> I have an customer who purchased an car that was parked for about five years the ignition
>> switch was change I am now trying to programme the keys but cant ,after
>> I login and change the key value it says error and cannot be saved .
Code:Saturday,12,December,2015,13:34:53:42721 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 15.7.2.0 Data version: 20151124 www.Ross-Tech.com VIN: TMBBT23U139038444 License Plate: PIN 00043 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 3U (3U - Skoda Superb (2002 > 2008)) Scan: 01 02 03 08 15 16 17 19 36 37 46 47 55 56 76 VIN: TMBBT23U139038444 Mileage: 141260km-87774miles ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No: 3B0 907 551 CJ Component: 2.8L V6/5V G 0004 Coding: 26551 Shop #: WSC 12980 VCID: 6DDA700027371F56B0-5120 TMBBT23U139038444 SKZ7Z0B1729779 2 Faults Found: 18034 - Powertrain Data Bus P1626 - 35-10 - Missing Message from TCU - Intermittent 18010 - Power Supply Terminal 30 P1602 - 35-00 - Voltage too Low Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01V-927-156.lbl Part No: 8D0 927 156 DJ Component: AG5 01V 2.8l5V RdW 1111 Coding: 00103 Shop #: WSC 12980 VCID: 78F451545875AAFE53-5102 5 Faults Found: 17090 - Transmission Range Sensor (F125) P0706 - 35-00 - Implausible Signal 18232 - Pressure Control Valve 3 (N217) P1824 - 35-10 - Open or Short to Ground - Intermittent 18227 - Pressure Control Valve 2 (N216) P1819 - 35-10 - Open or Short to Ground - Intermittent 18258 - Powertrain Data Bus P1850 - 35-10 - Missing Message from ECU - Intermittent 18155 - Transmission Solenoid Power Relay P1747 - 35-10 - Open or Short to Ground - Intermittent ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 3U0-614-517.lbl Part No: 3U0 614 517 B Component: ABS/ESP front 1312 Coding: 04497 Shop #: WSC 00028 VCID: 3260A37CFE8980AEAD-5102 1 Fault Found: 01119 - Gear Recognition Signal 35-00 - - ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 3U0-907-044.lbl Part No: 3U0 907 044 A Component: CLIMATRONIC S B5 C 2004 Coding: 17000 Shop #: WSC 00028 VCID: 3162AC70FB8FBBB6D4-513C 3 Faults Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent 01274 - Air Flow Flap Positioning Motor (V71) 37-00 - Faulty 01341 - Control Module in Instrument Panel On Comfort CAN (J285) 27-10 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl Part No: 1C0 909 605 H Component: 0B AIRBAG VW51 0K 0008 Coding: 12354 Shop #: WSC 00028 VCID: 29524410D35FC3761C-5102 1 Fault Found: 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1J0-907-487-A.lbl Part No: 1J0 907 487 A Component: Lenkradelektronik 0005 Coding: 00118 Shop #: WSC 00028 VCID: 2F66AA08EDBBAD46C2-5102 1 Fault Found: 00926 - Terminal 30 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 3U0-920-xxx-17.lbl Part No: 3U0 920 840 C Component: KOMBI+WEGFAHRSP VDO V06 Coding: 31125 Shop #: WSC 12980 VCID: 3260A37CFE8980AEAD-5102 TMBBT23U139038444 SKZ7Z0B1729779 5 Faults Found: 01176 - Key 65-10 - Unauthorized - Intermittent 01315 - Transmission Control Module 49-10 - No Communications - Intermittent 00476 - Control Module for Fuel Pump (J538) 49-00 - No Communications 01304 - Radio 49-00 - No Communications 01300 - Control Module for Navigation with CD-Rom (J401) 49-00 - No Communications ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 Component: Gateway K<->CAN 0001 Coding: 00006 Shop #: WSC 12980 VCID: 70E469743005F2BE9B-5102 6 Faults Found: 01315 - Transmission Control Module 49-10 - No Communications - Intermittent 00476 - Control Module for Fuel Pump (J538) 49-00 - No Communications 01304 - Radio 49-00 - No Communications 01300 - Control Module for Navigation with CD-Rom (J401) 49-00 - No Communications 00463 - Control Module for Digital Sound Package (J525) 49-00 - No Communications 01303 - Telephone Transceiver (R36) 49-00 - No Communications ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: 3B1-959-760.lbl Part No: 3B1 959 760 E Component: Sitzverstellung 0301 Shop #: WSC 00000 000 00000 VCID: 2F66AA08BDBBAD46C2-5102 2 Faults Found: 01008 - Note; Emergency OFF Switch is Active! 000 - - 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1C0-959-799.lbl Part No: 1C0 959 799 B Component: 5F Komfortgerát HLO 0003 Coding: 00258 Shop #: WSC 00028 VCID: 36689F6C12E19C8E81-4ACE Subsystem 1 - Part No: 1C0959802 Component: 5F Tõrsteuer.FS KLO 0009 Subsystem 2 - Part No: 1C0959801A Component: 5F Tõrsteuer.BF KLO 0009 Subsystem 3 - Part No: 3U0959811 Component: 5F Tõrsteuer.HL KLO 0009 Subsystem 4 - Part No: 3U0959812 Component: 5F Tõrsteuer.HR KLO 0009 8 Faults Found: 01330 - Central Control Module for Central Convenience (J393) 53-10 - Supply Voltage Too Low - Intermittent 01135 - Interior Monitoring Sensors 36-10 - Open Circuit - Intermittent 01331 - Door Control Module; Driver Side (J386) 53-10 - Supply Voltage Too Low - Intermittent 00928 - Locking Module for Central Locking; Front Driver Side (F220) 27-10 - Implausible Signal - Intermittent 01332 - Door Control Module; Passenger Side (J387) 53-10 - Supply Voltage Too Low - Intermittent 01359 - Internal Central Locking Switch; Passenger Side (E198) 27-10 - Implausible Signal - Intermittent 01333 - Door Control Module; Rear Left (J388) 53-10 - Supply Voltage Too Low - Intermittent 01334 - Door Control Module; Rear Right (J389) 53-10 - Supply Voltage Too Low - Intermittent ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4Z7-907-357.lbl Part No: 4Z7 907 357 Component: dynamische LWR D09 Coding: 00005 Shop #: WSC 73430 VCID: 040C35A414BDFE1E4F-4B00 2 Faults Found: 00776 - Level Control System Sensor; Left Front (G78) 31-00 - Open or Short to Ground 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 3U0-919-283-7X1.lbl Part No: 3U0 919 283 Component: Einparkhilfe V008 Coding: 01114 Shop #: WSC 00028 VCID: 78F451545875AAFE53-4B96 3 Faults Found: 01545 - Sensor for Parking Aid; Rear Left (G203) 29-00 - Short to Ground 01547 - Sensor for Parking Aid; Rear Mid-Right (G205) 29-00 - Short to Ground 01548 - Sensor for Parking Aid; Rear Right (G206) 29-00 - Short to Ground End-------------------------(Elapsed Time: 03:12)--------------------------
