2010 Jetta TDI ABS issue missing software code
Homefront
C?ID=262513
Jack,
had no luck with them long codes, this could be me. This coding thing could be me as this part is a learning curve for me.
- Then I tried to follow (Change Cluster/Matching ECU)
http://wiki.ross-tech.com/wiki/index.php/Immobilizer_II_Immobilizer_Swapping_(Instrument_Cluster)
Determining IMMO-ID (ECU)
[Select]
[01 - Engine]
Look at the first "Extra" field. The 14-digit string is the Immo-ID.
[Close Controller, Go Back - 06]
Note: If the 17 Digit VIN is shown the vehicle does not use Immo II and the procedure here does not apply.
(scanning this got me the VIN but did not show the 14-digit string for the Immo-ID)
Well that failed so I went ahead and changed the cluster to the Matching ECU (donor car):
with no luck just got more codes with the matching cluster. (key not matching) Immobilizer has been unlocked so I am able to start the car with the correct cut key and lost steering wheel controls.
I was told the code was 4144 after having the ecu done as stage 2 ( Immobilizer code)
how do we come up with this long code?
Ok im so lost now..
I no I should not do this but here is my cell I hope someone will be able to get me on track here
612.203.8913
Thank you all!
SteveOOO
   #22
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Jack,
[Select]
[01 - Engine]
Ok im so lost now..
612.203.8913
Thank you all!
SteveOOO
I gave you answer in post #19.
And most likely when you fix VIN in both modules , you will need to go to Vw Dealer to get online ABS coding, best and safest way.
If you put original cluster in car , of curse you will get Immobilizer code bacuse cluster is not programmed.
   #23
You could send me all your equipment so it can be properly programmed, because VW-Audi GeKo policy to change entire identity must be changed with all new parts.
You still have not posted the data I requested...........
Put what works in there for now with matching cluster, key and ecu that operates even if immo defeated.
Don't alter config from here trying this or that........
Post a full auto-scan and give me additional data ...
ecu 0x01-10-091 and 0x01-08-081
Immo 0x25-08-003 and 081
Stop putzing around.
Last chance because I have this car in my bay right now while playing G235 and other service.......
I can simulate this with entire car.......
   #24
Homefront
C?ID=262513
Jack,
I put everything back to factory now.
081 shows the correct VIN #
01 engine doesn't show vin# or Immobilizer
025 no codes on Immobilizer
003 ? showing EGR 100% all good there
Cluster I have been googling dont no how to get you that info...
here is the update scans I pulled I hope this will be helpful
here is the full scan
Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: Release 15.7.2(x64) Data version: 20151124
Dealer/Shop Name: Homefront
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Monday,14,December,2015,14:08:02:34959
VIN: 3VWAL7AJ3AM116056 License Plate:
Mileage: 139920km-86942mi Repair Order:
Chassis Type: AJ (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 65 72
77
VIN: 3VWAL7AJ3AM116056 Mileage: 139920km-86942miles
1C-Position Sensing -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Cannot be reached 1100
56-Radio -- Status: Malfunction 1110
Self-Diagnosis Log
Page 2
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 CM HW: 03L 906 022 TS
Component: R4 2,0L EDC G000AG 9971
Revision: 12H03--- Serial number:
Coding: 0050078
Shop #: WSC 02408 444 11192
VCID: 78FFB5480B5BC4FE53-802C
001166 - Sensor for Exhaust Flap
P048E - 000 - Short to Plus
Mileage: 139923 km
Date: 2010.05.06
Time: 00:05:01
Voltage: 11.86 V
Lambda: 99.4 %
Lambda: 0.0 %
Bin. Bits: 00000000
Voltage: 5.016 V
001029 - EGR Sensor 1
P0405 - 000 - Signal too Low
Mileage: 139923 km
Date: 2010.05.06
Time: 00:05:01
Voltage: 11.86 V
Lambda: 99.4 %
Lambda: 0.0 %
Voltage: 0.000 V
Bin. Bits: 00000000
009258 - Exhaust Gas Temperature Sensor; B1 S3
Self-Diagnosis Log
Page 3
P242A - 001 - Malfunction
Fault Status: 01100001
Mileage: 139923 km
Date: 2010.05.06
Time: 00:05:01
Voltage: 11.86 V
Temperature: 14.4°C
Temperature: 18.0°C
Temperature: 930.0°C
Temperature: 18.0°C
001141 - Exhaust Pressure Control Valve
P0475 - 000 - Electrical Malfunction
Mileage: 139923 km
Date: 2010.05.06
Time: 00:05:02
Load: 0.0 %
Load: 100.0 %
Lambda: 99.4 %
Temperature: 18.0°C
Temperature: 14.4°C
005184 - EGR Valve (N18)
P1440 - 000 - Open Circuit
Mileage: 139923 km
Date: 2010.05.06
Time: 00:05:02
Self-Diagnosis Log
Page 4
Load: 0.0 %
Load: 100.0 %
Lambda: 99.4 %
Mass Air / Rev.: 0.0 mg/str
Temperature: 14.4°C
P242A - 000 - Malfunction - MIL ON
Fault Status: 11100000
Mileage: 139923 km
Date: 2010.05.06
Time: 00:05:06
Voltage: 11.86 V
Temperature: 14.4°C
Temperature: 18.0°C
Temperature: 18.0°C
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 052 T HW: 02E 927 770 AL
Component: L DSG AG6 511 2114
Revision: 51112 Serial number: 00001004291528
Coding: 0000024
Shop #: WSC 02069 000 90108
VCID: 2541AC3CEC69891638-8070
Self-Diagnosis Log
Page 5
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Shop #: WSC 00066 000 00000
VCID: 7AFBAF40F557D6EE25-802E
Reset counter: 179
Date: 2010.05.06
Time: 00:07:25
Count: 3
Count: 12
Count: 20992
Count: 195
Count: 42752
Fault Status: 01100101
Reset counter: 179
Mileage: 139923 km
Date: 2010.05.06
Time: 00:06:29
Count: 3
Count: 12
Count: 4096
Count: 279
Count: 43008
Count: 768
Self-Diagnosis Log
Page 6
Reset counter: 179
Mileage: 139923 km
Date: 2010.05.06
Time: 00:06:29
Count: 3
Count: 12
Count: 4096
Count: 295
Count: 43008
Count: 768
Reset counter: 179
Mileage: 139923 km
Date: 2010.05.06
Time: 00:06:29
Count: 3
Count: 12
Count: 4096
Count: 270
Count: 43008
Count: 768
Self-Diagnosis Log
Page 7
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00148
ROD: EV_ClimaBasis_VW36.rod
VCID: 75E1BC7CD449B99648-8020
B10AB F0 [009] - Too Low
Reset counter: 175
Mileage: 139754 km
Date: 2015.12.08
Time: 06:59:11
Self-Diagnosis Log
Page 8
Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
Component: BCM PQ35 B++ 111 0129
Revision: BI111001
Coding: 2D200B1A902F3EE4800800854000000401000086510085605C8020000000
VCID: 377D767486C50B869A-8062
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 19031 21 0512
Coding: 009795
14 Faults Found:
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 219
Mileage: 139923 km
Date: 2010.05.06
Time: 00:19:20
Term 15 On
Voltage: 9.55 V
Fault Frequency: 26
Reset counter: 219
Mileage: 138941 km
Date: 2015.09.07
Time: 17:43:41
Term 15 Off
Voltage: 8.50 V
Self-Diagnosis Log
Page 9
00532 - Supply Voltage B+
Reset counter: 219
Mileage: 139923 km
Date: 2010.05.02
Time: 06:56:10
Term 15 On
Voltage: 8.65 V
Fault Status: 00101010
Reset counter: 210
Mileage: 139465 km
Date: 2015.10.01
Time: 02:11:21
Term 15 On
Voltage: 13.85 V
Reset counter: 210
Self-Diagnosis Log
Page 10
Mileage: 139465 km
Date: 2015.10.01
Time: 02:11:21
Term 15 On
Voltage: 13.85 V
Reset counter: 210
Mileage: 139465 km
Date: 2015.10.01
Time: 02:11:16
Term 15 On
Voltage: 14.05 V
Reset counter: 210
Mileage: 139465 km
Date: 2015.10.01
Time: 02:11:16
Term 15 On
Voltage: 14.05 V
Self-Diagnosis Log
Page 11
Reset counter: 210
Mileage: 139465 km
Date: 2015.09.30
Time: 22:09:49
Term 15 On
Voltage: 13.50 V
Reset counter: 210
Mileage: 139465 km
Date: 2015.10.01
Time: 02:11:16
Term 15 On
Voltage: 13.90 V
Self-Diagnosis Log
Page 12
Reset counter: 217
Mileage: 139923 km
Date: 2010.05.01
Time: 05:49:11
Term 15 On
Voltage: 11.65 V
Reset counter: 217
Mileage: 139923 km
Date: 2010.05.01
Time: 06:41:57
Term 15 On
Voltage: 11.60 V
01800 - Light Switch (E1)
Reset counter: 210
Mileage: 54223 km
Date: 2015.07.29
Time: 00:00:04
Term 15 Off
Voltage: 12.55 V
Self-Diagnosis Log
Page 13
Reset counter: 210
Mileage: 139465 km
Date: 2015.10.04
Time: 21:52:11
Term 15 Off
Voltage: 12.05 V
Reset counter: 210
Mileage: 139465 km
Date: 2015.10.04
Time: 21:52:11
Term 15 Off
Voltage: 12.05 V
Self-Diagnosis Log
Page 14
Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
Component: 04 AIRBAG VW8R 036 8900
Revision: 06036000 Serial number: 003EVM02H6PY
Coding: 0012340
VCID: 6ED39310791F8A4E89-803A
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME4F10263BD
Subsystem 3 - Serial number: 6342MSME4F414F1BR
Subsystem 4 - Serial number: 6351HSME1F75282EL
Subsystem 5 - Serial number: 6361HSME1F751544A
Subsystem 6 - Serial number: 63727SME2157565D4
Subsystem 7 - Serial number: 63827SME21576C40+
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001731
VCID: 76E3BB70014FB28E41-8022
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Coding: 00000130
Self-Diagnosis Log
Page 15
Part No SW: 5M0 920 970 G HW: 5M0 920 970 G
Component: KOMBI H05 0305
Coding: 271F00
VCID: 346741789FB3E09EBF-8060
13635840 - Supply voltage
Reset counter: 217
Mileage: 139923 km
Date: 2015.12.10
Time: 06:56:38
Self-Diagnosis Log
Page 16
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 040210F1000342
Coding: ED807F07001612001002
VCID: 69D9E00C40F16D76DC-803C
Fault Status: 00110100
Reset counter: 217
01304 - Radio
Fault Frequency: 88
Reset counter: 179
Mileage: 139635 km
Date: 2010.04.29
Time: 06:50:58
Reset counter: 179
Mileage: 54320 km
Date: 2015.07.31
Time: 12:24:14
Reset counter: 217
Mileage: 139923 km
Date: 2010.05.02
Self-Diagnosis Log
Page 17
Time: 06:56:09
03272 - Control Module for Audio Interface
Reset counter: 179
Mileage: 139635 km
Date: 2010.04.29
Time: 06:50:58
Part No SW: 1K5 919 965 D HW: 1K5 919 965 D
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1293324T4Q0C05
Coding: 0000004
VCID: 3C7769587FE328DE77-8068
Reset counter: 219
Mileage: 139923 km
Date: 2010.05.02
Time: 06:56:07
Component: IMMO H05 0305
VCID: 6ADB9F008DF7666ED5-803E
Self-Diagnosis Log
Page 18
Address 2E: Media Player 3
Self-Diagnosis Log
Page 19
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000567620
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 275DA6345E659B060A-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004703294
Coding: 000490
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 179
67589 - Turn Signal in Exterior Mirror
B11FD 01 [009] - Electrical Failure
Reset counter: 174
Mileage: 139635 km
Date: 2015.12.07
Time: 06:56:39
65793 - Supply voltage
Reset counter: 217
Mileage: 139923 km
Date: 2015.12.10
Time: 06:55:08
Self-Diagnosis Log
Page 20
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
VCID: 3169486CA8A1D5B6D4-8064
Fault Status: 11100101
Battery Volts: 11.2 V
DD
Temperature: 13.0°C
Count: 3
Steering Angle: -5.25°
Count: 1
SteerAng n.Init
Self-Diagnosis Log
Page 21
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0000549125
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 285FA508537B947E03-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004706195
Coding: 000490
B11EC 54 [008] - Missing Calibration / Basic Setting
Reset counter: 217
Reset counter: 175
Mileage: 139645 km
Date: 2015.12.07
Time: 07:08:06
Reset counter: 217
Mileage: 139923 km
Date: 2015.12.10
Time: 06:55:07
Self-Diagnosis Log
Page 22
Address 56: Radio
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Component: RDK 111 0821
Coding: 018705
Address 77: Telephone
End-------------------------(Elapsed Time: 02:29)--------------------------
Homefront
C?ID=262513
Address 01: Engine (03L 906 019 CM)
15:06:30
3VWAL7AJ3AM116056 Vehicle Ident. Number (VIN)
3VWAL7AJ3AM116056 Immobilizer Ident. Number (IMMO-ID)
139920 km Vehicle Mileage
Im am not able to find (IMMO-ID) everything has matching vin#'s now
as for the cluster I cant find what it is your looking for, im sorry
VCDS is kicking my XXX lol, had it now for 2 weeks so much to learn about it.
   #26
Revision: 00H30001
Revision: 00H30001
Coding: 114B400C492A00FC880D02EC921E0042310000 <<<<<<<<<<<<<< Found trolling scans!:p
TRY this !
114b400d49230000880b02e9921f0042310000
3VWAL7AJ3AM116056 <<<<<<<<<<<<Yup....... can't trust you verse the scan see........?
3VWALJAJ3AM116056 <<<<<<<<<<<<<<<<<<<<< Inconsistent VIN .....face palm.
Now for the rebuilt car:
Vin: 3VWALJAJ3AM116056 ............from page 2............OP!
   #27
Homefront
C?ID=262513
im entering these codes your sending me under ABS/ESP - Coding I hope that is the correct place if so then no again im ready to ship it if your able to correct the damn coding issue
   #28
Homefront
C?ID=262513
Jack up one.... LOL lets just say my blood pressure is now boiling
   #29
Homefront: When you post scans, please do not use [Print]. Please use [Copy] or [Save]. The results from [Print] are much more difficult to read on-line than the results from Copy or Save. Thanks!
Any luck with above codification?
Please let me know if the ecu accepts it..........?
FYI ............this code below in 0x44 must be adapted before a codification will be accepted in 0x03 ABS.......... in some cases not all from my personal experience.
http://wiki.ross-tech.com/wiki/inde...ng_Assist#Sensor_for_Steering_Angle_.28G85.29
Sensor for Steering Angle (G85) Important Note: This procedure ONLY applies to Models with Conti/Teves MK70 ABS/ASR.
This Procedure does NOT apply to Conti/Teves MK60, MK60CE, MK60EC1 and similar ABS/ASR/ESP systems. Check the Vehicle specific Diagnostic Procedures pages for each ABS System page with documentation.
Prerequisites:
  • Start the vehicle.
  • Turn the steering wheel one turn to the right and one turn to the left.
  • Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
  • If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
  • Ensure that the steering wheel is not moved again.
  • Keep the engine running and do not switch off the ignition.
  • System voltage at least 12.0 V.
[Select]
[44 - Steering Assist]
[Coding-II - 11] or if that function is not available then use [Sec.Access - 16] instead
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 060
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
After a successful basic setting, field 1 should say "OK".
[Done, Go Back]
To make sure the basic setting was successful, check the sensor again.
[Measuring Blocks - 08]
Group 007
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 °.
[Done, Go Back]
Note: After successful basic setting, the Steering Limit Stop needs to be adapted too.
Page 20
Revision: 00H17000
1 Fault Found: <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
DD
Temperature: 13.0°C
Count: 3
Count: 1
SteerAng n.Init
   #31
Homefront
C?ID=262513
well thank you,
____________________________________________________________________
Monday,14,December,2015,19:34:55:34959
VCDS Version: Release 15.7.2 (x64) Running on Windows 8.1 x64
Homefront
Control Module Part Number: 1K0 953 549 CD HW: 1K0 953 549 CD
Component and/or Version: J0527 056 0111
Software Coding: 0001731
Work Shop Code: WSC 00066 000 00000
Additional Info: 5K0959542 E221__MFL-TAS H05 0010
Additional Info: Geraet 00000
_________________________________________________________________________
Coding: 271F00
No Luck with the long code's
   #32
Jetta 97
C?ID=81680
Jack,
You need to go to 17- Instruments , then Advance Id to see VIn, I mention that in Post #20.
Example:
5G4gml1HMccQ09zfKSVj6sz8mYvdCOxnJM9AHyCXW_SVuGJNCnds9OQ643Lwvv7ZvyAtu0kSfFhG_M64Dv0o-TWmBD7jkgNb9FmrjQ8IFJ6JFYOnauEuQnDxIJGNon9iJVjA9FjtbVJuV8ljuUJIhWs_8HWPTC0dJU6FDnlSVn4ZDlaVsTPDHyjeyRF0GWYNJ-dfuWT4eBD0GfxyeFolu4qpNyr2_lvvFo6TmErnNRWavz_sbw8-XgTGkINZLQdoZ_P-blzft954nZz2vKwbXBLxY8WVRXUdFoAP0l-EDnu4QEeYLax_6wDTgRFjCI-BL07u6m9wOSYTJ_UmcxlfGkwVzuqMUQkppeCGcTOs16jcVAAgD0uytdzRnoh9vL2Vp3hlpfuVu4owuJkW3VFGHpZ0aIHfsWaBy5FyjAW-E-4PLLIz-oWDVU1vW1wMSsjlv0e_dkTRsJE_ttR-dQfoshGqMfhw7GolsGeSMxakL8YH1dUn9_o7ctGYEQ0ZdshUChshNJWSFyAxjOFBNLH8KdfSTMkdkO00dre3hOsLHB6p97Uez_BZeRsqoDXYHilfYHWi=w1002-h606-no
Then :
AT0WjKT-99svxk2pZM5--IQ_mE4Ef5ihpKYAnsblUzy0a7CBy6bVsi88ICzCd41_-Uz1CKwY8-CPHylzHLELQNINcCJlGbExtgEEjiY-Hfdb_Omk7PpDygIkiduuSxXLhGz3IwLk3AYSSOYJnS8kIVVDPpQ1wZVbTKVfo2j7FkKI7UyCXlUdWfSRrCcEppyK5-cJ65vIHlYwdrShv5jxQRzJycHf7YuGDttWIU7h0tH1KqeZ2kU8bhKqLnXl8f-UVbJ1hOHRmPiLnTgf4g6NUxOnaMKN1F5tmQl8jTFkADxgK7KTxTQkZGyC4hDBz7PjF4xdhFJkj0KgV9M6xcCoukyBOo-ItB8P7CsrHF8wK2-21tyrGF4c7SG_ZvmGQ6FfJKPkphwNJaIY6wb4gK9dVxQ_8cZxyzJ2Vj9LnNN7BS6ot_UMmmGbXbZkMqcgbtV4J18V78kQzZsmX0uq64u2fPT8KI5xv5ShlcxRzX5It96ooI-vDdOw6rm_v60IdXVgzpqqIe_6L6dar_BEOPas-gmj1Ou9hAEuGiuSEid6dHagRZ5vxaDmSltY1IEziEbSAMWU=w1004-h616-no
well thank you,
__________________________________________________ __________________
Homefront
__________________________________________________ _______________________
Coding: 271F00
WTF is this above?
I said 0x44 ....why are you posting snippets of information?
Did you adapt the 0x44? show a new auto-scan please.
0x44-Steering Assist -- Status: Malfunction 0010 <<<<<<<<<<<<<<<<<<<<<<< Did you correct this?
Battery Volts: 11.2 V <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< VOLTAGE! CODING NOT POSSIBLE
DD
Temperature: 13.0°C
   #34
Homefront
C?ID=262513
Jetta,97 TY that is also a match now (vin#),
Jack, you just got to love noob's! we are getting close to this now, im going to try fixing some of the other little issues then re try them long codes this morning... do i need security Access under 03 abs/esp before going into 07 coding and pasting them long codes?
Homefront
Tuesday,15,December,2015,09:02:31:34959
          77
VIN: 3VWAL7AJ3AM116056   Mileage: 139930km-86948miles
09-Cent. Elect. -- Status: OK 0000   (FIXED)
17-Instruments -- Status: OK 0000 (FIXED)
25-Immobilizer -- Status: OK 0000   (FIXED)
44-Steering Assist -- Status: OK 0000  (FIXED)
   Coding: 0050078
               P048E - 000 - Short to Plus - MIL ON
                    Mileage: 139923 km
                    Date: 2010.05.07
                    Time: 00:05:01
                    Voltage: 11.86 V
                    Lambda: 99.4 %
                    Lambda: 0.0 %
                    Bin. Bits: 00000000
                    Voltage: 5.016 V
               P0405 - 000 - Signal too Low - MIL ON
                    Mileage: 139923 km
                    Date: 2010.05.07
                    Time: 00:05:01
                    Voltage: 11.86 V
                    Lambda: 99.4 %
                    Lambda: 0.0 %
                    Voltage: 0.000 V
                    Bin. Bits: 00000000
               P242A - 001 - Malfunction - MIL ON
                    Fault Status: 11100001
                    Mileage: 139923 km
                    Date: 2010.05.07
                    Time: 00:05:01
                    Voltage: 11.86 V
                    Temperature: 14.4°C
                    Temperature: 18.0°C
                    Temperature: 18.0°C
               P0475 - 000 - Electrical Malfunction - MIL ON
                    Mileage: 139923 km
                    Date: 2010.05.07
                    Time: 00:05:02
                    Load: 0.0 %
                    Load: 100.0 %
                    Lambda: 99.4 %
                    Temperature: 18.0°C
                    Temperature: 14.4°C
               P1440 - 000 - Open Circuit - MIL ON
                    Mileage: 139923 km
                    Date: 2010.05.07
                    Time: 00:05:02
                    Load: 0.0 %
                    Load: 100.0 %
                    Lambda: 99.4 %
                    Temperature: 14.4°C
                    Mileage: 139923 km
                    Date: 2010.05.07
                    Time: 00:05:06
                    Voltage: 11.86 V
                    Temperature: 14.4°C
                    Temperature: 18.0°C
                    Temperature: 18.0°C
Readiness: 1 5 0 0 1
   Coding: 0000024
   Revision: 00H30001
            000 -  -
                    Reset counter: 180
                    Date: 2010.05.07
                    Time: 06:35:25
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 49920
                    Reset counter: 180
                    Mileage: 139929 km
                    Date: 2010.05.07
                    Time: 06:35:23
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 295
                    Count: 50176
                    Count: 512
                    Reset counter: 180
                    Mileage: 139929 km
                    Date: 2010.05.07
                    Time: 06:35:23
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 270
                    Count: 50176
                    Count: 512
   Revision: 00009001
   Coding: 0000001002
                    Reset counter: 175
                    Mileage: 139754 km
                    Date: 2015.12.09
                    Time: 06:59:11
   Revision: BI111001
   Coding: 009795
   Coding: 0012340
   Coding: 0001731
   Coding: 00000130
   Coding: 271F00
01304 - Radio
                    Fault Frequency: 12
                    Reset counter: 180
                    Mileage: 139923 km
                    Date: 2010.05.07
                    Time: 00:29:47
                    Reset counter: 179
                    Mileage: 139923 km
                    Date: 2010.05.07
                    Time: 00:29:47
                    Reset counter: 179
                    Mileage: 139923 km
                    Date: 2010.05.07
                    Time: 00:29:47
   Coding: 0000004
                    Reset counter: 219
                    Mileage: 139923 km
                    Date: 2010.05.03
                    Time: 06:56:07
   Coding: 0004B5
   Slave Driver:
   Coding: 000490
                    Reset counter: 220
                    Mileage: 139929 km
                    Date: 2015.12.15
                    Time: 06:15:56
                    Reset counter: 180
                    Mileage: 139930 km
                    Date: 2015.12.15
                    Time: 07:15:07
   Revision: 00H17000
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
                    Reset counter: 180
                    Mileage: 139929 km
                    Date: 2015.12.15
                    Time: 07:13:15
Address 56: Radio
   Coding: 018705
End-------------------------(Elapsed Time: 02:24)--------------------------
Homefront
C?ID=262513
Ok guys everything is fixed now with the exception of - Address 03: ABS Brakes
Homefront
Tuesday,15,December,2015,11:03:34:34959
          77
   Coding: 0050078
                    Mileage: 139932 km
                    Date: 2010.05.07
                    Time: 20:00:38
                    RPM: 828 /min
                    Voltage: 13.91 V
                    Lambda: 99.4 %
                    Lambda: 0.0 %
                    Bin. Bits: 00000000
                    Voltage: 5.016 V
                    Mileage: 139932 km
                    Date: 2010.05.07
                    Time: 20:00:38
                    RPM: 828 /min
                    Voltage: 13.91 V
                    Lambda: 99.4 %
                    Lambda: 0.0 %
                    Voltage: 0.000 V
                    Bin. Bits: 00000000
                    Mileage: 139932 km
                    Date: 2010.05.07
                    Time: 20:00:38
                    RPM: 828 /min
                    Voltage: 13.91 V
                    Temperature: 81.9°C
                    Temperature: 162.0°C
                    Temperature: 138.0°C
                    Mileage: 139932 km
                    Date: 2010.05.07
                    Time: 20:00:39
                    RPM: 828 /min
                    Load: 0.0 %
                    Load: 100.0 %
                    Lambda: 99.4 %
                    Mass Air / Rev.: 455.0 mg/str
                    Temperature: 81.9°C
                    Mileage: 139932 km
                    Date: 2010.05.07
                    Time: 20:00:39
                    RPM: 828 /min
                    Load: 0.0 %
                    Load: 100.0 %
                    Lambda: 99.4 %
                    Temperature: 81.9°C
                    Mileage: 139932 km
                    Date: 2010.05.07
                    Time: 20:00:42
                    RPM: 828 /min
                    Voltage: 13.91 V
                    Temperature: 81.9°C
   Coding: 0000024
   Revision: 00H30001
03306 - Coding Not Valid
            000 -  -  - Intermittent
                    Reset counter: 181
                    Mileage: 139933 km
                    Date: 2010.05.07
                    Time: 20:40:32
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 4161
                    Count: 49408
                    Count: 512
            000 -  -
                    Reset counter: 181
                    Mileage: 139933 km
                    Date: 2010.05.07
                    Time: 20:42:09
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 320
                    Count: 49664
                    Count: 512
            000 -  -
                    Reset counter: 181
                    Date: 2010.05.07
                    Time: 20:00:24
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 50176
   Revision: 00009001
   Coding: 0000001002
   Revision: BI111001
   Coding: 009795
   Coding: 0012340
   Coding: 0001731
   Coding: 00000130
   Coding: 271F00
01304 - Radio
                    Reset counter: 181
                    Mileage: 139932 km
                    Date: 2010.05.07
                    Time: 20:03:45
                    Reset counter: 181
                    Mileage: 139932 km
                    Date: 2010.05.07
                    Time: 20:03:45
                    Reset counter: 181
                    Mileage: 139932 km
                    Date: 2010.05.07
                    Time: 20:03:45
   Coding: 0000004
   Coding: 0004B5
   Slave Driver:
   Coding: 000490
   Revision: 00H17000
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
Address 56: Radio
   Coding: 018705
End-------------------------(Elapsed Time: 02:25)--------------------------
Dana
Western PA, USA
Based on this VIN: 3VWAL7AJ3AM116056
.. the ABS coding should be: 114B400C49230000880B02E9921F0042310000
Copy and Paste that directly into the New Coding and enter non zero WSC/Importer/Equipment numbers before clicking Do It. Providing the coding is accepted complete the first 4 Basic Setting operations on this page:
http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Brake_Electronics_(MK60EC1)
   #38
Jetta 97
C?ID=81680
   #39
Homefront
C?ID=262513
THANK YOU ALL FOR YOUR HARD WORK!
That code worked, the engine codes will be gone with the ECU Stage 2 tune.
Now I got to ask a question? where can I learn about writing these codes for the ABS module so if this happens again I can keep my head on straight being I am doing repairable as a hobby I'm sure I will have this issue again.
Homefront
Tuesday,15,December,2015,22:59:50:34959
77
VIN: 3VWAL7AJ3AM116056 Mileage: 140020km-87004miles
01-Engine -- Status: Malfunction 0010 Stage 2 Tune will fix this
19-CAN Gateway -- Status: Malfunction 0010 (Android Head Unit)
2E-Media Player 3 -- Status: Cannot be reached 1100 (Android Head Unit)
56-Radio -- Status: Malfunction 1010 (Android Head Unit)
77-Telephone -- Status: Cannot be reached 1100 (no phone)
   #40
How come no final auto-scan of the code that works...........?
http://wiki.ross-tech.com/wiki/index..._%28MK60EC1%29
Yeah I said that code too in post #26 almost close.
