Skoda Superb
TOPPTRONICS
Barbados
C?ID=57569
> I have an customer who purchased an car that was parked for about five years the ignition
>> switch was change I am now trying to programme the keys but cant ,after
>> I login and change the key value it says error and cannot be saved .
Saturday,12,December,2015,13:34:53:42721
VCDS Version: 15.7.2.0
Data version: 20151124
VIN: TMBBT23U139038444   License Plate: PIN 00043
Chassis Type: 3U (3U - Skoda Superb (2002 > 2008))
Scan: 01 02 03 08 15 16 17 19 36 37 46 47 55 56 76
VIN: TMBBT23U139038444   Mileage: 141260km-87774miles
   Part No: 3B0 907 551 CJ
   Component: 2.8L V6/5V      G   0004
   Coding: 26551
   Shop #: WSC 12980
   VCID: 6DDA700027371F56B0-5120
   TMBBT23U139038444     SKZ7Z0B1729779
18034 - Powertrain Data Bus
            P1626 - 35-10 - Missing Message from TCU - Intermittent
18010 - Power Supply Terminal 30
            P1602 - 35-00 - Voltage too Low
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 8D0 927 156 DJ
   Component: AG5 01V 2.8l5V  RdW 1111
   Coding: 00103
   Shop #: WSC 12980
   VCID: 78F451545875AAFE53-5102
17090 - Transmission Range Sensor (F125)
            P0706 - 35-00 - Implausible Signal
18232 - Pressure Control Valve 3 (N217)
            P1824 - 35-10 - Open or Short to Ground - Intermittent
18227 - Pressure Control Valve 2 (N216)
            P1819 - 35-10 - Open or Short to Ground - Intermittent
18258 - Powertrain Data Bus
            P1850 - 35-10 - Missing Message from ECU - Intermittent
18155 - Transmission Solenoid Power Relay
            P1747 - 35-10 - Open or Short to Ground - Intermittent
Address 03: ABS Brakes        Labels: 3U0-614-517.lbl
   Part No: 3U0 614 517 B
   Component: ABS/ESP front       1312
   Coding: 04497
   Shop #: WSC 00028
   VCID: 3260A37CFE8980AEAD-5102
01119 - Gear Recognition Signal
            35-00 -  -
Address 08: Auto HVAC        Labels: 3U0-907-044.lbl
   Part No: 3U0 907 044 A
   Component: CLIMATRONIC S B5 C  2004
   Coding: 17000
   Shop #: WSC 00028
   VCID: 3162AC70FB8FBBB6D4-513C
            37-00 - Faulty
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
   Part No: 1C0 909 605 H
   Component: 0B AIRBAG VW51 0K   0008
   Coding: 12354
   Shop #: WSC 00028
   VCID: 29524410D35FC3761C-5102
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00118
   Shop #: WSC 00028
   VCID: 2F66AA08EDBBAD46C2-5102
00926 - Terminal 30
Address 17: Instruments        Labels: 3U0-920-xxx-17.lbl
   Part No: 3U0 920 840 C
   Component: KOMBI+WEGFAHRSP VDO V06
   Coding: 31125
   Shop #: WSC 12980
01176 - Key
            65-10 - Unauthorized - Intermittent
00476 - Control Module for Fuel Pump (J538)
            49-00 - No Communications
01304 - Radio
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 12980
   VCID: 70E469743005F2BE9B-5102
01304 - Radio
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 E
   Component: Sitzverstellung     0301
   VCID: 2F66AA08BDBBAD46C2-5102
01008 - Note; Emergency OFF Switch is Active!
            000 -  -
   Part No: 1C0 959 799 B
   Component: 5F Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 00028
   VCID: 36689F6C12E19C8E81-4ACE
   Subsystem 1 - Part No: 1C0959802
   Component: 5F Tõrsteuer.FS KLO 0009
   Subsystem 2 - Part No: 1C0959801A
   Component: 5F Tõrsteuer.BF KLO 0009
   Subsystem 3 - Part No: 3U0959811
   Component: 5F Tõrsteuer.HL KLO 0009
   Subsystem 4 - Part No: 3U0959812
   Component: 5F Tõrsteuer.HR KLO 0009
8 Faults Found:
            36-10 - Open Circuit - Intermittent
01359 - Internal Central Locking Switch; Passenger Side (E198)
Address 55: Headlight Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00005
   Shop #: WSC 73430
   VCID: 040C35A414BDFE1E4F-4B00
00776 - Level Control System Sensor; Left Front (G78)
            31-00 - Open or Short to Ground
Address 76: Park Assist        Labels: 3U0-919-283-7X1.lbl
   Part No: 3U0 919 283
   Component: Einparkhilfe        V008
   Coding: 01114
   Shop #: WSC 00028
   VCID: 78F451545875AAFE53-4B96
01545 - Sensor for Parking Aid; Rear Left (G203)
            29-00 - Short to Ground
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
01548 - Sensor for Parking Aid; Rear Right (G206)
End-------------------------(Elapsed Time: 03:12)--------------------------
Gone But Not Forgotten
You have to erase all keys first with VCDS, before you can add all including new additional key count during next login session saved should start with Zero keys.
