Is it possible to change the 12v power socket in the boot so it is ignition fed? currently it is permanent live.
Ideally by coding but info on any other way is appreciated.
The car is a 2015 Škoda Superb MKIII ()
Gizmo: Hello. Alas I fear that I might have to disappoint you because I beleive that a tweak won't suffice for your needs. My suspicion is that what is needed is an old-fashion, low-tech, fuse-yank!
I believe that the arrangement for the ciggy lighter (Uwe has advised that PC terms aren't needed here - so I won't call it a 12v power socket) in the skoda superb is very similar (same?) as the mk7 Golf (even the method of getting access to the fuse box is the same - I believe). This being so, all that you need to do is move the position of fuse #40 as shown in the picture below. The second, smaller picture is from the on-line free Skoda manual - notice the similarities between the two cars and notice also the inclusion of the down-arrow on fuse #40!
Please note that the factory default in a mk7 is for a terminal 15 supply (i.e. switched 12V with ignition-on). Clearly the default for the skoda is opposite (i.e. terminal 30), so your objective is to have fuse 40 in the position shown in the 1st (mk7) picture
There is a full write-up of the complete process
HERE
Cheers
PS: the other fortunate aspect of our cars is that we both live in enlightened countries that have the steering wheel on the correct side of the vehicle!
PPS: Fuse position #40 supplies the in-cabin and hatch ciggy lighters, so the change will impact both sockets
