3AE50B96A784E93-803A
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 H HW: 4G0 820 043 H
Component: KLIMA 2 ZONEN H10 0056
Serial number: 27041100040473
Coding: 34010008A0
ASAM Dataset: EV_AirCondiBasisUDS 002033
ROD: EV_AirCondiBasisUDS.rod
VCID: 24478C782F26821E35-8070
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 J HW: 4H0 907 063 B
Component: BCM1 2.0 H12 0092
Revision: 13012002 Serial number: 00000001011081
Coding: 690000108034A7600405008300005F5F0F9C820826080101000004402000
VCID: 2F6D73547EE03146D8-807A
Component: WWS57X 110409 H35 0051
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 HW: 4G0 941 531
Component: E1 - LDS H07 0044
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG0027JUA
Coding: 30323436313230303039554A304C34473053
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3663463089BA008E9B-8062
Serial number: 3575HRB404T0H922CGB9
Serial number: 3585HRB405H0HM76D0E9
Serial number: 3515JRB40690EB5UJ164
Serial number: 3525JRB404R0HCMSFPDO
Serial number: 3554VRB40550FAMAFP3S
Serial number: 3564VRB40530FAMAG95E
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 E HW: 4H0 953 568 E
Component: Lenks.Modul H03 0003
Revision: -------- Serial number: 90372KDD0014G
Coding: 000010
VCID: 3561413C9CBC0B9692-8060
Subsystem 1 - Part No SW: 4G0 951 528 D HW: 4G0 951 528 D
Component: E221 - MFL H07 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 900 C HW: 4G8 920 900 C
Component: MDieRdw H29 0086
Revision: 18420081 Serial number: 658300311593012
Coding: 1305080003010008010000
ASAM Dataset: EV_RBC7KMID 004040
ROD: EV_RBC7KMID.rod
VCID: 2A5B62404D02546E0F-807E
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 B HW: 4G0 907 468
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000130347
Coding: 00CD074400
ROD: EV_GatewUDS_AU57.rod
VCID: 2F6D735476E03146D8-807A
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650125719
Voltage stabilizer:
Part No SW: 4G0 907 637 HW: 4G0 907 637
Component: SARA 3D H02 0004
Revision: -------- Serial number: EJ1BPA32004WD50
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA.rod
VCID: 6BD5A74482788D66B4-803E
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 C HW: 4G8 959 793 A
Component: TSG FA H04 0210
Coding: 011C06205000620002080002
Shop #: WSC 02312 785 00200
VCID: 408F20E8D37EBE3E31-8014
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 F
Component: RCEPS H32 0010
Revision: 00001000 Serial number: 0010064151
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS.rod
VCID: 326B7A2065D21CAEB7-8066
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0147986312
Coding: 0100062000B904C083200804000100000000000000000000000000000000
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0210
Coding: 011C06205C00620002080002
VCID: 3F8D2314AE80C1C648-806A
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000064319
ROD: EV_ParkiBrake_AU48.rod
Part No SW: 4G0 035 180 A HW: 4G0 035 180
Component: RMC H43 0530
Coding: 0100000001411947002B040001010000000000
VCID: 1D31B99C044CB3D67A-8048
Subsystem 1 - Part No SW: 4G0 919 603 HW: 4G0 919 603
Component: DU6 Basic H42 0084
Subsystem 2 - Part No SW: 4G1 919 615 K HW: 4G1 919 615 K
Component: E380 BDT C7 H08 0120
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0210
Coding: 010804204000620002080002
VCID: 428B2AE0DD72AC2E27-8016
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0210
End-------------------------(Elapsed Time: 03:27)--------------------------
